PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Looking to purchase '96 A6 Avant
  2. RE: Need help....
  3. clonking on full lock left and right
  4. Just wanted to say....
  5. Overheating Problem......After changing O2 sensor
  6. Bentley - Support
  7. Custom Exhaust For Audi 100
  8. SQEEEAK!!! Bushings, control arm, camber link?
  9. Need part number for driver side Headlamp washer nozzle
  10. anyone wants a set of four new NITTO NT450 205/40/16 83V tires? only $200 :)
  11. How necessary is having Ross-Tech for a transmission filter and fluid change? (long)
  12. All-Road Wheels
  13. Help with sun roof
  14. As far as wheels go for a 93 100s
  15. Best place to get E-Code's for my '91 100.
  16. Thermostat Replacement
  17. Building a VAG-COM RS-232 => ODBII Connector ??
  18. bentley cd rom
  19. '93 100cs needs new tires
  20. Need spec. for G92 potentiometer...
  21. 1991 100S Front Wheel/Brake Squeeking
  22. MikTip...are you running the Nology wires?
  23. Fishing for someone parting out a 92-98 A6 *Avant*...anyone?
  24. anyone selling...
  25. what are the best rear speakers...
  26. leak in hose
  27. Hey, 93100q (Jody), have you had a chance to get a pic of the relay (for the APS25) ? Thanks
  28. Light happy
  29. Sales advice needed
  30. Florida Folks: Audi A4 Speed World Challenge Tech day at Shelton Audi - Saturday, March 8th
  31. Old 100 2.8q - fuel pump....
  32. Pesky O2 Sensors
  33. bose cd
  34. Wooooo WOoOOo!
  35. Anybody have rear bottom out with eibach bilstein combo?
  36. performance poll. What is the highest torque/HPs acheaved on 12v/AT?
  37. ignition wires
  38. 2nd hand rims
  39. Dexron or other ATF for VR6 Passat
  40. Turn signal bulbs for clear corners?
  41. Food for thought.... (purely for entertainment value)
  42. Overdrive/D3 "slippage" on 1993 100S
  43. Rear Trunk Light
  44. looking for set of 10spoke wheels 5x112
  45. Buzzing sound during take off!!???
  46. General question ?
  47. How to convert IR system to RF
  48. Anyone want my old stock cooling fan setup.. the passanger side fan works fine.
  49. *NEW* 12v v6 2.8l
  50. Cruise Control '93 CS 100
  51. Climate Control Trim
  52. 95 A6w alarm nightmare
  53. My stock cooling fans were on ALL the time what do i need to replace
  54. Replaced front cooling fan with 1 big 16 inch proform fan
  55. GOD help me plz, EGR system - Not Ready
  56. 18" Moda R6 Wheels. Will They Fit?
  57. Re-post continuing old thread on replacing IR remote keyless entry with RF - 93100q, ARK?....
  58. Rear brakes and that special tool..
  59. Remote Fob Programming
  60. I recently installed bilstein/eibach combo all the way around and... (more inside)
  61. 1989 100 Quattro
  62. Timing Belt Covers - Removal?
  63. shudddddder
  64. Has anyone tried Stainless flexible brake hoses?
  65. Whoa! weird. is this normal? (Brakes)
  66. 92 100 armrest woes
  67. Strut Life?
  68. Yay! Got the first call from a buyer. I'm showing him the car tomorrow... any pointers?
  69. Anyone want to trade an Avant for a nice '90 V8q
  70. Would people be interested in a custom suspension kit for 95-97 A6Q
  71. Got that pesky o2 out!
  72. How much room is there under the trunk of my 95 A6?
  73. Purchase of '97 A6 Quattro Avant
  74. I ordered my A8 rotors from stoptech.
  75. is going from 205/55/16 to 205/45/16 makes much difference (car is not lowered)?
  76. Neutral safety switch replacement Question. Is there a adjustment? My symptoms are...
  77. Wheel bearing tools
  78. Do you think installing Nitrous Oxide on my 97 A6 2.8 12v would kill my engine? I need more power.
  79. Ok. Here she is repainted. Had to post this guys to hear your opinions...
  80. My cabin filter didnt come with instructions another Dealer blunder.. can anyone post them.. thanks
  81. o2 sensor extraction problems!!!
