PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Gas smell in cab at 20 below
  2. Anyone know where I can get used wheel speed sensors?
  3. 1995 A6 2.0L (ABK ENGINE) Setting timing
  4. SnoKing..did you ever get your heater motor working ?? You were looking for a fuse??
  5. Anyone see "Making of Victory by Design", the show on Speed tonight (its still on)?
  6. audi glass
  7. 92 AUDI 100 CS PARTS
  8. Will the car overheat if the blower motor fan doesn't work?
  9. Need help asap!! My drivers side power seat is stuck all the way forward...
  10. how to dump the trouble codes again
  11. white-face-gauge update...
  12. 97 A6 Trans Shifting Question...
  13. shifting funny from 2nd to 3rd
  14. '97 A6's
  15. Sticky gas pedal update- (105 on 88)
  16. No heat. Cold gages.
  17. Oil Leak at engine oil cooler SOLVED!!!!!! Thanks Guys!!
  18. Can You help me locate aux fuse #28?
  19. Engine prices??
  20. new clutch kit should arrive this wednesday :-)
  21. reset remote audi 100cs quattro
  22. To buy or to Wait...that is the question??
  23. bumber cover fits?
  24. how to test my alarm system..??
  25. If I have some sort of battery drain, how do I find that or fix it?...
  26. I know its cold when I go to open the hatch for the ski bad pouch and it shatters. Anyone else
  27. Upgrades to a 100 S.
  28. Replacing the brake fluid reservoir 1992 100 S.
  29. Exhaust Leak?
  30. If its not one thing, its two...battery
  31. Hey .....tridolf1......are you still around???
  32. Need some help with an annoying squeak problem...
  33. UM...is this a bad sign?....
  34. CT/NY Audi Group Get Together & Dyno Day Update - Dyno Scorecard & Car Wash
  35. odor??? just mildew or heater core?
  36. Opinion on best price O2 sensor for A6
  37. HELP Please..No Headlamps '95 A6
  38. advice needed - tailgate strut replacement
  39. Engine Coolant Temperature Sensor
  40. Trying to get organized...
  41. 1993 100 CS check engine light
  42. I spoke to chris from force5auto(.com)
  43. Chrome/Brushed Mirrors...
  44. adding a trip computer to my 92 100
  45. Re: These pedals will also fit any 92-96 100/A6...
  46. Accelerator cable replacement- lube? hints?>>
  47. does anyone know if the prestige APS25KB is the same thing as the prestige APS25?...
  48. snowking, i just got off the phone with my boss, he said he sent it out...but YIKES!!!!
  49. CT/NY Audi Group Get Together & Dyno Day Update#5 - This Saturday 1/24...
  50. High Milage -- Club / what to look out for?
  51. What other Audis have you owned?
  52. Brought my car for a NY Inspection and these morons put quattro to the dyno.
  53. 97A6Q Malfunction Indicator Light = Replace Temperature Sensor?
  54. Ipod and Gamma (xpost)
  55. would this remote key idea work?
  56. Green, you send me that grille? How much was shipping?
  57. We gotta spice it up around here...
  58. Half of my instrument cluster is out, does anyone have the Part#for 2w bulbs? or website? TIA
  59. O2 sensor problem
  60. Programming door lock key turns
  61. promlem with climate buttons...
  62. What kind of engine should i get??
  63. anyone know where I can find a short shift kit for my 93 100csq? TIA!!!!
  64. Odd Electrical Problems Appear at Once
  65. Electric Mirrors stopped working
  66. just a bought a 1993 100CS Quattro (auto)
  67. Gosh Dang EGR! Code 2411 is unstoppable!
  68. Paging 4N 4RING
  69. 1997 A6 headlamp (bulb only) replacement???
  70. Dash lights...and no, not a howto on replacing them...
  71. Thought I could get by but this is killing me!
  72. Heater not so hot
  73. Please help me identify the V6 TPS Pin's
  74. instrumentcluster
  75. Is it uncommon for the cooling fan relay to go dead when not used for 4 mo.?
  76. Topped 105 MPH today- gas pedal stuck..>>
  77. 94 100 auto trans into 97 A6?
  78. snowking, i have the grille for you if youd like it....
  79. Audi A6 Transmission
  80. talking about Subaru: just passed 95 Legacy, which made 1.5 turn in the snow (NYC)
  81. Air Fuel Guage
  82. Floor mats!
  83. Transmission in limp mode and stereo doesn't work
  84. The ever overheating wagon... Ideas?
  85. Does anyone know what I should give for a set of these 15" wheels...
  86. 95A6Q Interior lights question.
