PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Alarm goes off by itself
  2. Can anyone give me a breakdown of seat removal? Link in FAQ is broken.
  3. My new C4
  4. no start on my 12v rebuild!
  5. No power to lighter/lighter illumination bulb
  6. Stupid avant hatch wiring! warning: rant content
  7. Look what I found
  8. power locks wont work after charging battery '92 100 quattro wagon
  9. Y'all might want to look at this and consider the various applications
  10. Multi Function Switch
  11. Hey Doug, I;ll get you the diff codes tomorrow.
  12. Brake light fuse keeps blowing. Did I already ask about this?
  13. S6 for sale in Squamish
  14. Safe temp variation in '92 100CS Quattro?
  15. FS: 96 A6 Quattro
  16. Anyone know of a how to thread for removing the exhaust manifolds?
  17. Speaker size for 1995 S6
  18. Vanishing coolant, heater core maybe?
  19. Dammit. I just drove an Avant to my shop. Now I must have one.
  20. vemo door contact switch
  21. Brant's famous!
  22. Found what it is. Still wondering...
  23. 95 a6 quattro
  24. For sale: 96 A6 Quattro
  25. PITTSBURGH
  26. 95 audi a6 quattro
  27. Finally got the clear corners for my 97 a6 vista cruiser...
  28. Anyone have a active carfax account? before I pay to run one car.
  29. Anyone know of a 1997 A6 with Platinum Interior in a junkyard??... Must be MINT.....
  30. Gear Shift indicator cluster woes.....
  31. master cylinder upgrade/swap?
  32. ATF LEVAL
  33. which alternator do i need
  34. repair
  35. Help! Anyone have an extra Hella T.S. adapter for the 1157NA bulb?
  36. Were 100s available in emerald? Other models with black door trim?
  37. Evol, I need a small favor..
  38. My climate control has a mind of it's own! The buttons never
  39. has anyone done the Import Vision headlight upgrade?
  40. Cheap Bilstein Shocks, ebay
  41. I would say I have a mess of oil and exhaust here.
  42. Todd, anyone can the vacuum pump hold suction to keep all the locks from turning when the battery is
  43. Are the rockr arms adjustable on a 12v v6 ? The motor has a tick which
  44. Here's a nice Sachs Advantage failure
  45. waiting on my clear sides from ebay, 97 a6 q avant
  46. OT: Eurovan that ate pistons is up and running. (Some I-5 Audi content)
  47. Headlight washer diagram/part names please
  48. cheating Catalytic converters on a 96?
  49. Looks like I need to do the "yellow wire" mod to my alarm/lock pump.
  50. Perhaps A6Gary knows this one...
  51. Oil leak - PHOTOS -=- any ideas where?
  52. Transaxle or maybe shift linkage problems ???
  53. clunk in reverse but not in forward?
  54. ac blows blower fuse, but heat works fine...
  55. driveshaft flange seal at rear of transmission ..?
  56. Blower motor not turning on, code 18.3 from cc
  57. Fuel tank is dead
  58. FYI
  59. Picked up new to me Avant 2 weeks ago, pic in sig. I want to do
  60. Sunroof dial mis aligned?.... My Sunroof doesnt correctly shut when the..
  61. does this seem ok
  62. Where can I purchase a left rear caliper for a S6 reasonably ? ?
  63. Oil leak - back of the engine? Whats the cause?
  64. Slight surface rust/corrosion inside right passenger side door well, ideas on how to treat?
  65. Audi OEM rear spoiler mounting kit?
  66. Looking ahead: Summer Tire Recommendations for 98 C4 A6 avant 225/50/16 on UrS6 Avus
  67. Engine cover doesn't fit (and serp belt squeal)
  68. cant unlock radio '92 quattro 100
  69. Auto to manual swap on 1990 audi 100 fwd non-turbo I-5
  70. Worth it?
  71. Oil pan plug crack.
  72. OT: Eurovan detonation damage update...mild Audi content
  73. Callin 4Driver4:
  74. Is SCarGo02 around? I need to ask him a question but can't access his email....
  75. IC bulbs problem ???
  76. Just cleaned my EGR passage! Went great until I broke something...
  77. Well, I think I am going to let the insurance co. take my car. I just bought a house and I don't
  78. Avant hatch lock problems
  79. can anyone with a CARFAX account run this VIN for me please? i apreciate it
  80. IR to RF conversion - '95 A6
  81. No air flow through dash vents - works for defrost and footwells
  82. 100 to a6 panel swap?
  83. A little engine moding form the other forum.
  84. Whats should I do with Kelly's car?
  85. 20 ET too shallow?
