- Bose radio code for 96 A6 Quattro Wagon?
- Private mechanic in Greenville SC?
- Looking for Audi 1993 CS100 Steering Rack
- Eibach & Bilstein combination installed
- Dumping the codes.
- European or S4 Headlight upgrade for 92 100 S
- car wont driver slower than 130mph....
- Mikesho, I cant seem to get...
- check engine light...
- Any good "Audi shops" in the Cincinnati area?
- 500 K miles + audi cab
- 100CS Wagon Rear Seat Belt Extenders?
- Project: Reading Lights
- Looking for a decent Audi/VW garage in Chicago
- Anybody is selling a 92 A100 pump to steering rack hose?
- 95 100/A6 hesitating and engine judder
- Instrument cluster for Sale!
- Car accident
- Fuel Pump
- 1992 Audi 100 Audio questions
- do i have an angel?
- too lazy to check, anybody knows?
- Paging Mikesho
- won`t start
- Replacing the starter...
- Front suspension question>>
- Car running hot?
- Wipers too slow on 94 100S, what could it be?
- hey cuatrocoop....
- How concerned should I be about this?
- Does anybody know what 2.5" straight pipe for custom exaust will cost+labor for new cats&muffler
- EGR
- New Tranny Needed.....
- Some instructions and more information regarding the cabin filters for our models
- The man in brown might as well been wearing red because it was like Christmas today when my brakes
- how much power should my radio get?
- Anybody want to take a rough estimate at this?
- oil pressure gauge is messed up.....
- Looking for plastic piece that holds sunroof controls...
- Light bulb replacement
- Sqeeking Fronk Brakes
- went through 100000 miles today :(
- Checking Automatic Transmission A6 1996
- anyone invoke warrenty on 10yr. perforation??
- Tranny Troubles!!!!
- Canned response is where?? I searched and found:
- Audi A6 2.5L TDI (AEL engine)
- Light Bulb Question
- Procedure for buying and replacing o2 sensors
- rewired my radio today
- 1996 A6 Radiator Fan not working
- faulty warning light
- parts car washer pump
- I replaced the headlight lenses with ones ordered from Blau.......
- hot air
- Bulb # on shift indicator in console
- Silicon on CV joint boots
- We are now officially the '92-97 100/A6 forum! No more type 44 talk!
- Paging: All!!! car sputter when acelerating around corners or starting from a stop
- what's the procedure for replacing fuel filter?
- need help with inside pass. door
- Taking the car out for the weekend...
- 1992 cs100 quattro wagon sluggish???
- Intresting article "Confessions of a Car Salesman"
- I want these lights
- Loud clicking coming from drivers footwell at idle sometimes
- Looking at '94 100 in Mpls. - advice? inspection?
- Both the reverse lights and rear fog lights are out. Coincidence? Or Conspiracy?
- Transmission cotrol system...
- Air filter type
- Fuel Pump Relay/Fuse 94 100CS
- Sunroof Cover and motor 94 100CS
- Transmission Rebuild Prices Needed!!!
- One touch down/up windows
- Want to change oil for manual transmission and differential. Questions about plug sizes and oil:
- 12v.org
- ELECTRIC SCHEME
- Alright... friend of mine looking at getting rid of his Jeep for an Audi... (details inside)
- Help How do you remove P/W switches 100CS
- air cylinders?
- Aftermarket headlights...
- Help! - '96 A6Q A/C won't C/A...
- Back Speakers dont work
- J-E-L-L-O!!
- Cluster Display Question...(more)
- Brakes and Shotgun in the '95 A6 Beast
- Re: Shopping for BMW 850 as a toy car. Anyone know...
- Sunroof Switch Cover keeps falling off. One of the ...
- XPost to Pearl White touch up spray question in detailing.
- Question for Muhammad regarding oil pressure warning
- Hoo Ah! I can now read the climate display
- popping noise
- power steering leak.....
- Made the switch from A6 to A4 (more)
- No Air will Come From Center Vent??? Please Help
- MikSho, could you please expain DEPO headlight installation
- Rotors
- Auto shifter selector light in Center console 1997 A6
- Why is the wiring different in euro stock headlamps? Very confused how to install them...
- new car?
- '97 A6 Quattro Oil Change
- Fluid change Rear drive diff
- Paging MikTip...quick question about the clear corner bulbs
- 100000 miles?
- 92 100s throttle body
- Where can I find clear "euro" turn signal bulbs for clear corners? No luck with searching
- 94 100CS Fuel Pump
- Oxygen sensors
- Creaky front right side of 92' 100 S
- Low Mileage 97 w/ high hours, Trans?
- Follow up on reverse lights
- Cabin Air Filter
- 92 100s washer pump
- 100s chips
- How many valves on 92 100s
- Audi A100 CS Sun Roof
- Repost: Blacked out grille pictures...
- How to replace a bulb
- 123456
- New member looking for help
- 97 A6 Avant Quattro 96k miles $11000 do you think i should buy?
- Where can I find the paint code on my car?
- question for MikTip
- How do you remove the headlights on a 100...I cant seem to figure it out...
- Debadged, left yellow ghost, suggestions?
- I remember somebody on this forum selling black leather seats; are they still available?
- who said, that A6 has bad brakes?
