- The Bosch ME-Motronic System
- Any quick install info on control arms and coil overs for Vogtland GT (besides tech section)
- CPO Warranty expiring in one month! WHAT SHALL I GET CHECKED?
- rear loose in wet! quattro not kicking in properly...
- Finally was able to take the car to the dyno and the track.... 12.3@115.94
- New seat / Airbag light fix... What did I do wrong?
- Should I pay? / Squeeky steering column
- Replaced door speakers with some JBL 5.25s, removed rear deck speakers, and
- Differance between 2000 2001 2001.5 2002?????
- some pics of the ride
- xpost from 2.7T forum: Im hoping I can get more reply here as there is more traffic here : )
- How do you like the sound of this thing?
- What is the appropriate tightening sequence for the intake manifold bolts?
- RNS E cangate clock module...
- Would this cause a boost leak?
- Met up with friend with a B6......and my Stage 2.......
- nice Silver S4 on School House Lane this evening?? wayne pa
- My Ghetto DIY rattle can bumper respray
- to stasis tranny owners .. am i really getting better gas milage??
- Is it possible for a crank positions sensor to go bad?...
- Good deal on 2000 S4???
- Iconoclast- Can you shoot me an email when you get a chance? I have a question for you. Thks.
- What year 2.8 heads/cams are the ones that work the best on our cars?
- How do you know when a wheel bearing goes bad?? could i have damaged it when...
- S4 front fender part number
- Happy to announce, after a very long day, scott (arcteryx) actually DROVE his car home last night ;)
- Just saved $1,100 / 6 months by swithing from Allstate to Geico :) That is all.
- stage III install and AC.
- New oil leak. After recently having the lower oil pan gasket changed...
- Stoptech Stg 2 Brake Install, Spark Plug Change & Clutch Slave Cylinder Bleeding
- Mark P: Thanks for the great wheel bearing swap tech art.; Silva thanks for the camber arm advice
- yummmmm.. clean black s4
- Today is not my day -- need some creative help.
- S4 Pimpin.last night i go to a gas station, some older black guy looks at my car then comes
- I had a dream that I took a 2.7t and dropped it in the R8!
- Why do some tuners need throttle cut defenders and others do not?
- How the hell do I get coolant back in the system?
- Where can i get this bushing??
- Black SSR Comps on an A4/S4?
- Rear wheel bearings are singing again...what gives?(more inside)
- outside tire diameter question
- stfa all day. can someone please give me the electric dumps link.
- If i have giac ko3 software, can i upgrade to stage3- for free? How does it work?
- Bruno, your email server is rejecting my emails due to my IP address. I'm working in Cent. America.
- autox video from local time attack challenge here in corpus christi, tx
- vagproducts.com vag cable test ($24 SHIPPED from China)
- Best place to get V1 hot wired in Phila area??
- what's best air-pressure gauge?
- I've been STFA for pics of a specific black widebody avant... and came across this (wow!)
- Question for tracking stock S4...
- So is this throttle cut? Block 003 from Vag. Sorry, I'm no good at charting :-(
- Spent the day detailing my wheels.
- Still hearing squeeking sound when turning left...
- Girlfriend gets ring. I get exhaust/DPs or coilovers for my stage 1 tip.
- Shifting problems....pressure plate, master cylinder, air in the system?...
- New 1/4 mile times today - Best ET: 13.094 (@ 105.59), best trap: 107.41. EDIT now with slips:
- Pics inside, how to remove Valve cover with FPR Valve Stem In the Way
- Vid for Sat: VF SC M3 vs Tweaked AWE Stage 3 vs OTS AWE Stage 3
- Just drove a chipped (Vishnu) 335. Pretty nice car. I haven't driven a stage 2 ish S4...
- Overheating Testing 1 + vid of engine noise
- Storing car tomorrow, belt noise today!
- Thermostat placement? It has one little arrow that points up, then the little bead thing..
