- Front Rotors Hot After Changing Pads
- 1993 Audi 90S HEATER CORE CHANGE
- TT owner (former C4 A6 owner) question about mirror electronics
- A LITTLE LITE VIEWING!!
- 92 100s near mint, what is it really worth?
- Good low-dust rear pad for 95A6QA
- need help choosing
- cruise control stopped working today
- Taking out Servotronic relay -
- Rear Brake Rotor Shield on 95 A6QA
- What's the average damage on getting a new torque converter? 93 100s.
- Poll: How much longer you are going to keep your car.
- Best way to dispose of an old car? eBay? Donate? Part out? Cliff?
- Reset brake pad warning light? (0)
- foglight dilemma, kinda silly but I cant decide
- Foaming P/S fluid?!
- changing AT fluid in 96 quattro: DIY or trip to mechanics?
- madness
- Has anyone developed a PS leak at a line fitting next to the spark plug?
- Cabin Filter for 96 A6
- L reg Avant also dies at random
- so what could it be? 95 A6 quattro...climate control works when it feels like it
- Parting out '93 100s (edit: decided to fix)
- 1998 Avant dies at random, will restart 15+/- minutes later.
- Somethings leaking onto my passenger side cat pipe..
- Bentley Repair Manual 3-Volume Hardcopy up for action on eBay....
- who here has redone their door panel fabric
- 92 100cs upgrades
- What do I need to do before I can remove the steering wheel on my 97 A6?....
- Need help replacing starter
- Has anyone here used Worldpac transmission mounts?
- Anybody looking for a '92 100CS 5 speed???
- does the MAf from a 93 100S fits a 95 A6 quattro?
- Audi 100 V6 (1993) belly pan needed
- Quirky Audi Elec Systems...aka Horny Wiper Madness
- Remove Shifter Cover
- has anyone recharged..
- new pads/rotors
- good old memories
- windshield washer pump not operating
- Being that gas prices are out of control, How many miles are the quattro drivers getting...
- 100CS failed smog, needs valve job?
- Problems with Power windows on 1990 100
- 92 100S for parts
- Headlights don't turn on!
- First Drive of My "New" '92 100 CS--some lingering questions.
- TPS query
- PS or AT problem?
- I knocked something off of my door...little plastic cover thingy 4AO 853 589 A
- Not a Audi ! But pretty close! Black Beauty!
- Typical Audi owner
- best method to fix stripped oil pan bolt hole?
- No start, dash lights dead, no fuel pump sound
- any tips on removing front right axel?
- Where can you buy an antenna mast 94 100S
- How long do heater cores last???
- 94 100 blower motor - what does a shop charge?
- A/C relay or relays?
- MPH sign on from time to time.....95 A6 quattro
- What the heck is this?
- What is the size of the axel nut, to remove front drive shaft on 94 100?
- I require the tranny dip stick part number for my 93 100s...
- Just replaced wheel bearing. It is definitly not a DIY.
- battery dying
- Air Conditioner not working on 97 A6, Need some help please...
- Wanted: 4 crappy crap rims with terrible tires
- 1992 100CS suspension questions
- Ok, how can I adjust my damn clock???
- Update: What have I gotten myself INTO?
- 95 A6 quattro - windshield washer pump can't find it to save my life.Anybody has a picture where is
- HID before and after Pictures
- short changed on wattage ( mild complaining)
- How to replace headlight unit with washer
- Cross post from 80/90, I guess should have posted here first.
- fitting Black Plastic Piece on bottom of door
- went to richmond va yesterday and saw THREE audi 100's or s4 wagons
- upper pan still leak, help p p p p p p p p p p plllllllllleeeeaaase
- Buying an old Audi
- x post: a few question on removing exhaust and replacing final drive seals on a 100.
- Started My $134.00 HID project today. (Several pics)
- Someone with a bentley, code help: 16690
- wiring diagrams pdfs/jpeg website
- overheating 92 100cs
- If I remove tie rod end and try to twist the tie rod. Does it supposed to turn at all?
