PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. [SAT Aug 12th] Special event for SoCal, Tour of the NEW Audi Design Center in Santa Monica
  2. A Little 4-Wheelin' in My FWD
  3. voltage before starting engine
  4. Oil leak hell continues aka: Leaking oil pump gasket
  5. Comrades- Since I'm a moron with computers could someone help me post some pics of...
  6. Where are the fan relays?
  7. Need help replacing PS hose on '95 A6 Avant
  8. Poor quality door panels falling apart in my 96 A6
  9. Anyone have any pointers on removing the original stereo from a 95 A6 Avant?
  10. 100CS Bose Door Speakers
  11. 1997 A6 Avant -- figuring out offer price?
  12. GOOD HORN ANYONE???
  13. Replacing Sunroof Switch
  14. Tire Size Question
  15. Tailgate lock rubber fixed update!!!!
  16. A/C Condenser Lower Tube Leaking
  17. Intermittent AC
  18. Anyone have any radiator fan motors for sale?
  19. austinado16, HELP!!
  20. replace key tumbler
  21. Found my leak....
  22. Springs for C4 Audi A6 Quattro
  23. Where's the lights on buzzer located?
  24. Motronic fuel pressure regulator electrics
  25. Name That Part
  26. Dig the '94 100S Wagon on craigslist
  27. Parts Cars?
  28. 96 A6Q T=Belt job-got the Blauparts package
  29. Rattling tailgate / rear hatch fix
  30. Front suspension clunk....could it be rear front subframe mounts?
  31. Engine oil consumption update
  32. Front crank seal done
  33. Cruise Control Problems
  34. Mystery vacuum line.. Does anyone know where this goes?
  35. Engine coolant temp sensor location
  36. C4 A6 AT Transmission leak
  37. 95 A6 FWD Clock Spring Part Number
  38. Anybody still need a nice Gamma??
  39. Broken air hose...front pass side of engine, going from the front to the ground?
  40. replaced master, bled slave; something's not quite right (pls help)
  41. Hey VB chil-n, this should tick you off.
  42. New Tint Job
  43. finally got chipped...
  44. Remote start
  45. Final Notice! Old School quattro gathering this weekend in Cumberland, MD!
  46. anyone parting out 1995-1997 A6 12valve AFC engine code vehicle?help
  47. 94 Cabriolet parts
  48. Towing questions
  49. Changed Front Oxygen Sensors on a 1997 A6
  50. bodykits for an audi 100 s
  51. My Mysterious Mirror Memory Module
  52. Can anyone w/ a carfax acct. run a VIN for me?
  53. Coolant Heater Core Leak !
  54. Ready to let go of my extra 1996 A6 Servotronic steering rack
  55. Pics for you guys to oogle at!
  56. New 034Motorsport Fuel Pressure Gauge Adaptor
  57. Remember me anyone?
  58. Tail gate pneumatic lock removal on 96 A6 wagon?
  59. Burning oil smell (again) '97 A6
  60. Closing windows with the key
  61. All windows not working...
  62. Favorite front brake pads?
  63. gauge swap
  64. Air-con belt squealing
  65. A6 sway bar upgrades
  66. can someone look at there bentley for me re: front diff.
  67. air conditioning squeak
  68. Has anyone done a headgasket?
  69. Figured our C4s have to be represented on Myspace!
  70. New problems: limp home and car stalling.
  71. Setting the timming on a 1993 audi 100
  72. Recharged '92 100 A/C with new EPA approved R-12 direct replacement ... R-420A >>
  73. fluid under clutch pedal
  74. 92 CS100: Speedometer working intermittmently:
  75. question
  76. A6 transmission & engine codes
  77. 3rd brake light inop...the rest of the story.
