PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. looking for freeze plug on engine block
  2. I've got lifter noise. 100cs 1992
  3. only one heat setting
  4. seating rear brake piston '95 A6
  5. How Difficlut is an EGR cleaning?
  6. Aftermarket clutch
  7. Thanks to those who advised me on taking out my seats. Carpet's super-clean now !
  8. Trunk Shocks?
  9. Avant rear wiper stopped working...
  10. Official (3 vol.) Factory Repair Manual for sale 100, A6: 92-97
  11. Has anyone found any aftermarket door mouldings?
  12. Some pictures of my car.
  13. Instrument Cluster - How many 2W bulbs to buy?
  14. 1997 A6 Autobox Installation Questions
  15. trip computer
  16. Evaporator locking flap
  17. So, if a inner cv joint was improperly rebuilt, could there be a metal on metal grinding noise?
  18. 1996 A6 2.8 V6 strange rpms behaviour
  19. Cooling System Flush
  20. Winter(Upstate NY) Oil Change Soon
  21. This is whats making the beeping noise everyday?
  22. If anyone wants a Gamma radio, search ...
  23. Hey guys- I need some advice on how to remove my power seats to clean my carpet. There are...
  24. Can you help me with a Radio Code...?
  25. having a clutch problem HELP!!
  26. Analog clock - speedo cluster
  27. How to change AT and diff oils.
  28. VIN Numbers
  29. Is my bose radio Delta ot Gamma?
  30. Heater core housing - looking for advice
  31. V1 install for those who wanna know...
  32. PSA: Check your strut mounts, this could be the source of your clunk.
  33. Here's a little preview of one of my fun projects (the dented door is NOT one of them though...)
  34. Need some help with differential lock
  35. I was away in Tokyo for the most of the year. Did I miss anything.
  36. pulling to the right
  37. Looking for a picture or diagram of vacuum routing on the drivers side valve cover
  38. no bulb will work
  39. 1997 Audi A6 Quattro value
  40. Catalytic Converter
  41. Climate control fault code for "central flap"
  42. tire swap question
  43. Just got car back from dealer
  44. Brought my car in for alignment and dealer wants $289!
  45. A6 2.8 V6 won't start
  46. What is the best source for a trailer hitch? A Universal kit preferred.
  47. 95 A6 Quattro Wagon question
  48. Valve lifter replacement, help!! :(
  49. Rock meets headlight - you know the rest
  50. odd wiper question
  51. Power seat issues
  52. Euro License Plate Mod?
  53. Wiz-Bang headlight bulb update
  54. Any of you audi owners in annapolis MD
  55. I'm doing my rear struts tonight, any wise words?
  56. 95 A6 Tranny Issue
  57. 1992 Audi 100 CS- any experience with Bilstein touring class struts/shocks?
  58. Climate Control
  59. another radio question
  60. REGISTER NOW: New England GTG on Wed, Nov 15 in Framingham, MA
  61. For Sale...95 A6Q Cheap
  62. Delta CC frequency spacing - programmable feature?
  63. Tire question-not about brands
  64. Need some advice on how to clean my engine.
  65. Any of you clusterswappers have an extra gear indicator display?
  66. First rule on changing the pollen filter on a '95 A6...
  67. Backup bub replacement
  68. Alas, my chariot is wounded...a pic to share
  69. Part Information Needed. DOME LIGHT/ SUN ROOF SWITCH OVER HEAD CONSOLE
  70. Who sells headlight lenses for an A6?
  71. 95 A6 Q Wagon - how to tell regular or sport suspension
  72. Auto trany
  73. Auto to 5sp. ???
  74. Window Relay
  75. Dash Lights
  76. If anyone's got a spare rear pass. door I may need one...my car got hit and run yesterday! I'll...
  77. Running '94 100S $900.00 **Ohio**
  78. Cruse contorl electronic unit location
  79. new remote headaches
  80. Blaupunkt Gamma CC Wiring... Help Decode this...
  81. Replaced the Grooved Discs and it is smooth braking now!!!
  82. New England GTG - X-post to POLL on Oct 25 date for meeting
  83. I need a new cluster..for my 95 A6
  84. Anyone parting a 95.5+ A6 or able to get parts from one?
  85. Does the hood have to come off to change the front strut inserts?
  86. ABS control unit leak
  87. Looking for a cheap trunk cylinder lock w/key. Thanks.
  88. New Ignition fixed many things.... Amazing!!!
  89. Will a Concert deck work in my 1994 C4 100s? (x-post from audio)
  90. Window Problem
  91. v b chil-n: Your VW premium IV radio, can I retain use of my factory 10 disc changer?
