- Is there any recall on ignition switches? My second switch has now failed! Best place to buy?
- Valve Body '92 100CS
- Upgrades to a 94 100CS?
- quick survey: what usually goes bad first or need replacement on our tranny?...my A6 has 130K miles.
- Is the A6 big brake upgrade(A8 rotors + TT calipers) worth the extra $$$?
- My A6 is 10 today (aka the $58k 95A6Q)
- 3500 RPM @ 80 mph?
- Cleveland weather + Quattro driving = Not so bad...
- Head gasket or Hose?
- fuel mileage for 92 100 csq
- Chip for 2.8L?
- Looking for headlamp covers?
- close up pics of egr passage intake manifold
- Remote locking programming
- 93 100 stalling
- rear headrests
- I love this car.. But I think I must move on to a faster car - SALE
- Axels
- was someone looking for serp belt tensioner? there's one on ebay
- Directional Signal Problem, Hello it's been a while
- Odometer Stopped
- Honest Opinion
- Window problem solved!
- Looking for some opinions
- A8 Brake Upgrade
- Fuse keeps blowing
- Who has taken one head off with engine car?
- White Gauges
- One more question about bleeding brakes on 1995 A6 FWD Auto...
- tints
- Control arm bushings, ball joints, tie rod ends.....
- 94 100CSQ transmission
- WTB: Bentley manual for a '92 100CS
- What is it with the brake lines coming apart on these cars? Need help with bleeding lines...
- Battery Getting Drained
- question for people who lower their cars
- What are the signs of a failing transmission fluid temp. sensor?
- defroster not working
- 1993 100CS wont start
- 100 V6 Hydraulic lifter replacement
- Coil spring R&R and ball joint question
- Serpentine tensioner bearing?
- WTB: 92-94 100CS Electronic Climate Control Module
- 96 Wagon battery died totally from sitting for 2 days withouth driven???
- 159k
- cold air intake for '92 100s
- Audi Repairs near Phila, PA???
- any one know some numbers?
- SMOKIESMAN you still got the rims???
- problems with my 100csq (rather long) TIA for everyone's help!
- rattle from sunroof above drivers head. anyone know if something up there likes to come loose? 97A6
- rim question, please adise
- 1992 Audi 100 (not quattro) tell me about them!! !
- This sucks: my transmission has gone bad
- I really need your help guys!! shaking with throttle input
- Newbie with questions
- greetings from 80/90 land. was wondering if ne1 has a spare TripComp from a 12v 100.. actually I'm
- anyone w/ FWD want to lower their car, have H&R springs
- Disabling the servotronic...
- Which Tech Article should I follow to replace rear brake pads and rotors?...
- Audi grille for sale
- Farewell to my trusty A6
- '93 100CS (A6) Quattro Wagon, tranny fill amount needed
- Gas Type
- Grinding from rear end !
- Audi injector recall Code KS
- Heater blows luke warm air even when car is warmed up.
- Thermostat stuck open?
- couple ?'s
- tow hitch pics?
- Wheel bearings
- Door remotes (again!): deeper problem
- Mirrors
- headbolts? avoiding warping and buying new bolts?
- 96 A6 Wagon Ignition hard to turn from lock when cold - Fixed
- need some new wheels and tires!!
- Does the rear differential go on Automatically?
- Answer to fan speed problem- now need part
- Strut on fire!!!
- Cooling Fans not working
- 1989 100 wagon questions
- Hmm....feels a little damp in here.....
- BOGE TURBO shocks and struts!!!!
- Auto-Check Code 42
- power stering glitch
- Exhaust color change A6
- Is this one of you guys? Near Reno in the snow....
- audi 1992 100cs power steering hose replacement
- If you had under 20k to spend---
- Just replaced thermostat on my "new" A6
- Any potential issues running Mobil M1 0W-40 in a 94' 100?
- Premium vs. Mid-grade
- Radio code guru needed!
- tracing egr pressure...
- Replace rear inner tail light lens (98 A6 Avant)
- How to tell what tranny?
- ISV - idle stablizer valve
- Clearing Codes on the Climate Control?
- Thermostat 96A6
- Brakes- sqqqqqquuuuuuuuueeeeeeeeeeaaaaaaaaakkkkkk
- Want an inexpensive, *mint* condition commuter in NJ? Click here!
- Paging "Snowman '92 100" & "SLAB" Re: blower removal...
- Transmission downshift 96A6
- Anyone have a good compressor clutch for a 95 A6? Is just replacing the bearing enough to fix ....
- Looking for an auto tranny for a '92 FWD 100.
- where to buy front grille for 93 100 cs
- looking for 2 15 inch wheels for snow tires anyone got some
- Car dies when it goes down below 1000 rpm...please help.
- Rattling air bag... steering wheel sounds like a mexican maraca. Anyone experience this? Fix?
- Are any of you in Michigan? Audijim?
- Front shock... conclusion
- help removing intake manifold
- Anyone removed their front end on a 100...?
- CD CHANGER
- CD changer or head unit replacement for 1996 A6
- Malf light question.
- 96 a6 with 110k. might buy this weekend
- Audi Parts Catalog (like BMW ETK)
- Switch Climate control to manual???
- Cigarette lighter plug not working on my A6
- wheres the fuse for the cd changer?
- Trouble with climate control fan
- Don't seem to be getting power to my seat memory buttons, lights dont work, checked fuse not problem
- Struts: DIY or Stealership??? What to do?
- Bentley CDROM
- SoCal, last chance to RSVP to "Audi Odyssey" the holiday party of the year! - Saturday DEC 4th
- Relays draining battery... I think
- Electrical Problems help
- Timing belt change turned expensive...
