- Anyone else with ReplayTV recording LeMans ?
- Replaced Spark plugs. .Now getting Misfires code ... !!
- Got some new toys! Part 2, got everything done,
- what to get ?? stage 3 or rs4 bumper, wheels, suspension, exhaust, brakes.
- New Pep Boys "Energy Suspension" mount, to replace torn AWE DTS mount
- Catch Can Install part II
- Aren't Trans Am WS6's supposed to be pretty quick? I'm running an APR 93 octane
- need some fly wheel advice - opinions
- My ASP exhaust doesn't growl nearly as much as it does in the ASP sample vid -
- Replacement Bose deck speaker
- 1/2 synchro question...STFA
- we dont talk about speed density much anymore...
- Anyone feel like test driving a car in Lawrenceville, GA for me?
- Is $600 for an "A" box APR chipped ecu a fair price?
- X-post... need some exhaust help
- Any hood pins that don't stand out for my CF hood, I would rather go back to metal than run pins you
- CEL light on, VAG'd and got coolant temp. sensor code. This may sound strange,
- AWE IC Kit still for sale if anyone is interested. Link to updated classifieds ad in my sig. Thanks
- First kill of the weekend bmw 318 1991 with a fully built 6 cyl alpina motor cams4speed slap shift
- a few tech questions regarding afterrun coolant pump system, if someone could help...
- Help with VAG logs and diagnosis?
- 5MM Throttle Body Bolts 3 - Me 0.. APR BiPipe Headaches...
- I love my new wheel color!! Silver Arrow!!!
- anyone try powerflex suspension bushings?
- looking for reputable audi mechanic in northern/central jersey
- Paging SIMMPLY please come to the curteousy phone...
- new S4 owner needs advice
- I figured out why my ecux cuts out during FATS pulls
- Audible creaking when turning or going over bumps in the road - Upper control arms?
- is one org. gasket BW head and phenolic and sealant BW phenolic and IM enough? ASP phenolics
- ***IPP Intercooler Review and Install*** Thank you Sergio!!!
- Can someone tell me how I am hitting 23psi on AWE code without a TCD???
- If you have long term idle fuel trims between -4% and -6%, you should ______. (fill in the blank)
- LONG my baby (S4) decided to just die on the beltway last night. was cruising about 100 mph then...
- My new addition to the family.
- Recommendations on books for tuning Motronic ECUs?
- For those of you who have used BOV's or know something about them, does anyone have a definate
- Just finished a little fun project! hehe
- Help on DV's
- Paging Mihnea
- I am still looking for a replacement HID ballast. Is this the right one for our cars?
- steering rack replacement, need instructions
- pressure test help - how do i remove this hose clamp?
- Here is the fuel breakdown of the R8 and R10
- Cant get lemmiwonks to connect......STFAd
- How do you test if the Lidatek sensor/transponder is working? I tried my TV remote, which set off my
- How do I search for all posts made by a specific user? I tried searching...
- Gas Gauge Level changing from cold to warm up
- What is the going rate for a set of non-curbed S4 wheels with decent tires?
- Anyone know how to remove chrome from aluminum...
- Ever wonder what the big APR semi looked like?
- Homebrew Stage 3: VAST RS4 Airbox/MAF vs. VAST Open Element Intake vs. Other Options
- Has anyone heard anymore about the new carbonio in take for the S4 or seen it?
- ANYONE IN SAN DIEGO HAVE A VAG? I'll pay if I can use it.
- Does anyone ever use the passthrough in the firewall right behind the brake fluid reservoir? (more)
- *URGENT* Please help, big problem inside... =(
- Anyone know where I can find wood shifter trim and hazard surround? TIA!
- The tipper wont start tonight
- ANY b5 s4 owners in San Diego?
- Hypothetical question ... making your own rims
- 18x8 HP EVO...
- Got some new toys! hehe
- anyone know the offset of the oem b7 rs4 rims ? asked the guys at the audi parts dept..