  78. Looking for a set of wheels in the seattle area.
  79. check out my fresh new cold air intake. took about 2 seconds to install
  80. I realize this isn't the detailing forum but what are you guys using for cleaning/wax? Anyone try...
  81. A Midsummer Night's Audi GTG Boston Area August 8th
  82. C4 A6 to 4.2 conversion?
  83. How bad will a valley pan leak get? On my '94 I noticed that the...
  84. You know...I love my car...but the number of small issues are starting to get to me
  85. Would Secondary air injection issues cause any type of rough idle?
  86. Looks like I'll be replacing the front crank seal on my '95 A6. Any BTDT's?
  87. I disconnected the battery and now by stero dose not work.
  88. ABS/Airbag fuse problem.....
  89. Shokan: X-Post
  90. timing belt
  91. cluster swap, it works...well sort of
  92. recharging on the low side A/C port for 96 and up r134 systems
  93. Dose anybody know a good Tech in South Florida?
  94. Need an opinion
  95. A8 Brakes possible?
  96. 1992 100 CS For Sale
  97. exhaust noise
  98. 96A6Q T belt --best place to buy that rents the cam tools
  99. Ronal 17", -$129
  100. Need some help with inop 3rd brake light
  101. 1996 Delta CC Radio possible to install in my 95 A6?
  102. New Audi Parts !!!
  103. Chip Herr running 6th in first offical practice of the 4.5 Mile Miller Motorsports Park
  104. 1993 Audi 100 Quattro automatic 4 spd question....
  105. Anybody know who this "private " is?
  106. Transmission Service
  107. Airbag question??
  108. really stupid noob question...sorry
  109. 100CS quattro stuck in park
  110. A6 Quattro Avant...Sorry for the dumb question but need to ask for a lady friend...
  111. Audi 100 Steering Clunk
  112. Clear corner queries
  113. p.s. rack
  114. After a tough event at Infineon, STaSIS heads to Miller Motorsports for round 5 of the SPEED WCTC.
  115. center console...
  116. The wide range of parts prices
  117. Who makes a Suspension kit for a 93 c4 Quattro???
  118. Anyone need clear corner - pass side only?
  119. Progress on clunk/thud under floor.....and an engine/trans mount question
  120. Car isn't starting.
  121. Fan Fun
  122. black leather interior
  123. Having a garage sale...
  124. 96 A6 accessories
  125. Yet another episode
  126. Any INDY shop in St Louis to Recharge my AC R134
  127. time for axel repair
  128. Sunroof drain holes
  129. FS: control arms, tie rod ends
  130. Brake and Rotor replacement
  131. Uh oh..partial engine seizure I think. How serious is this?
  132. Ronal 17" Wheel Sale
  133. Hey does anyone have a TPS that I can have/buy?
  134. spoiler
  135. bottom door trim
  136. headlight washers...
  137. Random plandom...LED Brake Center High Mounted Brake Light
  138. what do you guys use to replace the hoses from the valve cover to the intake plenum
  139. Liquid dripping from vents.
  140. A Few Wreck Photos
  141. Fuel tank sending unit?
  142. mirror glass
  143. remote starter
  144. Question for all those more mechanically inclined than I am...
  145. Octane Rating & 06 A6 Rental
  146. Check this out, some mad things done to a C4
  147. Just bought a '97 A6.
  148. I have a new 02 A8. My 95 A6, w/ Mance's TB and MAF, is for sale.
  149. Rebooting the steering rack = fun....or not.
  150. rims/tires
  151. The ac systems uses r12 correct?
  152. Anyone spare a Part Number for the Bank2 Combi-valve of the Sec.Air Injection System?
  153. A/C Compressor will Not Stay on
  154. Intermitant transmission down/up shifting - 95 A6 fwd
  155. looking for pics showing timing marks on crank pully for '93 100cs
  156. help needed
  157. A couple oil leaks down...how many to go?
  158. Need a part if anybody knows of one.
  159. 1995 A6 12v -Cranks, but no Start. What items to check?
