- Nub radio antennae? Who's tried?
- headlights
- MAF gone bad and consequent problems. Don't let this happen to you!
- (O2 sensor/Bank 1 - Sensor2) Is it driver or passenger side after cat?
- Paper Bentley
- Headlights out
- '97 A6Q thermostat acting quirky...easy to change myself?
- Audi tool
- My friend has a 97 A6 , he's not getting heat when idling ...
- Audi transmission saga woes solved (this is long)
- Wiring for speakers
- Audi Crash update....
- Alternator
- Where did the thread about the Kamei grill go?
- Temperature gadge not moving much
- wheel alignment in Toronto
- Any C4 platform wagons with a 5 speed?
- 97 C4 A6qAvant Transmission fluid level help-quick reply?!
- I just put generic power steering fluid in my resivour. Is that bad or do I need a special kind?
- Rear brake lights on the Avant
- 5 speed transmission.
- what other performance upgrades
- looking at a '92 100
- Quick Poll: What color would you repaint your C4 if you had to?
- New wheels
- Lowering springs
- Panavise Cell phone mount
- Oh the humanity, T-boned today..........
- Timing belt/Waterpump Question 96A6Q
- Rear brake caliper repair question
- Autocheck functions
- stupid friekin Smog inspection
- how the bottom of the sock is attached to the strut?
- searched this forum AND all tech: How to aim headlights>
- car will not start
- where can I get a new wiper-arm other than a dealer.
- Bleeding cooling system..... a little help needed
- The scarriest thing just happened in my 100s about an hour ago...
- Ignition switch...which one???? Please, help me!!
- Quattro - everything I had dreamed of!
- What should I do to reattach the "CS" symbol....
- Are the front door and rear door speakers on a 93 Avant amplified?
- FAQ Thread?
- Deadline to register for our Buttonwillow Driving School is next WED March 2nd
- Elect Pwr Failure 95 A6, Ign Sw, or Relay ??
- A4 vs. A6 exhaust
- Cruise
- How hard is it to replace front struts for 96 A6
- Wiring diagram Bose Radio to (CD) interface box
- Start/Radiator Fan problem (please read inside)...
- windscreen washer jet adjustment
- Check engine light came on this morning
- anyone have a pair of wiper arms off a parts car?
- CT/NY Audi Group "Spring" Gathering - Momentum Tuning, Wallingford, CT - 3/12/05
- [SoCal] Don't forget to RSVP for the Angeles Crest Drive this Saturday, FEB 26th
- Rear Shocks/Struts question....
- Radio Installation Questions- cut and dry
- 97 A6Q Passenger side wiper not moving, swings free
- Wheel size
- Lowering the car with S6 92-95 springs/shocks? It is cheaper,and S6 has sport suspension. Pros/cons?
- Best source for a 96 headlight switch
- The answer to everything? Question about '97 A6 E-brake!
- Son of Quattrofest, PIR in Portland
- Radio Fixed, Do I just plug it in or do I need to do something else, also, I lost proc for code?
- I just fixed my power locks!
- Are A6 and 100 Rear headrests the same? Or different?
- getting new rims
- still in my 96...
- Fixed the temp and gear selector light, now they seem..
- Windows are Dead....plus other stuff
- front window tint
- 92 100CS Q Brake sensor won't go off!!
- optional net partition for the Avant?
- Tires
- These C4's are TANKS
- How do you remove the front corner signal lenses???
- harmonic balancer position?
- S4 auto box problem
- Where can I find the airbag power on 94 100CS?
- Rear brake problem
- Extra acc. swtiches in my blank slots? Seems like it'd be possible, no?
- Failure to STOP!
- Defroster short troubleshooting
- 2-button RF remote vs. keyless controller > which one fails
- Does anyone have a C4 w/ an ipod installation?
- Belt Tensioner Question
- Passenger side lock is jammed, can't get the "#/%#&# door open
- Fuse #12
- Need a new key, only have one. Confused: Is this cheap or not?
- dashboard removal
- Looking for a Haynes/Chiltons/etc repair guide...help!
- Outer CV boot replacement question...
- Weak rear brakes question on 96 A6Q
- Anyone install rear seat heaters?
- Busted power locks, busted cruise control...vacuum pump needed?
- Oil Pressure and Degree (92 audi 100cs)
- I have a 97 A6 bought off a lease, would it have a cabin air filter installed or is the space empty?
- Just out of sheer curiosity.....
- someone here claimed that Audi has changed the timing belt reccommended..
- REAR SEAL
- SoCal Reminder --- 2 events coming up this weekend
- oxygen sensor part #
- My Unbalanced Washing Machine -- A Dynamics Exam Question
- SLRvision silver turn signal bulbs???
- jetex exhausts
- oxygen sensor
- Any recomendations for an Audi mechanic in Austin, TX?
- Check Engine Light
- are there any differences between the 96 and the 97 a6??
- Looking at a 1997 A6, and need a little help....
- I was just thinking.....
- audi rims
- I just purchased an '97 A6 Avant Quattro!
- Audi Harness Adapter - Bose Speaker System
- Brake Switch Question
- UPDATE: 2005 Viking Cup Classic Annual Ice Race & GTG - cancelled
- Poll: what will be your next car.
- Radiator Fans will not shut off...Any Suggestions?
- audijim113- thanks- that was above and beyond- I owe you one-
- Heater won't heat feet
- Anyone here like the Kamie grilles?
