- Coolant and oil filters - A6 '96
- Question about my rear brakes -
- Performance ???????
- Heat HElp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Starter won't turn when cold.
- What would cause a new caliper to freeze?
- so a deer ran into my car the other day...
- Sunrrof motor needed!
- A6 Gary, you posted a while back the capacities for both front and rear diffs. I thought it was...
- 1995 a6
- Thinking of buying a 1993/4 Audi 100
- @!(*&@#(*^&$#!!!!!!!!!!! I think my starter took a dump
- Tie rod end vs. tie rod assembly
- If upgrading A6 rear brakes would one go with S4 or S6 components? Reason is...
- Noisy power steering when cold
- Knocking noise
- CEL on 95 A6QA. Anyone in Westchester NY w/ VAG COM
- Timing Belt change
- service reset tool
- kinderutz, I have info. on that chime. Send me an email...
- auto box problem CRH
- short shifter
- Don't mean to be a post whore but....
- 1993 100 Q Emergency :S
- What Should I look For?
- Alternator
- '96 A6 Interior part needed
- pwr stg fluid "mineral hydraulic"?
- Question to people who bought front Bilstein's shocks.
- New Audi Owner
- New to Audi - need some advice
- anyone have a black hood for sale?
- 1995 A6 Tuning Help
- Before I get stuck with a flat battery....
- Bleeding a new brake Master Cylinder
- Today was a good day....
- HELP can't find my pictures to reconnect wires
- Any cool VAG-COM programming available for a '95 A6?
- Radio Display in Instrument Cluster?
- 91 Audi 100 for sale
- CEL on.....again!!!! 2331 code found ... any help is wellcomed!
- Anyone have a GEAR SELECTOR DISPLAY?
- Driver Side Heated Seat, 94' 100 S
- 1990 audi 100 idle
- anybody have an extra front underside splash pan?
- What offset does a 95 A6 Quattro Manual have for the wheels.
- Will 17' sport rims from a 2000 A4 fit on a 1996 A6avant?
- Audi 90 or 100
- 1990 200Q purchase or 1998 a6 avant?
- Need to borrow a set of trunklid tails in NE, for a couple weeks, can anyone help?
- Steering noise when the car is cold
- Spice it up
- Bypass brake pad warning light.
- 2002 A4 Rims on 1997 A6?
- Picking up a '96 A6 Avant
- OUTSIDE TEMP. & GEAR SELECTOR DISPLAY
- nooooooooo not againnnnn
- Car will not move
- Some sad pictures from the UrS forum
- Audi A6Q 2.8 wagon vs. Volvo 850 T5 wagon
- Clarity on Auto Trans Fluid Change - 98 A6 Avant (I did search)
- Stereo upgrade in '97 Avant
- Car won't move
- Looking at buying a '94 100 Avant Quattro. How are the Auto trannies on these cars..
- key question
- Where is the remote entry signal received in the car?
- Funky Keys!
- Hey guys - quick fly by to say thanks - been researching a 92 100S
- spark plugs ....redish colour..problem?
- Anyone live near Phoenix and need a free full size spare?
- FYI: New ATF dipstick for the '92-'94 100 model on eBay...
- purchase of quattro wagon
- Before I stick this thing on ebay anyone need a 19" monitor
- Stalling problem
- Going to attemp to change water pump w/o camshaft tool....
- 94 100 Floor mats fit 98 A6 Avant?
- 92 100CSQ Pre-Purchase Questions
- Help -information Audi 100 /type 44 1883
- STARTIN TO GET COLD !!!
- Transmission Fluid/Rear Diff. Gear oil change
- 1993 Audi 90S
- 96 A6Q wont start
- xpost: thanks audijim and beep beep
- 96 A6Q auto trans fluid check
- I need a radio code for a 92 Gamma radio?????
- Audi Gamma non-bose head unit wanted or maybe something else...
- anyone have a set of rear tie rods from a Q?
