- 1996 A6 long-term decision
- Boiling coolant?
- Found a weird part when replacing my door glass (95 A6)
- Rear shock mounting question
- Suspension Advise (Bilstein or Koni)
- 1995 Timing Belt question (the car has 190K miles)
- AC leaks water onto gas pedal area '92 100 quattro
- How can the AC run the battery flat?
- AC problem
- 93 100 s speedometer
- 1997 A6 wagon wiring issue. HELP ASAP
- Help! 100CS overheating + dripping on our feet + making straaaaange noises!!!
- vacum hose routing
- EGR system, o2 sensor, or fuel pump?
- Climate fan stuck on full blast
- Strange Downshift Problem
- '94 100CS Electrical crazyness...need suggestions
- Transmission Fluid
- Spark Plugs 1996 A6
- Changing Transmisison Fluid 1993 Auid 100 CS?
- where's the water pump?
- I think I just killed my car.
- Help with A6 Tripod Inner Joint R&R
- automatic problems
- Odo not working
- Engine doesn't crank
- 1994 100s stalling
- Looking for C4 parts
- drivers seat won't move
- no fan work
- Climate Control TC
- strange noise
- 1996 Audi A6 Possible TCM issue?
- 1992 Audi 100, 2WD axle replacement
- Hesitation under acceleration - misfire or transmission
- Oil pressure.
- Ur S6 Lower Dash Panel Removal
- recently replace heater core / now cooling problem
- A6 - 100 - Taillight Differences?
- Smog Failure (Second Time)
- '91 100 Bose issues
- looking for service manual for 97 a6
- 1998 A6...Big problem
- lamp control unit
- starter interlock relay
- what to try next
- 96 A6 wont crank
- 1996 A6 Overheating.....
- 96 A6 Security System
- 96 A6 Remote issues
- 96 A6 Bose issue
- Retrofitting on-board computer A6 C4 1996 2.6
- 93 100 CS hard to start/keep running
- Steering Wheel
- C4 OR E34 bmw!?! Input please!!
- '97 Audi Sunroof & Radio Issue - WARNING:I'm a newbie
- best brake fluid
- temperature
- 100$ via paypal if you can help
- 1997 A6 with problems
- What sensor plugs in here...
- What is this part? and where does it go?
- How much transmission fluid?
- Advice on Trans Mount and Subframe Bushings
- Audi 100 Wagon
- Brale light still on after new pads with sensor????
- Craigslist find
- Link to C4 FAQs......
- Trouble pulling codes
- 96 A6 Quattro - several issues
- My 98 A6 Avant needs a little TLC advice
- 91 100 driver's side lock off track
- Front End Clunk -
- temperature
- fuel pump runs, but no start
- cabin air filter
- brakes, air in system
- C4 Window Winds Down & Refuses to Go Up
- Any BTDT with KYB GR-2 front strut inserts?
- What's the problem here all A6 experts?
- 1996 A6 Quattro Wagon OBD II
- Key not opening driver nor passenger doors
- Oil warning light on dash
- A6 Avant 97 Spring recomendations?
- Lifters
- power steering pump bracket
- air intake
- Cruise Control Prolem
- TRANNY DILEMA
- After Market Cd Problems (GROUNDING)
- coolant loss overheating
- Amplifier install
- INSTALLING KEYLESS ENTRY SYSTEM
- Sunroof Issue
- HELP KEYLESS ENTRY!!!!
- door lock does not work
- door lock wiring faulty
- Too hot engine
- 1995 A6 Quattro Brake Failure, after driving through a puddle.
- Cleaned EGR twice CEL light still comes on
- Motor seized
- 1994 100S EGR valve
- Steering Question
- Gamma stays "Safe" mode with code
- audi a6 1997
- Automatic to Manual swap [Can it be done?]
- Radio code help request
- manual to automatic trans swap
- Keyless Remote Entry fob and,,,,front lights out?
- Rear Washer Nozzle?
- Annoying System Autocheck - Please Help!
- Euro sport spring group buy....
- Motor Mount Toque spec?
- Timing belt tensioner positioning
- '94 A6 estate fuel pump
- Door chime won't stop
- Audi 100, 2.8v6, quattro, manual gear box shifting problem?
- removal of throttle body
- Tips for replacing pump to accumulator hose
- transmission seals.. diagram?
- Can't erase codes
- I have a problem with digital clock
- Is there a flow chart/ list of common no start problems?
- Autocheck 1994 Audi 100
- 1995 Audi A6 Wont Start - New Battery Low Voltage
- Diagnostic Can't Find My Transmiision 100CSQ
- 1995 A6 Cooling problem
- '92 100 quattro key with remote button still available new?
- Dead battery -- can I use a laptop charger to charge & jumpstart
- 92 100cs 2.8 tapping
- VAG wont connect to urS4
- Coolant Leak at radiator?
