- How to install window switch
- My heat is not very hot, any thought or solutions?
- FYI - Bentley 3-volume Repair Manual up for sale on eBay (no relationship to seller)...
- having trouble removing rear brake calipers
- Cleaned out my EGR (part 2)
- drain plug
- So if I'm leaking coolant and it's pooling between the AC compressor and the crank pulley...
- Outer Tire Rod
- I need a new job/career change. Ideas? What does eveyone do? Please list your careers...
- EXPLAIN..... PLEASE EXPLAIN
- I have a loud screahing when I turn to the left, 96 Avant.
- Stalled when shift to N or P from D
- stuck in park
- Sunroof raintray repair update
- Timing belt link in FAQ is down
- What's this button on my B pillar do?
- 96 in for rear brakes.
- Cheapest dealer part competition! The cashier said she has never sold anything as cheap as this.
- Heat problems in cold weather. I have bled this vehicle forever and still heat goes cold at idle.
- I read the screw fix for the Broken gas pedal But
- Sluggish upshift when cold
- Camshaft sprockets, anyone used old bolts for reinstall in 12V?
- Thought I got everything working OK, now a new problem arises....
- New radiator...
- Airbag light stays on
- VAG-Com fun
- '93 Audi 100CS Parts or Whole
- I got up close and personal with the R8 today at the L.A. Auto Show....
- eBay: CF Trim
- Magnetic Euro License Frame?
- Does anyone know if newer C5 full length mirrors will fit our C4's?
- OFFSET
- ecru interior parts
- So I put on my aspestos undies and went over to the S-car forum, and...
- xpost...I know there is some wisdom on this forum, could you guys give me your opinions?
- cig lighter shorted out?
- in need of 2.8 oil pan!
- wanted: A6 5 spoke wheel
- Goodbye for now
- Anyone parting out a '92-'97 100/A6, I need some things.
- Noise when steering the wheel
- When 19" rims aren't big enough....
- sidepipes! are you kidding me
- Window regulator cable keeps jumping over edge of track.
- Anything special I should know about changing my thermostat?...
- 96A6qa FS
- Well it's official....I've upgraded to a 1997 A6 Quattro
- New AKG radiator...
- Hey Todd, you remember how much that crank bolt cost?
- Anyone have any of the front engine plastics around? Thanx guys.
- ANyone in SE PA or S Jersey with VAG-com wanna help me out with a radio reprogram?
- 92 100S: Oil in coolant tank + no oil leaking from oil cooler = head gasket!
- Best Brake disc and pad combo for 96 A6 Q......... your thoughts please ladies and gentlemen
- Cargo light not working: common problem?
- Front suspension noise finally solved.....I think (long)
- OBDII code reader not working on the s car
- If you like drifts...wouldn't you rather see a C4 S car Avant do one?
- GOOD CARGO COVER up for grabs
- Seat skins replacement
- Cabin/Pollen Filter location (a/c model)
- yellow coolant???
- Does anyone have a pic of...
- What a drift General Lee
- To the brink of disaster and back again! (Long)
- hood strut
- axle boot replacement... HELP!
- anyone here from NNJ?
- The year has flown by...another fun year of Audi ownership and lot of projects....
- torn ball joint boot
- window motor
- Anyone removed and replace their leather seat covers?
- Help. Engine Block Heater ideas
- control arm removal
- Doors Frozen Shut
- Electric window cable broken
- Just acquired 1996 A6 Quattro Sedan need help
- look at this guy drift!
- Exhaust manifold sealing screw rusted off
- Hard to steer at idle solved
- Thank you so much for the help guys. I might just get this.
- Ball joint removal
- Coolant Flush
- brake rotors
- run in with deer.
- power assist steering
- "signing" comming from rear of car
- Cargo cover interchange ???
- Out of Topic and Brand Stupid Question...
- reliability discussion ... <flame suit on>...long
- Being that were on crash tests heres a german site, some look ok.
- possible future trouble with clutch?
- Rattle in dash...need your assistance...
- Say aloha to my new fogs...
- Possible selling my suspension setup (100 q)
- My thermostat rant
- Has a rear crash test ever been done for the Wagon/Avant?
- Incase my first plan fails, who might be able to led me & V b chill-n their timing belt tools?
- 95 Audi Quattro A6 - Oil Pressure Light On after Engine Bath
- Would the recent cold nights here in Ca. have any effect on my coolant level..? My res is down...
- Anyone here Have Koni Struts/Shocks?
- I think I have A8 envy....or something!
- It's -25C. and i smell gas!
- warining lights questions, break, oil pressure, check engine and interior lights
- Anyone parting a car? I need some rad fans
- new to the forum and could use a little help please....
- gear stuck .....pls help
- Sellin' a spare underbody engine cover and right fog light assy...
- Check engine light, but no codes? Need Help
- Fried battery.
- Has anyone ever fixed there non working power mirrors?
- Love my 96 A6 Avant!!!!
- Anybody knows part number for crush washers for fuel filter?
- Front end/steering help please
- Need 2 rear non-bose speakers
- Rough Acceleration
- Paging austinado16...if you're interested in a set of 5-spoke A6 factory wheels...
- Dave F - since '98 avant quats aren't banned......
- Centering rings question ?
- Thoughts - Air bag deployed & replaced w/ junkyard VW wheel?
- Odometer question ?
- Anyone know when Traction Control became available on C4's ?
- I'm struggling getting the second front sway bar bushing in...
- Need Rear Left Caliper
- lights for gear display in dashboard
- Happy Thanksgiving everyone! Don't eat too much and working on your cars is off-limits...