  82. Converted the remote to RF in my 93 today
  83. AHA! The strange noise coming from the back wheels is a bad wheel bearing, not a brake issue.
  84. RE:Beep-Beep, I checking if polen filter is present...
  85. Enhancing the life of auto trans
  86. Couple GOOD questions
  87. different tires
  88. DID IT! Servotronic is now history!!!!
  89. heheh.... I can now easily detect <97 vs. 97 A6's....
  90. has anyone ever tried removing cruisecontrol lever from the steering wheel? how hard is it?
  91. Check engine light woes (long)
  92. Power windows and sunroof not working
  93. Could someone post a picture of the front of a 95-97 S6. Getting a new front bumper.... (more)
  94. Need location of Servotronic relay
  95. Okay, I think my ECU is failing. I'm either going to need a Stock ECU or an Aftermarket performance
  96. Help - Brake Problems! Does anybody know how or what the Brake Pressure Regulator does?
  97. brake upgrade progress
  98. Are taillights interchangeable between Avant and Sedan?
  99. does anyone have REALLY REALLY SLOW WINDOWS?
  100. climate control woes
  101. oh yeah, my cruise control doesnt work either. When I push the set button...
  102. O.K. got the two tools for timing and ribbed belt replacement.
  103. no heat!
  104. RE: 1992 100 AT/FWD, transmission will go bad soon. Need
  105. A6 Sun roof Issues
  106. I have installed polen filter.
  107. H&R Springs Does anyone have any Tech info on changing the springs?
  108. subtle jostle from right front tire area
  109. A6 starting troubles
  110. Damn snow/ice. Any ideas where one can get a 95 Avant RR door (complete)?
  111. New headunit finally installed! (gamma radio available to someone who wants it)
  112. Serpentine belt (multibelt) change
  113. 100S acting up...vacuum leak?
  114. where's the article on aftermarket keyless entry for about $40?
  115. car runn ing cool
  116. SpedhedEd: Many thanks!!! The headlight removal link was a lifesaver.
  117. CD Player and Hubcaps for 1992 Audi 100
  118. Bridgestone Potenza RE950: Impression
  119. Changing the MT gear oil
  120. parts for your AUDI
  121. damn this car is sweet. (100cs) what does a turbo feel like?
  122. Clonking noise on hard accelerating !
  123. 96 A6Q Not sure what the issue is.. Struts, Tires...
  124. Wou just can't beat the price for this. I understand this is a set...
  125. Gear shift vibrations
  126. Can a rear caliper seize up intermittently?
  127. Custom Exhausts on 100's...
  128. RE: Help,,, someone with benley , need to know ...
  129. Side View Mirror Replacement
  130. and my accelerator pedal came off when 8 million degree H20 poured on my foot from heater core leak
  131. Right on!, another ?. whats the largest tire diameter and width I could install on 92 100cs?
  132. Window Machine Gun noise.
  133. o.k.!, so I have some money, about to take care of me car.
  134. Air injection pump...
  135. Anybody unhappy with the way the tail lights light up??
  136. f-ing trucks/SUVs
  137. did anyone catch this story? What do you think? (click on the links to go back to part 1)
  138. MikTip - Can you help me?
  139. Heater unit HELP!
  140. Getting a new front bumper and need some advice... (more)
  141. Car shipping companies?
  142. Miktip: Tell me about your motor!
  143. I had spent this weekend at Killington.
  144. General Questions - Not really audi Related ??
  145. Interesting
  146. 2nd Gear GRINDAGE
  147. not worried about money, just want to drive while I'm alive
  148. Power Steering Fluid Leak... Where is most likely source?
  149. Anyone replace there pressure relief valves under the valve covers?
  150. My review of the Chicago Auto Show
  151. Battery doesn't hold charge
  152. 89 100 quattro driver side mirror doesn't move
  153. Headlight removal
  154. 16" wheel lug covers
  155. I dont care what you have you are not getting out of this snow..
  156. European Headlights on a US 100?
  157. wtf! is this fo real? did this ever come out? (A8 coupe)
  158. Tools in a can !
  159. Wind Noise
  160. SNOW!
  161. Hey audijim113....question for you on AC clutches
  162. Advice on clear corners for the 92-94 model
  163. Once and For All, Will the SGI Kits Fit our American 100's?
  164. will this fit in trunk...
