- Another case of misfires solved ->Another driver's exhaust cam & lifters bite the dust
- Stratmosphere Year End Clearance 2006-2007
- How much power steering and coolant do I need if i drained both of them?
- Anyone had an Air Bag light with no DTC? Light stays on when cold and then eventually . . .
- RS4 Cluster at night money shots:
- Need some insight on my logs
- Blackstone oil analysis results not good. (long)
- "GREAT" deal on fleabay for RS4 mirrors...check it out
- KW V3 or STaSIS Tracksport
- Display on my cluster not working
- is the ko4 upgrade all bolt on?..........
- Ipod hook up
- Guys: I'm about to pull the trigger on what is probably the best snub mount I have ever seen
- Same coolant issue interesting conversation with the dealer
- What is the thread length of the standard bolts for the 6 spoke D2 S8 Avus ET 48 18 x 8 wheel ?
- Which color leather to get?
- what size hex is the heat shield for the driveshaft?
- Does this look like a blown H&R.....Any ways to test when off the car?
- Jeremy@matrix is the hook up....600 for ko4 inlets and hardware to my door...
- My new RS4 Cluster just arrived!
- Lovin the AZ cold weather!
- O2 Simulators, Non-Foulers, ???
- about to install streetsports - how do i set it to 25.5 before putting them on?
- Look what I got in the mail...
- Anyone have TSW volcano/nogaro/thruxton rims on their B5 or pictures...
- what is the clamp size on the hoses attaching to the Y-pipe???
- what could i expect to pay for a clean stg3?
- Am I dumb or confussed, Please answer
- Does anyone know what the stock injectors lb. & flow rating is? TIA!!
- EPL is pleased to announce the introduction of stage 1,2, and 2+ software.
- Woo Hoo this is what cold ambient can do to us *Socal folks* more inside
- Using VAG Com, How to troubleshoot ABS Module and Speed Sensors?
- asp exhaust question/poll thing
- What shop has the cheapest ko4 inlets? I have to order them today.
- To any of you S4 owners in the Madison, WI area.....
- Going through some old bookmarks...OWK memory....
- Is ~40$ a good price for replacing the steering wheel badge?
- i am thinking about going on the AKA rally this July. What should i do to my car so it will be up to
- Those who have done the RS4 clutch / Lightweight fly from AWE...opinions?
- update on my awe rsko4 phenomenon - question
- AWE Tuning Holiday Sale Extras
- Cold weather and coolant light
- Has anyone put B7 RS4 reps on a silver B5 yet? Photos?
- Thoughts on MBC with ASP stg 3 kit please...
- APR vs. GIAC stage 1? And whats the difference between Flashing it and getting a new ECU?
- OK somethings not right and i cant figure it out...
- No0b pole. Who *does not* have access to a VAG-COM tool?
- Many Repairs Which Should I Do
- is bi-pipe worth it money at $300...just install a new OEM TBB tonite.
- For a AWE Stage3 is 20psi about right? or is that low.
- Engine has to come out for the frame to be fixed...
- Highly recommend Wheel Collission Center for refinished Avus Wheels
- Ok I hope to find answer -awe rsko4 Q - everyones baffeled (long)
- For those wanting a Casa Avant...
- full boost
- Going APR stage 1 - ICS (Stamford, CT,) RapidParts (Monsey,) or ship ECU to the mothership?
- Tony from EPL broke my seat!!!
- todays dyno run awe stg 3 w/ tcd/mbc (fixed pic)
- How much time does Audi say it takes to replace a thermostat?? Is there...
- What i am doing wrong at the track? ...........
- Snow tire vibration
- Anyone know where I can get a the front core support...
- Question about TCDs.
- anyone know if the 18" S8 Avus wheels will fit over Cayenne Turbo calipers?
- Do all the 2001.5s have the same key remotes? 3 buttons total, same FCC ID and all that...
- Anyone here run these RS4 DTM reps?
- hmm..am I getting raped royally or what?
- My fog light(s) randomly shut off when they are on sometimes, anybody else experience this?
- Good deal PSA: Four 235/40/18 General Exclaim UHP tires with road hazard : $490 shipped.
- Indy shop that my H&R strut is blown?.....help
- Group Buy for extended warranty about to close...
- A4 vs Dog in snow. Vid. Possible repost, but I hadn't seen it.
- Quiet stroll down memory lane. Sorta.
- Where to buy 68mmOD/57.1mmID hubcentric rings?? I also have free rings for
- Anyone have a stock MAF housing laying around?
- Strange Surging in 3/4/5/6 gears
- Tie Rod Ends?
- Is anyone running the new Dunlop Wintersport 3Ds in 235/40-18?
- Possible to remove the radio without the special tool? Trying to remove all the trim
- 2001 S4 Avant Oil Cooler size
- FYI if you need new locks.
- RS4 Injectors for sale
- Who posted the pics of the custom piggie pipes with the.............