- Homebrew Logs + Ebay Exhaust video at the drag strip
- Does the dealership sell 710n's DV valves or just stock DV valves? Thanks
- Anyone in the pittsburgh (i'm in wexford) area i need a 2000 shifter asap
- Kind of inspired by Ducttape's dediction... even with dial up. Its true, man.... i need this place
- Whats tony@epls email need to ask him a couple questions.
- Iconoclast- I need to talk to you, too. Would you email me with your address when you get the chance
- Oil return line leak - how easy to fix?
- Bruno_S4; shoot me an email when you get a chance, please. I sent you one, but it was undeliverable.
- Rocker panel trim repair question...
- So when did Stasis bump the price of the standard rebuild to $2,900 from $2,200?
- Anyone on here ever bore, and stroke the motor ??
- How often do you see used good shape ko4's in the classifieds ???
- Tunk Lip Spoiler... which one is best, and where to get it?
- Im going back up to CT in a couple days and for some reason my car just doesnt feel right...
- Final word on Lidatek Jammers: Entire build process being redone...
- what do you think about electric dumps?
- My Turbo Lady Video...tell me what you think, regarding the whine TIA
- Does anyone still have a flawless LCD display on their instrument cluster? Please post yes or no.
- On my way home from work today, at a stop light I didn't notice a black Jetta in other lane...
- wife drove s, came back smelling of clutch...
- is the wiper fluid resevoir in all b5s the same? Would one out of an 02 fit in an 01?
- OT funny a$$ super mario clip
- Who's car is this?
- Does anyone have a need for a OEM S4 hood painted silver rear trunklid and rear bumper? All in near
- Paddle Shifters from M3 retrofit only $100!!! (WARNING TIP CONTENT)
- Is this "Secret Code" stuff real? If so what is it ;-)
- K04's arrived. Thanks Brian@Avalon. BWW
- I think my Overheating problem is from my FMIC cause nothing else is wrong with my cooling system.
- BIG props, to Brian and his boys @ avalon..
- Question about metal shavings in an oil cooler..HELLLLLPPPP !!!
- PS request. S4 launch wheelie!
- who owns this car?
- Found a used Milltek catback...
- holy cow... just put 100 octane into the car.... i didnt think i would notice a difference
- I really need a god damn transmission!!!!!!!!!!!!!
- After STFA, I have found that some people say to pull the engine to do the clutch...is it
- just installed electric fan in front of radiator, mine was missing.
- those who have done a clutch replacement...did you just drop the tranny? do the downpipes need
- does anyone have busted apr bipipe, i just need the upper half
- how do you get the transmission to stop spinning when you have it out of the car with the engine?
- blow-off valve for 2001 S4 w/ no ecu mods
- where can I get an a-piller for a 60mm boost gauge? spp?
- Is 103K Too Many Miles?
- few questions about clutch replacement...first, I dont know why, but the audi dealership told
- What's up with Lidatek? LE-30 unavailable. My LE-20 is broken. I'm not happy.
- 75K maintenance costs
- What exactly happens when your ABS computer fails?
- Thanks PureMS!
- this is what i woke up to this morning- stricken with rage -
- Stage 3 Tip owners why not use RS6 tranny?
- i have heard a few people say that the fidanza LWFW will not work with the RS4...that it
- Intermittent smoke coming from engine?
- Front right brake chirps when you drive very slowly and when you barely
- Wedge bracket install... Urgent help needed...
- I've had some bad luck lately...condo burned and almost took the S4 with it!
- Finished installing my Vogtland GTs tonight. Follow up on ride height settings...
- noise from engine at low rpm
- Stage 3- VS B6
- TJM Motorsports
- Where can i get the S4 logos for my calipers? or can i even get them?
- I have Sportec mono 10's-the valve stem hole is half the normal size
- Misfires on all cylinders but 4, no other codes? (more)
- Tiff drove it. Now Leno drives it... R8 pron.
