- Antena
- Any clues on how to split the heater box?
- Sticking shifter among other problems.....
- Anyone have pics to taking off front door panels on the C4 A6? I've looked in the archives but...
- rather loud high pitch ringing coming from engine...
- Anyone have an avant hatch trim panel?
- Delta Radio Code Problem
- Where is the second oil pressure switch on a 2.8l V6
- HEY... dont buy cats from them!!!
- 5th Annual Audi Expo - Come be a part of history again!
- '93 quattro 100cs overheating
- 1996 Audi A6 audi quattro wagon TRANSMISSION for sale in philly area (classifieds werent working)
- How difficult is the timing belt on 1992 2.3L 5 cyl.
- any adwise on how to reinstall rubber boot on the front strut?
- Rear Brakes
- strut and shock replacement question
- oil pan gasket help
- check engine light .... reading codes ..... 12v.org
- You guys ever seen this before?
- POWER steering leak
- Removing relay cover
- Won't Turn Over (start) problem
- Coil Pack Failure?
- anybody experience CC recirculate mode not engaging flap in glove compartment?
- I wrecked an S4 so if you need any parts please let me know.
- Finaly my radio turns off with ignition
- Regarding adding Seafoam to the crankcase, I have a 97 A6, where is the vacuum line I want to use?
- Steering - control arm?
- 96 A6 Delta Radio Removal Instructions?
- I can't seem to add my car to sig. Help
- anyone have a picture of what the brake booster looks like?
- Seafoam (what the hell is this)
- Need thermal switch for fans...best place to get them?
- Do A6's have a built in somewhat ram-air intake?
- high rev's after atf change....
- Anyone have a spare CLIMATE CONTROL head ????
- Brake pad warning light comes on intermitently
- Whats the difference in trannys between a 96 quattro auto wagon and 96 quattro auto sedan?
- Need help....Car won't start...flooded engine?
- Need lower door molding fast! Ideas?
- New Exhaust
- Need help from a russian speaking person
- Steering Rack slow leak advice??
- Outside temp sensor- how is it mounted? Mine's dangling!
- X-Post: NE OHIO - Valley Cruise, Bunker's, BBQ, and ALMS this weekend!
- Barke Caliper Piston Question
- An Emotional and Proud Owner
- Front Passenger Window
- Headlamp check light came on
- Re: Brand new tranny was installed yesterday (92 FWD AT) and...
- Need OEM part# for O-ring filter to tranny gasket for 97 A6(see pic)...
- gearbox fluid change
- Re: Need to rent VAG tool for 1hour in San Diego area ASAP
- after market pre-amps to bose speakers
- Another newbie question.....where are the fuses located?
- newbie Q's--picked up a 96 A6 quattro wagon and am unable to get gas door/sunroof open--dont laugh
- Power Window Relay
- Placement question, Is the flasher relay behind the cluster?
- 94 100 S Banging sound when shifting on hard accelleration
- coolant bleed screw?
- AHHHHHHHH Blasted
- What size vacuum hose?
- Carlisle PA honouring the Quattro this weekend!
- Turn the ignition and....
- Registration is now open for our Streets of Willow track event - July 8th & 9th (Fri/Sat)
- Has anyone realigned a door? Whats the procedure?
- Engine cuts out on 100 2.8E
- where to get camber plates?
- SOMMERFAST 2005 German Car weekend in Stowe, VT
- 1994 Audi 100S needs oil
- Are Falken ZE-512 good tires?
- how can ı learn KKK 03 turbo rating
- %*&*^. My steering rack leaks again.
- oil leak investigation continues
- crank pulley removal
- Tire wear?
- my 92 audi 100s has a mystery leak of water thats somehow gets inside behind the driver seat
- what are the two metal boxes that have wires going into it under the back seat on the left side?
- Upper rear control arm replacement procedure...
- what type of dianogstic device will work for my 92 audi 100s?
- key in car - need to break in
- Write up on replacing engine coolant temperature sensor on AAH.
- Can you reset the oil service warning without a vag-com?
- Annoying beeping sound came on today
- Auxiliary fan switch - Where is it?
- 96A6Q: Sunroof Motor Cover doesn't stay attached
- Turn signals
- I did EGR connecting pipe replacement the other night.