  87. Buying advice needed!!! Thanks.
  88. so i decided to get the transmission some genuine audi fluid
  89. Let's Compromise...(snowking look inside!)
  90. Is the Mother of Pearl Effect touchup paint worth it?
  91. Rear headrests for my wagon? WHere to buy?
  92. The Stealer is funny, guess what they asked me?...
  93. S4master1 did you get my email? I think I may have sent it to the wrong person.
  94. Reminder: EPQC Events THIS weekend (skiing and karting)!!!
  95. Wanted: 15" / 7" oem 10 spoke rim ; 93 100csq wagon
  96. New Year. New GTG. New Location - NE Ohio GTG 01/17/2004
  97. Battery Replacement...DIY?
  98. used A6 valve cover
  99. Anyone have a part# for the airbag warning bulb?
  100. *feeler* Anybody got a 100CS badge for sale?
  101. Forgot to post how much faster my car is...
  102. gear shifter indicator (console) bulb replacement
  103. Brake Fluid:
  104. Sticky gas pedal only in frigid weather.....>>
  105. This is what I found on the quattro....
  106. $700 for an Upper Oil Pan leak?
  107. Battery / Alternator Problem - Opinions?
  108. Windscreen crack - repair?
  109. Engine Code Question AFC - AHA
  110. Driver side mirror
  111. Circuit Diagram for Bulb Failure warning system?
  112. Audi 100/A6 auto tranny fluid level
  113. POLL: Does your 92 100 have a Trip Computer...?
  114. Final Question
  115. In 2 flashing when car is turned on !!
  116. Got Accident Estimate: Seems Too Low
  117. need help!
  118. Is it true that Torsen works only till 25mph and then my car becomes a 2WD???
  119. 92 100s mineral oil leak
  120. What an evening....worked on the sunroof and managed to drain the battery.
  121. Need some help with sunroof problem
  122. coolant flow question
  123. Help, Quick thermostat question
  124. need advice
  125. Well- the time has come!- Selling my A6
  126. Uh-Oh, Blower Fan Noisy...
  127. My oil pressure warning is coming on intermitently
  128. Where can I get A/C Compressor Clutch 95 A6
  129. 95A6 Mirror glass delaminated-how to replace
  130. Dipped headlight problem Audi A6 2.4 V6
  131. A6-97-Quattro: WiperBlades and Blinkers Dead
  132. Cold Weather Battery Problems
  133. Since it's a cold winter night and you're not working on your cars anyway,
  134. Sunroof: How do you get it back in sync?
  135. Green light on in dash and no idea what it stands for !!
  136. Driver side mirror
  137. Does anyone have a spare grille and emblem, or just the emblem I can have/buy?
  138. Wiring Diagram - sunroof
  139. It's been a little chilly here, check out the pics...
  140. Sunroof Woes
  141. 92 CS 100 Q Black Audi for sale
  142. Junkyard in fredericksburg VA (off topic)
  143. Cold air leak in driver footwell (97A6QA)
  144. Deciding to keep the car..... Need some advice and help on the following:
  145. it's so slow here lately... what's the deal?
  146. Quick question about oil cooler O-ring TIA
  147. Ok...electrical gremlins are back. I need some advice
  148. cold and short drive to work
  149. 1998 A6 Power Steering Leak
  150. What should it typically cost in the NY area to have CV joints and boots replaced on the front axle?
  151. Going to buy struts (or "inserts"?) on my own and have shop install... any recomendations?
  152. Passenger Side Door Lock Problem
  153. Don't forget to add procedures to this post -- link:
  154. Anyone have Vogtland springs?
  155. Opinion: To sell "as is" or fix and keep? (revised,my fat fingers hit send by accident)
  156. 94 100 Bose driver side door speaker cuts out?
  157. Recommended Repair Manual?
  158. CT/NY Audi Group Winter Meet & Dyno Day - UPDATES #3
  159. anyone know the injector size for the 12 valve v6???
