- Bilstein question...
- Phatnoise/Phatbox conversion using the existing 8-pin changer cable
- Two turns with the key to open driver side door
- A serious poll, what type of Audi guy are you?
- Auto trans shift up problem
- Bose System.
- Save The Date. AWNE Boston Area GTG. Thursday, April 27th - Waltham, MA.
- Pre-wired for a CD Changer? Where?? And where to locate 6-disc
- WTB
- Power steering fluid looked like used motor oil. Think it was time for a change?
- How hard is it to pull out the heater box.....
- New Audi Racing Pedals with Special Intro Pricing
- What springs can I use to lower a 95 a6 the greatest amount.
- Guts of a 96 A6 Servotronic steering rack
- Anyone live near a salvage yard that has A6's?
- suspension
- BOSE sound system...
- SCC Audi's March events -- Angeles Crest Drive / The Stand GTG / Buttonwillow track event
- hey Bmthorn
- 5 sp transmission
- 1995 A6 Instrument Cluster question...
- Headlight washers broken..anybody got a pair?
- Bentley on e-bay ...cheap!!!
- RE: Can the T-stat be replaced without removing the Timing Belt? Thermostat cover doesn't come off
- Preemptive front end maintenance?
- How to replace my HU and amplified speakers
- parts needed, '97 A6 avant
- side mirrors
- Doh, Can anyone help me diagnose this?
- 93 Audi 100, Wireing harness for the radio?
- headlights
- Hunting down the burning smell - found some leaks - need some help.
- finnaly!!!!!!!!
- won't start
- Question about front strut boots
- It was nice out yesterday... So here are some teaser pics for my old 100/A6 buddies...
- Still have this C4 around if anybody needs anything....
- remote start Audi 100sc
- Well, my fuel gauge problem is moot as I got "T-Boned" today in my 96 sedan. Upgrade to C5 or not?
- Master Key and Trunk Struts
- Free tech session at speedware...no need to be a member.
- 95 S6 trouble code found...2111...big deal?
- 94 100cs quatro
- 1993 audi 100 cs Avant
- I smell a Scam
- Rotors Size
- Why you should clean your lenses
- I think my driver side cat has a problem.....
- Are the halfshafts/CVs the same on 94 100 FWD and 92 100 FWD?
- Corner lights
- 96 A6Q fuel gauge pins to 0 and light comes on intermittently.
- If it were in good shape, would you buy it?
- 94 100cs quatro
- Finally got to change the oil. Is it normal
- Crankshaft center bolt -- how to get it off
- Excess voltage?
- S6 for sale in my area...how bad are those miles?
- 95 S6 HR Springs work on my 95 A6 ?
- REMINDER.............SERVICE
- Looking for ISV that still works. Mine has seemed to go bad on me.
- selling the c4
- thermostat replacement - '97 A6 Quattro Sedan
- Easy way to add MP3 to Gamma/Bose
- When you change the valley pan gasket, do both the cover and block have to be
- looking at 97 A6 Avant...few ?'s
- How hard to replace O2 sensors.....
- Some good pics for Valley pan/Egr/Intake job. 97a6Quattro
- Just bought a 97 Avant. Part it or fix?
- Anyone have some burlwood trim laying around??
- Which car wold you buy for reliability? 95-97 A6q or 92-95 S4/S6?
- Crankshaft sprocket turned when using puller to get it off
- oil
- Paint job is completed, now the parking lot paranoia kicks in. MORE PICS
- Tranny dipstick
- Hey guys- need opinions on these. I don't think they'll fit but check 'em out:
- anyone parting out a '92 100 or similar
- Audi 100 wiring fault.
- 1991 Audi 100 - over heating indicator
- major PS leak....don't know yet where is coming from...but it's nasty
- I cleaned my ISV today as per instuctions posted here, idle still dips low...(more)
- Sony CD changer installation questions
- About to purchase a 93 Audi 100
- Trying to decide whether to change head gaskets myself or let a shop do it for $900
- AZ100, I sent you an email about the grill stuff. Let me know what's up.
- took the lugs of my 2 of my wheels to check the slow leak problem....
