- new kid on the block
- A/C clutch
- Delta CC Radio question
- Need help with clunking noise on front suspension on 97A6q wagon...
- headlights on relay?
- Lifter Direction?
- can someone check this to make sure I'm getting the right part?
- anyone know where i can get a set of interior pannels?
- Anybody have any luck with these ETKA parts programs off Ebay
- A.M. Radio reception question
- The Quattro feel?
- Starting issues... no spark
- Where is the antennae signal booster located?
- If I change my clutch, do I also HAVE to change the clutch master and slave cylinder? TIA
- Redline Tranny Fluid In 96 A6 Avant Any BTDT??
- Replaced lifters - New strange behavior
- Not so pretty sound....
- how many hours to remove Cylinder Heads and replace Cam Belts and valves?
- need steps to change the bulb in the .....
- Any sources for upgrade A6 '95 anti-sway bars??
- What was a good year for the 100's? Thinking about getting one...
- Turn Signal Conflicts
- I need a Bentley for cheap! I'm poor. Help me out, if you dare...
- Factory headlight options for US A6/S6
- clunk- like strut mount but not cause I did them-
- Does anyone have an in dash coin holder for 97 they want to sell?
- the front vents on Audi A6-97
- * * uh oh...* *
- Wanted 95-97 A6 Wagon in Atlanta Area
- How to remove toothed belt sprocket from crankshaft
- 1990 100Q thermostat location
- Replacing Control Arm Bushing
- wiper/trip computer stalk replacement
- Newbie Question???
- Just Got My Red 97 A6 Q Today....
- Anyone ever replace the footwell/defroster flap motor on a 96 A6?
- Radio problems
- Help! where is the fuel pump and fuel relay located????
- Sensor post AGAIN 3 wire front 4 wire rear???
- seat memory
- blinking water temp warning
- Bentley Needed
- Oh crap for me too, My timing must be off or something like that...
- Anyone ever replace the lifters? Any tips?
- how do you tighten the e-break cable?
- I need a front end cover (bra) for the front of a 92 please help i cant find one
- Oh Crap
- Fuel Trim: Malfunction: Bank X. What to do?
- Mass air flow sensor- passat?
- Valve Body Solenoids
- I need the Bentley, anyone wanna sell? '92 100cs
- Need advice! Most successful way to sell a 100 CS quattro?
- Possible factory cd changer, and trailer hitch for sale
- Audi Bose system questions...
- just looked at the hummer.com. OMG
- How do I properly bleed the brakes with a hand-held vacuum pump?
- How feasible is a auto to manual swap...
- WANTED 92-97 5spd audi trans good/bad or even parts
- Window switch
- New Fogs...Best price? $121 at Blauf..anyone find them cheaper?
- Dull headlights as well....
- 95 A6 climate control
- The 12v CAN be effectively modded - Crosspost from 12v Development
- My car's a hostage at the dealership
- LOOKING TO BUY 92+100 or A6...VIRGINIA AREA
- 6 disc cahnger w/ non bose system
- Obnoxious "Service/ Maintenance" Reminder
- Changing ATF
- Lowerred 97 A6Q
- Passenger side mirror removal
- Anyone have a salvage washer pump?...
- Pass. door handle broke - ideas?
- Misfire resolved
- idling problems ... solved !
- Is 12v.org gone for good? Anyone know the story?
- Is window washer and hdlgt. washer same pump?
- Where Can A Deck Lid Wing Like This Be Purchased
- X-post (LLTEK RS Front)
- 93 - 100q Steering rack
- Do I need to Gap Antilock Wheel Sensors?
- installed keyless in my 92 100s with no factory setup
- Heated mirrors not working
- Fellow 12v owners of 1996-97 A6's--a question from your A4 brothers:
- Repainting time?
- Timing belt Installation
- Is it possible my vibrating clutch could be due to not enough lubrication in the throw out bearing?
- Audi lowering springs inquiry
- 41 cents caused grief @ automatic shifter
- headlights...
- auto climate control
- in-dash dvd's?
- will do but
- Need more light
- My dealer strikes again....So I took my dash apart to change the bulbs that were and found
- 10v to turbo conversion...
- Leaking Power Steering Hose - help
- Power window LED part number for Radio Shack?
- Keyless entry application
- 100 3spd auto
- door locks, someone help me unlock this mystery
- Repeater, quick followup question
- Car is literally falling apart!
- Anybody have a hood release cable and under-dash lever for sale?
- What would cause Fuel Gauge to stop working?
- cs 100 electrical issues
- Dash Lights, 89 100E
- Are 1989 Audi 200 guages interchangable with early C4's?
- Sound from Passanger side rear Wheel
- 92, 100 - What's avg. gas mileage on these cars? Maybe my odometer is bad (uh-oh, I got jipped...)
- front speaker problems, lots of loud noise!!! weeeeeeee!
- Rough Idle/ Misfire V6
- Removing Automatic Shift Knob on 96_A6?
- Re: 92 100, hand rest that attached to the drivers seat...
- clutch/hood price.... anyone know where are some deals?
- Removing rear view mirror
- Does the CD changer mount in the right well in the trunk?
- 96 A6 Over drive RPM & SPEED?
- Considering getting a C4 Avant. What should I look for?
