- 2006
- a BAD day in A6dom - subtitled - "to total... or NOT to total". and a happy new year to all.
- VAG-COM communication issues
- Now to get serious about looking for avant
- Pic of my 100 Avant
- Coolant is boiling and coming out of tank....
- well...this is my latest problem..i need a little help.
- Somebody up North needs to get this.....
- Can somene help me to locate the coolant temperature sensor? Audi 100 2.0E C4 1993
- Looking for some honest opinions about these wheels.
- does anyone have a good picture of non-Q front suspension?
- Many thanks to Audijim113
- my new baby...
- Enjoy the movies!
- 1/14/06 - CT/NY Audi Group Winter Gathering - EPL, Stratford, CT (Updated info)
- Clicking
- Heated Seat Conversion?
- How to change air filter? C4 2.0E 1993
- Auto to Maunal conversion... any info on this for 100's?
- Anyone have a tie-rod "freeze" on them? Can't align my car unless I can adjust the spanner so...
- Central lock vacuum troubleshooting...
- Sensor questions, related experiences...?
- radio code decoders on ebay
- CEL turns on but scan tool finds no trouble codes...???
- Fluctuation in Gas Mileage
- Oxygen sensor refresher needed...tried searching but still a tad confused
- What is the top speed.......?
- 100 (non-Q) axles... which one is which?
- Mystery smell....
- Bought 100 Avant with bad tranny.
- audi 100cs body styling
- Coolant Temperature Sensor - Location Please????
- Steering knock on 94 100 CS Wagon
- Looking at a '93 100 Avant Quattro tomorrow with a bad auto tranny, questions...
- Problem with diarming alarm from driverside door! Need help!
- Foglight
- Disabling ABS on 98 A6 wagon
- X-Post: Anyone know of a garage bay availale for rent in SE PA, S.Jersey?
- Hard To Start If Cold Out (Audi 100 2.0E 1993)
- Just got a new digital camera for christmas. Thought I'd share a few pictures.
- Reverse Lights on '94 100
- How do you read the ECU codes on a 92 100CS quattro?
- well i replaced a temp. coolant sensor...
- bose help needed
- HARD TO START ENGINE WHEN LEFT FOR 2 DAYS
- need some more parts...
- Hard to start audi 100 c4 '93 model
- 96 3 Spoke A4 Sport Steering wheel...Is this a bolt up for my 95 A6?
- 92-94 100 ECM pinouts
- can someone run a vin for me
- Purging Air from Cooling System
- headlight assembly replacement on 97 A6
- Injector failure
- Eibach Springs/Boge Struts..wheres the cheapest to purchase from?
- GPS unit install?
- Best $115 interior upgrade EVER!!!! (teaser)
- Milky sludge in oil, 92 100S 106k miles
- 100 CS Dashboard light fuse problem
- central locking issue....
- Tie Rod sleeve question
- Anybody have the E-code Headlights from Importvision/Ebay? Any fitment issues?
- When the oil level is at the low mark.....
- What was the 'Sporty' model of the C4 called? S4 or S6?
- Who has installed remote starter?
- No crank issue could be an open circuit from the alarm system
- looking for...
- resetting codes
- Cam Pos Sensor?
- Thoughts on additives to coolant to prevent leaks.....
- Radio question
- Need beige sunroof panel with switch...
- Looking for suggestions on how to fix bumper.
- Hot Start Hesitation....
- Anyone with a A6Q Avant notice that their front suspension rides higher than their rear? I'd like...
- Radio Center display
- Auto up/down window
- Major bummer - Bentley Repair Manual CD "no-worky"
- Distilled Water in Radiators
- Looking for a crank sensor
- AudiJim, you'll love this video: A8 twin turbo diesel v8 goes 800 miles on a single tank!
- source for 90 degree vacuum hoses at back of each valve cover?
- Defroster not working
- wow oh wow
- Need some parts......
- Need right inner taillight
- need suspension info
- Before I drop the belly pan, exactly what's involved in taking out the lower corner grills on my A6?
- Time for a new Radiator?
- Oil pressure problems
- Delta CC Radio
- windshield wiper linkage needed
- Post-VSS Transmission woes
- Camshaft Position Sensor
- MPG question...
- The power of Quattro
- Anyone have the part # for the rear shock mounts, 2WD and Q
- Few Questions and would appreciate help!
- Looking for a passenger side headlight.Got one? Let me know.
- What can a bad Heater Control Valve cause?
- Need right taillight lens for 97 Avant
- ran codes now what do they all mean
- Cost to replace CV boots
- New 100 Master Cylinder Source?
- S6 questions......
- Be carefull out there in the snow...
- For those of you located in Southern California...
- groaning sound when starting out in reverse
- Rats just missed this one... I thought I bid all the money
- check eng light
- Front strut had water in it!
- Check Engine Light on '97 A6 ACK?
- battery light on '92 100SQ
- 92 100CSQ oil/colant issues
- easy way to turn off alarm?
- A6 - Confusion over part name/number
- Well, I have a coolant leak somewhere......
- CEL and VAG error code
- 96 A6 Oil Temp Guage
- Even the Mechanic is baffled...
- Quick question:
- Whats the right antifreeze to use......
- problem with my 92 cs 100
- door locks
- Fun with Audi Parts
- Transmission and Speedometer acting up...
- Now thats it 16 degrees out and the car wants to act up.....
- can someone run a carfax for me...
- Manual lock question for you guys......hmmmm
- 96 A6 Battery Drain Found; comfort-relay f. el. windows ?
