PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. A/C high pressure switch replacement ?
  2. A6 BRAKES PROBLEM
  3. Check engine light
  4. a/c problem
  5. Sun Roof
  6. "Anti Lock"-Switch Audi 100
  7. Air/Con
  8. Quattro Wagon differences 93 vs 94?
  9. 92 100 cats&muffler
  10. Last piece of my A6 left... cleaning out the garage.. anyone want a set of stock springs?
  11. eurostyle headlights on ebay run out today
  12. 100s Radio Install Problem
  13. i finally got all my stuff together and published it on a website
  14. window regulator
  15. Anyone want to buy a radiator? early '92 100.
  16. How many miles do you have now?
  17. ordering brake hoses for the rear.... is there and inner and outer hose?
  18. I found a new engine... Thanks for the reply.
  19. Can I use Mobil 1 ATF for my A6???
  20. Did Audi sell any diesel powered cars in North America?
  21. car is shaking...
  22. Anyone here need a gauge cluster?
  23. 92 100 CS Power Stearing Fluid question
  24. Muhammad, I got quick question(s) about your brakes
  25. Trying to find 95-98 A6 Avant 5spd, having a hard time....
  26. DIY - Oil Change Instructions
  27. ok. so i am done with the transmission but now i have air in the brakes... fixed accident pics
  28. Used 92 100s Washer Pump
  29. Looking to buy a 95 A6 2.6 automatic gear - What should I look for?
  30. where does the a/c DRAIN out??
  31. Questions on fuel economy
  32. How hard is it to replace a timing belt on a 1992 audi 100
  33. Lucas Engine Treatment on a 92 100s
  34. How to reset ABS light in the dash???
  35. after another day of working on the car i got some stuff done
  36. sell or fix question on a 92 100cs
  37. Vacuum line replacement question
  38. R&R for the EGR purge valve?
  39. just came back from the stealership!
  40. Beeping noise
  41. What bulbs are in the headlights of a 1994 Audi 100 S
  42. Phew! 96 kmi maintenance finally done. Happy again.
  43. A/C question
  44. 94 100S radio
  45. Inspection Test
  46. '92 audi 100 brake question..
  47. what kind of antifreeze can I use??
  48. I need the tail light lenses that go on the trunk lid. Anyone??
  49. rear brakes again..
  50. after hours of laying under cars i went to work on the audi and got
  51. Help Wanted!
  52. can somebody explain the pricing on TDL for me please...
  53. Radiator fans are always on and running/spinning fast
  54. Atlanta - Meet tomorrow at Lake Lanier
  55. Rear bike carrier for Avant?
  56. Cruise control switch R&R?
  57. Need expert advice on a 1992 Audi 100 CS
  58. 96 A6 FWD I'm Looking to buy ...Have ??
  59. Hesitation/Rough Idle
  60. Re: Need to rent a fender roller...
  61. Will this CD Changer adapter work in our cars??
  62. 92 100s wont start
  63. Is $290.00 to much for brake pads fw/rw and labor?
  64. just had an alignment done and ouch! i really needed it
  65. who was looking for white guages? they have on on yabe right now from an S4
  66. locating the transmission id plate
  67. Oil in the tranny?????
  68. How do I....
  69. 95 A6 Air conditioning problem
  70. while we are talking about ebay
  71. Whooew... a nice engine on EBay. Check it out !!!!
  72. Cooling and brake questions
  73. Grille Rings...Question..
  74. How will the audi 100S sound with a magnaflow muffler
  75. What are the dimensions of the stock audi muffler also what replacements are there
  76. rear brakes
  77. Cracked Air Filter
  78. Can Mintek Redbox brake pads cause rotors to warp?
  79. How to reset sensor light?
  80. Mobil1 0w40, extreme spec oil.
  81. Odd intermittent squeek from front end
  82. has anybody done chip upgrade, port. intake mani., port. throt. bod?
  83. suspension for 97 a6 quattro wagon
  84. could someone verify some numbers please?! 92 100cs fwd automatic
  85. Limp Home
  86. Question About A 96 Non-Q I'm Looking At
  87. Unchipped speed
  88. EGR!!
  89. does anyone have pics of the trim along the doors taken off or painted?
