- Few questions about keyless entry in 92 100CS Quattro
- 1996, A6 Radio resetting fiasco... Help!
- Dash lights
- Replaced the cracked vacuum pipe today...
- 92 100cs does it have odb
- Smoke around steering column
- reset ln.a and ln.2
- 100 Avant quattro Engine Swap
- '91 100 Spark Plug Recommendation
- what does the third "check..." light mean?
- Metallic clunking/clicking sounds when shifting gears...
- Followup on power steering fluids
- brake failure update.
- Help!!! Audi 100 shuts down after 5 minutes
- Shimmy and vibration- 96 A6Q-HELP
- 100Q Leaking oil
- Wanted Red 97 A6 time to upgrade from this...
- Has anyone done an HID upgrade on their C4?
- Where can i find clear corners for a 97 A6 that are good and not too expensive?
- What do you guys have as performance exhaust for my 97 A6? Mufflers?
- Jack how is the fuel injector install coming?
- Dyno Results (take 2): UrS4's Stage 2+ Throttle Body and MAF inlet velocity stack for 2.8 12v.
- Head light swap info needed...
- Hey ShoppingKart- Did you do the axle assembly swap yet?
- All this talk about power steering systems....
- How to replace the upper door molding of 100S?
- cheapest place for this part...
- Excuse me for screaming, but: MY BRAKES FAILED!!!
- Ok, the brake light warning is going on and off at random times...
- Can anyone please explain what the difference is between the Bilstein HD and Sport shocks?
- Need new screen Name!
- So, my 95 A6 has always drank about a quart of oil every couple thousand
- A6, '96 steering rack.
- Has anybody had any problems with their brake booster, or vacuum leaks?
- strut tie bars
- Question about my car... it's idling pretty rough and...
- Thermostat replacement
- speed bump..
- MotoDyne memories! :->
- do I have to do a alignment after I replace my axle?
- Brake Pad warning came on today, how long can I still drive on it?
- c/v boot joint axles
- Rear Axle Headaches -- Anyone Else Experienced This?
- how much trannsmission fluid should i put in?
- Help, front final drive, center differential, rear final drive
- lowered suspenssion blueses.
- '94 100s - Fan still running after shutting car off?
- is this bad? Should I fix asap? What is this part called? Can I do it myself? how easy? thanks! :)
- oil on the bottom of my oil pan. Should I worry? Should I replace the oil pan, or just the gasket?
- Wiper relay noise and cruise control noise
- this is amazing.. is lpg available here?????
- Finally got some pics!
- Intro/1995 A6
- Where to buy 93 100S door molding?
- Squeky Seatbelt Covers ?
- nervous...
- Air Con recharge
- I haven't been posting a lot lately...
- Wagonmann: What did you have to do to your tranny @ 55k miles?
- Federalizing a Euro Spec 1992 100
- Auto Shift Knob Thread Diameter '96 A6?
- General Automotive Question - How can I safely dispose of old gasoline?
- how much are stock foglights?
- anyone know if there is a site to get interior wood pannels?
- Do 97 A6's have heated outside mirrors? is so how do i see if woking? if not how do i fix? unplugged
- Dyno Results: UrS4's Stage 2+ Throttle Body and MAF inlet velocity stack for 2.8 12v.
- will s6 steering wheel fit 94 100?
- Anyone have a spare lower grill?
- cops stop me because "in the corner my wheels almost get of the ground". I need bigger sway bars...
- Who here would be interested in a group buy on A/C compressors???
- Is there going to be anthing else going wrong?
- 93 csq auto transmission help needed
- Anyone got HIDs installed?
- Looking at a used 97'
- Tranny work
- Engine vibrations 2.8 1992 at 1800 rpm
- HID kit sites and prices for H1 bulbs? 97 A6 Comments?
- Dash light replacement
- Is the stock front rotor size for a 95 A6 FWD 288x25mm and rear 245x10mm?
- A/C compressor troubleshooting...any thoughts? (kinda long)
- Does anybody have any tips or a procedure for replacing the ignition switch?
- a100 2,8A'92 adding automatic transmission fluids
- Audi 8 Pin Cd Changer
- '95 A6q Avant Auto Climate Control Troubleshooting--revisited
- 8-Pin Cd changer plays louder out of right channel
- Audi repairs in Boston area
- Rear Rotors
- 1995 A6 suspension mod's
- Anybody wants to sell the spare wheel?
- 97 A6 Power Windows & Sunroof died
- anyone here from vermont?
- trunk power lock fail
- 2.8L AAH nearly dies when cold during acceleration
- No air con in 93 100 CS
- looking for fuel pump relay
- how much is my car worth...
- oil pressure sensor aah engine
- Brake Fluid Change
- Upgrade Help on a 92 100CSQ
- ODB
- Minor tranny leak in '96 A6 FWD Avant - Suggestions...
- Air Con
- Reverse lights comes on with headlights
- no fuel at rail
- Lights in the A6-1997
- Someone's selling S4 headlights on EBay. Nice stuff :-) Chance to get'em cheaper...
- How much should I ask 100CS 1992?
- A question here. In the last two days my car is making a cracking noise somewhere from the left dash
- just installed HO alt...
- got into an accident yesterday
- I am looking for a lower grill for a 100. Anybody have one?
- Is the diff switch from 100Q same as 90Q?
- Not so smooth
- a/c compresser question... does anyone know where
- thgt i'd give it one more try... part # for Fuel Sending Unit (Fuel Float)
- Mysterious Audi cold start clanking noise...
- Control arm bushings-is it a DIY?