  86. Just finished heater core install, I think I over torqued the bleeder screw
  87. EDIGREG YGM
  88. ABSOLUTELY SMOKIN test
  89. anyone got a drivers side marker light for 97 a6 avant q?
  90. '98 A6 Avant value
  91. Paging EDIGREG, YGM!!
  92. Oil can light... I searched the forums
  93. are these wheels anything special?
  94. Never posted this yet, but I have the payoff amount from the insurance company...
  95. Broken Front Bumper S6
  96. hey guys(heat stuff again)
  97. New rubber - Nokian WR-G2's
  98. C6 & C4 side by side shot - interesting changes
  99. Rear control arms: supplier/manufacturer advise?
  100. Is the sunroof switch panel no longer available new?
  101. Engine misfire, rough idle and intermittend power loss
  102. Co-worker has an A6 Avant, with no reverse lights. I have not looked at the car..
  103. How many of u have ever checked ur brake hose, if not please
  104. diff drain plug on my quattro,,1995 different?
  105. 1992 Audi 100, replacement headlights
  106. car shudders at low rpm under load. anyone experienced this & how did u solve it? need advice
  107. Well gentlemen, seems I have some tranny issues so a few questions...
  108. Need to buy a key
  109. air conditioner / heating
  110. Anyone in the North East
  111. 3.5 hours for a brake overhaul?
  112. closed cell foam for heater core seal
  113. Cross-post FYI: C4 Avant Antenna homebrew upgrade
  114. Pearl hood & fenders for a 100 in Cinci, OH
  115. changed oil cooler oring, battery went dead now airbag light is on?
  116. Exhaust..After almost 9 hours of cutting,grinding,drilling and replacing all of the
  117. I posted my write-up on my new intake manifold on the 12V Forum , enjoy!
  118. Its been awhile audiworld. I'm back and now I've moved to this C4 forum.
  119. Is there a web site that I can see Audi paint colors on, not the
  120. The new intake manifold is in....
  121. Does anyone have some side moulding for sale? I need the lower's driver side door to be replaced.
  122. Power steering
  123. anyone have an extra driver side PCV hose?
  124. Are the front or rear rotors on my 1997 a6 avant pressed on?
  125. is there a way shut off the rear window wiper off after use?
  126. When are the timing belt service changes supossed to be done
  127. Found this while browsing youtube; Audi Coupe Commercial
  128. Talk about an Ebay scammer....
  129. euro tail lights (germary)
  130. both mirrors stopped working a while back and haven't figured it out yet...anyone had better luck?
  131. Looks nice
  132. Left Rear Tail Lens Needed.....Anybody have one to spare???
  133. RH Signal Lamp Replacement
  134. Detonation Damage photos...Eurovan project
  135. Help with strange problem
  136. Just ran across this Audi on Chicago Craigslist :)
  137. Got my mirror switch bulbs replaced thanks to ricoblanco's nice write-up. Pretty easy but...
  138. I have posted this question before but it's still buggin me.
  139. AUDI 100R Facelifted twin turbo under way. (verry verry long)
  140. 95-97 (C4) instrument cluster wanted
  141. oil filter housing question
  142. audi 100 diagnostics?
  143. heating problem
  144. Calling all Diesel Caddy people......
  145. 96 A6 quttro...auto check oil light blinking/beeping...what did i forget to plug back in?
  146. EGR Temp sensor
  147. I need "Transmission identification", STFA didn't find info.
  148. Anyone in AZ looking for a parts car?
  149. Has anyone added rear back heated seats to their A6/100? from UrS cars?
  150. Not shifting to second?
  151. guys the temp gauge is working but the back light has gone off is it a solder job and what size bulb
  152. Europrice is now www.europrice.us...
  153. motor gone ... who wants to buy a 1996 A6 Avant parts car
  154. Car For STEAL..(Sale)
  155. Don't get over here to much. Mostly on the S4/S6 side. Just wanted to share this video.
  156. Need advice, helping my buddy sell his dad's '84 BMW...
  157. Your help needed! Please read inside...
  158. Does this make sense re: heated door lock: Frosty morning, open door with remote, lean in, start
  159. My latest adventure. Warning, some Volkswagen content (some Audi content too though)
  160. xpost: my s6 avant now for sale
  161. is there a flange gasket between the exhaust manifold and cat pipe?