- Have firm plan for catch can.. finally cut into new $100 spider hose
- Meet At VIP Showgirls
- ANY one have k04/rs6 turbos that they decided not to install from the GB?
- Paging lemieux@curbside
- Anyone have any stock MT DP's for sale? searched classified..
- Advice on purchasing an s4
- Stage II S/W...K04s...MBC...how much boost is safe???
- By popular demand wicked/VIP meet this Wed June 21st, at VIP Showgirls parking lot
- I attended my first ACNA DE on Wednesday and Thursday. Best money spent ever!!! (summary inside)
- Tranny gurus, grind and wont go into 1st when clutch in
- wheres the cheapest place to get o2 sensors besides zodmans ??
- WTF? Killing 2 turbos with 1 Bird? LOL
- X-Post: Thinking of selling my B7 S4 Avant...
- please post some pics of how you fabricated the gap(s) on your RNS-E
- So i went and saw it.......
- who here has taken the time to balance the signal lines to their BPVs?
- has anyone ever put these rims on their car - will they fit?
- woo hoo, FedEx brought me something from Tomasz :)
- Where to order conical seat lugs? Im looking for 20 lugs plus 4 locks
- Anyone know the thickness of a stoptech rotor hat? I need to order lugs and need that dimention thx
- Snowtrooper and others whom didnt get mail i sent today on fire your boss.......
- ECU Connector Wiring Diagram / Rev Matcher Mod
- Looking for stronger hose for the blow-off valves
- S4 + big turbos = FUN S4 + bad mojo = NO fun
- (X-post) should I be concerned with this rust on new Stoptech rotor rings?
- Couple quick questions....
- Anyone around Massachusetts/RI with Vogtland coilovers?
- If I have an ECS magnetic drain plug + copper washer do I need any other crush ring? 9/99 build.
- Paging ecux@goapr.com, check your mail.
- Weird reverse vapor-lock issue
- [TUESDAY June 20th] Don't forget GTG @ The Stand (LA/SFV) next week at 7:00pm
- After recent discussions about loading on dynos, I decided to look into it a bit more...
- Took off my bellypan and found oil coating everything. What's happening?
- anyone have experience with the AWE Stage 3 race code (100 octane)?
- How much should I ask for my APR Chip with Stock/93/100 and my piggy pipes? Just got 3" Dahlback
- Which swaybar combo?
- Ashtray removal? The archives thread pic doesn't look like my ashtray?
- So my buddy literally killed an S4 this morning in his C32...
- Fan Clutch install - is this a reasonable DIY job? Can anyone provide a walkthrough for me? TIA
- motor and trans out for stage III, 70 k should I replace starter?
- *** 2006 CT S / RS Drive Vids **** (AWW)
- I've had a revelation...
- What is my car worth? :'(
- What's the average life span of an alternator on our cars? Mine literally died...
- I upgraded my dampers... now sway bar questions...
- Milla Racing weekly GTG. S.E. PA & 'Jersey guys. Who's' going tonight. Tons
- I am the one having the mtm chip not boosting past 7psi. what is limp mode. No codes showed up.
- You gotta laugh at all of the drunk posts that show up in this forum @ night. I
- Got some cheap rotors but one side has rust, best way to clean them ?
- Everybody show your love, props to ckymike everyone has to hand it to him.....
- MTM CHIP ISN"T BOOSTING PAST 7psi HELP
- GO HEAT!!!!!!!!!!!
- Free tickets to AMA Superbike Races at Miller Motorsports Park in SLC, UT this weekend
- with all teh weight reduction talk, what about moving fuel cell to spare tire well, >>
- What else do I need to build a RS6 fighting Allroad?
- Anyone know where I can buy a european trunk lid..not carbon fiber???
- Help. Rattling sound coming from behind the timing belt cover? Loud at startup then gets more quiet?
