- My Cliffs Run 06 Pics from Sunday
- short Clip of me vs AWE Stage 3 on XR and Whipple Cobra again............
- Still no boost.....Bad turbos?
- Implemented some changes in the newest ECUx Templates (v11beta)
- i'm kind of digging the new Volvo C30..
- Launching techniques: Please post links to in-car videos of 6spd S4 launches.
- are the CPP/AWE products lifetime warrantied ?
- What size battery goes in the key fob?
- How would a bad N75 valve affect requested boost?
- Paging OW Kenobi .....X Post
- So this woman just swiped my rear bumper...
- Nice Sunday morning drive
- Video from last week...Poorly running SIII B5 S4 vs. B7 RS4
- Is anyone still running Toyo T1S tires? I'm holding onto one spare 235/40/18 with the thought
- When mounting a FMIC, would it be best to leave a gap between the core and the AC condensor?
- Traction Control Light , ABS Light coming on at the same? Need your Assistance
- In the Spirit of Halloween , here is my bloody dyno run : )
- Looking for Chipped B Box ECU for a 2000 Tip S4..Giac/MTM/APR, anyone selling? if so email me please
- rear tie rod replacement??
- dap ygm
- So... my primary O2 sensors when I pulled them out were totally white... Normal?
- Free Stickers? You have to be kidding me! www.eufac.com (courtesy of Autospeed Performance)
- Anyone else have their shifter stick in the down (into reverse) position?
- i have to push clutch way down to start the car .. but shifting the engagement point is normal
- Can the PCV possibly do this????
- Had a nightmare last night that my EPC light came on... then I look today and there was a post last
- need some input here guys , regarding the TO bearing types (throw-out)
- what is the best oil grade
- brake pedal goes 'soft' during an easy brake and then 'catches'. Is this the master cylinder going?
- Some weekend "Stage 3-" logs with stock boost levels...
- Please help...Lots of issues
- As i'm about to sign off I want to commend the maturity level today, there were quite
- A Couple questions
- I've tried and tried to get up the nerve to do 3,500 RPM hold launches, but just can't...
- APR want to have a conversation with Mihnea on his statement that ECUx doesn't log CF's properly"
- Speaking of logs, I pulled some from my stage 2 91 octane car from last october
- did I miss anything special at the jasons4 mini meet?
- Anyone have the turbo warning sticker?
- How do you confirm a failing Clutch Slave Cylinder?
- Found this regarding steering gear adjustment.
- posible to put a KO3 turbo on a sport bike? (600cc)
- Need Tuning Advice
- Just finished cleaning TB with positive results. Any other easy jobs in the engine bay? I'm bored.
- Where can i get a coupler like AH10s? Is is just a normal silicone coupler??
- GMG rocks, I sent them an email from their website and the VP responded today
- For a homemade heatshield whats the best material to use? I was going to do either sheet metal or...
- Fixx Fest Fun... few pics... nice meeting everyone.
- Picked up some new turbos yesterday
- Heat/AC Blower Motor Replacement
- hmmm. 6.19 FATS on GIAC-X + 2/3 tank 91 octane
- What is the advantage of having a lower compression ratio?
- New addition to the Audi Family (sort-of)
- Cross-post: Does anyone have an RS4 version of this logo ? Or can you photoshop wizards make one ?
- EPC light came on. Codes below...
- Are MTM chips soldered in? Is it possible to take out the chip?
- Love this weather....just did 6 FATS runs
- suspension first or exhaust first.....
- is the m-box or the t-box the latest ecu?
- Kinda funny video friend just showed me. It's OT, but thought some might get a kick out of it.
- best FATs on Kalifornia Craptane 91......post your results (Stock, Stage 2, 3 don't matter)
- There was a little confusion with part numbers for the OEM TOB for Rs4 clutch.....
- Can anyone guess what this is?
- paging milpitas ygm
- 12.45 @ 111.. Fixx FEST AWE stage 3 on 100.. =/
- Car won't start. died two minutes after gas fillup. I'd like to disconnect line at fuel rail to
- Primary 02 sensor replacement job.... Begin!
- 11.77 @ 120.63 mph...
- a quick shot with the suspension and wheels on.
- Dont you hate when this happens?