  162. Cold start at minus 22*F
  163. Instruct me on rear calipers. Is the parking brake cable a pita and do you need a compressor tool?
  164. Anyone have one of these?
  165. A6 and S6 rear caliper question ?
  166. A big thank you to DaveinSaltLake for his soldering advice today, got my chime...
  167. Calling for all c4's to be lowered an inch or two!!!
  168. I moved to Minnesota, on the way out went into the ditch..might be totaled
  169. while were on the subject of rear wiper
  170. Avant rear wiper fuse
  171. 96 A6 quattro exhaust question
  172. EGR code 1408
  173. Oil Check Light / Pressure Gauge Issues...
  174. 1997 A6 Quattro Avant Transmission Sticking
  175. So as I was changing my coolant reservoir I noticed some MY changes.
  176. Fuel Injectors
  177. C4 A6 Headlight circuit fault
  178. 1997 A6 engine noise/tick and check engine light
  179. Gotta drop the subframe. Need to swap a piston. FARK!!!!
  180. oil dripping from oil filter mounting plate......anyone with K&N oil filter please read..thanks
  181. need some advise from the guru's
  182. Quattro saved my life... Twice in one night.
  183. Question about Driveshaft construction... car is @ the shop
  184. Damaged Drivers Side Key Lock-Barrel
  185. last call for sport steering wheel
  186. t-stat swap in my 95 a6?
  187. keys locked inside with dead battery '92 quattro 100 HELP
  188. 4hp-18 Gear Ratios?
  189. 2 question's
  190. Automatic transmission whining fixed, oil level was low. Amount of oil added
  191. Emergency repair with a 100w soldering iron...what is it?
  192. radio replacement or RCA L&R plug adapter?
  193. The results are in...
  194. 2000 A6 avant on ebay cost $2500. It is hard to justify keeping my 1996 A6 :)
  195. Clutch Replacement '95 A6Q - Words of Wisdom
  196. Diagnose wheel bearing?
  197. A quote from my mechanic today...
  198. any DIY people in here? anyone needs this?
  199. Does anyone need a Windshield Washer Tank/Resevoir?
  200. torque converter issue
  201. Anyone have a snazzy trick to remove a stripped thermostat cover bolt? Mine...
  202. Won't Start
  203. Got myself a Quattro's whole exhaust system
  204. Carfax anyone?
  205. 94 100 CS Quattro transmission
  206. strange electrical problem still here.
  207. Any one parting a audi 100 with a nice 4 spoke steering wheel and
  208. Bosch wiper blade refills ?
  209. errors errors BEEP BEEP
  210. Anybody have Factory Floor Mats that slip?
  211. Someone putting a avant to good use
  212. Does anyone have a TCM near the Indianapolis/Chicago area for a
  213. looking to get a cd player for the car
  214. sport steering wheel anyone? 95 and up is plug and play
  215. HELP - Immediate Assistance Requested - Vally Pan Gasket
  216. A big thumbs-up to genuinevwaudiparts.com....got a new factory mirror panel for...
  217. Sheild your eyes!
  218. Keyless Entry Remotes
  219. Found a Great Dealer
  220. '92 100 quattro rad. fans come on when cold on start up?
  221. need to find coolant hose. the one under expantion tank.
  222. car says "inspect 2" anyone know what that means
  223. New Years gift to you.
  224. Happy New Year Post From FL
  225. My audi ....beeps. I recently fixed my climate controls, i reconnected everything well, but it beeps
  226. Picture Wednesday (close enough to Friday)
  227. Need Kombi 078131101A
  228. controll arm removal '93 100s-
  229. Dashboard Lights
  230. trans fluid advise
  231. Anyone have stock set of A6Q springs laying around? I just need physical dimensions in terms of...
  232. UPDATE: Looks like my thermostat is ok, the gauge seems to be flukey...
  233. Anyone have your bumper off?
  234. Windshield washer trouble.
  235. so the high revving 4th gear at 80 MPH seems too weak. 3700RPM?
  236. Cannot lock the doors while inside the car but I can unlock them via the switch on the driver's side
  237. Flexible pipe on exhaust
  238. Can the crankshaft seal be reused after oil pump removal? The gasket needs...
  239. Weird electrical situation - Electrical gods->Please HELP:]
  240. C4 plans for 2009?
  241. Top up Transmision Oil on A6 Automatic
  242. WTB: lamp control module 95 audi a6.
  243. eliminating bad LCM
  244. I might have another bad thermy, this would be the fourth in 4 years.....
  245. Will 235/50/17 rub? Found a pretty good deal I don't want to pass up...
  246. Transmission oil for Audi 100 '94, 4 speed automatic - what's best
  247. Austinado16...I have a question for you.
  248. No e-brake.
  249. how many liters does the a6 12.v transmission take?
  250. I am happy to say that thanks to a few good people, I am the proud owner of a factory keyless entry!