- I am giving up and pulling the engine now.....hopefully i can do all the prep work today and
- Bars Leak's still holding strong, coolant contamination falling slowly, oil analysis inside
- I love my OZ SL's but the finish on them is getting old and tarnished. Should i A. buy new wheels
- APR Holiday Sale Continues!
- What is it with Folks driving there S4's like Sally's
- Major APR announcement
- Anyone have contact info. for a B5 S4 owner with the handle vwaudidriver? I'm
- Poll for the stg3 folks. How many are running Samco TBB and how many APR bipipe? I need to make some
- Help me decide 235/40/18 or 255/35/18 all-season tires
- Mike2kS4::ASP and other ASP k04/RS6 cars, just curious on your dyno numbers??
- My Xmas Present
- Any reason I can't fill (bondo or whatever) and paint over the front license plate holder panel?
- SIICCKK silver wide body S4 with HRE black wheels at "the shop" today in norwalk ct...
- Feeler, is there still a market for APR K03 software?
- Does anyone have these wheels on their B5 S4?
- Throttle Cut?
- so wait.....whos GT kit is the best and makes the most legit power now?
- Anyone need a stock exhaust??
- sorry i just have to LOL.. not even the crickets will play a tune here now...
- boost issue/boost controller question
- Does the 2.7T just inherently have a somewhat rough idle?
- Does anyone have a custom installed Garmin Navigation?
- Well well well.... Check out the new SIG!
- Cracked Avus rim is the cause of my slow leak - any good places to find a replacement?
- Opinions on getting OEM RS4 suspension? I have an avant and can pick up the coils/struts for cheap
- Map sensor information please...
- Attn. Stage 3 owners: How many miles have you been stage 3±, And for how long
- Anyone got one of these?...
- bbs lm...
- Pic request...B7 RS4 reps 19's 18s?
- Has anyone tried the 034 Snub Mount Bracket yet?
- holysh!t, CJK did it again! on pump 92
- DP O2 question: I am doing a piggie DP and Twin2 install..
- Hit or skip. Is ADR a good wheel or crap?
- Lets play guess the parts supplier.
- how well does the anti-fouler method work for piggie pipes?
- OT: Anyone here a high school driver's ed teacher, or a high school teacher in general???
- best sway bar kit out there?
- Anyone know a company that makes in car video recording gear??
- THANKS IN ADVANCE!
- Can some one give me the B7 RS4 brake caliper and disc part numbers ?
- Job opening@APR
- Just checked my 710Ns during routine pressure testing. Still AOK after 35k miles.
- once the heat shield above the turbo and DP for the driver side is unbolted, how do you get it out?
- Anyone ever order anything from parts4vws.com?
- is the stasis 4:1 center diff worth getting on a stage 2? this car sees alot of
- FYI. Meyle tb tensioner failure in an allroad....
- tracksport 700f/800r for daily driving?
- After the talk of BBK and stopping distances.....
- for those of you who replace oil pan, does it come with gasket ?
- Who likes presents? Your Audi does! STaSIS Race Down the Chimney Sale is still going strong...
- Has anyone been successful with getting K04's done on on CPO'd at the dealer?
- Engine is back out and sure enough its the turbo's causing the smoke on decel...
- 1 Week until Christmas
- is this an accurate quote???
- My dad's A6 HID's do the auto-level thing at startup, my 2000 S4 doesn't. Is something wrong?
- what causes auto-dimming mirrors to go bad?
- Poll, how many in here have driven every s and rs car made
- AWE Tuning Holiday Sale week 3....It's turbo time!
- If you could build a custom 6spd, what options would you have?...
- Out of Maroon Shirts in XL... So far $108 has been donated to Matt Ammon Fund.
- Is there a DIY for making clear corners?
- Just got the car back from the shop. Headlamp toubles. Any tips?
- Was reading a write-up on downpipe removal from startup racing's website...
- re-ring
- have any of you forgot to hook up your hood latch cable ? if so how did you get the hood open
- Ebay exhaust manifold. Should i get umm
- How many of us does it take to change a light bulb?
- Who sells a new rear view mirror for my 00 S4 black color? Mine stopped dimmin..
- In case anyone cares anymore, here are the results from JD/Piggiesmalls' ECUx logging tonight....
- I have a new found appreciation for how viciously fast a Stage 3 B5 S4 is.
- i need RS4 lower grills, anyone has them?
- 'Bahn Burner's S4: 1, Porsche Carrera 4 Guy: 0
- have question and already stfa (much more) someone please be up!
- I have a very, very slight leak (looks like just a couple drips thus far) on the...
- piggie o2 relocation question
- 2000 S4 Seat Cleaning
- I just took all the weights off my wheels but one and put in spacers. Why are these spacers making
- Does the frame rail just support the bumper ?
- After all this discussion about spacers...
- For those who have done piggies with the car on jackstands, what was the worst part?
- Boost question
- Last spacer question, this is a serious post....TIA
- In the holiday spirit, here's a funny repost
- Help with codes after fixing my coolant aux pump.. i start the car and get "fuel level too low" and
- Spacer question.....
