- Hard starting sometimes
- Power Steering Fluid
- Finally going to Arbitration with extended warranty claim
- How Smooth Should my AT Shift?
- REAR SPEAKERS
- Ignition Switch Recall 96 A6Q
- 1993 2.2l 100s
- 100S keyless entry ?
- All cleaned up and ready for a new week!
- Radio power ??
- Transmission
- Muhammad: I read your post on extended warranties and have a few questions...
- AUDI S4 4.2 AVANT!!!!!
- Any idea how to fix the front strut cartige nut?
- OK, I've got a deal of a lifetime today...
- what tool do I need to push in the piston when replacing rear brake pads? (97 Audi A6Q)
- New web site for So. CA. Audis/VWs
- My in dash thermometer light burned out, how to replace?
- I replaced my ignition switch tonight, now it returns to "run"
- '94 100s Infrequent Steering Noise at Startup
- Blank Key/Remote for 95 A6
- 1993 Audi 100 what are the front and rear turn sig. bulb numbers?
- 92 Audi 100 Advise on purchase/maintenance
- Getting screwed by dealer?
- Is this related or what? Let's do a meet not concerning the As ;-)) Lookie inside...
- Had Heat Yesterday!
- Ummm, okay, will this CD Changer work with my Delta head unit...
- Ok, here's more. I need the p/n on the little latch (holder) of the sunvisor on driver's side.
- How easy (hard) is it to swap a sunroof? I'd really like a glass one.
- 100CS Climate Control
- Here I go again. I need (desperately) the part number for the sunroof/dome light console. Please....
- Bose Amp Question .92 100 csq
- Anybody upgraded their CDROM Bentley manual for free? Pros/Cons?
- are shocks the answer ?
- Bentley CD A6 92-97 4 Sale
- doors
- What's new (or old) on chips for the 100/12V? Did a search, found little of interest. Thanks
- Where can i find a body kit for 1992 100cs??
- Where's the fill plug for the rear diff?
- Please Help!!!!
- I want to sell... I want to buy.... need your opinions..
- Radiator
- DRL's on A6
- Adding keyless entry to 98 A6
- stereo problem
- Bad Rack
- Muhammad, I bought the SPS A2s, concerns unfounded
- Im finally getting around to my 150k maintenance.. what am i forgetting to do!
- Suspension Issues...help requested
- Debadged my Audi a few minutes ago...
- Squeak Squeak Squeak
- Shaking Problem
- Oh man. What a beauty
- So I did my own transmission service this weekend...filter and fluid from HE double hocky sticks...
- Vague steering
- Had to replace my battery Friday
- srigs
- Did anyone do lower control arms lately>?? How much did you guys run into>?
- This guy screwed pretty bad on his auction's title ;-) Go 100 !!!!!!!!!!!!!!!!!!!
- Windshield washer fluid level warning switch-I could not find it
- Changing my tranny filter today. There is red fluid in it. Pisses me off if only Audi worked on it.
- Audi A6/100 freon charge?
- Audi 100 Quesion
- Question on the sunroof swithch / domelight console... urgent, please help!!!
- Part of my climate control LCD is out
- Behind the panels
- 100Q trans replacement cost?
- Timing Belt Special Tools on EBay. No, they aren't mine.
- "Bomb" for sale...
- NGK Bosch 4's Splitfire
- Raceware head studs (cont'd from prior post) - >>>
- Seattle Scott
- Dash lights going out one by one.
- **NYC Metro Area - Krispy Kreme Run Reminder 5/9**
- power window switch dead?
- No Heat Now!
- I need a winter car for VT snows.....I dont want to spend more than 4 or 5 thousand....
- 1995 A6 interior lights
- How many "pre-amp outputs" does an 94 100s need? any other specs I should know about?
- 1995 A6 Cabin filter?
- Head gasket PM
- Gotta love Brooklyn... my car got broken into last night
- Newbie - Autobahn Cruising Speed Pic
- Does anyone know a good place to find a repair manual for a 1992 100cs. thanx
- Front brake rotor upgrade?
