- say hello to my little friend !!!!!
- How do you know if the head gasket is leaking oil or if it is the valley pan gasket?
- "Clutch drop to the floor and stick" -Update-
- Transmission fluid line couplings
- Zdrajca Polski & icos6, have the pics of the p/s rack(fits V8Q, 100, S4Q, A6 w/8mm)
- What are the thick cables on the transmission?
- Is the oil pressure relief value under the value cover the same part/part number on the A6 and 100?
- I continue to sit and stare...
- so after ~4 weeks and more money invested than the car would be likely to sell for...
- Request for part numbers for fuel lines (includes some old recall info)
- Heres a better picture.... I believe its the subframe like skolnick said...
- Any good service manual?
- Tire replacement question
- Rear Shocks/Struts - what are they supposed to include
- 1997 A6 wagon bose head unit with CD changer controls
- still looking...
- I'm smelling gas when I first start up the car??? It seems to be...
- First tank. Got 315 miles to the warning light. 70% highway.
- Auto-2-Manual swap..... Day 4
- Damn, these would look sweet on an Avant...
- Anyone know what size bolt goes here?
- Need a new front bumper cover for an A6 Avant 1996 - any good sources? salvage?
- Good places to get a lock cylinder cheap?
- Anyone replaced the oil check valves?
- Are there other things to change when you change the Valley Pan Gasket?
- How do you change the serpentine belt?
- transmission stuck in "fail safe" - suggestions
- I got a problem with the back-up and fog lights, they're both out, mysteriously.
- Will a 1993 hood fit a 1994 100?
- Can someone point me to a site that describes my '97q system? I'm interested in how it works.
- Still having ingnition problems.....
- follow up to the 92 100S winter project car i picked up
- Misc 100S Items for sale
- Hub Shark - Anyone have one for sale or rent near Chicago?
- Filter....... Cabin Filter
- Coolant Leak
- Replaced ECT F76 and ECT G62 temp sensors...better gas mileage
- How do you change a wheel bearing?
- Groan in front end.
- Now to the trouble pics.
- Took photos of the car, with the new wheels.
- What happens if you mix Pentosin 7.1 and 11s?
- Strut Cap removal
- Anyone have a lower passenger front grille? Or a rear drivers tailgate lens?
- Anyone have a PS pump for 95 A6 or direct me to a good source for one?
- Cleaned EGR inlet 2nd time(per faq) & still getting P0401 DTC. Any ideas why it still happening?
- Are the C4s suppose to use the pink coolant or green coolant?
- Houston, We have a problem now. Tell me what you think.
- 2/11/06 - CT/NY Audi Group GTG & Dyno Day - XX Tuning - E. Hartford, CT - 4 dyno spots left!
- Power problem 2.5 TDI AEL
- Auto-2-Manual Swap.... Day 3
- Houston, we have an A6. Shopping/Fix list begins.
- Remote Key question
- Can somebody with a manual 100 clarify something for me?
- coolant
- strange auto tranny problem... (1993 100CSQ sedan)
- Since when do cars have medical record privacy rights??!!
- Looking for opinions...all are welcome
- Auto-2-Manual Swap... Day 2
- swapping seats in a 100 series
- What do you guys think of bras?
- AC problems need advise
- Do 100's with 5spd's have dual mass flywheels? I ordered clutch kit and clutch is solid hub.
- Since AZ100 likes his Koni struts so much....
- new winter project, just got it to the shop
- Autocheck indicates no oil pressure above 1500 RPM but pressure and wire is OK....
- 2 Questions in one - Side Emblem and Dash Lights
- 97 A6 Quattro Transmission Problem.......
- Here's a stupid question for the Avant people here.
- sorry for the noob question but did c4 a6 ever come in manual?
- I need an AC compressor
- radio reception sux .... where is the antenna
- Re: Anyone parting out a A6, 100 or 90. Need a Power Out Stage.
- How do I wire in engine?
- 2/11/06 - CT/NY Audi Group Dyno Day - XX Tuning - E. Hartford, CT - 6 dyno spots left!
- Here's a strange one...one of my clear corners got sucked out by strong winds today while...
- Thinking about a 97 A6
- Just a little Poll: Anyone here have the 3rd row seat and not the seatbelts?
- Fuel pump
- Methods to determine if control arms / suspension is bad??
- Anyone have experience putting B5 wheels on a C4?