  90. European front bumper on US A6?
  91. Tach zusammen !!!
  92. Here's ya chance! ;O)
  93. has anybody everdone a tiptronic conversion to an a6 (c4)?
  94. Annoying knock under carriage (A6Q 1995 5spead 110K)
  95. Poll: What fluids to use in man. trans and diff?
  96. Coolant resevoir leaking! Anyone know any places to buy one besides dealer and audi quattro parts?
  97. My car was faster then Porsche
  98. Loss of power/ not getting gas
  99. AC + Rain = leaks on my driver side floor
  100. 2 antenna wire problem
  101. Anyone have a used engine for a 96 A6aq ??
  102. what is this loose cable
  103. pictures of the cats removed
  104. automatic transmission fluid change.. a dilemma??? (big pictures dialup aware)
  105. Automatic Transmission vs. Power Interruption
  106. Thermo warning light on @ ignition & eventual overheating
  107. Speakers on a 94 100s
  108. lol.... bet you didnt know about that
  109. OEM Factory approved fluid??
  110. fOLLOW UP ON BACK UP LIGHTS
  111. Catalytic Sealer/Gasket
  112. Fuel guage inaccuarte-Any input?
  113. 92 100s wiring diagram
  114. Any Bentley 100 A6 3 Volume sets for sale?(1992-1997)
  115. Tackometer stopped working?
  116. ecu location please?
  117. Anyone know the procedure for rebuilding front calipers on a 92 100CSQ?
  118. Engine is 'pinking' or 'hunting'
  119. Brake Bulb Warning sensor light on dashboard is always on, can anyone tell me why?
  120. Please, can somebody help me find correct magnaflow muffler?
  121. AAAHHHHHHH!!!!!!! 12v.org is down
  122. 92 audi 100s speakers
  123. '92 1C Lifter/Valve Tick
  124. '92 1C Ventilation Filter?
  125. Alright guys.... what brand and weight of oil do you use?
  126. Need help Installing Distributor in 5-cyl. '88 90 Quattro
  127. Update on electrical charging problem.
  128. Seal Replacement
  129. fresh air motor makes squeaking sound.
  130. Oil pressure error, check engine light flashing rapidly along with a ticking sound, please help
  131. Stupid brakes! What size is the hex key?
  132. Newbie Questions/Hope I'm on the right forum!
  133. Vag-com Questions???
  134. Do I have to change my front rotors everytime I change front brakepads??
  135. 100/a6 tdi
  136. Back up lights Again
  137. Stainless Steel Braided Brake Lines
  138. Washer fluid reservior leak
  139. LOOK HERE!!!!
  140. 1996 A6 2.8 O2 Sensor Replacement?
  141. Mirror parts needed...
  142. Aftermarket camber plates?
  143. European Front License Plate Holder??
  144. look what i found
  145. Looking for OEM warning triangle
  146. SHAGINWAGONA6 and Pacs Legend, any interest in selling your tow hitch?
  147. Think I need a new CPU
  148. Muhammad, found the sticker from my '92 100CS
  149. Fuel Pump tool?
  150. Reset Service message on 96 A6 without vag-com
  151. 1991 100 Power steering fliud...What to use?
  152. Brakes Reliability???
  153. So it seems like it's the voltage regulator in the alternator.
  154. 93 100CS CV Joint
  155. PLEASE HELP Fuel Pump
  156. K&N Filter
  157. Got my Falken tires
  158. replaced my brake line with stoptech metal. Lessons learned:
  159. Transmission oil change - 1992 A100
  160. Vendors / Sponsers of the 2003 Northeast Audi Event....(This weekend!)
  161. Anybody knows where to find digital compass with red backlight, matching instrument cluster lights?
  162. early a6 profile
  163. coolant problem
  164. Climate control diagnostic trouble codes RESET
  165. Wheel Changing
  166. car radio replacement with a red display and the station output
  167. Will a parking light form a 91 100 fit a 95 a6 and ....
  168. Clear Turn Signals
  169. any tips on how to replace brake hose?
