Log In
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. gear indicator in cluater
  2. Rear window sunshade
  3. Brake Lights Do Not Go Out
  4. Error in the instrument cluster
  5. Gearbox doesn't go into reverse, and 4th
  6. mechanic says I need a new engine
  7. 1992 100CS Engine swap
  8. 1993 audi 100cs brake light question
  9. Audi A6 C4 illuminated sun visors
  10. Henry
  11. i need radio code for audi audi a4 2008
  12. Jack Stand Location
  13. ho do I force tiptronic into failsafe mode...
  14. WTB 2 breather hoses for 1993 audi 100s
  15. 97 A4 factory alarm
  16. 97 A4 factory alarm
  17. 1991 Audi 100 VSS
  18. Audi 100 1994 2.6E ABC wont start
  19. Coolant drain plug
  20. 4B0927156G Transmission Control Module
  21. 1994 Audi 100 just sent all of the water out of the cooling system
  22. Ignition problem 2007 Audi a4
  23. front Cigarette lighter plugs not working on my 2007 A6 quttro\
  24. Help needed! Audi A6 1995 Avant backseat removal
  25. Interesting issue nobody can figure out
  26. Cam belt change ++
  27. 95 S6 - opinions?
  28. Remote key fob
  29. 97 A6 trunk question
  30. 1993 100cs, Need underhood wiring info
  31. Car idles for a few minutes then dies.
  32. few problems with my audi 100 1988 avant quattro wagon
  33. ignition coil
  34. Source for Avant rear hatch actuator 4A9-862-153-A
  35. Window problem.
  36. Audi A6 Le Mans 2009 6 CD Changer Issues
  37. coolant system in 1.8L TFSI
  38. NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
  39. Headlamp bulbs
  40. Climate control issues
  41. ABC V6 60-2 trigger wheel
  42. Audi Avant Euro tail lights
  43. Check engine light on 1995 A6 2.8 non-quattro
  44. Engine swap help - Blown ECU?
  45. Audi S6 1995
  46. Video: Replacing steering gear boot at the C4
  47. Key FOB
  48. Clutch problems?
  49. low power/sluggish
  50. Knock in the engine. 2.5tdi 85kw.
  51. Engine swap a6 quattro ideas
  52. Front axle seal
  53. 1994 Audi Cabriolet - worth restoring?
  54. Cosmetic piece for front bumper?
  55. Audi a6 4f 3.0 tdi year 2005 vibration
  56. 1995 A6 alarm remote not longer communicating with car
  57. Rear Differential Rubber Boot on Quattro locking Mechanism
  58. 100 crashed
  59. 1993 100cs coolant overflow tank ?
  60. ’95 Audi A6 Quattro slow clutch pedal return
  61. Bentley manual- valve lifter section
  62. Loss power or sputter at consistent speed
  63. 1990 Audi 100 - idle control valve
  64. My epic C4 A6 4.2 V8 6MT is F/S....
  65. Valve noise
  66. Rattling sound when AC clutch is engaged
  67. Camshaft tool NJ area
  68. emergency brake
  69. Audi 100 Quattro manual transmission
  70. 1995 A6 quattro 2.8 12v 5 speed
  71. Bluetooth?
  72. Audio upgrade
  73. Any way to judge if 96 A6 Quattro will pass MA emissions inspection from IL?
  74. Alarm activation/armed dash light
  75. 1993 Audi 100 won't engage in 2nd gear but accepts downshift into 2nd.
  76. "Automatic" sun roof
  77. 92 100 quattro transmission slipping
  78. Washer/wiper issues
  79. FREE AutoPreme Floor Mats!?
  80. Flush automatic gearbox audi 100 2.8 quattro 1992 mod
  81. audi 100 2.8 quattro automatic gearbox codes
  82. 1993 audi 100s back up lights not working
  83. Side mirror question
  84. Sway bar bush replacement - A6 C4 Avant
  85. 1995 S6 dash cluster into 1997 A6-possible?
  86. 97 A6 performance help?
  87. A6 C4 valve covers- any sources?
  88. 1998 (c4) a6 quattro avant dash question
  89. ODB location 1996 A6 UK 1.8 petrol
  90. 1992 100CS speedometer
  91. '98 A6 Quattro camber alignment issue...