- Okay largest dyno numbers for a stock internal S4? Can i get all the various numbers
- I checked for any loose hoses and there are none....I VAGs my car and this is what i got
- Random thoughts about SDR cams and misfires...
- so is anyone else here running 8" rear springs on koni motorsports?
- Opinions on best-engineered 2.7t 'RS4' or similar upgrade kit?
- so who kows a compay that has H&R or Eibach sport springs IN STOCK for an 01 AVANT?!?!?!
- bye...bye....RS4 front bumper..... :-(
- What's that thick greasy stuff some use to hold brake pads on the calipers when changing?
- Go Bucs!!
- When I swap my ignition amplifiers from my stock airbox to RS4 airbox should I...
- FATS time 5.94, what is the problem?
- Oh Man.. Snowed about 4'' last night.. Summer rubber still on the car!! Winter is here dammit.
- apr 3 mode chip, telling which mode is which
- Ohio S4?
- OK, this new $345 dell laptop should work with ecux:)
- interesting chip tuning link
- Anyone come across a good way to mount and charge the Razor in our cars yet? Morgan? anyone?
- For the last 3 days I havent been able to get the idea of a Satin widebody out of my head...
- My cousin bough a 2002 M3. I took him for a ride in my B5 S4.
- old vids of me vs c5 procharged vette and a heads and cams zo6 vette also cobra and dsm..........
- Update on coolant consumption issue - Bars Leaks appears to have saved the day
- i've seen that some of you are running B6 stockers on your B5 S4's...
- What would stock fueling set up be worth? Upper intake box, maf, maf housing, injectors, etc?
- ran some fats ...
- RS4 injectors VS Green Giants
- So should I get piggie pipes or go with an aftermarket DP??
- Brazilian Grand Prix was pretty awesome.. Amazing talent and 20K RPM crazy..
- Curbed my Sportec's hauling ass around a corner
- Stock B5 Avus with rubber vs Stock B6 Avus with rubber. Whats lighter?
- New pedals today!...
- 17" wheel choices for brembo 355 brake kit.
- What DV's are people using with DUH FMIC?
- Good source for bolts to mount 993TT rotors to ECS hats? ECS does not sell them seperately.
- what are some k03 worth 50,000 miles?
- Clutch Fan Pully Removal
- Ok so I was driving home, brake pressure went out-
- WindycityS4 and I tackled my torn front passenger cv boot today..discovered something
- Bam, trigger pulled on hombrew fueling. Thank you Piggie =P
- ok seems like i found my problem.. i'm dirty now with the tranny on my lap ;p
- Ran a search on this UID "25793" (Mineah) I have missed many great threads in the past
- What's a good source for random stock parts?
- man i'm pissed... a friend of mine let me borrow his apr home programmer...
- Need quick answer : Is J box compatible with a AA box ECU
- Steering Racks Interchangeable?
- Last night after a hard launch my pass side tail light went out...this morning i checked it out put
- Catch can install. Let me know if I'm thinking correctly.
- When running a standalone MBC and leaving N75 plugged in, is it necessary to
- Wow! An S4 doesn't stand a chance against these cars!!! (BWW)
- so my daddy was tracking his car yesterday and his trans. doesn't go into 1-2 anymore....
- should i go with AEM dryflow 5 inch or 9 inch cone ?
- Will the Samco Y Connectors fit with RS4 Y pipe?
- Paging PSmalls, Imolavirus and others interested. X-post from forced induction forum.
- Lots of smoke, after pressure test. help
- Finished the "ed4" Front Plate Mod...(pic links editted)
- anyone ever tried ebc brake pads?
- Looking for seat suggestions...
- OT - Driving dads Cayman S today - sooooo much fun
- ebay.de-ing
- Opinions on the Tial Eliminator kit? Will it work? Anyone have info on the turbo dimensions?
- What were you charged for labor to replace your turbos? Number of Hours?
- 25mph exit ramp+rain+EPC light=dirty boxers!!
- Wet Passengers side front and back carpet what do i do?
- What is the sensor or part that conotrols the speedo? Mine is wandering under accel ...
- repost? what a d-bag!
- SHE'S BACK!!!!!!!!!!!!!!!!!!!!!!!!!! After 10 weeks, 3 KO4s, 1 exhaust manifold, 1 motor pull....