- shock comparison: bilstein v boge
- Vibration/Cavitation when turning to the left?
- 97 A6Q shocks and front rotors/pads needed
- service light
- Starting oil leak project
- s6 suspension into 100?
- so i just bought a 97 2.8, what can i do with this car? my bf has a 2001 and a half S4, and he has
- Question for you guys, I notice my raidiator fans come on regardless of temperture, when the key...
- MIL, CEL (check engine light)
- Will these muffler tip polishing tips work with our cars?
- finally installed new radiator fan motor myself...
- Audi 100e 2.2 transmission whine
- What's a '96 A6 Avant worth with 205K Miles?
- fuel pump 86 5000K??????? where's it hiding?
- after shut down clicking-grunting noise
- Not sure if they even fit, but do used UrS4 front brakes or springs have any value to you guys?
- hey guys....my gf just bought a 97 a6 and was wondering what kind of milage you guys
- Oil leaking from a crack in lower pan and between the pan gasket below oil cooler. 2 questions:
- off the cuff does anyone know the proper ECM# for a '98 C4 quattro avant? i STFA and, well, you know
- fixing climate control
- Rain in Maine
- how can ı upgrade my clutch
- Any here install a phatbox/ know if its possible? Thx.
- extreme rumbling
- need rear caliper what years are interchangeable?
- Minor annoyance: anyone have a loose seat, shifts slightly on mount during accel? Curious...
- How do I remove instrument cluster, pls?
- Exhaust smells like rotten Eggs.....
- Has anyone ever changed the fuel pump?
- OIL CHANGE from MOBIL ONE to regular oil????
- x-post: ECT sensor replacement
- sad day for me and my A6 ........
- So I want to read my engine codes, as layed out in this article - but my '97 had other plans!
- 5th Annual Audi Expo! - It's coming!!!
- Armrest rattle fix?
- Car shuts off on highway (long) - long time problem - advice needed
- Antenna and radio reception question
- No High Beams?
- How do you reset the remote key fob for a 97 A6?
- 15.7 Miles Per GALLON!?!! This keeps getting worse...O2s, right?
- Dissapointment! Missing cell phone speaker!
- Which bulb is for the left side of the spedometer?
- Anybody has lower (bumper) grille and side grilles for 96A6Q? Thanks.
- Has anyone tried taking apart the e-brake cable and cleaning it? Or is it only replacible?
- [SoCAL] Last call for the Julian Drive. Please send your RSVP by tomorrow, April 30th
- New Hartmann Blowout Specials.
- girl needs stereo repair help!
- Tried ATF flush method posted below -no suction
- What is going on???
- defroster/footwell vent flap
- Emergency Brake question.....
- Brake question, Does my 95 A6q have G57 or G60 front clampers?
- help!!!!!
- Anyone know the steering wheel removal procedure?
- A6Gary? In a past posting, you said (P/N 01F 321 431 A)
- central locking
- Set of Bentleys on Ebay
- this is pretty cool and rare
- Nasty AC smell
- Transmission service finally done. Under $150 incl. labor and own supplies. Only catch...
- i am confused... my radio is in SAFE mode
- Just noticed oil dripping on my cat, any idea what might leak in that area?
- How do I tell what serp belt tensioner I have?
- Gas smell??? Any ideas?
- Question regarding mirrors on A6 (C4)
- [SoCal] The Julian Drive is coming, only 2 weeks away -- Saturday May 7th. RSVP needed by April 30th
- SOS. Need part number for EGR vac reg solenoid.
- Oil change / service reminder re-set
- Transmission Problems and Codes HELPPPPP!!
- Does '92 100 have a low side AC port?
- Parting is sweet sorrow
- Reverse Lights
- Plan B with ATF fluid level 94 CSQ?
- DRIVERS SIDE CAT IS BAD
- What 5-speeds will work to replace an Auto in 93 100CSqa
- Has anyone ever taken their Quattro C4 "offroad"?
- brake line failed third time. This time I left car to replace tires.
- failed inspection
- I see antifreaze drop from the bottom of the cooling pump. Is it emergerncy
- Stereo is in safe mode on my 99' A4?
- Re: dj_dc thank you for poosting a diagnostic procedure for the 096 tranny...