- how to disable the (o) at the board level
- Car stalled
- 1994 cs 100 Quattro wagon
- Worn Driver's Seat Replacement
- Temperature control unit
- Tow Hitch for 1997 A6 Wagon
- Factory alarm wiring diagram???
- Were any C4 Avant Quattros made with a manual?
- need help diagnosing problem......
- Antifreeze Red vs. Green
- Driveline center support Bearing
- Need Suggestions for Tires- '97 A6Quat -Northeast Car
- What would cause the odometer to stop working?
- Should I keep resonators in custom exaust setup or not? What will the difference be? Thanks!
- My A6 is finally on its way...
- replaced my front struts and what a difference
- 96_A6_WAGON QUATTRO Shifter doesn't return to PARK?????
- Automatic 'final drive'
- Trouble Starting
- I.S.V question
- Hey guys, need a little help...
- what can i expect to get for my car?
- Brake pad light comes on...
- PARTS - How to determine engine "chasis range?"
- The horrible trip that ending last night
- why are my posts getting deleted?
- What do you think of this wagon?
- Where can I find a body kit for my 97 A6 wagon?
- why are audis built so well
- Taking time to show our support
- brake probRems!! '92 100 HELP!!!!
- OEM Avus S4 wheels vs. Repros
- Alloys
- bentley manuals, my opinion.......how about yours
- 2003 NORTHEAST AUDI FALL CRUISE-info on the News & Events forum
- Alarm and interior light problem
- You guys ever get a bad water pump?
- I need some parts. I'll pay. $$$ BLING BLING... sick
- Can anyone help me on this question? If so, thanks a bunch!
- replace MAF or O2 sensors?
- Anyone ever install these bushings?
- anyone install keyless entry on a car that does not have factory wireing?
- they just took my 91 100 away
- Finished the timming belt ...... now on to the CV joints
- 95A6Q burns oil~! what do to?
- Heads........
- automatic transmission
- can I bring my car to the race track? I am serious.
- where is the TDC sensor located???
- VIR December Driver School
- I think one of my valves are stuck
- need V6 Engine Cover ..
- update on stuff
- I tried search- rear O2sensors- how to access?? and..
- Mann vs Bosch
- automatic transmission fluid
- when to change timing belt in audi 93 100s
- i feel lots of vibration while am driving
- Misfire running on 5
- gas in oil???
- 95 A6 Quattro
- strange rattle /vibration in left rear of car?????
- Noise when use A/C
- Survey: Fuel Filter Replacement Interval (more).....
- changing timing belt......what happen to 12V.org?
- Is there any procedure or guide I could purchase for a clutch replacement on my 93 100csq? TIA
- 95A6Q Need a grill... know where I can get one online?
- uk audis
- anyone have a extra Idle valve?
- changed out my Gamma radio to kenwood 10 disk Cd what a difference
- Lost Clip from Brake Sensor Connector
- Anti lock shutting off???
- Pollen Dust Filter for 94 100S
- A6 2.8 v6 quattro saloon manual will not start, has battery, fuel and turns over?
- Where to order keys online
- Tach Issues
- Is it possible to replace the bulb(s) in the mirrors control knob? "W" and "S" arrows are not lit.
- I'm selling my A6. What can I reasonably expect to get for it? Should I ebay it?
- Do I have a light(s) out on the tach? It is my wifes car and the tach has always looked uneven on
- I don't like end of daylight savings time. I hate going forward through 11 hours on the
- Gearbox oil level and differential level...
- 1992 100 2.8 Knock Sensor issue
- reminder: dubsnorth audi/vw gtg
- Bose "CD OO ERR" Message?
- BIG GTG , Carshow & O'Fest @ Hartmann this SUNDAY 11-5
- exhaust manifold leak
- Cooling fans running
- Audi 100 glovebox light question
- Just finished fixing my new key, what do you think
- We're in good company!
- ignition switch misbehaves
- Tranny swap in 92 100CS... easy or PITA?
- Windows Always Have Power?
- When to Sell 100CS Quattro
- '96 a6 wagon with 3rd seat issue
- Heater core replacement (tips)??
- Post Head Gasket replacement questions. 93 100s
- winter car
- need headlight assembly for 100s 93 audi
- i think search function of this forum is broken
- gear shift light is out
- My son just totaled my 91 100...
- Dashboard Lights '96 A6
- Duh - Serpentine Belt Diagram
- Headers?
- noisy lifter or a/c?
- Engine "good for 150 K miles"???
- RPM too high
- vw audi meet this weekend dubsnorth!
- What would happen if the vacuum hose on the trunk lid were to break while the car was locked? Would
- So if I decide to try and install my new clutch with my uncle...
- need bose Amp and front speaker
- '92 100CS Quattro Hesitation (Again)
- boo-hoo. It is getting colder. I plan to switch to all season tires.
- intermittent Dead battery ????
- Dim headlights -- why?
- time to replace...... where to buy parts....
- Please help 96 Cabrio 2.8 12V AFC Oil pump/pick up problem
- My wife though I was having a heart attack when I fell out of my chair to make a point about an Audi
- Two of the most helpful tools I own..........
- Is it worth getting used O2 Sensors?
- Remote battery 1997 A6
- High Mileage '96 A6
- Rear speakers wont work....
- back from upstate to staten island to upstate
- Fuel Filter
- wiring diagram
- 95' S6 black Recaro interior on Ebay
- Looking for some pointers
- CD Changer for sale on e-Bay
- Headlight washers...
