- Best riding OEM size tire?
- new generation of HCCI engines on the way - interesting article
- 1,2,3 or 4?
- 2002 S4 Front Ash Tray
- Get your detailing gear for the Labor Day Weekend 20% off
- Got my first oil analysis back. Clean bill of health! Now to stretch those change intervals...
- NEED HELP!! How to properly drop sub-frame for DP work
- What the heck is up with these codes.? LTFTs don't look that rich. MAF? Leak?
- Whine and vibration BT: recently had the followin done, rebuilt drive shaft, new RS4 clutch, PP, etc
- 22.1 (F118) A/C Refrigerant High Pressure Switch, static open - does this mean bad switch? or leak?
- Ohlins upgrade
- Anyone have an Icelink or a M3 lip they dont need
- Anybody do piano black on just the 3 center trim pieces: ashtray, shift surround, etc. leaving wood?
- The Master 6-speed B5 S4 Avant Thread
- Any complete write-up on brake fluid flush? Didn't see it in the techarticles
- Anyone using the Power Gasket intake manifold gaskets?
- How can i tell if I need to replace the front rotors?
- So i Solved my Clunk!!!!!!WoOT
- Has anyone had to replace the rubber guide booth on the rear calipers?
- stage 3 guys: what TBB are you using and how do you like it? already STFA too.
- OT 0-170
- WTF?!..... look at that hood alignment though, and hideous body kit ;)
- Paging Visintainer [vis] - YGM
- Someone recently posted a cheap fix for sagging side skirts...
- S Fest Pics
- Totalled...=/
- Considering a B5 purchase
- $445 for AWE race tune???!? Wasn't it just $150 a week ago?
- Hey Guys, anyone have, or know where I can get a Milltek 3" exhaust clamp?
- Uh...have you guys sen this yet? (RS5)
- RS4 Motor Mounts?? 109$ is the best price i can find. Anyone have a better Lead?
- Help me choose a wheel, have to replace ABT's that finally bit the dust
- Need a tip. Did driver's side O2 sensor and when moving coolant reservoir...
- B5 dying off.
- Cross-Post from VAGCOM forums about immobilizers....
- What do you guys run for street tire pressures? My Falken 235/40 -18's don't ...
- The plastic on my 4 bar FPR cracked while pulling it out. Does anyone have a spare?
- clutch hose broke on me. how much do these things cost?
- Okay, now that I've already done it, is there a better way to change front rotors ..
- new M3 4dr.... THE UGLIEST M3 EVERR produced?! I saw one this weekend and I almost puked!
- Anyone catch T.Richards B5 RS4 in this years Gumball? I was flicking channels and saw that beauty on
- Shameless: To those who upgraded to ER ICs.... what did you replace?
- Comments on ECS 993 BBK?
- Anyone have a spare PURGE valve, located near the N75 valve?
- Best place to buy euro wiper kit? Other than ECS Tuning...
- am i the only one who thinks this insane
- I went to the track friday. My times and question about launching.
- What's the best way to fix a bad ABS controller?
- one more TIP stg3 poll, fellas.. your turbo option, TC build, stall, and >
- Has anyone run (or know anyone who has run) the coupe quattro clutch/flywheel setup on our car?
- I don't know about ya'll but my car in hot weather, 90 deg+, runs like poop!!
- side view mirror, price difference left and right?
- Another Up date on botched stage 3...car dies after 10 secs at idle...
- Why don't we build a Bonneville car, Gear ratio charts please, Euro TDI etc . . .
- Whats the best setting for the h sport rear bar for agressive driving?
- So when will ER shrouds become available?
- Anyone know what wheels are on the silver TT on the audiworld.com opening page?
- Which 18in Wheels Should I get??
- Part # for broken hose behind intake...
- Central Lock Pump Disc
- Our bumper supports and such should have 4 bolts each going to the subframe right?
- NT test...
- Just a picture I took...
- stfa- but search didnt yeild much. Anybody have recommendations for a street battery?