  160. engine no. on 1996 A6
  161. Cruise control replacement A6 1996
  162. HELP MORE ELECTRICAL PROBLEMS
  163. 91 100 Quattro alt. belt problem - need help
  164. Has anyone with a Delta Bose
  165. fans will not turn on when I turn on the A/C
  166. Taking the A6 up to Mont Tremblant for the week...
  167. vibration inside the car on idle
  168. Need 96 A6Q Wagon Wiring Diagram.....Help
  169. 96 A6Q Wagon floor mats and OEM CD player
  170. Newstand Audi magazines.....
  171. Free hood...
  172. Audi 100/A6 (C4 92-97) FAQ Digest
  173. Guys, we need to organize FAQ for our cars. We have same questions over again.
  174. WTB: Wheels from a '97 A6
  175. FS: 95.5 A6/S6 Phone, trunk piece and bracket
  176. Billowing blue smoke! Oh great....
  177. block heater / water circulator anyone ever install?
  178. 92 100s auto trans, when cold shifting problems
  179. audi 100 93quattro shifting problem
  180. Audi 90 / Audi 100CS Interchangeable Power Steering?
  181. Question for my buddy who just picked up an A6.....Transmission question. TIA!
  182. 93 100 wagon oil leak
  183. wagon rear wiper problem
  184. Pagid pads and bleeding brakes......
  185. 1997 A6 has no spark
  186. fans wont work at all, even when I turn the A/C on.
  187. there are two clutch master cylinder for chasis -038000 or 038001-, how do I know which is mine? TIA
  188. Anybody know of a good alignment shop in Phoenix area?
  189. New ECU needed
  190. ISV???
  191. Clutch got stuck to the floor...
  192. Okay... I need new brake bads that don't give me brake dust, and that look cool (ie Colour) and...
  193. O2 sensors, manual on CD, and gaskets...oh my
  194. Hit a bump at 35MPH -- now my car drives with the steering off by 15 Degrees
  195. radiator fans not working/ H2O running high/ no heat from heater
  196. When looking for remotes- do the FCC#'s have to be exact match?? How close?{end}
  197. best source for lower control arms?
  198. does the 96A6 remote ONLY lock/unlock doors- no alarm, no trunk??
  199. Is the perforation corrosion warrenty in writing?? where?
  200. Aux Panel
  201. OBD-Interface in AUDI 100 from 1992?
  202. added a little too much oil to my car on my last oil change...
  203. Brake pads
  204. Need gear indicator in dash
  205. Please send pic of a 90cs fuse box, were missing a few relays.
  206. Radiator Fan relay problems
  207. static electricity
  208. When stepping on the gas pedal, it takes almost a full second...
  209. Electrical drain.
  210. Does anyone know of a place I can send my remote entry to have the switches replaced...
  211. Another happy A6 with Silverstars...
  212. Scratch & Dent Clearance from Hartmann Wheels
  213. Some tips for front brake pad replacements...
  214. Why was the bolt on my oil pan nearly impossible to get out (so tight)...
  215. defroster '93 100cs
  216. In case any of you guys are faced with a stripped bolt, here is a clever way to fix it...
  217. head gasket failure
  218. is this the corretc forum for a 1989 100S?
  219. Does anyone know if this can be changed from green to red?
  220. You guys like my new hat... :-)
  221. Broken hood release cable. Procedure? I searched but didn't find anything.
  222. 1997 a6 will not start
  223. I was told to only remove the filter to get the oil out, theres a nut!?! (100csq) OMG!
  224. 100/C4 91
  225. TCM questions.
  226. Audi 100 S 2.8 Heads??
  227. hey 1atlantis... did the key that came on the remote have to change out or can i have that key cut
  228. Are these VW wheels, Audi or aftermarket
  229. Question... the Airbag light in my '91 100 is on....
  230. 1991 100 Starts but dies, worse when weather is colder.
  231. gas pedal cover; not a monster problem
  232. changed my oil, only about 2 quarts came out after removing the filter, I have it up on ramps...
  233. No heat from floor vents
  234. I finished my headlight project...
  235. 97A6QW, when I let go of the brake pedal I hear a clunking noise.The pads/rotors are new.What gives?
  236. Excellent Job
  237. Electrical problem and engine lite problem
  238. Noisy lifters = bad head check valves and possibly oil non-return valves here are the part #s
  239. Need new water hoses
  240. Secondary Air Injection Combination Valves???
  241. Remote Entry is working intermittently 2 different remotes...
  242. I love my 95 ;)
  243. A6 Power Steering Leak
  244. Removing Wipers
  245. Now that my car is "fixed", old issues resurface... fresh air blower and more...
  246. exterior temperature display doesn't light
  247. Rear Ended - Need right rear tailights
  248. Windshield washer resovior cap broken!!
  249. Finally finished my heater core job. Took 4 hours to replace three light bulbs.
  250. Battery draining problem? - 92 100CS