- Magnet Mod 75% completed!
- need new o2 sensors will universal 20cm long 4 wire sensor work link inside $33
- New exhaust pics
- where are you guys buying N75's from these days? cheaper than $83?
- What temps do you see on the track (road course)?
- first ecux log. looks like my computer is too slow
- It's about time that I get my suspension set up (closer to) right.
- ABS/Brake Light blinking problem...
- Is a BOV sound on stock 710N's indicative of a bad bpv?
- Flexjoints okay on these dps? Don't know if they are fully functional now...
- New exhaust installed today!
- So 1600 mbar = .6bar = 8.8psi?
- Rakc and pinion boot cause leaking???
- Boost Log comparisons (AMS vs GIAC version 8, not flashed). I found it interesting.
- Catch can Installation
- Wow while searching for vw o2 sensors i came across o2 simulator for 7.50
- took some pics today *preview*
- ANyone have a Pic of the S4 logo on a 2001.5 versus a 2001 and before?
- Anyone going from Las Vegas to Orange County soon? I would be willing to pay them to transport
- Don't know if its a repost but it's sad someone would actually do it.
- GUYS, ladies, transgenderds, what is accurate 0-60 time for a stage 3 b5, and quarters, on 91 0cT.
- omg i am a complete dumbass.... "CV joint kit - front" is only for one side???
- brake fluid...pentosin or ate?
- Neuspeed 19mm Swaybar Group Buy
- Looking for a 944 LSD differential, anyone have one they are willing to let go or know..
- When buying a clutch from VAST, would you go with Ceramic or Kevlar and why?
- Too Funny!!!
- who has a copy of that audi s4 ad with the leopard in it?
- $50 for diverter valves! And i need 2...
- Anyone around the Boston area with Vogtlands?
- Vote for one of these 3 wheels (all are 17x8.5). TIA.
- Climate Control On Board Diagnostics?
- What size (ID) hose are our fuel lines?
- If i ordered my x-i intake for a AWE maf and RS4 intercoolers would it fit a stock MAF and
- I think this fender is flared ;-) anyone have more pics?
- Computech youve converted me I think Im getting ready to move down to the B5 and some ko4s
- Xenon Self-Levelling problem
- So, I've come to the conlusion that I may be SOL when it comes to 17x8.5 wheels.
- Repost for morning/afternoon crew: STFA and no conclusive answer on groan from front of car...
- Anyone on here have Volks LE's on a Santorin(Avant or Sedan)? Also..
- Check Engine??
- Anybody know what's the thread pitch on the rear caliper brake line hole? I thought M10x1, but no.
- Anyone here near Berlin that can help a former S4 brother out?
- Latest mod.....my personal tag...what do you think?
- So what do i do now I can't find M1 0w-40 or Castrol 0w-30, I did find M1 5w-40, what do you...
- Looking for a chipped abox. please email me if you can help me out.
- how does one seal the pressure tester to the Ypipe?
- Tip Fluid Flush
- AudiBMW.com Racing in car Videos on front page
- AWE Cold Start Issues Update - New MAF..
- this may be a silly question however...
- Repost for morning folks: Pressure test is showing leak at the inlet pipe to turbo junction...
- Question with boost (MTM chip). After install, still seeing 7 PSI...
- confirmation on part to fix problem please...
- Can a flaky EGT cause APR software to limit boost?
- Rusnak commercial?
- so is it going to be easier to rig dumps for dual 2.5 or single 3.5"?
- Anyone have a pic of the GIAC X chip?
- WTF... start again....Logging issue..
- foglight reinstall....yes or no..??
- Thinking about buying a B5 S4...
- Thinking about getting PSS9s... some questions
- Help. Replacing coolant temp sensor and aux fan thermoswitch. Where are they?
- Which Ignition Coil is #5 relative to facing the front of the S4? TIA
- quick question: b7 rs4 vs. e46 m3 cs on a race track...who will win?
