- Electrical problem Audi A6 2.0 97'
- Now this is a speeding ticket!!!
- Squeky A6Q
- Has anyone removed the headlight lens off of the reflector housing? I wana replace w/euro spec lens
- HELP!!! A6 Won't start after water pump change
- Darn oil plug won't come out, broke two sockets already!!!! How to get out??
- CD for 97A6Q
- Oil pan drain plug size??
- Attn. Muhammad!!!
- Factory CD Changer & 17's.
- My 2.8Q needs your help, please she's dying :(
- check engine light
- A6Q 1995 rear dark grey velour head rests WANTED!
- Heated Door Mirrors?
- Tweak Audi A6/S6 engine...
- engine's sudden stops
- Would ET45 offset (S4 rims) fit 225's on 95 A6Q
- What do you do with 15" wheels, after you upgraded your car?
- somke form the Air vent
- anybody got any dark leather front seats for sale?
- Emergency Brake Problem
- Not happy with my Audi dealer
- What Audi wheels are these??
- Considering a used '94 100 CS Avant w/low miles - Anything to look out for? Price?
- Gamma CC Radio is mute if turning on
- Audi A6 data channel
- Weird Sound - No Start
- 1990 Audi 100 Question
- Check out this pics I found of body kits for 100/A6
- Oil Change DIY or HID?
- Audi 100, y1992 - what speakers ?
- 95 A6 Oil Change
- Wrenches are ready. Prepared to dive in. But...
- Effects of salt on newer Audi's
- etka hardlock
- How to change temperature display from Fahrenheit to Celsius?
- Does anyone know where I can get a performance air intake for a '97 A6?
- Testing my new sig
- battery location
- Strange "knocking" sound on start up. Any ideas??
- I want to tackle my strut bearing project.
- another issue..
- How toget strainer insert out of the A6 brake fluid reservoir? And what's the 2d cap?
- The Diagnostic codes... and some....
- RS6... *drool* M5 killer?
- ANTI LOCK BUTTON
- engine noise on 92 100s
- Funny electric-motor kind of noise running after turning key off - what is it?
- Is a strut bearing easy to replace? And is the odometer backlight the same repair as the temp gauge?
- Door Speakers
- oil on spark plug
- Someone stole my right side clear turn signal :(
- Got Schooled By a 735iL
- DC-area garage recommendation?
- Anyone with a Bentley... Question for you.
- Outside temprature display gauge
- DASHBOARD WARNINGS
- my exterior trim is kinda fried out..
- Does anyone know the chasis code for the 1992-1997 S4/S6...
- Looking to purchase used 95-98' A6 Avant
- Whoever recommended impex autoparts i thank you!
- Selling venues?
- Odometer fraud?
- Please help! How do I fix my cruise control! Set - works, Accel - doesn't!!!
- Need info for Audi A6 2.0 1997
- Speaking of license costs, is it as expensive up there as it is in Linn Co., IqDOU?
- Serpentine belt dilema
- Does anyone know how to see elapsed time on cd tracks on Delta stereo?
- 93 100cs Computer Codes revealed?? COST?
- Cost per mile to own a used Audi
- 100 CS Transmission
- Dumb Question>>>>>>>>>>>>>>>>>
- Difference between 96' and 97 A6 Avant?
- I need a new shift knob..
- Restarting while rolling....
- New Hampshire Winter Driving School Pics & Commentary Posted
- Please help me...lol.. Check Engine light....
- Contemplating new cars...
- My "antilock off" light is now on all the time. Any idea? Bad Sensor on caliper?
- I love my Audi, it fixed itself :)
- Loose passanger door handel
- anyone in houston? I need some help...
- Anyone want a 92 100csq?
- No more HESITATION!
- how to pool out the fog light switch.
- will a Auto tranny like a 94' A6 work in a 94' 90CS? my tranny is shot..
- Tanker Truck was filling tanks while I was getting gas this morning and MIL light went on today?
- Kuhmo's
- Replacing ignition wire set.. what's so special about BOSCH?
- idle stabilizer valve
- Euclid - did you get my e-mail?
