- 96 A6 Q-wagon coolant bleeder hex bolt .. can't seem to get back there
- Not too much power
- A/C Service for '92 100
- jack@#$ back into the A6 today
- Rear wiper question
- losing power real bad.
- Idle Woe
- Looking for a 100CS Wagon...
- Three weeks left in the Audi Club raffle!
- Replaced Spark Plugs - Cables Resistance
- Anyone here interested in HID's for their audi, starting a group buy
- where exactly are the O2 sensors located after cat-conv on a 97 A6?
- Re: Cat Converter
- trying to replace outer control arm and anti-sway bushings
- Coolant temp sensor VAG 034 906 161 problem
- Dash lights....big problem....
- looking for transmission
- Help please. 97A6Q Stuck in PARK
- calling wagonmann
- 1997 S6 - with V8 and manual box?
- check engine sign
- Ignition switch recall "KB" campaign information...
- Tranny speed sensor nominal resistance
- So I crashed my car about 2 months ago!!!
- Hello everyone, does the front windshield on a 95 A6q have a antenna?
- Hubcaps
- X-Post DTW/Detroit Area Audi "Cruise"
- can anybody identify this clip...from wagon hatch...more
- Anyone got a diagram of the vac system on the 100...
- I need a front grille/headlight picture of an older C4 and of a newer C4.
- sunroof opened/stuck issues.
- Will the hood from a 97 A6 fit on my 93 100??
- Where is the Transmission fluid temperature sensor?
- 1993 Audi 100S
- reinstalled radiator, NO START HELP
- Ahhhh Nothing like a fresh wash and wax
- Leaking Oil Pan
- Possible purchase: 92 100CS, NEED HELP! (LONG)
- Anyone running plus zero tire size (215/60 R15)? I have the stock setup on my 95 A6 (195/65 R15)
- SOME GOODIES LEFT!!!!!!!
- Cat Converter Problems.
- Parting out 97 A6
- Y does AUDI Avant sound so much "cooler" than....
- The ignition switch assmbly has a cylinder, switch and wheel lock replace lock too??
- I have a stripped hub. Is this what I need to re-tap it? M14x1.50 at snap-on
- don't have a bentley yet, anybody know the torque setting for tightening spark plugs?
- question on the hand brake cable replacement.
- 96 A6 Wagon 4x4 ignition key is sticky (hard to turn in the morning) ?
- Manual Conversion
- 1996 Audi A6 front end
- Tranny Slip
- Any experiences with Xenon Conversions??
- Audi 100 CS Quattro Wagon 1992
- Dashboard question
- BOSE SYSTEM> DECK,SPEAKERS,AMP
- just curious............
- Update on Squaky Seats ..
- CD Changer Magazine
- transponder key ??
- fix/upgrade suspension
- Any interest in an 96 Avant FWD?
- Arrrgggghhhh Leaking Injector
- Alright, who wants it?
- Want to see some Audis move on your screen? Check out this site!
- Best spark plug wires out there? Anyone change theirs? At what millage?
- FOR SALE: 1992 Audi 100 (Auto, FWD, Red, 131000 miles) in central NJ
- Thermostat temperature on 96 A6 Wagon: 80c or 87c which one is stock?
- parking brake cable froze
- Poll: Do you like the Sylvania Silverstars headlight bulbs?
- can I activate the outside temp guage and trip comp. on my 100s
- X-Post: Targa Breitenbach - July 31st
- EGR Temperature sensor replacement help?
- changine differential fluid
- Warning when changing headlight bulbs !
- 00653 DTC transmission problem
- HELP!!! 97A6Q transmission leak round 2
- Selling the Avant
- A-6 SPEED LIMIT
- "Old - School Quattros" Gathering, Airport Autocross, Mountain Cruise, Crab Feast
- noise when moving
- Tachometer Problem
- I forgot the name of the used parts place in Fleishmans NY- anyone know it?
- cataylitic converter rattling
- cataylitic converters
- Bleeding brake procedure;/?
- what are the best plugs and wires for a 97 A6?
- Will Automatic climate control fit my 100s
- Anyone in the Northeast have an automatic quattro trans for sale?
- ghost in the machine
- Anyone with a 96-98 remote fob they wanna sell?
- Intermittent fresh air blower... diagnosing fun.
- Spark Plugs?
- Help sunroof leaking 97 A6
- Crankshaft pulley's bolts stripped.Any suggestions?
- recent post about seat belt retracting (not)
- Intermittent stalling on Audi 100. HELP!!
- Cruise control resume
- Can I use stock A4/A6 wheels on a 92 100 csq?
- who knows the pinout for the bose radio connectors??
- Interesting, a new Remus for $139?
- FYI: Bentley Hardcopy Manual (3 vol set) on eBay...
- What do you think?100cs for sale
- I'm selling my A6Q
- I have a pocket pc what else do I need to get a navigation system
- Front end whine
- I suppose the positions of these camshafts are not quiet right
- 1989 100
- front brake
- New to Forum
- Who can rent tools need to be done for TB replacement?
- anybody tried Auto-Rx oil treatment? A6 has 123K miles & thinking it might need scrubbing...
- I've decided that I'm not very good at bleeding brakes. Pedal is STILL squishy
- Smell from vents...
- can I put 19" chrome on my 100 S 92
- Smokiesman... you out there?
- aluminum hood on 96 A6 Quattro?
- help A6 just started pulling to the right really bad
- Squeeking steering wheel..what might it be?
- wheel info needed?
- Has anybody replaced wheel bearings in rear of the 100s
- 100 wont start
- A few normal operating guideline help please
- Belt/Pump Noise
- sunroof stuck open
- Ignition Switch Failure. 3rd time. 1995 A6 quattro
- Do you need a special wrench when....