- Valve Timing (TDI AEL/AAT)
- Searching for 92 up 100
- Queston on timing belt I haven't seen elsewhere
- We'll I won the auction
- Ignition Problems Continued again......
- cold air intake
- I think a few of us could use this about now!
- WTB Gamma Radio
- Too far, too much, too nice, crap
- Need some parts, anyone have inner taillights for sale?
- Anyone can help me diagnose the problem of the transmisssion system of my car????
- fog lights
- Would you be afraid of high miles?
- Where is the 2nd bleeder screw on the cooling system?
- nice project car on ebay.. going cheap in MA
- Tapping noise when hot ('96 A6Q 122 kmi).
- 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XX Tuning - E. Hartford, CT
- A6 avant gas mileage...
- Easy way to turn off active check?
- Lock Cylinder Problem again
- [SoCal Reminder] Saturday January 21st -- SCC Audi's Pines to Palms Drive/Poker Run
- I'm getting closer, I can taste it. Looking for an early A6 Wagon but possibly a late 100CS Wagon.
- Wife says the speedo is acting up in the 94 100S.......
- 1996 AUDI BURNING OIL
- transmission shift lock
- CEL @ 36-3800 RPM
- clear corners
- Radio Replacement
- ECT Madness.....
- Wanted: 1992 Audi 100 Belly Pan
- Well, it may be the end of my clutch, or at least part of it...
- Power steering fluid leaks on Rack & Pinion
- Any of you have the Import Vision euro lights on your cars installed, help.
- Finally got the remote working on my 96 A6
- Another 95 A6 Wagon question
- Steering Column Lock
- Will a grille from a 92 100 fit a 96 A6?
- Photos's from 1/14 CT/NY Audi Group Gathering at EPL in Stratford, CT (BWW)
- Any good references on the differences between the various 100/A6 years.
- Strange start probleme.
- Missing EGR FAQ...anyone have a copy?
- whats your rpm at when going 55?
- Can I fit a 17x9 wheel on a 92 100CS at stock height?
- Anyone want to guess what this is and where it's going?
- 95 A6 wagon questions
- Thanks for the feedback on tranny
- 1996 Audi A6 Quattro Is Burning OIL...
- Coolant disappears from tank as it cools down.......
- CV-Joint
- [SoCal] Saturday January 21st -- SCC Audi's Pines to Palms Drive/Poker Run
- Anyone coming down for 12 hours of Sebring?
- 1993 100cs Timingbelt broke nOw starter won't CrAnk
- Source for caliper bolts
- FEELER: Would anyone be interested in a center vent with LED's in the knobs?
- What's a guy gotta do to get his ignition lock to match his door locks?
- Transmission Level Dipstick
- "Normal auto transmission operation" Feedback please.
- Need bumper grill and side grilles for '96 A6. Force5 asked $90 for middle (new is $110). Thanks
- CD Changer fading in and out
- Need some opinions on a possible purchase.....
- Auto-2-Manual swap (DAY 1)
- Looking owner needing advice from the A6 Group
- 95 A6 Transmission Gone. Options
- p/s rack-pinion(fits V8Q, 100, S4Q, A6 w/8mm dia.) for sale...let me know if anybody's interested?
- Is VAG COM Release 409.1 or 311.2 and a 'dumb' interface enough for a '97 C4?
- Recommended Audi oils
- low volume to the front left speaker 100 w/ bose sound
- PARTS NEEDED!! I NEED A DRIVERS SIDE HEAD LIGHT FOR A 1997 A6Q
- lookin for a reliable mechanic in seattle area
- Where to buy new coolant tank, plenty out there but I want
- Well, my caliper bolt is officially striped.I'm gonna try 2 more things before I take it to a shop
- How can I get my A6 Radio out of SAFE Mode without the code?
- 1/14/06 - CT/NY Audi Group Winter Gathering - EPL, Stratford, CT (Updated info - Pizza!)
- Frozen rear brakes? Really hard to tell...but I'm sure it's easier to fix now
- 95 A6 Quattro Fuel Filter Change HELP!!! HELP!!! HELP!!!
- New to Audis... and transmission issues off the bat :-(
- What's it worth? Anyone interested?
- Cruise Control and interior temp
- anybody know the bolt size that mounts the throttle body...
- How do I fix 2 broken cigarette lighters?
- Anyone want a digital clock and voltage gauge for their C4?
- Transmission Problem (01F Auto, 98A6 wagon), third installment!
