PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Transmission fluid level checked when it is warm or "cold"??
  2. no bug juice !!!!
  3. Dash light replacement question(s)
  4. Try again!
  5. Here's a pic at her finest!!
  6. Help. 96 A6 Avant won't start. Wife pulled it in the garage one evening....
  7. oil filler cap gasket - dealer item?
  8. Is 137k miles too high?
  9. Todd, how does that head gasket tester gizmo work?
  10. Just want to confirm, replacing strut insert and mounts screws up alignment?
  11. Cigarette lighter socket needed for 97 A6 Avant
  12. good place to buy p/s suction/return hoses...any suggestions?
  13. Engine Fan
  14. Hi all, long time member of 80/90/CQ forum but I am looking to buy
  15. Avant parts in southern CA.....ouchie!
  16. I'm ready to change the struts, any tricks I should know about?
  17. Finally got the IR locks to work! WOOOT! Fixing IR door locks not working,,,
  18. you know how many of...long
  19. Ingition issue 1992 100cs
  20. Looking for 95-96 A6 headlights
  21. REVISITED: Brake repair leads to Transmission limp mode/94 100cs Quattro
  22. Servicing auto tranny
  23. Austinado how did you run U shaped bypass for heater? is it like this?
  24. There's been a lot of talk about the Mance XTB... which TB does this use?
  25. i was thinking the other day
  26. How to remove center arm rest?
  27. Anyone out there experience leaking fuse block?
  28. Still having trouble with coolant temp fluctuation!
  29. Cruise Control only works when its WICKED cold
  30. Coolant leaking on passenger footwell, drips to gas pedal
  31. so I have a 95 A6 Quatt......
  32. what else could it be?
  33. What bolt pattern do we have?
  34. Anyone have a right inner tail light for a 97 A6 in central - western PA?
  35. Power steering fluid (x2...)
  36. For those of you suffering the dreaded sunroof gremlins....
  37. Quick EGR "Insuficient Flow" CEL update
  38. So I got my new floor mats, last ones in platinum in Canada, but
  39. Sunroof stuck
  40. How to remove the floor carpet?
  41. For all you Audi 100 lovers (lurking ebay)
  42. One more from 'Spirited Away'
  43. Anyone seen the Japanese movie 'Spirited Away'?
  44. Can we get stiffer sway bars for our cars?
  45. This one's got me stumped. (Long Post)
  46. Anyone have a cd changer for a 96' Avant for a fair price?
  47. Now *this* guy knows how to market a C4... (disclaimer: NOT MINE!)
  48. Anybody in the Pacific Northwest have an A6 hood?
  49. Who has seen this Audi option before?
  50. Nylon Bushing for ATE Guide Sleeves
  51. Rear window update
  52. darn...need to know
  53. Is my beloved A6 on its death bed?
  54. Stealer Messed up my GF's A6
  55. looking for the cargo cover drape cover thing for C4 avant in black
  56. Holy crap, I may have discovered my coolant problem!
  57. Adding Fog lamps to factory location
  58. Anyone have experience with a "rebuilt oe" power steering pump?
  59. How many hp by "hogging out of the t-body coupled w/ the Mance MAF"?
  60. Update: I'm now running a large bore 3 pin MAF on my 92.
  61. put new speakers in my car, now radio doesn't turn on at all...
  62. Saw this on TV last night...Drivetime blog in Studio A..(A for Audi)
  63. could you...
  64. Subtle feeler....Homelink?
  65. How many have done the TT brake bracket-A8 rotor conversion on their G60 C4?
  66. So my rear glass on my avant just shattered...how badly f'd am I?
  67. 93 100S Down! =(
  68. EGR Madness continues
  69. TRANSMISSION (!)
  70. That's what I'm talking about!!!
  71. Anyone use Mobile 1 Oil Filters?
  72. Anyone ever heard about this? Is tempting but TGTBT
  73. FWD vs Quattro
  74. Is Audi Blue coolant compatible with Pentosin G11?
  75. Also notice a slight shudder when turning, anyone else?
  76. Really starting to lose my patience with this thing
  77. Brake repair leads to Transmission limp mode/94 100cs Quattro
  78. ways to inspect timing belt and water pump
  79. Dire need of metal trim below right headlight
  80. Question about headlights.
  81. How are the shipping rates from German Auto Parts?
  82. creaky steering
  83. Coolant leak
  84. what engine to look for when buying
  85. VW/Audi Power steering fluid
  86. Fuel gauge broken and Temperature light on
  87. they came in today...