  170. Laboured starting when engine is cold (but it's hot out!)
  171. Looking at a '95 FWD A6 wagon with 90k miles....
  172. Anyone here try AutoRX???
  173. Ribbed (flat) belt idler
  174. 60,xxx miles in 18 month
  175. I had to replace my front shocks yesterday. It's a new car!
  176. R12 air conditioning to R413A or Isceon49
  177. Oil Change Question
  178. LIGHT OUT symbol constantly on but no lights are out!
  179. Passenger side door latch broken
  180. air condition spits out water on passenger side around feet?
  181. Re: AudiJim113, looking for a headliner, what color...
  182. Check Engine light intermittent - No Codes - wtf
  183. A6 Avant 2.5 TDi 140bhp
  184. Transmission Cooler??? BG Trany flush machine???
  185. Where can I connect the volt-meter on the alternator to test it?
  186. Where can I get the OEM Factory Original shop manual at a good price???
  187. instrument cluster upgrade
  188. Sunroof Motor Failed - '96 A6 2.8 Quattro Avant
  189. Help, Front right window won't go up on 1991-100
  190. puhhh i just finished reading all the 4800 threads on this board!!!
  191. Manual Trany Noise.....Help..
  192. Just ordered Falken ZIEX ZE-512B tires.....
  193. Cat problem.... maybe... and air filter
  194. paging seattle scott..
  195. techron is the shiznit....foshizzle...
  196. resetting error codes from the a/c readout
  197. well. My brake hose broke again.
  198. power steering pump symptom question
  199. Pulling out Windshield Washer Pump
  200. Temp cure for overheating !
  201. Air Conditioning question
  202. The Audi's doing some strange things... any input would be appreciated.
  203. Any ideas where to get a tow hitch?
  204. My convenience close feature used to work....
  205. Coupon for performancemotorcars.com
  206. Power Lock Vacuum Pump Location
  207. windshield washer pump
  208. Anyone ever replace the rear control arm bushings on a 100q?
  209. Audi A6 or 100, (C4) 2500 TDI (AEL engine)
  210. kn air filters
  211. Hello. This I just found on EBay. I alredy do have a GS (glass sunroof) but this offer seems too...
  212. 1992 100S auto "Sticky starter" 2.8 V6
  213. S6 Melange (cashmere/bronze/etc..) on P'tree Ind. Blvd. in Atlanta - you here?
  214. 1992 100s
  215. AudiWorld Merchandise now updated
  216. Clear corners for 92 100s
  217. Overfilled ATF
  218. squeaking climate control fan
  219. Shoot, has anybody have had this BLAU?? Do they send you any upadtes on your order..??...
  220. Quick question: Is my car "-4AW005000 chassis"?
  221. Replacing Hydraulic Lifters
  222. Who has painted the black rub strips on their bumpers and door body color? Pix? TIA!
  223. Re: Come on fellows, show some support....
  224. Back to the Brakes
  225. Are there like used audi parts online stores
  226. Watch out for this seller on EBAY.de
  227. Tips on how to remove gas pedal... I cannot seem to get a socket on top right nut... no angle
  228. Should I hear the relay click when I turn the seat heater on?
  229. Used Audi Interior Parts
  230. audijim, do you still have the alternator on your parts car?
  231. Remote lock is WEAK
  232. Re: Need help, can someone post 92 100's.....
  233. 93. Audi 100 16v inline 4 won't start
  234. waterfest pics..
  235. Suspension
  236. is it ok to mix coolants...
  237. HELP! Blinker/Turn Signal malfunction?
  238. going to do some water pump/timing belt work....
  239. 2003 Northeast Audi Expo
  240. brake calipers the same 92 100 CS and 92 Quattro?
  241. X-Post of AW rafting trip G2G info.
  242. New Front Speaker HELP!!!
  243. noisy radiator fan
  244. Steering Wheel
  245. '89 100 trip meter
  246. Weird noise, coming from middle resonator
  247. transmission slips in reverse only -- bad things happen in 3s
  248. Stock alarm horn location?
  249. 95 A6, possible fuel pump failure..i don't know, please help.
  250. where can i find a cap to the power steering fluid reservoir?