- who does the best rs4 nose fitment in the tri state area?
- anybody have detailed instructions for a clutch install on a 2000 Audi S4
- bt: AWE Stage III
- My pictures looked like a drunken sailor took them, but 46@46,000
- just wanted to say thanks to everyone for the support over the years...
- Coilover ? - Is it normal for the driver's rear to sit 1/4 inch higher than passenger rear?
- WTF. APR won't sell me ecuX. they said they just want to get away from it. anyone selling???
- Okay ASP landed in SoCal today, but I didn't feel the pressure wave of opposing forces
- are Autospeed and KMD Tuning having a contest of non-updated websites?
- Beautiful day. Had my better camera, snapped a few in my driveway.
- How much difference in the 1/4 mile would a 17" at 15.4 pound wheel compared to a 18" at 24 pound ?
- Tons of Parts for sale - too much for classify!
- Does anyone have ASP cats they want to sell or rent, or test pipes. Basically I need cats that
- EPL fueling kit uses ASP MAF.. I don't think it fits the RS4 airbox top..
- Any of you guys have stock S4 grill lying around? I have some junk one currently and do not even
- looking for place to get a acc. belt w/o a/c or fan pulleys
- has anyone took a euro s4 rear bumper and put carbon where the black is? like hpa's mk5
- Anyone know where I can get a weld on flange for a hitachi MAF to mate to a custom housing?
- General Exclaim UHP tires-
- Can someone with a TIP tell me how much vacuum you get on your boost gauge during idle in P and in D
- which is better? Fidanza LWFW w/RS4 clutch or CM Stage 1?
- In case anyone is purchasing dba rotors...
- APR Now Provides Financing!!!
- cluster/VAG question...
- Could I have fixed my boost leak but car still be in limp mode and I just need to clear codes.......
- Friends trasmission isses... any good knowledge here?
- What to replace while front bumper (cover)*edit* is off?
- well guys, I am thinking about doing a fidanza LWFW with my new clutch...but I have
- Passing emissions, CELs, DTCs, bad cats, wailing, gnashing of teeth, etc.
- just saw video of R8 in vegas. i want to just stop spending money and save up for one. OMG
- Laser guys, reccomend a nice "subtle" tint % for me... TIA (I stfa too)
- CAN SOMEONE PLEASE RE-POST PIC OR LINK OF THE RS4 w the DUAL EXHAUST SINGLE TIPS PLS!
- where does the amp plate go on open element?
- would anyone happen to have a passenger side ecode for sale?
- STFU!
- Recaro Pole Positions installed
- Have any of you tried Startup Racing's rear "GT sway bar"?
- show me pics of the awe 60mm gauge on the piller pretty please....
- Oil lines...
- Who can tell me about this LWFW? Why so cheap? Has anyone else ordered from here before?
- well guys, the damage statement is in...called the dealership to get a quote on the clutch
- anyone have tips or a link or a/c complete removal?
- i think b5 avant with B7 RS4 fronts would be nice
- ok how do i link my sig...optional url?
- testing new sig
- paging ASP, 034efi, Stasis, whose gonna be the first to make a rear dif. mount that holds up
- Busted !!
- after 2 months of not having the car I finaly have it back...
- About to pull the trigger on SPP stage 3 lighting, anyone say no?
- This car is impossible to get rid of...
- Is it normal for boost needle to move when engaging the clutch?
- well, from what I can tell, my clutch is toast...more inside...
- 19" BBS CH with 245 series tires will fit our car correct? offset is 35
- RS4 Air leather Shift knob... how different it is? is it smaller? better quality?
- OT OT i was wondering why the disney chnannel was playing ...
- Anyone have the need for an MTM H box stg1 EEPROM?
- how hard is the install....(all these views no answer)
- You might be a AW'er if:
- FAILED Rear Diff Mount
- Dying KO4, questions inside.