- Intermittent Valve Tap
- 96 A6 Quattro Wgn (2.8) 0652 gear monitoring implausible signal
- Group Purchase - Replica S4/6 Sport Spring Sets...
- Did I just get the wrong transmission filter?
- 95 Audi A6 2.8L can't find starter
- Timing Belt Removal
- 93 Audi 100 quattro auto transmission problem
- Timing Belt Question
- Vacuum hose location
- 96 2.8l quattro A6
- audi
- Is the avant wiper switch different to the sedan?
- rear wiper relay position?
- Driver's Door Causes Weird Alarm Problem
- part ID help
- Newbie here with some questions
- 1996 A6 2.6 Quattro, Deal?
- 1995 A6 Issue
- Greetings from NY and a rear caliper question
- 96' A6q - 2.8 Coolant Leak
- 1994 Audi A6 2.8E fuel leak
- UR S6 on E-Bay
- 100 2.3E Avant fan
- Door Handle problem
- SAP - what will it break if/when it fails?
- 4.2 Engine swap??
- Replace entire hatch on 100 Avant?
- Sway Bar Installation Help!
- 97 A6 O2 Sensors
- '92 100CSq - Cam Plug Supercession?
- help, cold start issues on 1991 100.
- What one fits it?
- Transmission hesitant to shift when cold
- Rough idle / start
- 95 audi a6 quattro power window
- New a6 quattro avant owner
- 100CS fuel pump
- coolant flush/fill 95 A6 2.8
- Will clogged EGR valve do this?
- rear caliper rebuild guide
- 97 A6Q Headlights, lowbeam, highbeam, foglights F&R, foglight illumination on buttons
- 97 A6Q Headlights not working after replacing headlight washer pump
- Check Engine Light-i ntermittin
- 97 A6Q outside temp & gear select backlighting on dash
- How much did they cost new?
- coolant leak from radiator plug
- Can anybody use a 100 and an A6?
- Hqaving trouble searching this forum.
- EGR Valve Insufficient Air flow
- 92 100S issue list - advice appreciated!
- 97 A6Q Power Steering Mobil1 ATF/Pentrosin 11s
- 95 a6 rear caliper carriers
- Knocking sound - please help!
- 97 A6Q Headlight Washer not working
- 97 A6 CD Changer Manufacturer?
- Audi A6 Avant manual?
- 1997 A6Q Front outer CV boot replacement
- 1997 A6 Avant Electrical issue
- 97 A6 Quattro wagon front Drivers side axle
- 96 model instruments in a 94 model?
- 1993 100CS Q Intermitent overheating FIX
- chacking matching of Coolant Hose Radiator
- windshield waher pump
- auto trans problem
- CV Joint Update & Suspension Question
- Shifting issue?
- 95 A6 main central locking system location?
- Urgent: Looking for rear diff for sale (93 100 Quattro)
- 96 a6q therm. placemetn
- Rear diff might be broken? Help!
- 1995 A6 vs. 1996 A6 -- parts differences?
- 97 A6Q - Brake Pad Replacement
- Check Engine Light- No code?
- Bose Gamma CC Stereo WTS
- 1995 Audi A6 Quattro Driveshaft repair - I need this (see pics)
- Windows, Sunroof and Cruise stop working
- How to reset the 1997 A6 service indicator
- O2 sensor replacement HOW ?
- Hot tub in my trunk...
- 2.6E Transmission Compatibility
- 100S - Block Heater or Tank Heater
- Front suspention problems
- Heater core question
- How to check 1995 A6 Diff fluid...
- 1995 A6 Transmission issues...
- audi 100 c4 92'automatic gearbox problem
- Right Rear door conundrum
- rear output flange seal: Please point me in the right direction
- old style crank vent system in a 96 audi possible?
- Avant Spoiler Removal
- Heater core change in under 3 hours
- Opinion needed.....
- where to get a transmission valve body
- Ashtray swapout - help needed
- Fuel Pump?
- How do I know - Timing belt
- Luggage blind 1997 A6
- Tools and parts for sale
- Audi Gamma CC and Instrument cluster
- '96 A6Q Cooling Fan Problem
- Help! interior wooden trim removal
- front lic. Plate frame
- heater flap servo repair - an update
- Question about smoke from a 95 A6
- anybody can help on the EGR problem?
- PCV valve on 1992 100s
- audi 100 Engine problem
- Oil Pressure on 94 100S
- VAG-COM on a 100Q?
- Radiator fluid mystery
- 95 A6Q trans filter missing piece question
- non foulers anyone give me some info?
- HOWEVER IM BACK AND MORE INSANE
- why i disappeared good audi story.
- 1997 A6 Windshield washer nozzle removal
- Help! How to open back doors with battery dead
- Bentley CD
