PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Anyone with an Avant know what the SCSI-looking connector is that is in the...
  2. Oil Pan Gasket Replacement - 95A6Q5M
  3. Pinging @ 1/2 primary throttle. 95 A6Q New ACDelco Rapidfire 9's, p&p: tb, intake, maf, and...
  4. Oh hai. I just bought a flood damaged S4. Can one of you sell me an
  5. vacuum line diagram?
  6. Anyone know where I can get a new HU
  7. Are late 1996 and early build 1996 A6 ECM exchangeable??....i think the answer is no...
  8. windshield washers
  9. Waterfest 14 Gallery is live!
  10. Hello all...
  11. Anyone have a current post of how to change the blower motor? YES i have searched...
  12. Old Audi Keyless Entry...
  13. GT1
  14. Anyone have or know of a 96 or 97 A6 parts car...need engine ECM
  15. 'Tools' Section added to the 100/A6 FAQ...
  16. VAG-Com
  17. Towing electrics
  18. 1 of 3 things.
  19. so C4 A6, turn car on..RPM's drop completely, oil light comes on, put car in D kills car.
  20. Lowering my C4...Should I install the 13mm rear spring perches?
  21. P/N for Interior Dash Lights? (Speedo) specifically..
  22. I want to put a Manual trans in my 97 Avant?
  23. what's the deal?
  24. Awful noise just started happening from Transmission in Park...
  25. Rear brake procedure for 97 Avant quattro?
  26. wtb 1989 audi 100 steel rims
  27. H&R's website only lists springs for FWD cars. Do they make 100Q springs? Where to buy?
  28. FS: 1997 Audi A6 Quattro MINT!!!
  29. Detailer's Domain: Waterfest Special only 4 days left
  30. AC question
  31. Parts for sale
  32. How swappable are the ECM's...Will any 12v work or should it be within reason....
  33. Lower Control Arm: Anyone ever heard of Karlyn brand?...
  34. Camshaft Position Sensor
  35. Update to 205k and headgaskets are blown
  36. Heater core replacement and a tip of the hat to Austinado16
  37. Bye bye A6
  38. Yesterday is precisely 3 years since I bought my car!!
  39. Avant tailgate handle / latch not releasing
  40. vibration coming from the rear Audi A6 2.8 quattro 1996
  41. FS locally. 31k miles, red, avant. Not mine
  42. If radioator fan's not working does that casue coolant lose?
  43. S tranny conversion i want the power.
  44. What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
  45. ignition timing
  46. Need help to replace timing belt on 1992 audi 100
  47. 205k and looks like the headgaskets are blown
  48. Very odd- Anyone else notice this?
  49. ~Nate the "Rare Florida Native" Still have cig lighter for A4?
  50. Open headrests??
  51. rear passenger oxygen sensor location/procedure?
  52. Radio
  53. 92 100S Bog
  54. Friday Video: Audi 100 Commercial
  55. Window cable
  56. so I blew an airbag last night....
  57. so Im not stressing the CC's anymore for the time being......
  58. Just scored some '92 S4 Springs. Some questions.
  59. A couple pics - black and white ;)
  60. engine swap for 1995 audi a6 quattro
  61. camshaft seal
  62. Key Reprogram - 12v.org procedure
  63. My front suspension is beat. Anyone know if this is too good to be true?
  64. Cheap headers
  65. OMG are you serious ?!?!?!?!?
  66. Long story, A/C advice needed
  67. My favorite route in the morning now has some bad memories
  68. Just thought id stop by....
  69. psoted in car audio too but need a fast reply.
  70. bored at work today. any hypotheses about how this could happen to a car?
  71. Formal introduction of my latest project. VW content...not Audi.
  72. Cruise Module
  73. Replaced the outer CV boots today. Thanks for the help Daveinsaltlake
  74. 92' AUDI 100 - Car takes 15 seconds to get to 30MPH
  75. can you turbocharge an audi 2.3l 5 cyl.???????