- What spoiler is this and where can I get it! I love it!
- Whats the purpose of relocating the sensor for piggies? Do you really have too?
- Overboosting help....
- for those who filled in the front plate portion of the rs4 bumper...
- so in relation to my post down below...Does stasis use brembo rotors in their kits?....
- Feeler poll/post (not a gb post yet.) How many of you would be interested in a group buy on a
- What's a fair price to charge for installing a timing belt for a freind?
- Just got the AWE pressure tester from UPS...however, for those of you who own one...? for you:
- 2006 CT S/RS Drive and BBQ
- STFA and did not find conclusive answer on groan from front of car..
- This guy mixed up his tire shine with his spray paint (sorry for crappy cellphone camera pic)
- Just had my manifolds coated...
- Last night, my coolant temp gauge was way low while my oil temp was at 200*... is something wrong?
- Tranny versus rear dif fluid... Different weights??
- Its time for another round of .. Name that Part!
- since soo many want to see more wheel pics i gave in took pics with car dirty! Sticker warning....
- Wheel fitment/offset question
- Are these front sway bar links installed correctly?
- Locking or Non-locking Hood Pins for Carbon Fiber Hood?
- What would be a fair price to pay for a used Samco TBB?
- What is the Latest GIAC code? and when was it released? For K03's
- hit or skip on front grille and or rear
- OK!!! Finally found the problem.. with Mike Piggy : p
- Just in case you needed to throw up in your mouth today..
- Well my engine is apart... turns out all this hassle was over a snapped head bolt!
- Rough idle
- I got the last pair of Ko4's in the US. I don't know how.
- Stoptech/APR 332mm BBK guys: best prices for replacement rotors?
- ::Update:: new log with wideband..
- Andrew C. YGM - RS6 SMIC's
- Riddle me this: tip FATS = ? HP...
- 24 Hours of Le Mans this weekend!
- DVD FILMING/CAR MEET FRIDAY-PHILLY
- What's the full filename for the lastest x-chip code (I believe it contains L308X).
- TECH SESSION ON 2.7T REMOVAL/INSTALL/UPGRADES
- Cool, got an email back from Sergio/IPP
- Anyone have a blow up view of the front suspension?
- Avant just went over 100,000 miles, not sure whether to be glad or sad.
- i'm about to post some items in the classifieds, if you want to save me the time e-mail me.
- OEM RS4 bumper folks: how exactly do you remove the center grille mesh? TIA.
- *edit* X-1_Racer *I* put up those PSS9 instructions in my picposter.
- Couple of track pics from the other weekend
- Lidatek folks: how do you feel about mounting the transponder just to the side of the plate (m)
- Need Advice, Re: Oil Light
- why RS4 motor mounts $100 at purems and $130 at awe? are these the same?
- Help! Boost leak in hard to reach location!
- Who else, besides ASP, can offer good custom tuning and what might it cost?
- Oil cooler... which brand/make/model do you run? (for those that have added...)
- Anyone driving to Orange County from Las Vegas soon? I could pay some $ to pick up some wheels for
- 2001 Audi Certified S4 Santorin Blue W/ Alcantara Interior For Sale
- Where is there a passthrough into the passenger compartment from the firewall? I found pics for the
- POLL: After a hard track session, what are your oil temps?
- Do I need a "powered antenna adapter" to get good radio reception?
- Apexi Update !
- Feeler: Any interested in trading ASP TruDual for AWE Twin1?
- My photos from the S4/RS Drive in Danbury, CT.........
- X-Post from Motorsports forum... Missing my S4 at the track :(
- Audi Collection / Vibrant Exhausts are once again avilable.
- Why is PureMS' website so damned slow?
- Paging Imola Baby...
- I talked to a company about the ClutchMasters stage 4 clutch. They say they can get it in an 8 puck
- paging 808Guy...YGM
- Couple new pics from this past wkend
- Rear speaker wiring
