- How hot can a 2.8 get before there is damage?
- Head Gasket
- Windshield leak (1998 Wagon A6 12 V) !!!
- sold my audi, anyone looking for a Vag-com and laptop
- Rear defogger switch quesiton
- EGR
- Quick Suggestion!!! One of the Foreign Cars shop charge me around $500 for ATF and Thermostat
- Why dealers service really annoy me.
- Which OBD pins to jump for check engine? (97 wagon)
- 92 100 CS parting out - what should I nab?
- Fuel pump question?
- got my A6 detailed today,check it out....
- C4 A4 strut question -
- HI, I need to do my Thermostat/ATF filter change tomorrow..anyone got a procedure guides.many thanks
- When the Snow flies !!
- I need a battery for a 97A6avant. Dealer or are there other options?
- 93 100CS--Changing Rear Rotors and Pads
- 1992 Audi 100S 5-speed (I need a transmission) - same as V6 90's? Now with a picture
- 92 100 will not start PLEASE HELP!!!!!!!!
- I want a 92 S4 !!!!!
- timimg belt
- Top do not open on my 1995 Cabriolet
- WAAAY high oil pressure... what are the causes and fixes?
- Anybody ever change fuel pressure hose???
- electrical question
- 93 100CS V6 Tach Question
- Online ETKA
- timing belt/water pump replacement: should I use "Form-a-gusket"?
- 93 100s vs. 95-96 A6
- anybody installed one of those aftermarket backup sensors?
- NEWBIE HERE: can you please school me on the 95 A6 quatros?
- Valve Tapping when HOT
- anyone need a good Gamma RADIO?
- Items for sale.
- Bizzaro cig lighter problem
- HI guys!! is there a Procedure Step-by Step Guide for Thermostat replacement!!! thanks
- 94 100 CS ABS sensor?
- Shameless FS post: 100CS on eBay
- ... must update the cabin filter.
- dang
- Is the rear hub on the 2wd cars pressed on?
- parting out '97 A6 sedan ad in audifans.com
- 1993 100CS Electronics Issue??
- Will a 93 90 Headliner fit on a 92 100?
- AUDI A6 2.6 1996
- This '93 100 is gonna go cheap due to the headline ("high mileage" at 128k!!!)
- I just saw a set of Boge Turbo Gas rear shocks for C4s for $75 on Ebay(more)
- GOOD BRAND
- New error messages post belt change and trans flush
- subframe mount R&R
- Helpppp...I removed the collar bolt for drive axle but cann't seem to remove the CV-Joint from Exle.
- 1992 Audi 100 CS Overheating?
- Stereo Speakers Sound...need help
- Looking for a radiator fan motor
- 1994 100Q - lots of q's
- Is anyone parting out an A6? I need the outside chrome door trim!
- 95 A6 quattro.....what's the OFFSET ? 35 to 45 works? Thank you!!!
- **Needed** Audi 100 92-94 Headliner
- Anyone need anything off a 12v?
- adding a remote
- A6 1997 - Radiator fan starts late!
- Any tips on changing Brake fluid and lines?
- New owner of a 92 100CS Avant
- Frequency of Power Output Stage (POS) and/or Coil Pack failures?
- Chime for an 95 A6 quattro,anybody got one ?
- 94 Audi 100 S Ignition Switch Problem...
- EBC greenstuff , Pagid, PBR???? gotta change my brake pads...
- would the fuel pump relay stop the pump at random
- OEM Springs! Just wondering if the 1997 Audi A4 1.8T Springs are going to fix on the 1994 100S model
- 16824 - EVAP Emission Control Sys: Malfunction
- c4 a6 Q wagon suspension
- what is the size of 12pt socket for cranckshaft?
- I have compared specs of 1996 and 2002 A6. Not that different.
- Fuel system demons, HELP!
- Annoying Engine Light On/Off
- oil and catalytic converter
- after sitting 4 days in the parking lot next to my job i finally got it to start again !!! hurray!
- [O.C. Reminder] Audi GTG @ G.Bilotta's in Brea -- Tomorrow TUE Sept 27 8:00pm
- '95 A6 Infrared Keyless Entry HELP!
- x-post
- c4 2.8 30v swap
- Anyone Adjusted Front ABS Sensors?
- I think my thermostadt is failing...also a ?? about rad fans..