- Stumbling along on cold start
- 98 C4 A6Q avant timing belt, h2o pump, tensioner, serpentine belt, roller, thermostat, and a CV boot
- Anybody have a source for vacuum hose??? Not just...
- How to mount the original CD-changer in A6 sedan
- What is the part number for the ATF dipstick......
- Transmission shifting problem
- 1994 100 CS Quattro Wagon For Sale
- Anyone looking for a 100 cluster with a trip computer to do a swap into their car?
- Is there a upper and lower strut mount?
- VAG-COM doesn't scan engine module?
- Put in new Bilstien HD's in the front.... Bilstien says there's no need for a boot?
- how many people are still active on this board and driving?
- seat won't move back
- final drive and rear differential capacities.
- Why my '97 wagon was overheating
- extremely bad gas mileage all of a sudden...
- Fix this or part it out?
- My 100s on AMG Monoblocks.
- Any ideas as to where I can get a pair of drive shafts?
- NEED AUDI EXPERT!! ANYONE GOT TOOLS AND EXPERIENCE FOR TRAMSMISSION/TIMING BELT SERVICE NEAR SEATTLE
- No Back-up Lights..Where's the switch?? 95 A6 2wd
- Great service at Rector Motorcars in the SF Bay area.
- Buy it?
- do our cars have ...
- Can you remove water pump without camshaft holding tool?
- Seats cross post from 5K forum
- Fuel line leak?
- 1990 Audi 100 Auto Transmission Problem
- winter is here. '98 avant lost some coolant yesterday...
- How does the cam locking tool work?
- Brake Question
- A poll: what shops are getting in your area labor-wise to do a C4 front bearing? Just curious...
- 92 CS 100 Auto Transmission
- 92 CS 100 Lower control arm
- inner rear c.v. repair
- looking for a set of kick panels for 95 a6 black or light gray
- Can smell petrol in cabin!! Very annoying, what should I be looking at??
- Anyone have an ecru comfort driver's seat they wanna sell?
- Need help diagnosing some transmission noise and power steering noise
- Audi 100 1992 Xenon
- Possible air mass meter question
- L.A. REMINDER -- GTG @ The Stand tomorrow night, TUE Oct 25th,7:30pm
- Wiring diagram for stereo
- AZB Automatic Transmission -- no drain plug?
- New Edition of Bentley CD-ROM Available!
- Boston Area GTG is ON for tonight!!!
- Strut and Spring Replacement
- that's some miles !!!!
- Question about a coolant leak.
- 95 A6 Quattro wagon questions
- RE: Changing Brakes
- FOR SALE: 1992 Audi 100 CS Silver on Gray leather
- Anyone changed a front wheel bearing? I assume it's a press fit but I want to do it w/ CV boots.
- Anyone in Atlanta area with camshaft holding tool?
- EGR for 96 A6
- Hi guys, looking at getting a C4 soon..
- Anyone have a preference on PBR pads, Metalmaster or Ceramic?
- Does anyone know where the cruise control switch is located?
- Any Advice?
- Anyone have a power antenna? New or used...
- Picture of the 92 100cs Quattro Avant...Picture is up now........
- Europrice is Moving....
- Does anyone know what this part is. Please HELP!!!!
- what year did Audi switch to OBDII plugs
- Help--Electrical Problem--93-100CSQ
- Battery Drain 1993 100CSQ
- FILTER..... OIL FILTER
- Lowering Spring Questions...
- Transmission noise...
- Cold Start
- Help! S4 springs on 100CS
- Can anyone identify this sensor?...
- For Sale: Hardwired cell phone charger for center console.
- Keyless entry plans and questions.
- Shifting problems Help
- catalytic converters in ca
- Bose Amp update
- Anyone have clear corners from Pro Car Parts? Thoughts? I want to buy some off eBay.
- transmission problems .....
- PLEASE HELP> My cruise control is in/op...can anyone help???