  88. K&N air filter ???
  89. Put in my new sunshade from Dave...
  90. visor... sunvisor
  91. TB, DS seals, WP finally done! Now some more troubles.
  92. Testing HVAC / Climate Control Vacuum System
  93. still cant...
  94. All Weather Floor Mats for C4
  95. Any advice on where I can find a cd changer bracket for my 97 avant?
  96. A few questions about my audi
  97. i decided to order all of my parts last week...
  98. Want to buy: Emerald green front bumper
  99. where
  100. Gas Leak
  101. OT: How to get a new windshield, the hard way.
  102. Nice Part Numbers Resource!
  103. I rearended a guy today and need some parts....
  104. Factory alarm disable?
  105. What type and how much diff fluid for 96 Avant quattro.
  106. Recent CEL, secondary air pump... more inside
  107. Mr. EDIGREG here are your pics of the new wheels...
  108. What tests occur when key is first switched to "on" position?
  109. Guys came back from 9 day work trip to find my urs6 had flat batt,got jump started:
  110. I have to replace the struts on my car. Any thoughts?
  111. 1996 A6 instrument lights question:
  112. Trying to find oil filter
  113. Hey Brant, You Back Door is Ready...
  114. Alright guys, who did I snipe for the fogs?
  115. going to change...
  116. Sorry to repost, but I gotta. Exterior door trim removal
  117. Power steering woes
  118. Help with some Code reading from VAG pull last night
  119. CV BOOTS, STEERING RACK, BRAKES, SOLITUD AND POVERTY!
  120. Whiny Avant trunk
  121. How do the 1996+ quattros compare wrt torsion differentials?
  122. Fog lights
  123. Look what I get to drive in on a regular basis
  124. How Come?
  125. I got new shoes....
  126. License Plate Lights not coming on?
  127. Coolant
  128. C4 fun up the Mountain!!!
  129. Anyone need a Intake Manifold and Throttle Body?
  130. '97 A6 front bumper cover (black)
  131. Still haven't replaced my vacuum hoses, but...
  132. OK, found a dealer that can get mats, but what color is "melange"?
  133. is there supposed to be a copper ring on the drain plug for the rear final drive?
  134. Looking for carpet floor mats
  135. Washed my car today... it was -11° outside
  136. Anyone need owner's manual?
  137. Driveshaft Seals,etc-not going as planned!
  138. add one more to the stable...
  139. ECM
  140. sorry about all the posts today, but ...
  141. anyone ever replaced the gear selector arm on their auto transmission?
  142. one other thing on the other job
  143. looking for...
  144. Camshaft & Crankshaft Seals
  145. I want to find whoever designed the e-brake system and punch him in the mouth :[
  146. A6 C4 TDI avant
  147. Euro 100 avant w/ TDI
  148. Anybody have luck running CD-RW discs in the factory changer?
  149. Tearing into the TB today...
  150. how to rebuild rear wiper motor
  151. Still no heat at idle
  152. Temperature output is LO or HI, nothing in between
  153. Good deal i think....O.C. Craigslist...
  154. Hey Guys whats your oil temperature on highway run
  155. I'm officially a member of the 200,000mi club
  156. What do *I* have going this weekend?
  157. Coolant issues dealt with, YAY! (I think)
  158. ABS Fiasco. Help needed!
  159. How should my car feel?
  160. anyone know part# of the upper strut nut washer(cup) or spares for sale???
  161. WOW thats fast...
  162. 205/55/16?
  163. freakin front strut mount gave way...again!!! starting to hate those bilstien HD's...
  164. The gods must be mad at me..
  165. Reposted Update here...
  166. Spotted a couple of dirty C4's today.
  167. any of you guys need and engine and happen to be near Philly?
  168. OK, so I am an idiot.
  169. CRAP gas spraying all over under the hood
  170. every time i turn around its another thing...any slick tricks for this?
  171. every time i turn around its another thing...
