- oil pressure (long)
- Audi Lunch GTG: Reston, VA (Thursday July 11th)
- Audi 100/S4 Avant Owners Manual
- Battery Voltage with the A/C and Lights (High Beam) turned on?
- Converter alternatives....
- '93/'94 A100 Avant -> Door speaker size?
- 100CS A/C Controller
- Changed Broken Ignition Switch 1996 A6!!
- Hi Folks
- Hey Everyone
- Installed both oxygen sensors still get 2342 code
- ECS light
- door sensors??
- Exaust noises! Very confusing
- Anyone parting out an A6? Or know of one?
- Battery Exploded yesterday! Warning.
- need advice on buying 1995 A6
- does a 92 100s have a inline fuse connected to the cooling fan leads? Besides the Relays
- Car doesnt start.. searched posts, not like others
- ArmorAll Wheel Cleaner.... Whoa
- VT 100CS: Do you still go to Viriginia Tech? It will be my 3rd year there in the fall....
- Another victim of curb rash...
- Are the Automatic 100 radiators problematic? Whats the cost?
- Audi 100CS transmission problem
- Car won't start - 1992 - 100s - 135k
- This looks to be a much better place! :o)
- Cooling fan wont turn on. what could be wrong? 92 100 12v Read more..
- Can anyone post a diagram from the air vent system
- Follow - up Timing Belt Rplacement/ Lifter Damage
- Engine running problems
- Hi guys, need some advice on a dash light circuit that isn't working
- Car ( Audi 100 2.8E) slip to 1st Gear while driving.
- 1995 A6 FWD, 5 spd, 118k miles- Rattle from under car
- Car won't start sometimes unless you move the gear shifter
- I need a set of Clear Turn Signals Fast... Does anyone have any or know where to source them cheap??
- Changing Fuel Sending Unit in 1996 A6 Quattro - Need Help!!
- Muhammad
- Arbitration Decision
- Trany fluid specs needed
- Tranny Fluid in Coolant
- anybody change out front seats ?
- Audi 100 CS parts
- Timing Belt Service and Subsequent Lifter Damage (long)
- For IqDOU (or ?): about rear brake piston "turn and push"......
- Door Locks on a 95 A6
- 95 A6 Stalls when car stops/idles... But only periodically
- Message for Beep-Beep
- HELP EMERGENCY!
- Chip available for the 12 Valve 2.8L V6? Any other mods recommended?
- Can I change the fuel tank floats?
- starting problem
- cd changer
- beep-beep's dash light repair-what size bit to open the transmission display?
- cruise control problem on 92 100 cs
- door locks on '89 100
- Lessons learned
- 1992 100CS New Problem Heated Oxygen Censor
- Key Batteries for 95 A6
- High G Force Oil Starvation
- 170k Tune up...
- Hard to start car after work on high temp days... spark plug question
- Is there a tech article on how to do the fog light mod on my 92 100?
- 91 Audi 100 electrical still
- backfire on startup
- Pics of stereo as requested
- Can you tell me where the Throttle Position Sensor is located on 92 100 CS
- Hi Everyone
- Nasty squeaky control arms!!
- AUDI-100 Car audio BETA-4 unlock
- 1992 100CS Cam Position Censor
- A6 1996 - Need to take apart the sunroof switch console..
- Yea for NEW stereo
- Ignition Switch issues - Part numbers needed
- Headliner is comin' down on my head
- Auto transmission ZF4HP18fla - 1995 A6 Quattro
- 91 100 electrical problems
- Can I replace the center portion of my Steering Wheel (Horn Area)
- New Audi driver..............Audi CDROM? Anything I should have?
- Bad valve seals?
- Driver side power window - Auto rolldown feature
- Must sell 16" wineglass whls&tires...Came off 2002 A6 with 1200mi on em....anyone...anyone!
- Buddy has a 92' 100 but his car cranks a lot before it ends up starting! Fuel Injectors?
- Transmission Service at Dealer? Won't take my '94...
- rear brake job on a '92 100...is it pretty basic?
- Any possible Head mods for a my '91 100?
- headlights
- Transmission Noise
- Anybody with 1996 A6 with Keyless entry!!
- removing rear seat back cushion?!?!? urgent!...
- a few issues
- Anyone know the OE wheel offset of for a '94 100CS 15x7j ?
- Fitting Autodimming mirror in 1996 A6
- Muhammad - Do you have the Audi Delta Bose Manual for A6 1996?
- Could somebody lend me the 1992-1997 AUDI 100/S4/A6/S6 CD ROM
- Brakes 99 A6 vs 97 A6
- MIL came on
- 1995 a6 internal oil leak?!
- BOSSMAN is back!! and I'm selling my 1996 A6 for $11,900
- Stereo
- Cell phone connection
- Wheel Offset
- You can't keep a good man down ;-)
- BRAKE LIGHT
- O2 Sensors, need to know chassis build number???
- need help timeing belt noise
- Need help with vacuum line
- hey Viktor ;-) What the heck is on that CD? Nice voice ;-) I sent u an email.
- AC/Fan started making a strange noise
- Catalitic Converter
- 1990 Audi 100 Question
- 95 A6 auto Transmission shutter
- Workshop or Repair manual
- '92 100S - New Radio - Wiring Harness?
- should this happen?
- 1991 Audi 100 Problems
- Driver's door hinge rusting
- Question about fog light wiring
- What is the best brands of suspension to lower a '97 A6? more
- Anyone have a spare audi 100 wheel sitting around? (pic inside)
- Moonroof drain.