- 95 A6 quattro - what is the best choice in plug wires?
- What have I gotten myself INTO?
- Cruise Control Fitting
- Any mechanics in the Atlanta area?
- Seat belt light comes on after bump
- Installing trip computer: Need some help...
- Rough Idle post Timing Belt! Please help!
- Unusual Gearbox Trouble
- Has anyone attached an iPod or any sort of Mp3 player to the CD changer outputs?
- Still have hundreds of parts left from my wrecked '92 S4. If anybody needs anything...
- strange things with coolant. Anyboby knows why?
- Wheres the A/C service ports on a 92 100?
- Does Wendy Hager still sell parts?
- Quattro wagon question
- Got this code....Gear selector switch implausible signal....please help...
- Wanted: 15" wheel covers
- Info. on the ECS....Emmission Control System
- How to remove a car from the road for 8 months?
- Heater hoses for a 92 CS100
- Big BIG problems
- need your oppinion....(long)
- way off topic, what do you guys make of this..
- Anybody running on these Falkens?...(more)
- A quick question about the O2 sensors...
- Stupid @$#&# clear corner!
- ABS sensors 92 100 S
- wheel bearing caput.
- in case anybody is looking to replace their broken IC chime speaker...(UPDATED)
- 1996 A6 Engine Noise
- Infared keyless entry
- is there a VW forum like this?
- Finaly took the 15's off
- last try-Starter system help needed!!!!
- Question on driver side power lock system
- WWW.ELAUTOPARTS.COM...anybody bought anything from this site??
- Coolant and Power Steering Flush
- Anyone have an extra antenna mast?
- Selling my 1996 Audi A6 FWD
- Anywhere that I could find a color coded diagram of the
- Friend is looking for reliability of the 97 A6 Avant? What type of engine did they have then?
- Removing the power lock system...need advice from a vet
- Ronal, August Sale, 16-18" R38's
- Changed the ignition switch on my wife's 95 A6, but now
- Radiator Fan only comes on when A/C is turned on..
- Anyone have an idea as to how much it would cost getting the headliner re....uh...done...
- hi-flow cats
- Generic amplified Bose speaker question
- v b chil-n, YOU ROCK!
- Selling my 1992 100s
- x post: anyone ever have this with their 100/A6?
- Noise when car is in gear, not in neutral.
- 97A6Q - Hydraulic Fluid Question
- Well, off to the Audi Driving Experience in Barcelona....
- Cat Gut
- Got Oil
- The Final chapter......I would like to thank all who contributed their knowledge and comments...
- On the instrument cluster, what is the black square(space)
- Rear Hatch switch?
- Transmission moving muffler??
- The Audi gods have it out for me today...
- climate control unit works but doesn't light up...you can see the buttons around it but not the LCD
- Bentley Paper Manuals for A6/100 92-97
- what "15 inch" tire size do you run on your 92-95 100/A6
- Need help ASAP
- Hey guys. I got about 2 questions about my 93 100s...
- timing belt changed at 88K miles ...now it has 143k...when is time to do it?(95 A6 quattro) thanks!
- Losingthe "worn pad "icon on 100CSQ
- Hmmm So this is Episode Three I guess
- |skolnick², sent you an email on that solenoid...
- Parlor tricks for ST mech; outer front CV joint boot clamp install?
- front wheel makes noise while turning to the left.
- Looking to buy a 1995 A6....
- air bag light
- climate control unit LCD doesn't light up...
- OH Boy another episode
- memories of my old 100
- WAY off topic --- but i have a queation and i thought some of you might know....
- 100 CS parts
- Just brought an Audi A6 - 1994 2.3L 5-Cyl 110,000 miles
- 1995 Audi A6 quattro automatic
- This might be a silly request, but I just helped a very good friend purchase a '95 A6q 5-speed...