  76. camshaft seal
  77. Rubber flaps behind radiator area.
  78. Is the radio info (RDS) supposed to show up on the heads up display '97 A6
  79. radio/sound system electrical gremlins
  80. Recirculation flap and A/C
  81. Fuel Guage adjustment?
  82. A6 advice
  83. More cr@p quality new parts
  84. Guess what I did this weekend
  85. Diagnostics from climate control unit?
  86. Gear position indicator gremlins
  87. Gentlemen, looking for some minor things....
  88. New Wheels....C5 4.2 sport Fat 5's 17x8 forged alloy
  89. A/C problem
  90. Musings on an A6 trip computer upgrade... (longish)
  91. Thinkning about picking up a cheap A6 5spd, few questions
  92. V35 coolant fan info request
  93. pearl 100 parts
  94. Favorite tools was fun --- How about "favorite mechanic's tricks".
  95. Aftermarket cat converter experiences
  96. window
  97. Is this a good offer...
  98. does the wheel bearing press out from the inside or outside of the streeing knuckle
  99. Ignition switch replacement
  100. Clutch pedal is not firm after master cylinder/hose R&R
  101. oil recommendations
  102. EGR Testing
  103. Ok...what steering wheel can I use?! I've look for jah sake!
  104. FS: S4 Projectors
  105. Added steering column switch R&R to the 100/A6 FAQ...
  106. New wheels!
  107. mmm....picked up some C5 4.2 Fat 5's for the avant....can't wait to mount em.
  108. Sunroof motor gear -- 95 A6
  109. A Good Top Radiator Hose ?
  110. So I blew up my mower today.. but the cars are still running so its all good
  111. Coolant reservoir plug missing?
  112. Hi everyone finished my top gasket
  113. Looking for RR bulb holder for 97 A6 Avant
  114. Update: A6 Avant hatch problem
  115. anyone know how to remove one of these? Ignition lock reader
  116. A win for the little guy....pun intended.
  117. Anyone here with a C4 A6Q Avant from NY visiting pittsburgh?
  118. Need input guys! 17734 knock control code---Thnks
  119. rear window switches inop
  120. Found, belly pan for '92-97 C4....
  121. Rear window auto up
  122. Help! Radiator fan switch
  123. What are your favorite tools?
  124. Engine does not start while warm...
  125. Colour of CPS wires
  126. anyone here running tires filled w/ nitrogen? ....'curious george'
  127. Interior lights not turning off, no beep when locking...
  128. Anyone parting out an A6? I may need a couple things...
  129. Avant Rear hatch problem
  130. I hope the new AudiWorld Forum format doesn't affect our FAQ...
  131. Don't know what to do???
  132. I've still got a fender to fix but here's a sneak peak at my next engine project....
  133. Mann Oil Filters FS
  134. uhm finished my top gasket replacement
  135. I came across this car a while back
  136. Is there a write-up for front inner control arm bushing R&R and strut replacement...
  137. Need a switch (turn/cruise/lamps) for 97 A6 ...
  138. My new sig pic.
  139. So I'm driving down the highway...
  140. Mmmmmm...
  141. I'm wounded....
  142. 2 things i wanna do, but need info...
  143. How to replace the ignition lock tumbler?
  144. Climate control frustrations
  145. Anyone have a spare drivers turn signal?
  146. $396.00 to replace (1) one wheel bearing.... am I the only one that thinks thats funny..
  147. Does a leaky heater core ALWAYS leak into passenger compartment?
  148. DaveInSaltLake - Thanks for the junk yard heads up
  149. Radio removal tool - does this tool look right? (95 A6)
  150. ATF and Differential Servicing - Fluids
  151. favorite topic: what is going to be your next car.
  152. Anybody have the stock headlight harnesses to a 100 laying around?
  153. cruise issues
  154. Metal rattling noise on right turns
  155. Antena Question
  156. Remote upgrading??
  157. Burien, WA - Audi Expo - June 28th - Who's attending?
  158. Portland, OR Craigslist posting
  159. Picture Tuesday
  160. Selling a few parts on ebay....
  161. How much freon R134a: 750g (manual & Audi tech Bul.) for 100/A6/S4/S6 since 10.92
  162. 1993 Audi 100 CS - How to open the hood? Bowden floopy can't pull enought
  163. CNG conversion - Is this a viable alternative?
  164. timing belt service: 12V vs 30V...compare and contrast
  165. coolant leaks from the expantion tank.
  166. Part out of sell??
  167. 1993 Audi 100CS Q what freon it has: R12 or R134a?