- cd changer
- Going to try a slight upgrade from the 12v dev forum
- Transmission Dipstick Part Numbers Inside
- Fuel Sender unit /Floatation Device
- help
- Auto transmission fluid temp
- Problem: diagnostic display and dashboard lights
- Smell from the engine
- Anyone live in northern Indiana, southern Michigan and ever want to meet?
- 1993 100s with cracked left tail light...best place to get replacement?
- where can i find accessories like...
- Turn...Click...Turn...Click
- LOST KEYLESS REMOTE
- Friend's thinking about getting a 96 A6, how is reliability, what to look for, I'm...
- looking for mechanic in northern va
- accelerating problem
- 1993 Audi 199 milddew odor
- Is anyone's fuel pump loud? the bosch pump is really loud!
- A Problem That No One Can Diagnose....
- Mystery Illness is back...
- new audi owner HELP !!!!
- Ok i think we were all fighting for the smoked tails on ebay....
- replacement rear control arm. Is it DIY?
- 95 A6q Auto Climate Control Problems...
- Rear Window Wiper
- Fuel Pump Relay
- relay #111
- Front Cornering lenses
- Wanted, used/broken windshield washer pump
- How easy is it to re-aim the headlamps of a '91 100... is it a DIY type job?
- Finally got my baby back from the shop
- Power Steering fluid leak..
- Fuel pump???
- EMERGENCY! My trunk latch broke and I can't open it. How can get the trunk open through the car?FAST
- Warping door trim (92-94 100)
- Vag com/auto transmission fluid temp?
- Has anyone with tint installed brighter back-up bulbs? What wattage?
- pics are up!!
- Question: Why would a 92 CS 100 Quattro be selling for $7800?
- Audi 8-Pin Cd Changers
- Just had PBR pads installed.... Blah, quite spongy.
- 97 A6 automatic transmission
- 97 A6 front pads
- ignition stuck
- Temperature Regulator Flap
- Rear rotors
- Plenum Water Valve - Clean the valve.... What is the Plenum?? Where is it..
- Confirmed Audi mystery...Cold start rattle/auto transmission
- Smell of gas
- 15" Steel Rims Needed
- 92 100cs C4 body strut replacement shock absorbers
- No Heat!
- where can i find interior pannels for a '92 100s?
- 100 vs. 90
- Cool Car Ad......
- It's clutch time
- front grille
- worn out REAR rotors/brakes issues
- Radio stuck in "SAFE" mode
- recoding of 1995 A6 Quattro Auto transmission HP18fla...
- Looking for timing belt job special tools 6 cyl. engines
- Replacement Driver cat goes bad...
- Steering Rack Oil leak, '96 A6
- Where can o find a kit to go around an aftermarket cd player in a 97 A6 so it fits?
- How do i bleed Cooling System ?
- 95-97 owners, I want your stock hood grille!
- OT, but did you see in May Car & Driver that Audi won 2 (count'm, 2!) comparos.....
- What is my Wheel size and bolt pattern?
- Cleaned out under wheel arch liner
- pics of in-dash dvd w/monitor anyone?
- how do i get rid of open door dinging?
- Advice Needed for Wheels and Tires
- Catalytic converter problem...
- 100CS Problem, need suggestions
- Poll: What engine would you drop into your 100/A6?
- water leaking...
- BUYING ADVICE...which year and why
- Oil Drip Pan
- Muhammad...your in PHX right?
- Front brake advice
- Looking for some parts...
- A/C Malfunction help please
- Saw a post about popping in the speakers....
- Warm weather help? Turned on the a/c for the first time yesterday...
- Now here's a nice deal for a low mileage S6 Avant (white) on EBay
- Help with head lights...
- Center caps 97 A6Q wheels
- What kinds of HID upgrade options and kits do we have available? 97 with H1 bulbs. Prices? Stores?
- What are my options as far as mods go for making my 97 12v go as fast as possible?
- rpm & check engine it is Oxygen sensor help
- 12 V site?
- transmission issue 92 100s
- anyone dealt w/ www.acealternator.com ?
- Does anyone know where I can find the plastic piece that surrounds the rear plate cheap? Mine's...
- Wheels for Sale?
- How much is my car worth?
- Anyone for a Seidl-tuning grille for their A6/S6 C4 platform?
- alternator makers...
- G62 fault code
- Fuba Antenna Question...
- Question about Importvision(DEPO) headlights
- How does the alarm on a 93 100s work
- Relayed the headlights, now "bulb out" reminder is on...
- Who was talking @ the wind noise at speed? I have the same problem at the top rear of both front...
- Muhammad, how much did you pay to have your lowers painted? Shops tell me it cant be done... (more)
- Got A Custom Catback on my 100!
- The agony! WHY do people do this
- sigh-oh-narah, 100csQ.
- Drivers lock no longer locks all doors
- Fram Oil Filter, Throw away or use?
- I have installed Prestige RF remote this weekend. Issues.
- Deep Blue Funk
- 92-94 audi s4/100/100cs, do they share the same body?
- Pagid, ATE, PBR, -Which ones?
- Here is a strange one...
- Say Kamakaziep, I got a quick question(s) for ya.......
- Engine Cooling Temperature Sensor...
- please tell me this doesn't suck!
- Horrendous wind noise
- Catz Xenon HID 4300K install
- Oil Leak Help please... (pic)
- ATT! 89 100 Quattro needs help!!
- Windshield Washer Failure
- A6 Air Con Display Problem
- BUYING A 92 100 WITH 180,000 Miles
- what would it cost to get a new front bumper, painted, and installed? 97 A6
- Audi 1995 drivers side mirror (kinda long)
- FINALLY!!!!...
- ok, the wheel issue is over. I got S4 wheels with P03 tires. WOW
- Preventative maintenance parts suggestions
- Oil Pan Leak
- boots kit replecemant