- Any suggestions for a Mechanic in Chicago
- I don't like this feature in the Delta stereo
- 100 Nothelle suspension...anybody need one?
- Sometimes my Computer display scrambles
- My Lock system is in Reverse please help CS100 Q
- Help - EGR - Code 2411 - Engine idle Rough - Vibrates at 1800 RPM
- A6Q CD changer mounting bracket location question
- Front end feels funny when backing out of driveway?
- High pitched sound on acceleration at various speeds
- Anyone know about replacement ECU from Powerchip ???
- Audi 100 Estate 2ltr AAD engine Fault Code 587
- Wheels
- 1992 100CS running rough
- Groan when using breaks ONLY in reverse.
- Safety ratings/question (92-97)???
- MIL - Bad O2 Sensors?
- Transmission oil dip stick??? Check tran oil? for 95-A6
- Cosmetic Repairs
- Anyone have Mille Miglia Evo's that can post a pic of them on their car?
- If anybody wants to kill his car with SC. Here is the cheap one
- How to safely lift 100CSQ sedan?
- "In 2" service indicator on trip odometer
- How to align camshaft´s / timing belt on 2.8 V6 engine ?
- NYCMetro Area Audi Group Meet this Saturday, February 9th!!
- Shocks/Springs
- cold start hesitation problems..
- Hey Style12v, what kind of exhaust did you sell to BornAgainAudi a few months back??
- Oil Light comes on during left turn
- Sorted!
- Beep-beep, do you have the Radio Shack Part # for the bulb?
- Burning smell under load?
- Oil Pressure Gauge readings?
- Auto Tranny dipstick Redux - Olympic Import Auto Parts came up empty too - bummer!
- Got car back from audi and now, some problems..
- Alarm question... for the 1996 A6Q
- HowTo - Replace the factory Gamma radio with aftermarket unit (long)
- 1993 CS Issues NEW OWNER!
- Flourescent lights and keyless entry, whats the deal?
- Impex has the lower control arm for $100 audi wants over $300! Is there any difference?
- Non Hubcentric S6-Replia wheels
- Thanks to Seattle Scott, beep-beep, simply audi, Muhammad, jeff_c3121, ARK, et al. More....
- 95 A6 Rear Muffler Hanger Fix?
- would changing the fuel injectors to a heavier set increase performance on the 12v?
- trunk ALARM!! ALARM!! ALARM!!!
- need brakes...do I need rotors too?
- Hey fellows....
- Some guy has the 95-96 A6 headlamp assys on ebay. i think for like 149 each
- Fuel pump relay / or pump?
- Need to find a good mechanic in Montgomery AL area
- Beep-Beep...you da man! I fixed my dash lights w/ ease thanks to you!
- So if i were to sell my 16 inch 5 star rims how much do you think i can get
- Dr. SnowLove (or, How I Learned to Stop Worrying and Love the quattro) edited
- '94 100CSq speedometer
- 2-seater refit kit for Audi 100 station-wagon for sale
- 97 A6Q Wagon Questions????
- Did anybody installed VCR or DVD in A6?
- better to fix the brakes at a dealer or privately?
- 91 100 New Owner Questions
- NYC Area: Possible Krispy Kreme Run 1/31/02
- Fuel Level Information Sender....
- Guys, I'm all screwed up and confused. Is the water pump driven off the timing belt? (2.8 12v)
- How big can you go with 17 inch rims with 35MM offset. Can i squeeze 235/45R17 w/o rubbing
- New S6 Avant
- Cost of front rotors and pads
- climate control bulb
- Simple web page with pics of my car that is for sale.
- Where can I get a keyless entry fob?
- Does anyone know where I can get a auto-tranny "02" dipstick? Audi dealer says they can't get them.
- Program 97 A6Q Wagon Keyless Remote Entry Lock
- Ok... FINAL list for the S6 Plus euro taillight bars...
- Euro tailights
- New problem in Bose speakers
- Question for BEEP-BEEP......
- Anyone know what is the most likely EGR problem- EGR valve or EGR solenoid?