- Wierd smell when heat is on!!?? NOT coolant(sweet)smell..what is it??? HELP!
- QUESTION - '94 Audi 100 CS Q - Help!
- So does a Blaufernugen bored trottle body really help on low end?
- Not easy question
- Where should the temp gauge needle be sitting under normal driving?? Can someone tell me please....
- Dash
- need quick answer...how do I take the drive belt off? thanks
- 92 100cs quattro: cruise is in/op?? Slight binding when wheels are all the way right/left....normal?
- Problem with a rebuild engine
- Check Light Comes on Once in A while
- How many Miles is too much?
- Interchangeable parts
- SPARK
- Brems Licht?
- VW Bumper interchange with Audi?
- water in passenger foot well. What it could be (plenum chamber is clean and no leaks from sunroot).
- question about dash symbols
- Is there room?
- I can't tell if its my transmission or if I have water damage
- 96 A6: Something broke on the back of the sunroof...
- wiper fluid reservoir
- What happned to my paint? Anyone ever seen this?
- Audi Gamma radio for sale!
- HELP AGAIN PLEASE.....92 100CS QUATTRO WAGON
- Anyone out there got the special front strut tool they want to rent me or sell cheap?
- 95 a6 driveline vibration
- HEADLIGHT REPLACMENT (WITH WASHERS)
- Well, I found out what happens when the ball joint pops out doing 50 on the highway....
- Covert help wanted
- In My Quest for Satisfaction
- Need Help, Here Are My Symptoms
- I have these two 195/65R15 Blizzaks on ebay
- Timing belt done....shop recommendation.....
- PLEASE HELP.....1992 100cs Quattro wagon head gasket.....
- amber corner tail light- avant
- OLD NEW OIL FILTER
- Boston Area GTG 10/24 update...
- 2.8 AAH Cam locking tool for sale
- 2.8 AAH Spares for sale
- Front strut
- Key fob
- Mystery "Hella" electrical box next to battery on '92
- recirc/fresh air flap motor
- Best Repair Manuals for 1993--100CS
- trunk lock problem....a real head shaker....advice requested.
- Please Help.....1992 Audi 100cs Q wagon
- Bentley manuals
- Improving Gas Mileage for 100S using ACETONE
- mounts????
- Have been searchin around-spare key for '93 100 CS +remote?Thanx guys/gals :)
- Platinum UrS4 leather interior up for grabs.
- 1992 Audi 100 won't start
- 100S 5-speed on ebay, in Texas: $25?
- Trip computer, analog clock, instrument panel
- How hot can a 2.8 get before there is damage?
- Head Gasket
- Windshield leak (1998 Wagon A6 12 V) !!!
- sold my audi, anyone looking for a Vag-com and laptop
- Rear defogger switch quesiton
- EGR
- Quick Suggestion!!! One of the Foreign Cars shop charge me around $500 for ATF and Thermostat
- Why dealers service really annoy me.
- Which OBD pins to jump for check engine? (97 wagon)
- 92 100 CS parting out - what should I nab?
- Fuel pump question?
- got my A6 detailed today,check it out....
- C4 A4 strut question -
- HI, I need to do my Thermostat/ATF filter change tomorrow..anyone got a procedure guides.many thanks
- When the Snow flies !!
- I need a battery for a 97A6avant. Dealer or are there other options?
- 93 100CS--Changing Rear Rotors and Pads
- 1992 Audi 100S 5-speed (I need a transmission) - same as V6 90's? Now with a picture
- 92 100 will not start PLEASE HELP!!!!!!!!
- I want a 92 S4 !!!!!
- timimg belt
- Top do not open on my 1995 Cabriolet
- WAAAY high oil pressure... what are the causes and fixes?
- Anybody ever change fuel pressure hose???
- electrical question
- 93 100CS V6 Tach Question
- Online ETKA
- timing belt/water pump replacement: should I use "Form-a-gusket"?
- 93 100s vs. 95-96 A6