  92. temp readout
  93. still fighting w/ diagnosis on 93 100
  94. 92 100s questions
  95. Confirming ignition switch is the problem
  96. sad day for my audi's :(
  97. Headlamp switch, pretty easy. Took about 30 min total.
  98. Just wondering if anyone has put a Nav system in there C4.
  99. 1995 A6 upgrades (Sorry if that has been posted 1000 times but I can't find the info)
  100. flashing number
  101. c4 a6 project need help!!
  102. Sylvania Silverstars = nice headlight upgrade?
  103. Front end clunking is back....and worse than before
  104. 97 A6 Radio issue
  105. mad but happy
  106. Is there a way to add a solar fan to my sunroof?
  107. Looking for parts
  108. 93 100 not quat
  109. How do you post your pics and signature?... Vicious!!
  110. Pinstriped - what do you think?
  111. Can I use my stock sub with an aftermarket deck even though I ran new speaker wires.
  112. Questions about engine swaps
  113. What is the difference between Sachs Advantage and Super Tourings?
  114. c4 a6 project need ideas!!
  115. Headlight Washer Mechanism
  116. blower motor is jinxed
  117. Glass Sunroof
  118. [TUE Oct 17] This is it L.A., last GTG @ The Stand for this year... don't miss it!!!
  119. 1994 A6 Avant quattro: rear wiper and demister problem
  120. can anyone help???
  121. Which cable is the one taking 12V to the rear amp?
  122. Check Engine Light + Random Beeps!
  123. This might be old but, 96 A6's were recalled for ignition switches.
  124. X-Post from Audio forum.
  125. EGR error code
  126. Trans. Shift Flare
  127. Mintex Pads
  128. Automatic Transmission Fluid...what to use??
  129. Rear speaker cover/grille removal
  130. What causes high crankcase and head pressure and subsequent oil leaks in these cars?...
  131. Radiator swap - arrrrrgh!
  132. If any of you guys need parts from an audi 100 or 95 a6 avant email me.
  133. No Alignment/worn parts A6 Q
  134. Got It kday
  135. So how does one fix the hatch rattle/ squek.
  136. Just bought this
  137. strut replacement question- do I replace everything...
  138. performance parts
  139. Original A6 quattro sedan exhaust system for sale in Cali
  140. Avant Rear wiper arm
  141. Has anyone ever figured out the source of the annoying clicking sound when...
  142. trip computer
  143. frozen brake bleeders
  144. trans wiring swap
  145. When you speak about resoldering the cluster.... ???
  146. 93 100 s not quat
  147. The blue vacum velve
  148. Is there a trans service Tech Article for 4-sp auto trans fluid service?
  149. Carbon Monoxide and Fumes... Help!
  150. Wanting to chrome the grill, but wanting to use the door edge method, what size.
  151. spark plug gap
  152. Here's a good one....milk shake out of right inner CV boot?!
  153. Aftermarket Stereo... Rear Speakers OFF ???
  154. no heat A6 2.8 quattro
  155. Dash Lights and Taillights out. Headlight switch feels funny, is that a likely problem? (1995)
  156. Where can I get a new lighted master key.
  157. 93 100 S Intrument Cluster interchange models...???
  158. I found this site with some FAQ Check it out.
  159. need new tires, what to get though.
  160. Anyone with a Bently.....
  161. Cheap to a good home
  162. breather hoses on a 92 100 CS
  163. Latest CR Ratings for All-Season Radials (Nov '06 issue)...
  164. exhaust
  165. 100cs infrared key.. Dealer only item?