  92. 97 A6 Dash/warning LCD screen
  93. final drive fill
  94. P0116 code- which sensor?
  95. TDC step by step
  96. A6 fwd to quattro
  97. a6 c4 avant as a camper
  98. Audi A6 2.6 V6 Auto Trans 95' - Oil Leak, Urgent! :-(
  99. Audi A6 2.6V Aut. 1995 - Few Questions :-)
  100. Black Friday/ Cyber Monday deals from Car Parts Discount
  101. A6 C4 A/C Blower Part number
  102. 1996 a6 quattro really weird light problem
  103. Posting to classified section
  104. Need help with door locks - mechanical AND electrical
  105. Special promotion for Audi World Forum members
  106. Forum group buy with Car Parts Discount
  107. Ignition switch roadblock
  108. Rear suspension parts
  109. 94 audi 100s exhaust manifold
  110. front axle shaft seal
  111. Audi C4 2.6 Could not start
  112. how do u remove the rear cv-axle from the transmission
  113. Tranny pan where the dipstick tube enters
  114. Lost settings(ir keys,alarm,auto windows up etc)after battery off
  115. Special promotion for Audiworld members
  116. Low sound Coming out of the speakers
  117. Upper rocker panel trim.. how to remove
  118. 93 100csQ starts and dies runs fine w/ mass air unpluged
  119. False Warning Light
  120. Cruise control not working
  121. Video: Replacing the gasket of the cylinder head cover
  122. A6 Quattro Transmission issue
  123. ...and another thing: How to install lower door trim
  124. Coolant leak 93csq
  125. C4 fuel level sensor location
  126. Vacuum lines are confounding me
  127. A collection of questions from a new owner!
  128. Radiator part number
  129. C4 A/C Evaporator Core R&R procedure
  130. Cooling fan problem
  131. Educate me: A/C low side adapter
  132. C4 A6 on-board computer language
  133. C4 outer temperature display bulb
  134. AAN engine fault codes
  135. dead spots in acceleration
  136. Transmission goes into safe mode after 10-15 minutes
  137. [HELP] 1992 100CS NON Q radiator compatibility
  138. My new 92 100S
  139. 2.0E AAD Over flooding with petrol
  140. Gamma Bose Questions : SAFE on continously and wiring
  141. Retrofit an auto dimm rearview mirror
  142. New VagCom Report
  143. Timing belt issue
  144. Video: Replacing ball bearing
  145. What oil rear part auto
  146. coolant temp malfunction and climate control module
  147. Brake accumulator/ brake bomb
  148. Clicking sound front suspension
  149. what to do with car...
  150. What is this?? 1992 audi 100 cs quattro
  151. removing catalytic converter on 2.6
  152. Changing differential oil...oh no wait
  153. Replacing O2 sensors - any tips
  154. lower pistons for the 2.6 12v ABC
  155. ABC Advanced timing help
  156. A6 2.6 V6 lambda probes
  157. What v-belt do you like?
  158. replacing cooling fan switch.
  159. Seriously? (what I found in my fuel tank)
  160. chirping noise
  161. A6 gearbox compability
  162. moving slow forward on D. reverse work perfect.
  163. Exhaust bolts?
  164. Help with headlight switch
  165. What's missing from underside of my '93 100 CSQ?
  166. New rear caliper piston retracts too much
  167. 97 A6 Avant-electrical clicking under left side steering wheel?
  168. What's up with Audi 100 wheels?
  169. C4,1994 erratic operational of components
  170. Video: How to replace the timing belt at the V6 engine
  171. Parking brake cable attachment
  172. LED interior bulbs?
  173. Audi Bose radio problem, and Audi Gamma CC Bose vs Audi Gamma CC question
  174. 92 100 s 195k
  175. Removing doorsill panel
  176. Belly Pan/VIN S100001
  177. Removing the engine oil filter 12v
  178. Service manual recommendations
  179. Mysterious stutter at constant speeds (New Owner!)
  180. 1997 A6 (C4) 2.8L Stuck in "Limp Mode" will not shift gears (Auto)
  181. Can't find a one piece headlight trim
  182. a6 c4 s6 automatik only starts in N position
  183. Removing trim kick panel
  184. Headlight assembly cross compatibility
  185. Many questions!
  186. Ignition/Key help
  187. New owner of 100 CS questions (round 2)
  188. 95 A6 Door Locks, Alarm and Interior lights
  189. I need a mass air flow sensor for my 1996 A6 C4 , 2.0 E with Auto transmission
  190. New C 100 owner with questions
  191. 97 A6 Quattro ABS problem
  192. Exhaust manifold gasket question
  193. Catalytic Converter - looking for help getting correct part
  194. Newby Questions
  195. Changing Battery
  196. Heater core hose barb size?
  197. 1992 Audi 100S
  198. 1997 A6q keeps running with key removed
  199. I need some help. I am new
  200. Reverse Detected on All gear position
  201. 1992 100CS Compressor - HELP, please!
  202. A6 C4 1.8 ADR Cooling system problem
  203. Fuel pump replacement '93 100 CSQ
  204. Advice Request on Audi 100CS Repair or Yard?
  205. Throttle sticks when it is cold out...
  206. 1997 A6: Wipers move, no washer fluid!?!?
  207. Dreaded A6 (C4) transmission MFS repair
  208. 1994 100cs Head Gasket
  209. 97 A6 Q Exhuast
  210. AC refrigerant hose nut stuck
  211. Bentley Manual question Windows 7 Pro
  212. C4 Quattro rear differential question
  213. Radiator fan stays on 1992 Audi 100c
  214. New-water leak/carpet removal
  215. WANTED: 1991 Audi 100 Dark Blue
  216. 1993 100, broken sunroof
  217. 97 a6 hard shift/sticky throttle
  218. Pleas help..vacuum hose wiring diagram S6 4.2 AEC
  219. Upper Strut Bearing Replacement
  220. Trunk lock / button won't work
  221. C4 100/A6 Parts (Parting '97 A6 Quattro)
  222. How to test headlight switch?
  223. Headlamp replacement from C4 to S4 model
  224. Fluids for 1996 A6 Quattro
  225. 94' 100CS Starter Help....
  226. Windows, Sunroof----Seems like no power. Had this problem? Plz Help Thx
  227. H&R Springs (what should I list them for)?
  228. Pearl White 1992 Audi 100CS Quattro Available
  229. 1993 100S Transmission Woes
  230. C4 pics over on qew W
  231. Transmission Compatibility...???
  232. "Other" Audi
  233. Vag405 Scan Tool
  234. Central lock problem
  235. Abs Problems
  236. Feeling the winter time blues? Here is a 20% off Promo Code to get better.
  237. can you identify this part?
  238. Battery terminal connector question
  239. oil dipstick weirdness
  240. Might buy a 92 100 cs. ( Motor question )
  241. 97 Quattro 2.8 Heat works too good !
  242. What seats can fit in c4 a6
  243. 1995 A6 - Starting Issues
  244. front driver seat wont go forward
  245. Video: Replacing drive axle boots
  246. 1996 A6 Avant 2.8 quattro HELP: clicking and brake lights.
  247. Video: Replacing the radiator
  248. Suspension Problems
  249. Is there a correct side up for front springs?
  250. No Fire Wont Start