- Twin scroll turbo tech talk.
- went through a sobriety checkpoint on friday. this french cop complimented my car
- Anyone try 2006 A4 S-line 18" wheels (RS6-look)
- Timing Belt woes, part 2.
- We dont have strut bearings right?
- Is anyone from Raderwerks on here?
- Oil return plug removed. Turbo ok. However there is a coolant leak somewhere...
- Who's going to Dubs Along the Rockies tomorrow?
- Do u need a vagcom for a throttle body adaption or does the car do it automatically with the key on?
- Where can I tap 12V constant, 12V swtiched under rear seat wiring harness?
- discovered this today
- More Duryea video (external)
- M3 Deal ? . 2003 SMG Grey / Black. 52K miles Excellent condition. 25,998.
- Convince me to go with Water Meth Injection Route
- NVH BT: Already STFA'd but can't find source of my dash rattle coming from
- K03s KO'ed best solution?
- How do you pre-oil the turbos??
- Paging anyone with an RS4 cluster. my speedo is reading way higher than what it is supposed to.
- Will an 18 x 8.5 35mm ET Wheel w/5mm spacers require...
- Does anyone know what threading the EGT sensors have? While reinstalling it into the
- anyone know how to change the trip meter, and the fuel mileage from KM to MI? I have an RS4 cluster.
- Slight "gear" whine. I'm getting a very slight whine from the front of my car. I hear it when going
- Camshaft adjustment code
- Zeitronix finally installed!!! Did some testing and car is running pig rich...
- Vast Oil cooler
- I have access to a brand new rs6 cluster. has anyone ever made one work in a b5 s4?
- Anybody have their Phatbox stop working...then start working? <more>
- Need some advice (long)-
- Possible to swap OEM parts from stock headlight into Depo ecodes without swapping housings?
- Update on smoking stg 3: Drivers side IC hose full of oil...
- Does anyone have a used throttle body they want to sell?
- Island Dragway NJ tonight anyone, for test and tune?
- What's a good asking price for my car? (BWW)
- Repost: PureMS.com Summer Coupon Codes!
- Would any of you offer some opinions on the value of this listed S4?
- Hawk HPS street vs. PBR Axxis / OEM - opinions for daily driving. Cheapest place to buy?
- Post your favorite Audi video.
- Anybody have a used cluster with the new emblem lying around?
- How do you get the correct tooth for the timing belt?
- Does anyone have the link for those electronic dumps? I am going to my exhaust guy today
- Do I need to replace my throttle body? Please help me......
- My car was too low going into my new garage and dented where the DPs meet the exhaust. ->
- Started my car today after Stage3 install. White smoke coming out of...
- My car (stg 3 AWE)was running HARD and perfectly up until this:
- Tale of Two Spark Plugs: or, Misfires at high boost 101
- Need to trade my GIAC flashed A-box (year 2000) for a stock ECU. Anyone interested?
- i can has LCDz?
- Is the Vibrant Cat Back exhuast any good?
- after hitting 7 years of ownership the other day... I gave her some goodies
- Need Front Door Midrange OEM Bose Speaker or Replacement Suggestions
- Is anyone watching this "Auto Theft Task Force" show on A&E?? First bait car was a B5 A4...
- Oil pan has a small hole...any write ups, tips on how to remove and re-install new one?
- symptoms of waste gate failure ? what am i looking for here...
- Paging HdiaS4
- Good deal on silver 6-speed avant for someone
- secondary water pump?? best priced one out there.
- Black smoke under WOT
- has any1 ever used this brake rotors:
- Anyone have a black (sport package) ashtray they're looking to sell?
- ACHTUN!NG | 235/35-19 tires - $600/set with 19" Wheel Order!!
- OK, so I stfa, and only my one single post appeared, has anyone ever heard of, or used a VAG TACHO?
- any updates on the vogtland gt group buy anyone?
- Gorgeous Nogaro (poss. Santorin) w/ silver/black wheels northbound on I-25 btw. CS and Castle Rock
- B5 RS4 IC bracket P/N? Thanks!