- Autofrost R-12 replacement?
- Strange smoke emitted from the steering column….
- how fast can a 2.7T(tip) with chip run for 0-60mph and 1/4 miles ?
- Front Axels
- What are the symptoms of a wheel bearing going bad?
- Buzzing sound
- penny in transmission shifter...
- Audio help... 93 csq Gamma HU
- EGR connector pipe.
- Left rear caliper problem
- Girl needs HELP! 96 A6 stalls, battery problems
- Odometer stopped '94 model 100 - any suggestions ?
- 911 - need to buy stock '93 A6 bose front speakers/amp
- Question about the rear axle.....
- Auto Tranny filter and Pan Gasket FS - 95 A6 Quattro
- CD Question
- Got one of these brake bleeding tools for sale, Model 0100
- May 13-15 DE at Heartland Park (Topeka, KS) - register now!
- Rear suspension squeak.....what should I look for?
- Vancouver Audi meet - Apr 23rd
- Fuzzbeaner, just read your email but deleted it accidently!!!
- how do u remove the center armrest ???????????????//
- I tried to STF, but I don't think search is working. Will A6 headrests...
- Oh no! Hot weather is here, but my AC refuses to engage!
- Please check your front brake hoses at the caliper connection...
- Will these fit?
- Where can I get power steering fluid?
- For those of you with the lights out next to your shifter:
- I still am getting a clunk/grinding noise from rear-end...
- p/s leak update: no leaks the last 4 days...not sure what's going on (more)...
- Anybody know why the cell phone speaker keeps beeping?
- Engine fans seem to always be on, never go off.. any ideas?
- My auto won't engage reverse gear. Opinions?
- 97 A6 Avant Suspension Maintenance??
- Help: Rough Idle problems
- Etka parts help
- Advice on a 1990 100.
- Anyone's seat belt chime gone bad, become distorted and scratchy? Mine is....
- Why doesn't my transmission have drain & fill plugs???
- Tailshaft seal leeking again! 24K 23 months. '97 A6Q. Bummer.
- Which # bulb is the light next to the shifter in the center counsel?
- OMG rear caliper floating pins are expensive....SMOKIESMAN come to the rescue.
- EVAP pressure sensor
- Water in back seat
- Power Windows Fuse
- Struts! Planning on getting new strut inserts -- any advise appreciated
- HI everyone... I got a problem. My cats went out. What could have caused it?
- Audi 97 A6 for sale check it out, Good condition.
- Is there any advantage...
- Battery purchasing advice...
- ok guys my old audi is gone and has been traded for a bike. appreciate all the help and suggestions
- RE: Help, 92 100 FWD AT with Sport button, after driven...
- guy test drove the car today and wants to trade his 96 suzuki dirtbike for it. i think i will go for
- HELP!!! Question about ECU in Audi 100
- Anybody here have a EGR valve and the tube that connects to it
- Front speakers dont work
- A6 driver door mirror cover for sale
- xpost: to the guy with the green 100 on mission center road. u here?
- Horn continually honks after my battery drained
- Is this repairable?
- Wallyworld Battery - Need a helping hand!
- Body Kits, Lights, and Performance Parts
- Curious, those of you running H & R's on your q's, are your springs purple?
- greater-Boston Mechanic who can flush ATF???
- i have one other problem.. 97 a6q. the alternator light
- Good deal on the two timing belt tools on eBay for the 12V engine...
- Sticking rear caliper. SNOWMAN HELP....!!!! or anyone with Bentley
- battery is drained again after 24hours and even with a vw/audi solar charger. i dont care anymore
- Dumb question but... Why do the front wheels lock up and the rears spin feely?
- well, i found the battery compartment under the back
- Electronic Thermoswitch (F76)
- had one call ealier this morning so far on the car. we will see how it goes
- Need suspension advice
- could you guys chime in on this problem
- I need to put new front brake hoses on, is there anything...
- anybody replaced their P/S rack? mine started leeking & shop told me it needs replacing(more
- stfa: the window switch buttons stay on. i remember reading about it back in the day. whats the fix
- Would the C5 trunk mounted warning triangle bracket work on the C4?
- Just deleted Bentley...
- Air conditioner