- 225/55 R16's mounted!!!
- Crankcase vent hose
- Headlight is out....
- where is the fill plug for the center transfer case?
- Does anyone happen to have a lay-man's diagram of Connecter Station 3 behind the center console?
- Looking for a 16" 5 spoke wheel for my A6. Does anyone have one or know where I can find one?
- Coolant leak
- What socket do the head bolts take?
- Squeeking and rising front strut mount - whats the cause?
- motodyne charger
- selling my 95 A6 quattro....interested? $2800 firm
- IR system not working, tried to reprogram from steps in FAQ no luck
- Need Help Installing Trunk Strut Replacements
- Installing Door Molding
- Who has the highest mileage on a FWD tranny????
- 1993 100CS
- can anyone help
- Brake bleeding
- NO compression all cylinders
- FS: sylvania silverstar 9004s
- A few problems with my 95 A6 2.8L (lighting, vibration)
- Anybody had their head gaskets leak oil? I have oil leaking down from either the driver's
- Question about Bose system and where the common ground comes from..
- How long does a clutch generally last? Mine has 120k on it.
- Anybody installed an auto compass, RED? BMW mirror has red compass and rain sensor=expensive.
- I need the headlight washer and a GREEN molding under the right headlight. Thanks
- How to Repalce Throttle Position Sensor? I can't get it out!
- Is a leaking rear main seal a common problem on a 94 100? Any idea how much to replace on
- More bodywork progress.
- Anyone ever used oil dye to find an oil leak? Can you just use a black light bulb (like a lamp bulb
- tranny
- aftermarket radio fix...
- Anybody know of a good source for boge turbo gas shocks?
- FYI: Great deal on Bentley Service Repair Manual (2 of 3 hardcopy volumes) on eBay...
- Very low on fluid....or the tranny is toast....:(
- 1996 A6 quattro missing & idling rough
- Where is a good place to buy power steering fluid?
- foamy oil in breather tube. Is this normal
- cleaning/removal of seat switches?
- Anybody got a C4 A6/S6 pass-side HL washer jet & cover for sale? Pref black.
- Need an auto transmission. 95 A6 FWD
- Re: A6Gary, re:passanger seat reclines but wont come up. Car has power seats.
- Smoke, you still got that car? I'm looking for that front hub (or entire strut assembly). Thanks!
- Needed: Passenger Side Mirror and Housing for Silver 97 A6
- 12v coolant leak....
- came across several brand new oem projector 100/A6 headlights.
- The Avant is down again... Parked it at work today, then a minute later, there was lots of steam...
- NE1 Know how to adjust the trunk fit?
- Anyone know how many degrees equals one full turn of the toe alignment adjuster?
- Doing rear shocks tomorrow - need some advice
- How long can you go before changing the brakes once the light comes on?
- RE: 92 100, passenger side seat reclines back but want come up.?
- My tax refund well spent...
- Torn Steering Rack Boot!!!! What should I do????
- headlight wiring problems....
- Passenger Door Latch
- looking for a catback with dual DTM tips .... where to get online
- X-post: Aftermarket coolant tanks
- Does anyone have a digital copy of this body shop reference?
- Does anyone have a pic or diagram of where the high pressure
- Looking to buy headlight washer system for my A6 95' (+)
- Just in case you werent sure what a bad CV/Boot looked like.
- What's my Avant worth?
- Engine lost power on freeway, CPS?
- so now trunk won't open....&^&^#%*^ !!!! what to do ?
- Also....Leather care?
- 97 a6q failed emmisions???
- For those of you in CT...
- New 17 RS wheels for my A6 C4...
- Hello A6 brothers......looking at a 98 A6 for my wife, couple of questions.......
- Is the hood for a 92-94 100CS the same as the 95-98 A6?
- 91 CS 100: Cooling fans stay on consistantly when engine is running
- Need help!!!!
- Free front door shell.. Middletown NY
- is the EGR vacuum solenoid the same as the EGR valve? need clarification...(more)
- Could you guys chime in on this ?
- O2 Sensor stuck! Cannot remove it!
- Still waiting for that title....