- I'm thinking of taking the Kamie grille off and getting a stock one again.
- Is 5bar normal while driving??
- When splicing in a new O2 sensor, should i sodier (sp?) or use butt connectors?
- water pump
- DIY Timing belt
- Just got my first Audi ,1996 A6 FWD
- 92 100CSQ Climate Control Problem
- ABS Sensor removal A6 96 FtWD
- Please Help, How to connect power source to relays and switch to H4 bulbs in euro spec headlights...
- A6 96 FrWDFront shock: followup
- Can anyone tell me if tranny fluid runs up to the front of the car for cooling purposes at all? 97A6
- front passenger speaker doesn't work but makes noise
- 100 2.3 91' Radio wiring diagram
- 96 a4 Fwd in Limp Mode what need done with Vag?
- 95 A6 Won't start cold!
- Turn Signal noise
- Cracked Headlight lense...
- Install headlight adjust (motor) to C4 from 94
- Inner CV joint gook on 94 100CSQ Automatic?
- Beeping from dash 1994 100s
- 95 Audi Wagon fuel pump location
- Screwed myself. How could I be so stupid?
- How much to have head gaskets changed at a shop?
- 95 Quattro Audio Question
- I got the list of the parts to lower my wagon and put it to the FAQ.
- No vaccum going to EGR?
- Any possible reasons that a heated seat would stop working?
- BOGE Rear Shocks and Front Struts????????
- Need some help, I was in an accident and body shop told me....
- decent radio replacement for a 1990 audi 100
- Help loosing oil, can't tell where?
- Coin in my defroster...
- Anybody have an exploded view of the front bumper for removal
- Universal cats
- Cold air intake modification
- Hey SoCal, don't forget to RSVP for out holiday party "AUDI ODYSSEY" -- Saturday DEC 4th
- VAG-COM requirements?
- Poll: C4 Chassis Avant Lowering Results
- Radiator fan will not come on. Correct diagnosis?
- Changing Head Gasket
- Bose Radio Volume Control Goes Bad
- will H&R springs from a A6 sedan work the A6 avant?
- S6 on rt. 128 (MML... Plate)
- Tips on loosening spark plugs?
- Help with solenoids...........
- Antony's A6 Avanti, did you fix you seat memory? Mine won't remember either, but it doesnt make....
- Changing out valve body solenoids....
- Looking for working Audi Gamma Radio
- need used 97 A6 (Asian spec) [4 in line 2.0 lit engine] ECU...
- rs4 wheels
- Picture of factory changer in '97 A6?
- 1992 100CS
- 97 A6 Quattro with automatic transmission, is it 2.8 12v or what?
- engine swaps
- 3 Spoke steering wheel conversion
- Lowering springs for 97 Wagon
- Anyone have AVUS wheels on their Avant?
- Exhaust question
- Delta CC rear speaker problem
- A6 97 belly panel? other issues with new to A6 owner!
- Oil Level In Front Final drive
- Unchangable seat memory
- Fuel gauge moves real slow and never quite makes it to full
- Where does factory changer go in a '97 wagon?
- general suspension questions
- Timing Belt Job Question
- I have the stock "aerostyle" alloy rims... Bentley just told me so.
- 96 A6 wagon - remote question
- Hard cold starts in 97 A6
- oil pressure gauge (1992 audi 100cs)
- 1990 mod 100 heater
- In need of good Indie shop in Northern DE?
- Seeking Opinions...
- Brain fart: what's the wheel lugnut (bolt, actually) torque?
- Installing other Audi windshield wiper stalk with intermittent settings
- Seat memory inconsistencies...
- Battery location on 97 Avant????
- Dash mounted gear selector not lighting up
- Driver side power seat stopped working.....
- Has anybody replaced their brake master cylinder
- New Avant owner
- Brake Pads
- AVANTS: Radio antenna amplifier
- blink codes, need some help on a 94 100CSq...
- WHATS A 93 100CS WORTH???
- Indie shop joy!
- What outside temperature range does your AC stop working?...
- HELP: audi A6 transmission
- can anybody post a photo of the AT underpan for 96 A6 quattro
- Universal cats won't fit?
- Water Water everywhere
- TB change in Southern New Hampsire??
- help: front wheels expereincing wheel shake
- does anyone have experience with installing 100w H4 bulbs with relays to Euro spec Headlights?
- Just replaced thermostat, car still running hot... what else could it be?
- newbie................
- side mirror stoped working
- Has anyone else spent WAY too much money on their car?
- Heater Vent Motor only works sometimes???
- Sound Dampener Attachment Question
- Newbie To VagCom URL's?
- Speedometer head
- How much and where to buy thermostat 92 100CS?
- A6 FWD Front shock/strut cartridge - big problems
- rough ride on smooth road
- front speakers 1992 100cs
- Ignition Firing Order
- Quality aftermarket CV joint boot supplier? Cost?
- #%$&^ Rear Brake bleeder screws!!
- Chilly Willy Motor
- lamest question: what bolt appropriate for the license place (size and length)?
- AIR FILTER
- Speaker question
- WTB: Passenger-side Fog lamp and/or lens & rear headrests
- Intermittent Failure of Ignition Fuse
- Over heating problem.
- My seat memory buttons arn't working and they just were, any place to look beside fuse panel?
- How many times has the ignition switch gone bad on your cars? I have replaced mine once, and it
- Has anyone ever had trouble w/ car NOT shift gears? (more)
- A6 drivers with aftermarket rear 6x9's, what did you do with the speaker grills?
- removing control arm, why does the subframe need to come off?