  165. I wish I had quatro...
  166. low temp and poor gas mileage?
  167. Dash Lights replacment
  168. tail lights
  169. Changing out the Gamma radio
  170. Nooooooooooooooooooo!!! My oil pressure is falling!
  171. DEQ and Oregon.... well, and my parents car too!
  172. Problems with fans/heating
  173. mechanic gave me update...
  174. Is there a body kit for 93/94 100cs or 93/94 s4????????
  175. 96 A6 CD changer connector?
  176. New 3.0 A6 Big Improvement!
  177. A8 brakes: Anyone installed them on a 100?
  178. Choices for suspension?
  179. what's this worth?...
  180. Screeech! When I Start the 92 Audi 100
  181. Need some info
  182. 96' Audi A6 - Cable for audio system?!?
  183. What would you do to a 92 100cs w/ $2800 for mods ?
  184. Poor Audi TT drivers
  185. What are the dimentions of our radiators..
  186. Climate control on ebay
  187. Yummy!!
  188. anyone running 1 15" in trunk? if so how big's enclosure?
  189. diagram of rear bearing removal
  190. Timing belt retensioning?
  191. Continuing the "rattling on cold start" thread below, I spoke too soon.....
  192. New Grill Pics!
  193. Fuel pump location
  194. Redline MT-90 or MTL?
  195. If your last timing belt change is suspect on a purchased used car
  196. Petty rattling noise question
  197. I am buying S4 rear brake calipers
  198. Wiring diagram for a '95 A6 w/ auto transmission
  199. Car won't Start... Help!
  200. speaking of sucks
  201. Jersey City roads suck...
  202. Survey - Cold Start Noise - Rattling/Clanging - Not Lifter Noise
  203. ?. does a FWD 92 100cs have a rear differential?
  204. Audi refuses to fix mt timing belt cover and says that there is no benefit to it..
  205. So does A6 has a polen filter or it does not.
  206. rear wheel bearing replacement advice
  207. TRANSMISSION AT TO MN
  208. ISV Again?
  209. Well i think both my rad fans went.. because they are very noisy now.. time for the BLACKMAGIC fan
  210. SPORT GRILL, or new audi grill.....
  211. Auf Wiedersehen Audi from "Der Teufel"
  212. Overheating - fan stops working
  213. body styling
  214. O2 sensor socket size
  215. Car won't start. Any suggestions?
  216. timing belt, idler pulley, and water pump replacement.
  217. UrS6 interior stuff on ebay
  218. Post the sickest pics of your ride
  219. It finally happened!
  220. What would 4 Audi 100 CS 15" wheels w/ new blizzaks be worth?
  221. Another 02 sensor question. I will be installing new 02
  222. 94 Audi 100 S Batteries Replacement
  223. Why do I let my wife drive my car??!!!!
  224. How much have you paid to get your CV boots replaced? (pair)
  225. Alternator
  226. Rad fan always on
  227. engine clanging
  228. Sunroof question 96A6Q
  229. Anyone know where the vheicle speed sensor off of the computer is?
  230. A6 1994 Key re-program?
  231. Heard about 2004 S4?
  232. Aloha, one more thing...sort of loud tire hum..?
  233. Aloha, novice but stoked owner in need of help
  234. brake noise
  235. Transmission problem
  236. I am fed up with my Audi dealer...
  237. 7cft box in trunk??
  238. S6 on Brooklyn bridge 1hr ago
  239. where can i find 170 amp alternator?
  240. Audi Driving School, March 8-9
  241. Audio question...
  242. I need fog lamp cover!
  243. RE: 92 100, windshield viper reservoir does not....
  244. Lower? or not?
  245. Question for Gamma radio owners
  246. Getting ready to install Fog Lamps this weekend.
  247. Fenders
  248. 2nd alternator help...
  249. 1992 AUDI 100 FOR SALE..EBAY
  250. huge brake sale today...brembo and remsa gold pads