  172. Changes in eBay....no more negative feedback allowed...sad.
  173. Stalling/rough idle 100 2.3 5 cylinder with Air-con running
  174. IC chime functions adversely..HELP!!
  175. Cleaned out EGR path last night for the 3rd time on my A6...I now think
  176. Happiness is.....new lower control arms! Man, mine were really shot...
  177. Looked down at the odometer on my 98 C4 A6 Avant this morning and saw...
  178. Seat for every-ass....AUDI
  179. Half way thru replacing the trans rear output shaft seal
  180. Video from last weekends ice driving event.
  181. Anyone with access to a Bentley? Where's the Avant's fuel pump hatch?
  182. '93 100 CS Q - Reprogram auto tranny shifting pattern
  183. bumper pics
  184. HID upgrade and cold air intake
  185. Front bumper
  186. What is the funtion of this audio connector at the boot
  187. easy
  188. What type of coolant for 1996?
  189. Any parting or know of someone parting a '96 A6? Need the keyless control module...
  190. 98 C4 Avant 99950 miles passed BC AirCare easily but I have a question:
  191. Most efficient speed?
  192. Need parts numbers for driveshaft seals & rear diff
  193. Carbon fiber hood and trunk lid group buy is going forward!
  194. calling computer geeks...any help with this problem? Accessing Pandora.com from overseas?
  195. OEM brake hoses. The brake line nut stuck
  196. I knew that Audi part are expencive, but
  197. Does the transmission fluid ever have to be changed?
  198. Had my car's co tuned
  199. Need some info on ecu
  200. Cross posted from the A8 forum.
  201. Feeler: 94 100s parts, Ruby Red on Black/Ecru
  202. Fun times on some ice
  203. Anyone know of REALLY good leather seat facing replacements? My driver's seat is torn.
  204. Still need '96 style remotes if anyone has a lead...
  205. Well I guess its time I wander over
  206. Bought a Haynes manual to find out it doesn't have information about the V6 :(
  207. Look what the Honda guys are doing in 'THEIR* FAQ/DIY section now...fancy!
  208. I have found myself in a contry with favorable exchange rate to the $, and an Audi dealership...
  209. why is there so many deals on these cars right now....
  210. Kill switch ???
  211. Differential Servicing
  212. Door trim broken and falling, okay to cut off?
  213. '93 100CS refuses to start...
  214. bumper
  215. Compressor found - what year?
  216. Which fuel line is it that leaks when it is -million degrees outside?
  217. Soft brake pedal
  218. For god's sake, what am i doing wrong?!?
  219. looking for
  220. FOR SALE
  221. Holy s**t flushing the heater core is a bitch!
  222. Disappointed.......
  223. My last coolant bleeding question EVER! Where's the other bleeder?
  224. Anyone need a Passenger-side clear corner?
  225. Enjoy my new signature thanks to Holg!
  226. 97 A6 2.8 timing belt
  227. Cool modding for C4 , Have any one done this ?
  228. someone grab this quick.......
  229. Is there any benefit to aluminum valve covers (besides cooling)?
  230. Replaced the outside temperature & the gear...
  231. 1997 A6Q No 4th Gear
  232. transmission upshifts to fourth in parking lot
  233. Anybody here running G12 coolant?
  234. Contest: Guess where Todd's going tomorrow at 4:30am
  235. OK, got the car checked out at Audi Dealership, here's the list.
  236. Anyone got a extra '96-style OE RF clicker? My brother lost his...
  237. I own an S4, yet I always come to the A6 forum...
  238. 5 speed conversion....here you go!
  239. 94 audi 100 no start, code shows cam position sensor, could it be something else too?
  240. Please advice......Deal with insurance company after the accident
  241. Hate to ask...did search....?
  242. Should I change oil pan?
  243. Whats the normal coolant temperature 90 degree?
  244. Need: Bulb Check Relay - 374
  245. Coolant bleeding advice needed, again
  246. some craigslist finds
  247. Does anyone in the Hartford area have a 96ish A6 that I could plug a CD changer into?
  248. PSA... For those of you dealing with insurance companies after an accident...
  249. hey guys, friend bought a 100 and the abs light is on, after driving 20-30 mins the brakes..
  250. Was a cd changer cable standard on the 97 A6 quattro?