- 17-18" Wheel-Tire July Sale
- looking for a write up on EGR operation (not cleaning)
- man look at this (i was going to buy this car)
- ISV location on an AAR Engine?
- O2 sensor error and CEL at highway speeds.
- Pentosin Hydraulic Fluid Flush??
- Replacing spark plugs, oil filter, and oil after sea foam...
- does anyone know where the relay is for the seat memory? Mine doesn't work and nothing...
- Anyone know an easy and gentle way to remove the wood around the A/T shifter?
- damn little sign
- Trunk lock/rear hatch lock mechanism help.
- timing belt tensioning damper and oli temerature gauge ??
- OH thank heaven (LONG)
- AC only gets really cold once engine is warmed up...
- 1996 Audi A6 2.6se Relays
- 1995 Audi A6...one is quattro 143k miles,one is FWD 80k miles....
- Something strange on ebay...
- BC/AB x-post
- anybody changed their solenoid valve used for A/C recirculate flap?
- oil and camshaft oil shield
- a/c compressor replament, I have searched and not found a write or link.
- Has anyone used the larger C4 A6 filter on their 100 series C4
- Reminder: Achtuning Anniversary BBQ & Official Waterwagens Pre-Funk - Saturday July 30th
- Use Silicone Dielectric Grease on Brake Pad Sensor?
- '97 A6 Door won't open
- Does anyone who has replaced your High pressure PS hose, do you have a part number?
- I bought the tool 2079 for crankshaft pulley but it's too big?
- Transmission limp mode solved !
- largest wheel and tire size that will fit on a '92 100
- Power Window 1991 Audi 100
- '93 100CSQ Eletrical issue...
- Timing belt problem.
- New Springs/Struts = Banging...
- SoCal Happenings Reminder -- (Sat 7/23) Audi Academy Techfest & (Tue 7/26) GTG @ The Stand
- Ok I've had the CEL on for a while...
- The bellypan odyssey (or alt. title: "How not to get killed running on the 405...")
- She Starts. She Runs. But She Hesitates
- body kits
- general bs
- Squeaky Squeaky Squeaky
- Dead Battery
- Pricing, advice and guidance needed on purchasing a 95 A6 Avant
- Engine oil light comes on
- o2 Sensor questions
- Sticking parking brake
- wheels for a6.....
- cv joint removal
- silly ?
- Brake Fluid lower than normal...
- Serpentine belt tensioner removal on 96 A6 Quattro??
- Paging A6Gary...
- Anyone have interior parts ?
- Oil leak
- Engine Swap
- "switchblade" remote
- Oil Pressure Sensor Install
- Easy weekend assignment for someone willing to help
- anybody got a 92-94 100 engine for sale?
- Every time I bring car to mechanics, something else breaks. This time rear shock
- No starter-update
- brakes?? this is a long one
- air conditioning with a mind of its own
- should I put any sealant on the valve cover gasket?
- ok fellas I've seadrched but I'm still not sure how much
- HELP
- Anyone ever replace the rear drive flange seal?
- i need all your advice........what do you think of these.
- Tranny Help please
- Vacuum Hoses, Catalytic Converter, Brake Booster, Brake Pads, Rotors....
- Two windshield washer pumps?
- Sunroof console......
- Audi 100 2.3 Fueling Problem
- A6 Gary- I saw a post from last fall you replied to in regards to replacing a thermostat....
- Audijim113- I did a post a couple of weeks back. Was wondering..
- A little help confirmation on electric gremlins
- cleaning out my garage today found some stuff from the old 100cs
- Ronal 17-18" SALE
- oil consumption
- Delta CC Radio -- CD Changer Controls?
- 157K miles on board ...ATF never changed ...or not that i know of ...
- Cooling system curiosity....I hit a speed bump this morning and...
- SPARK PLUGS
- ATF Flush question... Is it really OK to change the fluid?
- Weird electrical problem with wife's 95 A6 Avant
- Recir button