- when replacing dashboard lights with the 2W from...
- AKTE help please.....
- transfer case leak at rear, part of auto trans f. refill?
- Annoying oil pressure alarm '93 2.8l V6
- Best weight oil to use (Mobil-1 10w30?)
- Does the automatic shifter face plate have a backlight?
- Replaced Engine Temp. Sensor
- Cruise Control
- Keyless Entry Issues
- Coolant Sensor
- after 7 months of having the c4 sitting in the driveway i decided to crank it and get going
- gonna try inner CA bushing bentley says...
- Will pulling the codes give ABS or airbag info?
- Where can I find a pearl white front pass fender-
- Could someone explain why lowering is such a negative topic in this forum?
- BRAKE PEDAL TO FLOOR! NO LEAKS! HELP
- Have you ever seen this happen beofre????
- Replacing Catalytic Converters, Is it Necessary to change Rear 02 Sensors?
- 1992 100CS Quattro sometimes does not restart after short trips
- Airbag and antilock off lights...help!
- UPDATE: 2005 Viking Cup Classic Annual Ice Race & GTG - pre-registration ends 2/11!
- Oil filters..seriously..
- Ok, lets play "Guess this part"
- Heather core replacement, Please help
- Is there only one temp sensor on the 2.8, is it on the block, where?
- understanding the codes....
- Hartmann M1 Sale!
- Does the type of coolant I use matter as long as I used extended life? Can I mix whats in there.....
- 96 A6 Quattro Wagon gas mileage?
- PARTS FOR SALE
- Used parts for sale
- Nasty screeching from front..
- rough idle when cold
- Sudden loss of acceleration and power
- surprise under center console
- '99 A6 Engine Belly Pan Needed
- SHIFT LOCK
- What did you drive before your 100/A6?
- anyone ever hear of or used
- How to sell a HIGH MILEAGE pretty good condition A6Q?
- I have a leak in my power steering system, is there any known problem spots? First place to look?
- no defroster!
- INTAKE SENSOR
- there are some noise, can everyone help me??
- Temperature/Coolant Warning Light
- Trunk Lock Problem
- Need Radio Code
- 2.8 oil pan replacment,
- Front-end groaning 94 100CSQ
- Everyone's Invited to Our GRAND OPENING!!!
- A6 2.8 won't start
- I want to fix trunk lock mechanism- parts? (96 a6Q)>>
- The EVAP canister purge regulator valve
- chassis range
- Car starts, then idle drops to almost stall...ICV?
- saw the funniest thing at walmart
- Headlight Question
- REPAIR COST
- questions on AT and Coolant service
- washer pump fixed
- Ohh....that sux- lost my CS symbol on the back.....
- CD Unit and clock question
- Hello all....
- OBD port location
- How does the emergency Triangle mount on the inside trunk?
- fuel pump access
- OIL LEAK
- Have you guys see this?? http://www.audi.com/q7
- buying new struts what to get?
- Seat memory and computer screen problems
- Did any avants come with a 5 spd??
- A8 Front brake upgrade...
- [UPDATE] SoCal Audi Club track event @ Buttonwillow Raceway -- March 7th & 8th
- Putting battery in keyless remote
- Catalytic Converter replacement options?????
- GAUGE LIGHTS
- 2005 Viking Cup Classic Annual Ice Race - pre-registration now open!
- Oil Leak Part III
- dejavu...
- Doing the outer right (passengers side) tie rod this saturday Any tips?
- tranny acting weird...maybe?
- Help with radio code. 1996 A6Q
- Central flap motor location.
- What should one do for a loose strut?
- Heater vent flap motor access
- Major oil leak Help Revisited
- Question about tranny fluid change procedure. Bentley wasn't 100% clear.
- Engine sounds real bad - need help
- compatiblity anyone know?
- transmission problems
- washer problems
- 1992 100csq,windows problem
- voltage drain
- What could be making my brakes squeal when the pads are good? '93 100s
- 1994 Audi 100 CS QuattroInconsistent Idling, almost stalling at stop lights
- Well the speedo's fixed (great shop experience)......
- twenty below in Cooperstown NY!! (and a ce light question)
- Big tranny problems!!
- rear bumper removal
- Speedometer stopped working.....
- REMOTE DON'T WORK
- Car takes a while to start
- shifter hard into park
- CE light is ON again grrrrrrrrrrrrr...
- Check engine light coming on. Carbon and bad gas?
- Rear Right caliper for Audi 100 up to 1992, brand new, OEM, cheap
- Self check
- Selling 93 100CS Quatro Wagon168K miles
- '93 100S windshield washer problem
- Switchblade Remote for 98 Wagon
- How long has your battery lasted?
- I am soooo happy, my tranny wasn't making the harsh noise I heard the other day.
- SCCV Ice Racing Sunday 1/30...
- Where is the best place to buy replacement front brake hoses? Need them very soon!
- SoCal Audi Club TechFest @ Pacific Audi in Torrance -- Saturday January 29th
- Well folks, it's been fun, but my A6 was just totalled
- instrument cluster
- c4 sighting
- Where is the fuel pump located (95 A6)?
- Major oil leak HELP!!!!!
- 93 csq pass side mirror
- Newbie in need of help
- Do you guys think that these will work?
- FOR SALE : A6 Car Cover
- Does this price sound right for timing belt service?
- For SALE: Bentley CD for 100/A6/S6/S4 1992-1997