- Just picked this VW up for my son on Ebay
- Suspension failure ... pinch bolt/tie rod?
- XPost: Can anyone direct me to good muffler & resonator upgrades?
- Left rear e-brake stuck....where do I start?
- A6 Temperature Sensor Fixed
- Something's Burning
- Engine bay fuse box
- motor Shroud
- Thermostat location
- Check out this S6 Plus Avant on German Ebay. Auction #8037861912
- Inop dash lights
- How to test Cruise Control vacuum pump
- does anyone have parts for a 94 or 95 we arent sure audi 1oo c quattro?
- Does anyone actually change power steering fluid and coolant?
- Rub strip paint?
- Pics from our recent Pines to Palms Drive
- I've lost my schematic jpg of relay panel #2 (the one behind the kickpanel) and can't find it...
- Power steering leak. My fluid is going down, Max to min in 3 months
- Climate Control Sticks/Freezes
- UPDATE ON EVERYTHING!
- Windshield washer problem, and proof of my auto-2-manual swap...
- Help Aliens Stole my Changer!!
- the stuff arrived!!!
- Side turn signal bulb replacement
- Can you tell from this pic if the head gasket is leaking?
- Will a VAG tool work on a 94 100?
- Hey, BigMouse, what the latest on yr tranny conversion??
- Guys with 16" wheels...
- fluids
- Exhaust - blowing out honeycomb in cats.
- Looking for a reverse light switch for an automatic 1995 A6
- Changed valley pan gasket, now car runs real rough at idle.
- Found where extra door piece goes
- Anyone have a spare A6 passenger mirror? I broke my mirror panel while...
- 1996 A6 Audi Quattro Flood lights "help"
- ignition switch on my a6...Hard to replace?
- XX Tuning Dyno Plots are up from Sat's Dyno Day...
- Wish me luck...I'm going to try and buy a 95.5 S6 tomorrow!!!
- RADIO CODE ??? got it!!!!!
- For Sale For parts 1992 Audi 100 FWD
- Source for Rapidfire 9's?
- frozen door lock cylinder
- climate control
- WTB headlights 1993 Audi 100Q CS and Expansion Tank
- need advice on brake upgrades....
- helpful input needed
- A list of random part numbers
- My photos from Saturdays' Dyno Day / Gathering at XX Tuning in E. Hartford, CT
- 1989 Audi 100 in AUSTIN
- Broken window regulator - now an extra piece!
- Some stuff to get rid of
- what a snow storm
- How much to divulge??
- Foam.......SeaFoam
- Have you all looked at Ebay lately???
- wil these lights fit?
- front struts ??? DONE!!!!!
- 95 Audi A6 quattro ...radio question
- CT/NY Audi Group Gathering & Dyno Day - We're still on for tomorrow (Sat) - E. Hartford, CT
- garage door opener - wood shifter trim
- In middle of process - need help finding radiator drain
- Arrested Development series finale TONIGHT!!!!
- X Post.. Audi 100 euros? Hello everyone.
- HELP!! Can't get tie rod end nut on. The bolt part just spins.
- Where the Throttle Position Sensor (TPS) is hiding?
- Wheel test fit: Anyone have two more of these?
- bilstein shocks
- Photos of my new VW project
- downpipe bolts
- When doing the front struts, where do you guys get the wear parts? stop, mount and boot?
- What's a good VW-related forum?
- engine head and oil
- Changed the Serpentine Belt.. how was I SUPPOSED to move the tensioner?
- Perplexing noise
- seat mounting positions
- Odd noise
- automatic climate control
- Who has the best deal on Bosch Universal 3 wire O2 sensors?
- oil leak around where oil filter is mounted(not sure name of part)...any ideas?
- sway bar?
- well i've cut everything down to 3 problems
- ACNA 2-day track event @ Buttonwillow Raceway coming up on March 27 & 28th (Mon/Tue)
- Oil filter-95 A6 Wagon
- it was boring around the house sunday...any thoughts???
- Reminder: This Sat, 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XXTuning - E. Hartford, CT
- 93' Audi 100CS 5spd FWD at auction