- Aftermarket Stereo Upgrades
- weid Odor smell fron inside the car!!!
- 94 100cs 2.8 keeps blowing head gaskets
- general engine maintenance
- '94 100q with Ronal R28 wheels.
- Saw a A6 avant in the neighborhood today
- hrmm..
- front of engine noise... normal?
- x-post: I tried some of the Prestone SuperFlush this last week and...
- Thought y'all might like to see...
- 95 A6 QUATTRO,AUTOMATIC - NEUTRAL SAFETY SWITCH .....where is it?
- OIL Question
- 95 A6 Quattro Auto Crank Sensor? No Start!
- BOSE SPEAKERS
- How many control modules are in a 93 100cs
- need your help!! starter is jammed,,,no sound no action,nothing,the car won't even try to start.
- Transmission now in safe mode! :-(
- crackling noise
- I can't pinpoint the drain/fill plugs on read differential..
- now what exactly is this?,....
- Rebuilt Engine Source
- rear differentail gear ratio.
- Saw the funniest thing today (A short story by me)
- Radio Problem!!! Need help
- struts
- REPLACING COOLANT TEMPERATURE SENSOR CONTINUED
- Can you disconnect autocheck?
- does catalytic converter have any affect on oil consumption?
- O2 Sensor(s)
- Need HELP !!! Car refuse to start.
- Stalling Update 4Driver4 you were right,,, $143 for a local pump $120 if I order it online
- REPLACING COOLANT TEMP. SENSOR
- Auto gear box
- Coolant, Power Steering Leak....
- 96 A6 Avant - Read Windshield Washer
- RADIO CODE & MY 94 100S
- any tips on pulling fuel pump (never done it)
- anti-lock brake sensor - how far do you push it in?
- Detailed my interior and a picture of my trip computer
- May sell my Audi, which means will sell VAG-Com Also whats it worth?
- Update on failed timing belt, with pic!
- Nobody mentions checking vacuum to EGR before recommending cleaning EGR passage. I should have
- NEW for The O.C. -- Audi GTG @ G.Bilotta's in Brea : TUE Sept 27
- Anyone looking for a '91 200q20v Avant and more?
- Question about tranny seals.
- PRICES LOWERED!!! FS: Misc Parts... (switches, trim, pedal) for audi 100
- Car died last night at a stop sign..
- 1992 Audi CS 100 for parts
- AIR CONDITION
- Meineke "right service,right price"...yeah right !!! PART 2 with pictures
- Before I go mad, how do I get my front bumper off my 1994 A6??????
- "AIR BAG" light came on!!!
- 1998 A6 Avant Wagon-should we buy?
- HELPPP
- See anything here you need? I am trying to clean out my basement...
- Pictures of my "HIGH-FLOW" exhaust.....created by Meineke "right service, right price"....right!!!!!
- new issue: cannot get ignition key out. Look like the locking cable stuck somewhere.
- Anything special I need to know about changing a valve cover gasket? I need to do one. Thanks!
- 94 100S radio code
- What's the mileage interval for replacing the fuel filter on 95 A6
- Anyone Interested in a Clarion AutoPc?
- Tranny problemo
- Eliminating exhaust sound by cats
- Hood wont open, only the drives side latch gives, but the other side doesnt pop out, nor does..
- Pacific Northwest Beer and Brats meet
- Cooling hose question
- wtb climate control dash module for 95 a6
- just installed Magnaflow hi flow cats and muffler....SUCKS!
- Can anyone tell me the best or worst Seller of clear marker lights on Ebay
- Timing Belt Broken???? Help!!!!
- EGR insufficient flow code. Removed EGR valve, clean as a whistle. What sensor senses the EGR flow?
- Anyone have a spare 10-disc changer cartridge?
- my hood bowden cable broke (next to the hood opening handle)
- What is the part # for the fuel pump relay..94 100S??
- tranny problems
- Radio Lockout?
- CV joint ball bearings are all out - is the joint junk now?
- Oil Puddles
- drivers side front window
- What the heck? Windows or Sunroof won't roll up in 94 100S..
- removing door panel on 1997 A6
- V6 Throttle potentiometer needed. Best place to get one?
- 2.8 head
- auto transmission dipstick! Read on if you want to make one!
- Power Window and Sunroof Relay
- WTB: AAH heads. PA/NJ is best. TIA.