- somebody sell 16" wheels and tires for $200.
- Trunk
- Remote Key batteries
- OK, I'm still kinda new here - what is uR, or ur or Ur or whatever? Thanks
- O2 censors
- Black S6 on the NJ/I80 ramp on Sat. night.
- Both coolant fans run all the time.
- I love german cars =)
- NE1 know where I can get inner taillamp lenses for wagon?
- Speedometer Bulb Burned out
- As an Official Member of the Lord of the Rings Jerk Off Club, I must report the Master Returns !!!
- just thinking out loud hmm.
- Anyone for 92-94 Audi 100 headlamps ... with housings?
- PHOENIX MEET~~~~~~~~ Saturday May 4th at 5:30pm~~~~~~~~~~~
- Got a query about front wheel camber on C4 chassis - too much........
- Reminder: Drive and BBQ for NJ/PA/DE folks on May 11th in the Bethlehem PA area (RSVP deadline 5/5)
- Front brakes are fixed..... $300 and my impressions of a new repair shop in my area.
- Oil Cooler Install?
- Head Removal and Coolant Pipe - 92 100s
- This may be a stupid question but...
- '92 100CS Front Drive Tranny
- Failed NOx emissions
- Kamakazie, what ever happened with the bad charger? Bad voltmeter?
- Second question: Possibly warped front rotors
- First of two questions: seepage in rear differential
- Nor-Cal Audi Club May Madness begins this weekend!
- Feeling lazy, didn't want to search. Any idea the difficulty of these repairs?
- Advice on shops needed in MD/DC area
- Brakes are squealing all the time, brake light on... how hard to change myself?
- Sluggish on start
- new (to me) 100E with clogged fuel line
- A/C down...needs fixed?????? (but how??)
- 16x7" Audi 5-spoke wheels
- Pre-oil change crank case "cleaning" ???
- TPS (throttle position sensor)
- Snapped a pic of a super-rare Merlin Purple A6 on Rt.80 in NJ. Interesting colour.
- Muhammad, anybody, know anything about the Yokohama A550 H
- Gamma Radio problems
- Ok...not a good day for the A6
- Anyone for an Audi GAMMA?
- Suspension suggestions
- Tires
- What do you think my car is worth???
- 1992 100CSQ Wagon - Anti lock light On
- A/C recharging problems... adapter???
- Lights in Window Switches
- What is this? What does it do? Hmmm....
- OK. I've got Mitchell On Demand open. TDY only. Any specific tech questions?
- Oh, an update on my A/C problem...
- How do I reset the rear brake piston on a 1999 A6 Quantro
- anyone know how much those thinkgs that hold the brake calipers on cost?
- Explosion in NYC today
- Squeeks & Rattles
- Shifting Problem....On the Manual Tranny
- New pics of my audi -- Dialup Beware!
- Any A6 owners with ignition switch problem please post complaint at NHTSA
- v6 transplant itno porsche 926
- I would like to Recommend a Audi specialist in NYC
- CD Player
- 91 100 window switches
- 93 100CS tail lights
- OK, did timing belt service, still overheats. Two questions.
- Ok...a bit OT, but close
- "Painless" stereo replacement question
- Timing belt and assoc work
- Dang you ARK and you too Muhammad !!!!!
- Anything you can do to keep rack from going bad?
- Outside temp backlight - Radio Shack? - LED? - Cat. No.?....>>
- Steering a bit clunky in my 97 A6
- Me again. "93 100CSQ Auto Transmission questions" I got it to work but...
- Does A6 delta Stereo have provision for CD Changer?
- Delta Stereo for sale on Ebay. 96 A6
- Baby is ready for her new timing belt, etc., etc., etc next week.
- radio reception
- A6 = Setting the Clock
- 100CS info 1992-1994
- O2 sensor question??