- Anybody tried B7 A4 S-Line wheels on a b5 s4?
- Oil leak - top left side of engine down to left side of oil pan, any ideas?
- o2 connector to ECU - wiring diagram from bentley anyone?
- Thanks for the info SUV! That is all ...
- Did I just f-up and order the wrong coilpacks? 'R' version
- audikillsbmw YGM and Paypal!
- Anyone have a copy of vag-com ver 504?....
- show me your zimmermann rotors!!!
- Anyone have any carbon trim for sale? Looking for ashtray and hazard surround .. TIA
- Stage 3 question: What are all the kits that are available and price? (m)
- Leaking oil and need help diagnosing where it comes from
- Anyone selling their 332x32 big brake kit- used? Looking to upgrade my Brembo
- Sorry to hear Carson...glad it got recovered and hopefully they
- Cargo net: Those that bought the Jeep one... You just get it from a Jeep dealer? What year Cherokee?
- Anyone know the part # for the shift boot frame or know where I can find it???
- I was trying to find the post of teir 1 gas stations. Did a search no luck maybe stating it wrong?
- CarlisleEvents.com #06 Audi S4 Hill Climb video
- maybe someones S4s will be on this???
- Question about plugs. I did the seafoam treatment yesterday in hopes it will help with my
- For those with Alcantara seats: How has the material held up over time? if you could do it again,
- Does anyone sell the S4 Logo on the steering Wheel???
- Noob S4 owner (not noob driver) had dumbazz in Evo MR wanting to race...
- Bad headlight wiring harness/wire?
- Gotta love ad's like this one one- I'm not buying the mileage either.
- Newb Question about S4 Chips
- hey what does a stage2+ do in the 1/4mile
- X-post...my GTI was stolen last night.
- Check out my video. It will give you a laugh I think
- my new ko4 stage 3 minus 00 a6
- Hey Chicken Focker's... Code p11289 and P1127, Fuel trim bank 1 and 2, too rich..
- what does the fastest Stage 3 Minus 6 speed Run at the track?
- Just got car weighed: 3,880lbs with me, spare, 2/3 tank of gas. No cargo box, rack or usual gear,
- I need a bumper so f'ing bad. Can someone help me out?
- Need someone with timing belt experience that I can hire ? NY/NJ
- Rear bumper question: Looks like the bottom can be separated from the top half? Separate part?
- part number request for pass side fender. Thanks!
- ECS makes me mad :-\
- I am still looking for a UUC shift knob wieghted ofcourse. who would like to sell?
- Snapped a few of my Imola Avant
- Oil Poll. What type and weight of oil are you using ? I.e. 15w 50 Mobil 1
- running rich
- R8 trying to swim? WTF
- Stoptech 332's and Falken Koblenz 19's question
- Going Back to Thepooj guys problem (diesel engine noise), I have the same issue
- Searched but didn't find a good DIY for installing the StopTech Stage 2 brakes ...
- Which would you rather: Mint 01.5' S4 stg2+ Casablanca White or High mileage stage 3/GT other?
- Best source for DBA slotted rotors?
- Is there an AW acronym list? Something that explains FTW, FTL and the like?
- Is this avant a good deal? Clean Title 2001 Audi S4 Avant 99k mi 6spd 1 owner no upgrades stock $10k
- will some sell me there uuc rob knob. I have a rs4 shift knob and or cash to complete the deal
- license plate lights, one works one doesnt? cleaned the contacts,
- I can't fill my tank! Anyone have any ideas what would make the pump click off?
- I love driving my car only on the freeway... 357 miles to the tank!! Filled up with 14 gal ~ 25.4mpg
- A stage 3 ASP chip doesn't have ASP written on it anywhere does it? Sold a chip to
- OT: What do you think will happen to the price of used B7 RS4's when the B8 S4 comes out? Drop/Hold?
- Any Nice BBS CH replicas???