  168. Anyone in Michigan looking for avant parts?
  169. Codes Pulled Today...confusion continues...
  170. How do I get this trim off to replace? See Picture...
  171. a6 tranny problem
  172. Where is my starter
  173. Need help, hit a deer....
  174. Sourcing plastic gas tank.
  175. Just got my thermostat swapped out w/o removing the t-belt w/ pics, enjoy!
  176. I would like to do some more maint. on the A6.
  177. Here's a new one on me
  178. Secondary Air Injection Issues
  179. bad injector or leaky head gasket
  180. Selling the 97 Avant Quattro
  181. Some parts for sale - Cheep
  182. Wanted:1994 Audi 100 CS Q wagon Rear Lid
  183. Got a switchblade for the 97 avant, programmed and all...now can I do windows up/down from key?
  184. no more overheating, but we have a mystery problem.....
  185. too much for this S4 passenger to handle?
  186. Do i suppose to have any indicator for the cruise control when set?I have a '94 100cs Q.
  187. need a new Ac Compressor for my 95 A6q 2.8 avant
  188. Quick solution for Power Steering Pump whine.
  189. Selling my FWD.... AIming for a Quattro...
  190. '92 100S overheating
  191. mmmm.front fogs
  192. Anybody have any luck with a FWD car?
  193. Vibration coming from the rear
  194. No airbag light
  195. Thanks Squirt-Tortuga - BB Up and running!
  196. Thanks Squirt-Tortuga - BB Up and running!
  197. 2B or Not 2B...aka Believe Bentley or not Believe Bentley
  198. Took a little trip in the A6 this weekend.
  199. burning oil
  200. starts - won't start - starts...95 A6 - any help with DTC?
  201. Serpentine Belt & Tensioner Kit Part Numbers
  202. 24 HOUR FATHER'S DAY SPECIAL 18% OFF
  203. smoking 2.5td
  204. A good hydrogen or Brown's gas link.
  205. any one have thermostat chang out instructions?
  206. system burped, still overheating
  207. My local junk yard just got a 92 100 Q Avant in.....very sweet....I asked if he would....
  208. Choose 230 mpg Hybrid or EV - Anyone seen the Aptera? I'm putting my order in
  209. Need help removing inner CV, please!!
  210. SOS Please Help Me
  211. What side is fill port for transmission pan supposed to be on?
  212. tightening torques and thread locker
  213. overheating....still
  214. MAJOR problem
  215. "Hidden 5th Bolt" AFC engine
  216. Would an auto trans from a '92 100 S 2.8 bolt up to a 97 A6 2.8 Auto?
  217. Brake Pad Suggestions 95 A6q
  218. ByPass Valve
  219. Lower control arms/suspension
  220. Anyone have Tom Saltino's email? Lost it and need to contact him, thanks.
  221. Oil pressure switch - brown or white?
  222. So with rising fuel prices, at what point do vehicles powered by various alternative fuels become
  223. "T" minus 10 days and counting to 2 years of ownership. Thanks for all the friendship & help!
  224. 3rd Annual Colorado 14er Climb!
  225. Any special goo needed for Valve cover Gaskets??
  226. Spot the difference - MAF?
  227. GPS Mount ideas
  228. Audi Expo 2008 - It's almost here!
  229. Car start difficulties
  230. I Need to replace my Brake Booster Can you Help me?
  231. Odd oil light behavior...
  232. I turned on my AC and got no air from the front dash vents...
  233. Is there a gasket between the flanges on the exhaust behind the cats?
  234. Nice Ebay Score
  235. Slightly less Embarassed now...
  236. More C4 painting fun....
  237. DaveinSaltLake, which junkyards do you frequent?
  238. Reverse lights on constantly on 97 Avant
  239. ECU Failure Update
  240. This is embarrassing...
  241. OMG.
  242. oil leak
  243. XPost: Revived the Pearl Paint on the A6Q yesterday. Car looks pretty good for 11 years old.
  244. Cutting stock springs
  245. Nightmare 12V EGR passage cleaning marathon
  246. Latest spark plug recommendations? I have no idea when they were last changed.
  247. who's got RS6's wheels on their C4 avant?
  248. 92 audi 100 ABS light
  249. Additional Shifting Issues
  250. Secondary Air Injection Insufficient Flow Bank One