- Definitive spacer answer needed please...15mm?
- Considering Stasis 4:1 Torsen. Who has done it themselves and how difficult was it? What was your
- Coolant leak help
- Since it is dead in here....
- center airbag removal question...
- The Silver State Classic Challenge- "fastest open road race in the world"
- Sorry to Repost, But does anyone know who has RS4 Intake cams in stock? Everyone I've tried is out
- crack my oil pan, where can I order one quick ?
- Bunch of pics from me, laseravant s4 and mpresiv yesterday. BBW!
- Finally, some logs and first hand impression of my custom EPL Stage 3 tune.
- does anyone have a used / worn blown passenger side k04? need one asap
- Who sells LM's and will they fit with 15mm spacers and a left over silicone hose?
- suspension noise help.....post wheel bearing install.
- hose kit question
- Look what Santa brought me.... escargots
- Noob question of the day. Is a 225/45/17 larger than a 225/35/19?
- [absent are even the sounds of crickets...]
- who's the vendor to speak to in regards to ordering a set of bbs LM wheels?
- Another ebay post what do u think
- Addco Manufacturing Rear Anti-Sway Bar
- What is wrong with powder coating stock wheels? Anyone have some black stock wheel pics?
- I'm just wondering if anyone that is running spacers(10,15MM etc..) get any vibrations?
- avc-r speed ?
- Anyone know anything about these two wagons??
- ill do my good deed of the day...ebay...ya got 50 minutes
- Paging S4Poor..or anyone else that uses that ISSPRO gauge...
- Who thinks that we can fit a W12 twin turbo'd in our chassis?
- 1650 to my door. WOOT WOOT!
- where can I get a FI CF hood that the price isnt jacked up lol i need one badly lol
- I really can't get the leveler motor ball back into it's socket on my headlight.....
- First logs after homebrew stage 3 upgrade...
- ABS controller repair; The solder won't stick!!! HELP PLEASE...
- Anyone selling some clear corners? I have looked in the classifieds.
- Do spacers affect handling/performance or are they just for looks?
- so HALF of my Stoptech 355 setup came today.
- Has anyone made thier own inlets. I found a muffler shop that can do it if I have the pipes.,,,
- removing left center pillar airbag...
- Anybody like this? Trying to figure out what to do with old rear badge...
- Jacob, thanks for the great work. Turbo's look awesome.
- Can anyone commment on..
- Where can I buy a Neuspeed rear sway bar, could be used also if any of you guys have one....
- MTM 15mm Spacers Installed Pictures...S4 Wheels are a bitch! to get off after you remove the lugs!
- Remote signal on stock bose amp, 2001
- anyone ever strip a bolt on the heat shields? its a allen bolt....how do it get it out now?
- Anybody around Winter Park, FL? I need a favor...
- woot! passed inspection with flying colors...
- STFA already, kill me if you must...but details on X-1 production now?
- New addition to the family..(some s4 content)
- Did Revell ever do an S4 model you can build?
- Jeremy@matrix has a group buy on Ko4 inlets. 476.00 for 5 or more. Anyone interested?
- On the subject of fuel additives...we discussed it alittle last night, but as far as
- A4 sludge removal methods....will these be ok to do on our cars?
- Paging Dr. Jerkyl, I just installed the MTM 15mm Spacers, the car looks great ride is fine I dont...
- Custom Chip From European Performance Labs, and my entry into the S4 world
- Has any ASP stage 3 k04 or rs6/k04 car run at the track yet? Im curious on times.
- O2 sensors have normal threads right? not opposite threads
- How many 1.5L bottles of G12+ do I need to get from PureMS to fill my cooling system
- Thermostat direction
- Timing Belt Writeup
- Rear badge placement. Pics please or measurements...
- Saw an X1 intake in person yesterday...
- What is this thing for?
- Anyone have an extra dash cup-holder laying around that they want to get rid of ???
- ASP Stage 3 Impressions
- Paging das achtzig: what are these seats in your picture poster??
- Where do i get the RS4 lower grills at Doggs
- Upgrading from A4 to S4... suspension compatibility questions...
- Can't find my boost leak. Today I installed new TBB and 710n's, but I still hear a BOV when
- any lawyers want to clear something up for me?
- Thanks to Jeremy and Matrix Integrated for the usual no nonsense great service . . .
- Do you think AWE will still let me get the holiday deal on mon???
- ASP Stg 3 vs. VAST Stg 3 programming on 91 oct
- ASP strikes again - this time branching over to allroadville
- Someone earlier posted about using torco instead of race fuel for the apr 100 octane
- Are my catalytic converters dead?
- Is it safe to install these MTM 15mm Spacers? 3 of them dont look right...
- Something AW should concider: On AZ if you run your mouse over a thread....
- Where do you guys get your Motul gear oil? Purems the best price i can find so far...
- when is the ASP FMIC coming out?
- LTFT help- What may cause my LTFT's to be super rich? I can reset the trims and within...
- When converting from mbars in 115 logs what base pressure value do