  160. Warning Lights
  161. My heater core article...
  162. Broken Delta CC unit request
  163. Anyone have a single extra ACDelco Rapidfire 9 plug?
  164. Hard to find 3-volume hardcopy Bentley Repair Manual set on eBay (not my listing)...
  165. 97 a6 quattro just add new ft brakes and it just makes a lot squeek
  166. These taillights on my car?
  167. Buddy just bought a 1996 A6. Needs a passenger fender, anyone ????
  168. So, I imagine when it sounds like marbles near my cats when blipping the throttle,
  169. Water pump gasket
  170. Sunroom acting strangly
  171. Bad FM Reception from stock head unit
  172. Engine won't start.......
  173. cluster swap
  174. decal
  175. electric gremlins caught up front!
  176. DTC 2342 ? O2 sensor ?
  177. Looking for a measurment on a C4 avant
  178. Under bonnet (hood) shot for Zytec
  179. Audi "Cruise to Paris"
  180. Need to know...
  181. 2nd big new A6 wagon road trip
  182. NGK ROCKS !
  183. Moaning when I turn the steering wheel
  184. In search of......"The Clunk".....
  185. Anyone have a BUSTED Bose headunit???
  186. A6 2.5 TDI- prepurchase check-up
  187. Burien Audi Expo roll call - who's coming?
  188. A6 vs 100 series brake pads / rotors
  189. axel boots?
  190. Vag-com
  191. finding radio code for 97 Audi A6 Quattro wagon
  192. Gear selector dash display
  193. electronic parts source/instrument cluster repair
  194. New Audi Parts !!!
  195. Key Sponsor Announcement and Round 4 of the World Challenge Touring Car Series.
  196. radiator fan air conditioner compressor problem
  197. Ronal wheel-tire sale
  198. shifter should light up ???
  199. Has anyone replaced brake lines? Looking for a procedure...
  200. 94 100S FWD starter problem
  201. parts needed: 93 100CS front passenger side glass window
  202. Ck engine light with no codes
  203. Audi Bose radio repair
  204. so my engine temp isn't reading
  205. Understanding the ECU?.........
  206. 1996 A6 Avant - Air Con Control Unit E87 behaving strangely
  207. Loss of engine power at 1500rpm......
  208. Anybody have a good Audi Bose stereo for sale?
  209. Where's the OBD plug-in located?
  210. Audi C4 headlight question
  211. Engine wash aftermath
  212. Would a plugged EGR cause a rough idle?
  213. Instrument light joy!
  214. Bose Audio Problems
  215. Brake hoses and new fluid = much better feel. Also the larger oil filter worked out great.
  216. Suspension clunk...driver's side floor area
  217. electrical problems, audi? never...
  218. Avant rear hatch courtesy lamp freakyness.
  219. My Oil Usage - 96 A6 Avant 140K miles
  220. Hmm...CEL today...VAG SEZ: Misfire on Cylinder Six - 16690
  221. brake rotor thickness? (OEM 288mm disks.)
  222. A/C Gone Wild !
  223. Newbie gets the A6 wagon....long
  224. Suspension noises update.
  225. need opinions
  226. Considering clear corners - can someone describe the "trim" procedure so they don't fall out?
  227. Spent all day washin' and waxin'.... just thought I'd share....
  228. Where is a good place to buy a breather hose.....
  229. WTB: Cam Position Sensor for a 2.8l
  230. Allignement
  231. Engine Oil Pressure Warning
  232. Audi 100 Engine Speed Sensor
  233. Changed my tranny and snub mounts today while the winds were throwing stuff around
  234. repairs repairs repairs
  235. Hi from a newbie & questions about possible '95 A6 wagon purchase
  236. Windshield washer
  237. A few delayed pictures from Mid Ohio. Though I would share.
  238. Hey VB, how's the weather?
  239. Heater Blower Squeal
  240. 097 Auto Trans Flare on Shifting
  241. IC Plexiglass
  242. Installed third row seatbelts.
  243. question about 1996 A6/A4 engine
  244. Temp. Guage
  245. If this is the best message board for audi's....
  246. behind the drivers kick panel...
  247. Can't find where driver side oxygen sensor wires go...
  248. Radio/Stereo question!
  249. 1994 100 S
  250. Need opinions on possible axle, cv joint problem.