- 92 100 S Rear Fog Light and dummy switch
- 92 100 S Headrest moves
- Thanks everybody:I replaced the CV booth with the info from this forum;saved 1 week beer money.:-)
- ABS kicking in at low speed
- Steering, self-centering
- A6 front seats
- Torsen explanation
- Ignition Failing
- strange electrical problem
- Here is someone with less luck than you B-SK 1982 , a nice story!!
- Removing screen in MAF??? I read this in another article...
- Evaluating possible purchase of 92 100CS
- What make/model oil filters are you using on 2.8L 12V?
- Air Conditioner Filter
- Howdy. Anyone have pics of the steering wheel(s) for a 1994 100cs Quattro? TIA
- 1993 100csq rims need: 17x7.5 with 40mm offset? what exactly do...
- Rear Speaker Problem
- Radar Detector
- anybody ever use paintscratch.com? I did and have some questions
- CV joints
- Strut mount question.
- 97 A6q camber aligment?
- HAPPY:Just bought A6Q 95,128 kmi, manual,winter pack, Alpine 6CD, cloth,v.good cond.for $4800 :-)
- Looking for a used winter car...need opinions...found a 100csq with 156K miles...
- Odd result to engine temp. after oil change and part change.
- Vag Com on "mar. 97" A6 2500 TDI Avant
- F**** me......car might have died today.....need help
- Newbie here, where I am with the A-6
- getting close to 123456 miles... the day ended with 123435
- Front Stress or Sway Bar for 1992 Audi 100 S
- How do I remove panels inside of my '91 100
- Rpm and Kph run out. Anybody knows why?
- Starting to think engine mods are of no use on the 100's...please make me feel better
- 1994 100CS ECU and/or TCM problem. Engine turns off while driving!?
- 1993 100 CS Wagon
- Some food for thought for you guys.. regarding O2 sensors
- 100CS Euro-Light Upgrdade -oem sensor still active
- Hi MikTip, I'm wondering which high flow cats off...
- Found A Red A6 Fredericksburg, VA
- Anyone Know of a Good Mechanic in St. Louis?
- Please Help- '92 100S Intermittent No-Start
- Just got headlamps off importvision, what are the best bulbs to use??? Thanks!!!
- does anyone have a shematics of an 95A6Q?
- how to get ashtray out of 92 100 CS? Crowbar?
- radio kill switch?
- 2x2 connector on 93 100CS
- Dash lights dim at stoplight, then brightened when going again.
- 96 climate control temp display. Right digit top segment not lit right top segment half lit. Is this
- Need advice buying first 100
- 95 A6Q aircon
- Radio Code to unlock?
- Air Vents Problem
- losing power......
- Do you need anything special for the headlights of importvision?
- What the dealer mechanic was looking for on an A6 I sold over a year ago
- Would lowering the car be a problem when driving in snow?
- Back Speakers
- Does anyone have a vacuum hose diagram
- high pressure hyrdaulic hose leaking. easy to replace?
- Any ideas on cause of wheel squeeking?
- flickering brake light
- another way to improve brake fade resistance
- cumber plate failed again.
- Oil leakage in valley pan
- They shut down your web page B-SK 1982?
- Steering Rack ?
- How hard is it to remove the power seats?
- 12v development
- procarparts.com is the worst
- Some cone filter information for anybody interested
- Engine removal proceedure ANY BTDT???
- Whats your opinion on rims?
- boo-hoo
- A/C problem
- How do I check AC R134 charge???
- What do you guys think about my car vs. these two with mods
- advice anyone
- Wanna know how slow our cars really are? :-)
- Clear Turn signals???????
- 1990 Audi 100 fuel problem
- What is "Lower control arm ball joint dust cover"?
- Switch Blade Keys
- Front brake pads
- Resync remotes on 1996 A6 (RF)
- What kind of suspension are C4 Quattro drivers using?
- 91 audi transmission problem...
- tonight on modern marvels on the history channel
- carfax is teh svck!
- New Rim Pics....
- 100 2.0 E idle problems
- A6 Brakes - solutions?
- New (to me) 95 A6 (Long)
- The caliper kit any how to instructions somewhere on what to do and what no to when replacing the
- A/C high pressure switch replacement ?
- A6 BRAKES PROBLEM
- Check engine light
- a/c problem
- Sun Roof
- "Anti Lock"-Switch Audi 100
- Air/Con
- Quattro Wagon differences 93 vs 94?
- 92 100 cats&muffler
- Last piece of my A6 left... cleaning out the garage.. anyone want a set of stock springs?
- eurostyle headlights on ebay run out today
- 100s Radio Install Problem
- i finally got all my stuff together and published it on a website
- window regulator
- Anyone want to buy a radiator? early '92 100.
- How many miles do you have now?
- ordering brake hoses for the rear.... is there and inner and outer hose?
- I found a new engine... Thanks for the reply.
- Can I use Mobil 1 ATF for my A6???
- Did Audi sell any diesel powered cars in North America?
- car is shaking...
- Anyone here need a gauge cluster?
- 92 100 CS Power Stearing Fluid question
- Muhammad, I got quick question(s) about your brakes
- Trying to find 95-98 A6 Avant 5spd, having a hard time....
- DIY - Oil Change Instructions
- ok. so i am done with the transmission but now i have air in the brakes... fixed accident pics
- Used 92 100s Washer Pump
- Looking to buy a 95 A6 2.6 automatic gear - What should I look for?