- will rs4 transmission mounts hold up to hard launches? i dont want anything stiff because of vibrati
- buying 2001 s4
- $460 for an autodim compass rearview? Anyone got a cheap source?
- Narrowed down my misfires but what do you think? Not POS, not Egt,
- Broken Spring
- Anyone have a AWE stage 3 kit MAF screen?
- Does EVERY S4 have a pusher fan? mine doesn't and there is no orphaned wire. Why?
- Next car? S5 with Alcons/Drive Select... RS4, or Cayman S?
- Which remotes will work for our cars?
- KMAC FRONT CAMBER CASTER KIT
- ECU upgrade decision- anyone know about AUTOSPEED vs GIAC vs APR
- how to be confident that the oil and water lines to the turbos are good?
- need brake/vacuum help
- For the VAG Guru's (and yes, I STFA but didn't find much) ...
- Thumbs up to Eric@SPP, he got me square away on muh track wheels
- can drilled zimmermann rotters be turned/resurfaced?
- oil change quick question
- I need some of these.... (part number request)
- Can my buddy replace his B5A4 headlight housings with B5S4 housings directly?
- Transmission Woes Part Deux...
- Manual Boost Controller
- Post-motor/trans/diff mount install notes and review
- ASP Stage 3 loss of boost
- Scary, costly, (lucky?) rattle
- ignition switch?
- If anyone wants I Have a brand new After Run Coolant Pump Thermal Switch for 30 bucks shipped
- Transmission Woes, Please help! (Long)
- VAST 2.7T Oil cooler kit now available!
- Seafoam: I am going to clean my engine today.Is there a write up on using it on a 2.7?
- Any problems with having car on stands with suspension unweighted too long?
- Well problem struck this morning, push the gas and nothing happens...
- ok, stfa for quite a while, with no real answers. what do i have to do to switch to an RS4 cluster?
- Cheap ECU for sale in CO...
- Does anyone have a spare lock nut from a TRE that they dont need anymore? I have 1, just need the
- e-code wiring harness for City Light... anyone's got any? or know where can I get it?
- RS4 Bumper-Current Recommended Installation Methods and Bodyshops around CT
- Engine Noise
- Who was the guy parting out the car the other day? I need the stock Bose front door tweets & MB
- teflon tape a DV?
- Looks like its time to move on.....I have to sell the S4
- Did a vag-com auto scan today, this is rather interesting...
- I just want to say ... stoptech sucks .... huge rant to follow
- cd player wont read cds....radio is acting funny. time for an upgrade. thought about the avic d3,
- startupracing GT coilovers (vogtland). show of hands for who would be game for a group buy? >
- Anyone here go to Woodward dream cruise this weekend???? Detroit IIRC
- Need help with Boost Problem... see graph please
- PFR7Q plugs for water/meth? or stick with stock?
- A.W.E. Tuning helps you dial in your suspension
- Ok who did this...
- Torque Converter, Rebuild Q?
- How accurate is Vag Com block 120 in calculating hp figures?
- can the oem phone mount (inside armrest) be removed?
- Do the rear springs in the stasis MS kit come out of the perches at full droop?
- just found my new fix hehehe cleaning the inside of my wheels...When its on the lift of course
- WANTED: B5 E-codes (actually, just one...) - who has them???
- i can not find it out on etka, What is the part number on the coolant temp sensor on the lower
- do the rear brakes have pad wear sensors (o) - my understanding was only the front?
- Money shot! =P
- those with etka could someone post a screen shot or help me where to find the settings to change the
- i made piggies now what do i do with the 2 vast celiminators???
- Water staining on the mesh covered rear (and a bit on the front) pillars...
- Searching for RS4 Front Bumper and replacement hood
- <Flame suit on> anyone know much or done much with the iPhone Dynolicious App?
- anyone here have a swap a lease account... care to help ?
- Rare sight: a pair of 6MT Laser Red Avants.
- Hey my power steering is making noises on hard turns whats the problem?