- What MarkP saw before the crash:
- well...i'll never curse myself again like this...
- 1 month after eibachs + bilstein, settled a LOT, pics inside
- 2002 S4 Avant (low miles) on Ebay
- bakersfield calling WMS....
- replacing steering rack???
- Who's happy with the OEM dual-mass flywheel with a ceramic or kevlar clutch? Any regrets?
- I polished my headlights today. (x-post)
- how to get a american s4 into canada?....and get it registered!!!
- Old school giac runs best w/ MBC to prevent boost spike? im guessing not to up boost
- Which fuel pump and oil cooler would best support ASP stg 3
- Starting issues - car starts but revs almost die off, only to return to about 1100 rpm..
- Has anyone done this and is it difficult?
- Any of you have one of these @ your house?
- can this flywheel be resurfaced and machined to like new conditon?
- Nick in Rear Caliper Piston
- Autospeed 85mm MAF sensor housing for sale.
- Anyone know where I can get flanges for the stock downpipes?
- Paging B5qship.....
- Pole: Whats the most boost you have seen on PJ K04's????
- Squeaky suspension means ... ?
- Where can i order just the terminals for a PC680?
- Stock B6 vs Stage 1 B5 vs Stage 3- B5
- On our way to One Lap!
- just wax'd a lightning :o) loving stage 2+,
- Cars going in for Cam adjuster seals, lw pulley, lw battery,...
- For those running RS4 cams, what software?
- does any one run the awe stg 2 or 3 clutch??
- Has the results from the IC comparo between AWE, IPP & RS4 been released yet?
- **GMG guys... sent email and no reply...
- Europrice Leftovers Sale, it's on the shelf, it's dusty, it's priced to go...
- RS4 Engine Value Question
- Train. Stabilizer Bar - will that fix my problem?
- Brake pad warning light, CV boot ripped, CV Joint needs replacing, and more fun...
- Does anyone have pictures of White Audi's next to eachother? (Casa vs Ibis vs Artik vs Polar)
- Where else to check for boost leak?? Checked TBB, DV valves, F-hose.
- Rolling shot..
- rolling shot!!!
- Newer S3 Vid. Hopefully not a repost
- Anyone know where i can get red smaco intake hoses ???
- City Light on ecodes... what do I need to hook it up? I got the w5w bulbs...
- Two Years ago I last saw my old car and then.....Here she is, my O.G. $ Pit
- Did johnnybravo ever finish his car? (Sant widebody)
- thinking of trying to get a 98 or 99 s4 from europe...yes?...no?....more..
- They are on. I love them.
- About to purchase Pagid blacks...few questions
- Installing some seats tonight... Will all of my air bags turn off if I don't use a resistor?
- how would a stage 1 S4 fair w/ a newer 350z from a highway roll?
- "piggie pipe" sale @ VAST, extended til May 31st, We have a large supply of cores ready to build to
- Some random pics from a car show I entered...
- I seached but found nothing... IS there a Intercooler fan for the SMIC??
- FMS Stem Caps --- Only $70 --- Order your set today!!
- electric fan kit. who is running one. is it possible to remove clutch fan w/o
- So besides some exhaust components is there anyreason a GT kit couldnt be installed on an Allroad...
- Casablanca white sedan, s4, hard as $hit to find, anyone selling theirs that has less than 70k miles
- w3rd, got the test pipe dps in, rs4 clutch and now rs4 ic's! woot!
- just was cruising around the hood and ran into a trailblazer SS. two older guys inside, gave em
- Blue Ebay vag cable. What do I need to get it to work.
- Ready for the track??? (Pics and Video)
- A couple of pics.....got the Volks refinished a while ago.
- i'm pissed my DTS hits on bumps. I am not even that low, but the biggest pain in the
- finally got some picks of the s in summer mode
- Yea i know its been asked, i searched but failed, Need to change my oil, best weight to use?
- Sorry if this is a repost...