- Car just died going 80mph:(((
- Hello there :)
- possible engine swap? '96 audi a6
- Recntly purchased 100CS, What service should be done?
- 91 100 Radio
- those of you with H&R springs
- ACNA Rocky Mountain new track fund raising event
- "OIL" - Service light reset
- C4 brakes
- BOSE System lockout
- where is the A/C high pressure switch
- A/C freezing up????
- driver side seat belt not retracting fully...anybody have the same problem?
- X-Post: NE Ohio GTG 7/17 - Bunker's & Winery Run 7/31!!
- I need a Delta CC bracket. I want to replace Gamma radio with Delta, bracket does not match.
- 94 100S transmission seems to be slow shifting at times
- Aftermarket radio info ..
- Running down a clunk- are these the parts to order??>>
- FYI: Papercopy Bentley Service Manual (3 vol set) on eBay - Item #7910709173.
- Anyone know the stock hp/torque of a Euro version '96 A6 with a 2.6 engine??
- C4 FAQ?
- Anyone with a FWD auto notice that 2nd-3rd shift is rather rough/jerky?
- Will a power antenna of '95 audi 90 fit my 94' audi 100, part# 4A503527C
- Ciggarette lighter has no power
- Broken arm rest - Please, please, anyone with a Bentley?
- Kansas City - Reminder - boba/bubble tea run TONIGHT
- climate control for 97 a6q....I NEED ONE BADLY ! ANYONE...
- Gamma Radion Revisited. HELP, I did get my Gamma
- Is there a way to center the steering wheel without affecting the alignment?
- Noisy Fan, My wife 94 Audi 100 has a intermittent noisey
- help! collision accident
- 94 100S keeps randomly dying when not in motion
- Blaupunkt Phoenix.....
- Where can one buy rebuilt brake calipers?
- How do you rebuild your calipers?
- Headlight Sensor
- Central air flap jammed. Have no air out from lower&upper vents.
- SMOKIESMAN do you have any door trim left....?
- can someone check a vac hose location for me?
- Looking for 1994 Audi 100 CS Driver Side Fog Light and Power Antenna
- Audio options with Delta Radio
- my car feels like its misfiring or something..
- Radio/CD Player which is the best??
- A8 front brake upgrade on 92-97 A6Q
- I gots to get my kids one of these
- Paint on bumper, washer fluid squirter not working, radio busted....
- Reminder: Achtuning Anniversary Car Show and BBQ this Saturday!!!
- Anyone have avant outer tailights they wanna get rid of?
- I had to make a new Vac Reservoir 'cause the nipple broke on mine
- can anyone find the TSB for "adjusting" the brake booster?
- Interesting... Auto Tranny shifting points:
- Could anyone please post the procedure for...
- A/C Help
- Shock/Suspension Problems
- which plugs are the best, NKG, Bosch,.....
- Knocking noise when going over bumps
- I have an update on my situation Edd W and snowman
- is it unusual for the coolant sensor to go?
- Anybody know how to get the door panels off a 96
- the beauty and the beast
- locks
- Anyone wanna trade me a street bike for my Taylor 814ce?
- My car rattle
- Can anyone diagnose this?
- Is "stealership" only one place to buy a new window regulator?
- I am getting a serious vibration in the rear tires
- Console trim
- Power steering sluggish at low RPM (more or less suddenly)
- I need an airbag coil/clockspring, can anyone help?
- Surging/loss of power at high speeds
- ETKA - file "Preis.sav"
- I have an old o2 sensor from my 91 gti, and the plugs fit perfectly for my 100
- Which Thermo Fan Switch to Buy...
- Who in his right mind would put this on an audi???
- Y is the FAQ off? Did somebody take it off??
- Need Climate Control Help/Favor From C4 owners
- so my friend locked my keys in my car...
- need help. fri night my left rear tire started to smoke..
- Running slightly Hot..or Not?
- OBDTool.com
- starting trouble
- Cd Player Wiring
- Rotor play
- MIL with two lean codes, 16555 and 16558
- Did I switch where these vac hoses connect?
- Window stopped working
- rebuilding heads - starting
- O2 Sensor replacement?
- How do I install ipod in the aux line of trafficpro? Would I-link work?
- Kansas City - tech session on Wednesday July 14th at Volkswerks
- Help!! Start up problem..
- Doing a brake upgrade, hubs are crusty. stopping rust?
- A6, 2500 TDI - MAF sensor
- 1995 A6 A/C Error Code 29.4
- anyone here going to waterfest?
- INT-2 on Cluster Display
- does anyone have an special tb to sell me?
- Ceramic Brake pad?
- 1997 A6 Cell Phone & CD Changer
- Tried accessing on board diagnostic through the AC display
- Replaced EGR valve
- Rough Idle -- Can't find the source.
- Uh oh... limp mode + ticking even when in park...
- anyone need a parts car?
- Peeling Door Trim Help
- 2004 Northeast Event Pictures Up...........
- 93 Audi 100 Difficult to Start
- Has anyone port and polished??
- anybody who parts hi car. I need a small thing.
- Good afternoon all, i'm new to the C4 platform and I have a radio question.
- Does anyone need a pass side clear corner or corner taillamp or center moldings?
- OK, here is how she got ugly...
- What is a good tire for A6 avant quattro?
- 10Valve veresus 20valve? considering purchase. see text for my delemma/ 89 vs 91
- Parts Car??
- Vacuum lines?
- I just broke my fog light anyone have a spare?
- calling BRDMAN
- It looks like the clutch on my AC compressor is dead.
- radio wiring
- For reference
- for those in the Kansas city area picnic at shawnee mission park this saturday
- Does anyone have cracks in the outer end of their swaybar?
- trouble starting/ strange noise