- Does anybody know if the length of a manual and automatic quattro tranny is different?
- Please review my cars service history - let me know what I should look for.
- Selling my 92 Audi 100 S with $3000 worth of upgrades in it ......has to go !!!!
- I just want to confirm... The 100 and the A6 Non Qs' have differant springs correct?
- Where on the rear diff can I locate the code? Trying to find out if I have AET, CKL, or AAT rear dif
- Rubbing on front 2 wheels, any suggestions???
- Anyone in Chicago? Any advice for good indy Audi mechanic?
- Minor Petrol Vapors now Substantial Leak!!!! HELP!
- Struts 101: An Easy How-To W/ Pics Inside
- Looking for suggestions on getting a stripped caliper bolt off.
- more research posble purch 99 avant also question for all A6ers
- Anyone else having trouble getting Audi paint? I've had touch-up ordered for 3 months now.
- Anyone know the stock ride height difference between the fwd and Quattro A6/100s? I believe...
- Deer ran into me... need parts!
- SOOO, the body shop work order is in... NOT totalled. any guesses on the preliminary bill?
- Timing Belt change
- 1997 A6 Avant electrical gremlins..
- 93 100 CS Heater Fan Problem--HELP Im COLD
- Smoked Corner lights?
- Lets see some pictures of your cars!
- Who has chrome mirror caps?
- Rusted out Fuel Lines
- Photochopped pic of my Avant, what do you think?
- VAG-COM arrived today, here's what I got on my tranny.
- Needed: Coolant Tank 1993 100Q CS
- Good mechanic in Charlotte, NC?
- Latest findings with my auto tranny.
- Transmission TCU location and connector?
- Radio
- My plan for the 100 Avant
- wating for car to go get switch and pondering next vehicle
- Is this ignition switch problem? ....
- Anybody got pics of really nice 100 Avants? Preferably Lago Blue ones.
- Wish I would have read islingtonaudi's post earlier...
- so anybody can sell me a steering fluind tank (in usable shape)?
- Transmission Problem, How to Test Solenoids
- Paper Bentley manual
- tcu for 92 Quattro
- Did Audi Make a V-8 Manual Transmission A6 from years 92-96...
- Can somebody with a Bentley manual please looks something up for me?
- My 100 came with the seatbelts for the flip up third seat, but no seat. Worth getting? Fits Adults?
- Check Engine light is ON
- I should take the time a search lazy ass I am
- front end shake!
- ECU fault code plug
- what a year this is going to be... (posting from my PDA) I need some suspension help
- Who makes the anti-corrosion antifreeze additive, Pentosin?
- Comparing and contrasting Audis
- Looking for OEM Black Floormats..anyone have any for sale?
- topic repost, please help this time :)
- Can't get rid of the brake light warning on the auto-check display...
- Cleaning my room - a random 97 A6 water pump!
- Need to buy a steering fluid tank for 96 A6qw. Any idea, who sells it?
- How do you know when your wheel bearing is going out?
- Transmission Problem, Sequel (98 A6)
- Was experimenting with my 100 today, auto tranny questions...
- Can any of you offer sunroof advice? TIA
- 2006
- a BAD day in A6dom - subtitled - "to total... or NOT to total". and a happy new year to all.
- VAG-COM communication issues
- Now to get serious about looking for avant
- Pic of my 100 Avant
- Coolant is boiling and coming out of tank....
- well...this is my latest problem..i need a little help.
- Somebody up North needs to get this.....
- Can somene help me to locate the coolant temperature sensor? Audi 100 2.0E C4 1993
- Looking for some honest opinions about these wheels.
- does anyone have a good picture of non-Q front suspension?
- Many thanks to Audijim113
- my new baby...
- Enjoy the movies!
- 1/14/06 - CT/NY Audi Group Winter Gathering - EPL, Stratford, CT (Updated info)
- Clicking
- Heated Seat Conversion?
- How to change air filter? C4 2.0E 1993
- Auto to Maunal conversion... any info on this for 100's?
- Anyone have a tie-rod "freeze" on them? Can't align my car unless I can adjust the spanner so...
- Central lock vacuum troubleshooting...
- Sensor questions, related experiences...?
- radio code decoders on ebay
- CEL turns on but scan tool finds no trouble codes...???
- Fluctuation in Gas Mileage
- Oxygen sensor refresher needed...tried searching but still a tad confused
- What is the top speed.......?
- 100 (non-Q) axles... which one is which?