- Switched ignition live for upgrade Radio : '94 Audi 100/A6 C4 UK
- 2312 code ...coolant temp sensor....replaced ...2312 code again...what to look for?
- Concerns about my heater blowing smoke.
- Has anyone here bought and install the german keyless entry off ebay?
- Finally after 5 months of looking at these in the garage, they are on the car.
- Anyone have the round connector wires for foglights on a 100cs?
- found light prob. now i need a tiny little part
- Recommendations on good headlights (stock 9004)
- should there be a battery cover?
- Put '01 A6 wheels on with 205/55-16 V-rated Nokian Hakka WR's - whaddya think?
- Better pictures of all the stuff I need to get rid of...
- Anyone else hate the smell of winter gas, but like the smell of summer gas?
- still no low beams - swapped combo it's not logical - help
- Way way OT, but check out this silver A8 at the end. I just had to share this...
- Automatic Transmission Shifting?
- no low beams, but highs work
- What could cause my 93 100s to take a long time to warm up?
- Anyone have the heater/AC control available for sale? Thx.
- Bose Radio Unlock Codes
- How do I replace/convert IR locking system to RF ?
- Climate Control Auto Mode: Positioning flaps seem stuck...
- Question for those who have removed their catalytic converters..
- ygm |skolnick
- Remote Starter for a 1994 100CS Wagon
- Vogtland Spring Questions
- warning sensor trouble
- front passenger side axle assembly question
- 1986 Audi Avant 100 CD
- timing belt tool
- Radio balance control
- Car wont blow heat unless on the gas?
- Does anyone have a pass. side foglight for a 92? Rocks killed mine...
- Beep beep: you've mentioned "frozen" parking cables before and tell me how this sounds....
- Cheapest source for a rear tranny mount?? (92 100 CS non-Q)
- A6 Gary, do you know which exact tool fits the front diff plug? It looks like a 8mm allen but...
- Outer Passenger (US Driver) Side CV Boot, a few questions
- AC compressor
- Still have plenty of stuff in my friend's basement to clear out...
- 2.8 Quattro does'nt start
- Chillin
- How much is my underside pan worth to you guys?
- Dumb Little Thing - Freezing Indicator on Temp Display
- A6 Wagon rear washer motor location
- Do thermostats leak? Mine was changed 8k ago and now I'm seeing coolant in that area dripping...thx!
- Oil Leakage Near Oil Filter
- some issues with motor swap
- OUTSIDE TEMP DISPLAY, CELCIUS to FARENHEIT
- MY ALARM SYSTEM KEEPS GOING OFF 10 MINUTES AFTER I LOCK MY CAR...WHY?
- Changed Trans Fluid Today - '98 A6Q Avant (C4) QUESTION
- Anyone drained their front diff on an A6? I found the the fill plug, a 8mm allen but...
- carfax request
- cool (cold) engine temp
- 96 A6Q MIL (check engine light) on
- when **** hit's the fan - part 2
- My Alarm System/Battery
- carfax request--1994 100
- I am going on 3 month business trip next week. Do you think my G/F will destroy the car while I am
- 94 100 CSQ Wagon - engine 'whine'
- Poor Gas Mileage..What is to blame?
- When locking Car via Keyless, Car does not flash turn signals..Help!
- when **** hits the fan......
- AC question...
- 94' 100 S REVERSE LIGHT SWITCH
- Audi Bose Gamma CC compatible CD-Changers
- Bilstein Package Contents
- question on thermostat replacement
- Euro headlights for my 1993 100
- 1993 100Q CS Auto Tranny Info Needed
- AC compressor knocking?????
- ICELINK
- Plenum was plugged..but
- Struts ?????
- Bleeding the coolant
- Difference between two Heated Seat Switches
- off topic, but german car related, "what's it worth?"
- Looking for inner CV's, 1995 A6, AT, NQ
- new car question I know its off topic....
- Stiff Clutch Pedal
- 1992 Audi 100 'Busted Timing Chain'
- Replacing the TPS on the Throttle Body
- When it rains it pours (in the car)
- tap1 chip
- got a Bilstein engine flush today.....
- Won't start when hot
- Location of chime for leaving lights on
- can I find the clip that holds low beam headlight in place on early 1997 A6 ?
- 1997 A6 - is this the correct model Forum ?
- will the S4 factory wheels fit on the 95 A6 quattro?
- speaker question
- SMOKIESMAN, The drive shafts have just been delivered
- Temp Control Flap Motor Replacement Tip
- Automatic Trans Fluid Service
- A6 Radio Replacement
- 1992 100csq door trim
- replacing coolant
- Hey Smokey, can I have the right-front hub?
- Fuel Sending Unit 1993 100Q
- '97A6Q Noisy Blower Motor/Fan
- TB covers removal
- Headlight Lenses - Glass or Acrylic?
- Oil Leak on 95 A6 Quattro Wagon
- off audi topic advice other brand vehicle
- Driver's side tweeter stopped working
- Looks like I've got a leaky rear diff seal passenger side. Any idea how involved it is to...
- What I leanred on Friday
- exhaust diameter
- No coolant flow - Water pump or thermostat
- How many quarts of oil for my 94 100cs tranny and rear differential?
- unlocking the door!
- Happy Thanksgiving Day everybody !!!!! Thank you all for your help!!!
- Front Brake Calipers !!!
- Anybody have a problem with windows frozen shut..
- DAY
- HEATER CORE!
- Cheap question, don't laugh
- Headlight washer problem
- Audi purchase
- Cambelt Emergency!!!! V6 2.6 A6
- OK here's a new one.
- CV Boot or Joint replacement?