- 95' A6, Radio question
- Passenger Seat Rattles
- 30v owners are very rich and apparently they think all 100 owners work at a Burger joint
- question about my gear shifter.
- Picture of 92 100 I am selling. Looking to buy a 96 A6 Quattro.
- Sorry, not an audi question, but a Porsche question.........
- Found a good use for 15" '02 A4 rims and OVERSIZE P6 Fourseasons. (205/65-15)
- engine shutter
- Need an advice ...
- 97A6Q fuel gauge and Rear Washer problems
- Bentley CD-ROM in Fuel System contents (for AAH) lists: MMS 100/200, 300, 311, 400 - What are these?
- Dead Battery Gremlins
- A6 2.5 TDi 140 bhp 1996 - CC ODC DTC 08.5
- FYI... Low power at low RPM's is now FIXED
- Any word on that Euro style A6 taillight assembly.
- picture of 1996 a6 quattro dark green. anyone have one?
- Update UrS6, should I buy it?...... (more)
- Spot the Audi!
- Gamma radio variations.
- Springs for 94 100CS non Q
- can anyone tell me if KYB can be mixed w/Koni??
- 1992 100cs
- Question???
- Radio codes
- Buying 1993 100CS what should I be looking for?
- SE Quattro Club Drivers Safety Seminar @ Roebling Road
- Looking to sell my 92 100 S.
- looking to sell my a6 1996 audi
- How to Replace Bulb In Power Side View Mirror Control Switch
- HELP!!! serious hesitation problem..
- 1994 100S trans problem
- Power Window and Engine Vibration
- brake fluid resevoir..slow leakage...EEEEEE
- programmable intermittant wiper relay didn't work (?)
- 93 100cs
- Got the audi back. 306 to fix ignition switch.. and i have a bad lower control arm
- MidTex Audi&Porsche Specialist (Randy) in Naperville, IL. is having a Major sale on 100/A6 parts....
- Problems, Problems
- S6 Plus taillight assembly - $210 plus shipping. Anyone?
- can someone tell me about my 1992 100..?
- Manual Transmission and Differential Fluid Change - Quattro
- Too Hot!
- any way to add the anti-lock off button to the 95 A6?
- The 12 valve challenge
- What is a firewall and how much should a new one cost?
- So what transmission do I have? A ZIF ZF4HP18 or ZF5HP19FL and what's the difference?
- Changing the thermostat.
- Accelerator pedal vibration
- 1990 100 Heater box install question
- radio problem
- hey..my power steering became LOUD today..
- Ok!! how about the "BOMB" looking symbol with an X on it??
- 1997 Audi A6 trunk liner...
- 75k Mi Service Intervial.
- Any Sites to purchase Seat Heater elements? Other than dealer...
- Overheat Signal & Interior Fogging
- Query on Malfunctioning Turn Direction control
- 1995 A6 climate question
- what's this dash symbol mean (o) ??
- Cam timing on a 92 100Q
- Big question : Replacing engine
- Three blank buttons between "Emergency lights" and "Passenger's heated seat control"?
- 100cs Q Fog lamp replacement
- Gear selection switch on tranny.
- Can you replace a factory radio with an aftermarket one in an A6?
- Body kits for the C4?? I see there are many for the 96+ A4
- WA LASER SPEED TRAP ALERT (X-POST)
- Question about my 1st A6 - Is this normal?
- 94 100 CSQ - Rear Brake options - Rotor and Pads
- Remote Key Program for 100csq
- DELTA Radio Information & Unlocking Procedure
- GAMMA Radio Information & Unlocking Procedure
- defrost button depends on light?
- What was the U.S. price of an A6 back in 1997?
- Auto mechanic.
- Is this an H1 Bulb on my '97 wagon?
- Tire options 95 A6
- Compact cassette player.
- Dropping car off at Audi on Wednesday
- Please post your experiences comparing a 98 A6Q to a 96 A6 Avant FWD. Engine noise and performance.
- Pictures of the 97 a6 I just got
- 1997 Audi S6 6 spd manual, possible purchase ---->
- Pics of the A-pillar install
- Pictures of 16" A4 Sport Wheels on a A6 or 100?