- Replacing passenger mirror
- Bulb Out?
- Radio options
- Has anyone replaced the steering dampner??
- What's this?? - under the back seat
- 95 Audi A6 quattro!!! i need to know if i can put a throttle body from a 1994 90S .Thanks a lot !!!
- Not sure why, entirely, but I LOVE this picture. Ha!
- Anyone know where to get a black piece of trim
- Need advice on stuck ball joint pin.
- Head bolts
- Ghetto! but i kinda like it
- where can i get this engine..
- Fuel Delivery Problem - Audi 100 2.0E 1993
- Clear corners for a 95 A6 quattro.....are they different than the ones for a 96 A6?
- other than the cleaning issue,i think the design is genius.
- '92 Audi 100 oil in water - Head gasket?
- Q re Anti-Theft Switch Locations and Addition to FAQ
- ATDC setting up
- OBD-II conversion on 94 100S...does it really work good?
- Transmission troubles
- Am I the only one that hates cleaning the area by the trunk hinge?
- For Sale: Bentley CD-ROM
- Audi Driving Experience, Circuit de Catalunya, Barcelona, Spain...
- audi get together was sooo badass!!!
- ILL PAY YOU FOR WHEELS AND TIRES
- Oil Temperature !!!
- LOOKING FOR AUDI BOSE STEREO
- If I were in the market, my sites would be set on this car
- HELP!! Lower Control Arm Dilemna
- New here / Looking for wooden frame (Germany)
- I can just use a catco cat to replace one of our dead, driver side, cat on the A6, no?
- correct reading on temperature gauge
- sticky ignition...
- How much oil do you have to replace and how often?
- Rear brake replacement on 95 A6QA
- 100s for 100$ on ebay
- what size are the exhaust pipes on our cars.? too lazy to look
- 92 100S Battery drain
- How do I take my key completely apart?
- ATTENTION EVERYONE-(OVERHEATING)PLEASE READ
- vag-com
- Join us a for drive this Saturday, Sept 10th- from Malibu to Ojai w/ stop at Old Creek Ranch Winery
- DIAGNOSTIC TOOLS FOR 1993 AUDI 100
- "New" 92 100s
- plastic front grill damage. from idiots backing up their trucks.
- HIGH FLOW CATS do they make the car louder in a stock setup?
- mission "modified MAF" completed ...i now have a "bad-ass" car !! ;)
- Getting tired of the badly dented hood, anyone know of a Pearl one for sale?? '93 100CS
- No power. Need help!!
- where is the temp sensor for the EGR 95 A6 afc
- First Road Trip and Brakes Update
- 92 100S: Is there an OBDII connector? n/t
- 96 A6: Old or New remote doesn't work or program
- i'm looking to convert my exhaust from 2 cats to 1 bigger cat system
- Flushed my power steering fluid today. Used Febi S6161 (equiv. to CHF 11S). Anyone...
- Final word on CDT transmission oil?
- 92 100cs Emiasions Question
- 96 A6 Wagon tailgate lock leaks air, doesn't lock... How to remove the handle since bentley said
- Reminiscing 'bout my C4...
- CAMSHAFT ALIGNMENT TOOL,BEST PLACE TO BUY?
- Weird rattle/scraping noise from front of engine
- Front Center Armrest
- GOT THIS LITTLE GEM FOR SALE!
- '93 100 SUSPENSION UPGRADE SUGESSIONS
- Gutting Cats today....
- '96 A6 fwd w/ 121K mi is down to 16.7 mpg. What to do to improve???
- Just recoded the AC control head on the 96 A6Q so I can use recir without AC
- Annoying ticking noise coming from canister under intake manifold
- I want one of these
- Ethericaudi- do you still have the Boge shocks? I'm interested and live in Ca.
- What's the best way to fix a crack in the windshield fluid canister?
- 96 A6 O2 sensors & better gas mileage
- 96 A6 interior parts
- 1993 100 auto tansmission dipstick-help!
- 94 100 Manual Trans fluid change
- Replacing wheels/tires - how big can you go?
- 96 A6 vs 92 100S; should the 100S be slower than the A6?
- high flow cats with stock exhaust(center and rear muffler).....is it louder?
- REMINDER: BROOKLYN MEET TOMORROW
- Eibach Disaster
- E85 use in 2001 A6