- Rear Fog Light
- Gotta love the new O2 sensor learning process... 7.5 mpg after 75 miles...
- Do these look familiar??
- My other cars
- Key Chime & headlight Buzzer not working
- alarm/door locks arent working?
- VAG tool
- Center console light
- Voltage... need more voltage
- anyone know what p/n 4a1 955 113c is?
- Anyone going to waterfest?
- OhioVW Spring Drags
- Crosspost -- Pics of my Audi
- timing belt & misl inquiry
- 9005 to 9004 Bulb conversion
- 1992 Airbag OBD Plug Location?
- Oooooh look at this beautiful S6
- K&N Filter: is it worth upgrading from "regular" to Cone?
- What does "Blaufergnugen" mean in English? Thanks
- Climate Control starting to have a mind of its own. (Long)
- Here it goes again..... Nicest 100S on EBay
- Pics of my new Stereo System and Changer.
- just detailed my car
- Pick up my car from a tranny service today.
- refrigerant use
- Pictures from Sunday's Audi meet in Kalamazoo Michigan
- Brake Pad Warning When Turning?
- Pic of my burned out Odometer Light! Can anyone help?
- To debadge or not?
- Replaced rear brakes on 94 Audi 100cs ?>>
- Audi Delta CC Stereo for 96 A6 on Ebay.
- CD Changer on EBAY for 1996 A6
- Hey all that remember me ;)
- Head gasket - '92 100S
- Warranty Question
- Can I swap out 16" A4 (98-99yr) rims onto my 95 A6 Quattro?
- Questions for Kevin(100csq)
- 92 100 Temperature
- Rear Brake Light Out- need instructs on replacing
- Got the Motorola phone, got the service, need original Audi antenna; any leftover somewhere?
- timing belt
- Compressor on, system fully charged... but blowing hot...
- Has anyone here hooked up third part cell to 95 A6 or similiar
- New O2 sensors and some vacuum leaks fixed = new car!
- Who uses techron???
- C4 Styling GP (Web Page)
- AUDI '95 Key Coding (long)
- Is there a way to clean the Headlamp ?
- Accelerator problems on Audi 100
- Clunking pinpointed!
- 93 100CSQ Auto Transmission questions.
- Not Burning Oil
- Installing Brake Light on 95 A6
- Possible to enable/add daytime running lights?
- Spark Plug Anti-Seize
- 1993 CS Automatic
- Shucks. My compressor isn't compressing. Or something like that...
- headlight upgrades ?
- Voltmeter recommendations for 93 100CSQ....How to... and what...>>
- NE1 know anything about EGR block off kit?
- Will '94 S4 5 spokes fit '95 my A6q?
- Timing Belt
- Bose 6 x 9 Rear Deck Speakers and Amp for Sale
- Who likes anti-seize on their spark plugs? Who figures good Bosch or NGK plugs don't need it?
- Somebody do me a favor? When you get home, car warm, turn on everything at idle. Voltage?
- Delta SS Stereo wiring diagram / stereo installation guide.
- Audi Part 3272 Brake Piston Reset tool
- Shudder at 80 85 cleans up around 90
- Opinions: Thinking about doing my alternator along with the timing belt "Stuff".
- 91' audi 100, problems!
- Got car back from steering wheel being off issue............
- I need a gas-filled strut for armrest (411-881-791), $90@dealer, oops!
- Tire recommendations for A6QW?
- Tranny service $? 100csq
- Where oh where is Style12v?
- 3rd brake light corrosion = car won't go!
- Sound of a 94 100s Engine
- Comments, please: Was this a good deal?
- CD Changer 97A6Q Wagon
- lifter noise - GONE !
- Part Number Needed
- How do you bypass the brake pad warning light?
- bose radio
- Oxygen sensors
- Just got 95A6Qa back from new wheel bearing fix, but now......
- gamma radio
- How are the rear deck badges ("100CS," 4 rings, "quattro") attached?
- How to tell if timing belt has been replaced?