- BigMouse - you know ya want it.....
- Anybody have any pictures that show trailer hitch for Avant?
- Help with front suspension noise.....long story
- Some questions about the 12v A6 quattro
- Half Shaft Replacement
- I found a rats nest in the middle of my intake manifold.
- Did the 1998 A6 (C4 bodied) Avants have 12v or 30v V6 engines? I am getting conflicting evidence.
- WHEEL..... WHEEL SIZE
- Fix for broken map light switch a.k.a. interior light over door
- 92 100S: Fuel pump replacement...
- bought a 96avant as a winter car
- Valve Cover Leak
- Circlips holding the accelerator pedal: Reusable?
- Sunroof fixed. Thanks to everyone for all the help!
- What is the tube thing to the right of the light bulb?
- Remote FCC ID needed for 1997 Audi A6 Avant
- 92 100 S: Oil in the coolant expansion tank
- Needs light in the car.
- '97 Quattro - secondary hood latch jammed
- durability of C4 auto tranny
- Can someone post a picture of their 1995.5+ cigarette lighter.
- Thule question ???
- Audi 100 TDI 2.5 Diesel Gearbox
- Are the C4 automatic and C4 standard transmission chassis identical? What I mean...
- Getting cold out..something to think about replacing on your C4...the oil cooler o-ring
- For those that have done it, what kind of time does a timing belt replacement require? Is ....
- Do the '97/98 Avants have a transponder in the key handle for security?
- Door Mouldings... How? Anyone?
- 97 a6Q puddle behind drivers seat in Rainy Seattle..ugghh!
- Only Rear Speaker Working
- How much of a money pit is a 78K mile 96 A6 Avant likely to be? It sounds okay and ....
- So, could the oil pressure switch in the filter housing spray enough oil
- Mr. Thorn, I sent you another email but was bounced back. Do you have a 2nd email?
- Hi guys.........new forum member ;o)
- Does 357 miles to a tank sound right.
- Coolant bleeder screw
- Every thing 4 SALE~ 92 100 CS 2.8 luxury !!
- Heater Valve
- Crankshaft Oil Seal
- Sunroof Motor Cover Help needed
- Found a 'new' white 1996 C4 in my local junkyard today
- Thermostat or ECT Sensor...?
- who's had there seats redone with new leather?
- whats the worst case with a broken timing belt?
- squek in rear suspension of A6 Quattro
- Mock install -OR- I have too many parts to play with?
- Question on window switch pack on the driver's door ???
- Accelerator pedal and rear view mirrors controls light
- MIL - Chime relationship...Coincidence?
- Sunroof help
- Help.............found a pearl white .........
- Hey guys, having brain fade here...I can't remember how the wood trim around the shifter comes up...
- Audi newbie
- EDIGREG, how did your door mouldings work out? I bought the fogs off the same 100cs...
- Strut replacement hell
- KYB front strut inserts for sale
- Hood strut replacement
- I found a guy on British Ebay parting out a '96 2.6 Avant if anyone needs anything...
- BMW E34 525i Touring V.S. Audi C4 100/A6 Avant
- Loosen cam sprockets or else
- water temp prob.
- headlight relay
- CD player 8-pin on eBay, cheap (not my auction).
- High beams
- Timing Belt Tools
- 1992 100 keyless remote
- Front ball joint question...
- Exhaust Gasket ??
- Antifreeze Leak
- GONE
- Looking for a good left inner tail light
- 77 degrees on Wednesday, 12" of snow on Friday!
- Ign Switch going??
- Trouble...
- Fresh oil or friendly oil
- Any advice on getting the ball joint back in...
- European spare parts dealer?
- Looking for floor mats grey/platinum or black
- New Yahoo group for Portland, Oregon
- 200,000 miles.
- Rear Cargo Cover on eBay
- Quattro owners FYI: The sway bar must be disconnected from the control arm...
- Owners of 1992 Audi 100
- Is there a upgraded front control arm inner bushing, like the Delrin for the 4kq's?
- Airbag Light
- Re: Factory Audi A6 wagon ski racks
- Dumping fault codes without VAGCOM on '92 100S
- 1995 A6 quattro transmission mystery??
- strut
- Strange Hiss
- 1992 100 Radio always on
- shudder in fast corners
- Front end steering pull
- Is there a part number for the seal around the sunroof?
- Camber plates
- Oil Leak?
- Something shiny and new under the hood :-)
- How would these wheels look on a 96 Pearl white Avant?
- Just bought a sedan. Need trunk carpet & inboard tail lights
- DaveinSaltLake, email me. I got something that might interest you...
- Gamma Radio & Side view mirrors...
- OBDII / Door lock issue
- air from dash vents only!!
- Exhaust leak ?
- Anyone have used lowering springs for sale or know where to get some?
- Lister from the 4000 forum with a C4 question...
- Interchange Questions ???
- Has anybody installed the Bilstein PSS9 suspension kit?
- Can somebody hook their AM antenna to the FM input on their radio for me?
- cannot change the temp
- Anyone here have any EXCELLENT CONDITION RF door hinges??
- Concert Radio Question
- Driver side connector
- starter replacement on 96 a6 12v quattro
- Won't stay running. HELP!
- Anyone have experience with the WorldImpex 'German' radiator?
- Did the A6 ever come with 15" steel wheels?
- >> Please help my lovely 92 100 CS~
- How much does a Seidl bodykit cost? What do you guys think I should do.
- Maintenance Steps 1997 A6Q
- OBD Question - Air Conditioning
- Air Conditioning Question
- 1992 Pearl 100 in my Local Junkyard