- Oxygen Sensor wrench
- My mechanic needs a front bumper and fog lights in Penns.
- Audi Gremlins after 3,000 mile road trip
- '97 A6qw rear hatch problem
- A6 Auto Transmission problem
- 1992 100CS Quattro Wagon For Sale
- Anyone bypass their cats?
- Relay weirdness...
- Passanger side door lock problems
- True specs of my Audi 100
- Climate Control system: 3 Me: 0
- 1990 audi 100 warm/cold start problems during humid weather
- Audi 100 optical tuning to looks like A6
- O2 sensors
- Ignition cables?
- what tranny fluid, and is the trans sealed?
- lag
- O2 sensor symptoms? Condensation smoke from exhaust also...
- Mileage
- Programmable Intermittent Wiper relay for '95 A6 not working - Help????
- Seidl Body Kit what do you guys think???
- Introducing Achtuning!
- Got my camera working again..
- Anyone have an extra set of fog lights for the 100
- Turn Signal Problem
- Oil Changes
- For sale 95 A6 North Jersey Area
- Pads and rotors
- Audi Car Club nationals event info is on-line
- E.C.U
- Sorry to be a bother, but... Difference between Zimmerman Slotted and non-slotted?
- Replaced Oxy Sensors
- Xenon.. on Ebay... Should I even Consider?
- Why this forum is so valuable
- ['92 audi 100cs] central locking control module bad???
- Harsh engagement into reverse
- continuing battle with slow battery drain
- So I cleaned up (waxed) the pigboat this weekend...poor old thing.
- Gamma: Jammed Cassette
- 93 100s Is the trans slipping\also hissing noise HELP
- Power windows
- gamma bose radio
- Check Engine Light -- again (long)
- Tranny Service and Front Struts
- Extended Warranty Paying Off
- beep-beep, I need your help in getting some info on headliner removal from Bentley. That's where...
- Electrical problems
- Engine Stall
- Cheapest source for S4 head lamps?
- Changed O2 sensors..
- Beep-Beep: Dash light direct replacement bulb?
- Oil pressure gauge
- Anyone for a 92-94 100 passenger side headlamp?
- Flushed PS system
- Fastest speed in a 100?
- Automatic Headlights
- BENTLEY CD Manual $50
- Can someone recommend some good plugs and wires?
- 100/200 audi 016 gearbox
- Question about 1998 A6 Avant (which seems to be actually a 1997 car except for build date)
- lag
- guys.... please help, my friend needs some help with his 96 A6... tia!
- Power steering preload adjustment
- Leaking ATF
- Audi 100 is a big car right?
- Brakes geting hot
- Keyless Entry For 1992 100CS
- Pollen filter demystified...
- very good link http://catalog.exist.ru/
- changed timing belt (WITHOUT ANY AUDI TOOL)
- OK Style, I found the link I really wanted about shampoo. The info is from Amsoil but I love it ....
- Looking for front Strut tower brace...
- Oil videos, mobil one synthetic is scary!
- Anybody has ideas, what to do about the "bumper over the hight curb" problem?
- Some fun with Carb Cleaner
- cold start
- any ideas for repairing loose exterior trim???
- ELECTRICAL GREMILINS!
- 1999 A4 wheels
- Pardon my Ignorance but
- Fuel injector part #?: 1997 A6 quattro
- Tips for changing valve cover gaskets?
- HELP HELP FAST
- Got my Bilstein Sports today! Time to install..
- Does anybody know the Relay number for the Air-cond Compressor?
- My 1992 100cs is an AT but it feels like a stick when going through the gears. Is this normal
- Rear Glass
- Lights on chime
- Does anyone know where to find a body kit/ ground effects kit for a 1997 A6? Please Help
- top speed
- Audi radio
- So I did it...I have order #2 in Orlando for an RS6
- Oooooh a $10k S6
- White perl A6 this morning on NJ TP between exit 13-16W. Are you here?
- vwparts special! Stock 15 inch Rims for $69!
- Accelerator pedal action
- Shameless For Sale post: 92 100Q Avant, Red is your color!
- Ok, which AT fluid to use?
- 105k on 2.7T timing belts?
- Hey Everyone Audi 100 Question
- Hard starting sometimes
- Power Steering Fluid
- Finally going to Arbitration with extended warranty claim
- How Smooth Should my AT Shift?
- REAR SPEAKERS
- Ignition Switch Recall 96 A6Q
- 1993 2.2l 100s
- 100S keyless entry ?
- All cleaned up and ready for a new week!
- Radio power ??
- Transmission
- Muhammad: I read your post on extended warranties and have a few questions...
- AUDI S4 4.2 AVANT!!!!!
- Any idea how to fix the front strut cartige nut?
- OK, I've got a deal of a lifetime today...
- what tool do I need to push in the piston when replacing rear brake pads? (97 Audi A6Q)
- New web site for So. CA. Audis/VWs
- My in dash thermometer light burned out, how to replace?
- I replaced my ignition switch tonight, now it returns to "run"
- '94 100s Infrequent Steering Noise at Startup
- Blank Key/Remote for 95 A6
- 1993 Audi 100 what are the front and rear turn sig. bulb numbers?
- 92 Audi 100 Advise on purchase/maintenance
- Getting screwed by dealer?
- Is this related or what? Let's do a meet not concerning the As ;-)) Lookie inside...
- Had Heat Yesterday!
- Ummm, okay, will this CD Changer work with my Delta head unit...
- Ok, here's more. I need the p/n on the little latch (holder) of the sunvisor on driver's side.
- How easy (hard) is it to swap a sunroof? I'd really like a glass one.