  166. instrument cluster woes
  167. Is there really a difference with the early 1992 front doors?
  168. Why are our cars SO cheap in the USA and so expensive in Canada?
  169. Removing Tailgate Trim
  170. The dreaded transmission cold rattle
  171. winter tires
  172. nokia speakers A6 '95
  173. INVESTIGATE 911, VERY IMPORTANT
  174. Will these springs fit?
  175. Changed my instrument lights and now my buzzer wont go off!!
  176. '96 Audi A6 (loaded, blah blah) with 193k miles.
  177. Next year I want a '92 Avant. Keep that in mind.
  178. Would this cupholder work?
  179. Taking bets - Is it totaled?
  180. Help Me Diagnose This GD Toyota
  181. ignition problem
  182. Camshaft breather hose
  183. Suddenly I'm now having problems uploading multiple pics from my Poster. Anyone care to help?
  184. 92 100 Quattro Automatic, transmission reliability? Mother needs new car.
  185. Door Mouldings (1993 Audi 100S)
  186. LAST CALL: ACNA 2-day track event @ Willow Springs (Oct 9-10)
  187. vacuum brake bleeder
  188. STaSIS Motorsports Continues Home After Round 9 at The Petit Le Man's *SPOILER*
  189. Removing sway bar on 2.8 V6
  190. working on my strut mount....
  191. I can't WAIT until these are 12 years old so I can afford one!!
  192. trip mod on my 97 a6
  193. Defroster/ Footwell Servo.. Help!!
  194. Crazy Swedes and their turbo cars
  195. Roof Rack for Wagon?
  196. Ipod with Bose headunit
  197. RIMS
  198. Windshield Fogging up... Any ideas?
  199. readingf the 02 sensor with VAG-COM
  200. Looking for a new/used Audi near Boston, MA, come to me!!
  201. No door buzzer in accessory position, mod!
  202. Aftermarket Cd Player in my 95 A6...is this possible?
  203. Owner's Manual Related Question (Already ordered one...)
  204. AC Troubleshooting... PROBLEMS
  205. How to Remove the Radio?
  206. Noise
  207. Accidently shorted my headlight! Blown fuse?
  208. My dashboard lights.
  209. Hitch swap question....
  210. **Hartford, CT GTG - Tomorrow - 9/27- Forecast is 73 degrees and sunny!
  211. Neutral safety switch?
  212. So I bought a Concert unit on Ebay and...
  213. Cruise Computer
  214. TONIGHT: L.A. GTG @ The Stand in Encino (SFV) - 7:00pm
  215. Damn, my passenger side mirror doesn't tilt down in reverse. I geuss not a feature on 5speeds.
  216. EDIGREG: Here's the email that got lost...
  217. Axle Shaft Removal
  218. Anyone looking for a '97 A6 quattro?
  219. bose unit
  220. Yeepeee!!!! A New Audi Owner!!!
  221. 00652 - Gear Monitoring -Implausible Signal....Please help
  222. guys...quick question 93 100S tranny compatible with 95 A6? Can it be swapped?
  223. Need Help! I am looking for a bose unit for my 95 A6
  224. Very dumb question. This will help me get started...
  225. Sunday night fun - key broke off
  226. Mercedes wheels for my 95 A6 wagon ???
  227. 95 A6 owners... or anyone that might know - air intake location question
  228. Rear lenses
  229. Anyone going to H20 today?
  230. windshield wiper issues...
  231. New AW STFA Avatar =)
  232. Q re Potential Effects of REALLY Bad CV Joints
  233. REMINDER: upcoming Audi GTG @ The Stand in Encino -- TUE Sept 26th
  234. Paging Jonathan....if you're still interested in a 4.2 conversion email me...
  235. Check This Out
  236. Add Temperature Display to Instrument Cluster
  237. EDIGREG... I sent you an email last night. I hope you got it.
  238. Where is connector Station 2?
  239. Temp Control and Fan Speed control not responding.
  240. can you buy crate engines from audi? ie a 4.2 V8 engine.
  241. headlights
  242. Car alarm won't stop going off!!!!!
  243. Help, Trunk Locked!
  244. New problem tonight...
  245. Instrument cluster out,now a few questions
  246. 1997 A6 Q passenger mirror tilt on reverse gear
  247. Tachometer not working
  248. Where's the best place to get a coolant reservoir?? 94 100S
  249. Anyone wanna fix my seat heater bulbs?
  250. How to replace instrument lights - needle pointer '95 A6Q