- new sig, yay or nay?
- You know you are loosing it when you drive 300 miles for a oil cooler bc you can't wait until Monday
- how much does weight of similar setup cars effect fats, qtr times, etc?
- A friend just gave me a 5gallon jug of VP103...its about a year old...ok to use?
- I have stfa and spent a good amount of time on this forum. I have also made a few posts....
- still looking for great condition exhaust valves..
- Replacing CV boot and lost a ball in the CV joint.. (more)
- Noob S4 owner
- Ok basically I need all these parts, if you have them and I can borrow them it would be great.
- wow.. best wife on earth..just told her that the cars going to the shop
- B5 RS4
- how funny is this? i sold an item to a tuner (~$300), got a returned check says "insufficient fund"
- Found this article interesting...
- Where can I get some S4 Sport Package Mirror Housings?
- Remember to double check your work!
- Has anyone talked to Avalon this week? I can't get ahold of Zev.
- Suspension install results: front 24 3/4 - Rear 25 3/4. Think I'm okay like this?
- I need brakes
- on the "theme" of the post below
- autox avant - fat pig on a small course ....
- Post dragway problems.
- Can I send my blown K03's to Jacob for rebuild hybrids or do I have to send him working K03's
- AUDI JOKE off topic
- Zena racing hoses from ebay?
- put S4 engine in Ford Explorer
- Maybe a stupid question but would it help to turn the heater on during a dyno run?
- Great mileage picture (sideways, but good)
- Sorta OT but its TT. BMW 335i Blown engine Already!! damn
- Opinions: Vogtland coilovers vs stasis streetsports.
- Who has the best prices on *authentic* rs4 MM's and tranny mounts?
- XP: Who's going to the HPDE at Infineon Nov. 16-17?
- Where does the battery ground connect to the chassis?
- STaSIS Halloween treats are almost gone, don't miss tricking out your ride...
- Some preliminary ASP K04/RS6 pump-gas quarter-mile info...
- NE1 going to E`town to take on the stangs,its stangs vs the world night,or Island dragway?
- Piggiesmalls: If you were to have a chance to start over again and pick out parts for going
- Comments on my alignment numbers....
- Fog lights *periodically* dont go on. Where should I look?
- How hard is it to remove the front seats? How long should it take me....
- Is anyone going upto NED tonight? I will be attending! I am shooting for 12's on my stock k03's!!
- Twin 2 and Testpipes = Hit!
- Can somebody tell me the most inexpensive way to repair/replace the LCD on the instrument cluster?
- The new STI comes with leather?
- bt: widebody...
- Stock S4 Springs
- Q: boost buildup without N75 active?
- When would you NOT invest in putting K04's in your car?
- Is $145 shipped for a oem oil cooler good?
- Dyno Poll: Dynojet, Mustang, Dyno Dynamics, or MAHA?!? if you had a choice............
- B5QShip's Friday Trivia Q: How does the "temperature" of HID bulbs relate to their output spectrum?
- Friday POLL: How many posts per day since joining AW?
- NE1 install the Statis center diff...looking for install points...
- Anyone know a cheap place to transport S4 from FL to NJ? It doesn't run.
- Crap, I am starting to think I have a headgasket leak on my passenger side head.
- Where is the connector for the drivers side rear 02 sensor?
- Anyone know if the AWE flywheel has a replaceable friction plate?
- Does anyone have a n75 I can borrow/purchase?????
- Imola avant with black wheels on 80E near Patterson, you here?
- Auto-X'ing a S4
- Is front seat removal the same as in the 98 A4?
- 98 s4 questions. How come people say they have um but there isnt one to buy in the US.
- hello all, i currently have bosch platins but i need colder plugs, what would be my next step up....
- Ok i have replaced the n75 and now it runs good on apr chip but only boosting 15psi....
- To Stasis: Is the motor mount that broke on Jeff Courtney's car last weekend the same as...
- Any S4 guys have experience putting your car on the Amtrak Auto train??
- Anyone here build a Porsche 993 BBK for themselves?
- ok to Run Stg3 on Stock IC's for the Winter?
- Opinions on a little bling polished bipipe??
- Does 363hp/400tq sound about right for my mods?
- Who have you noticed has disappeared from this forum that youre curious about?
- Found the wheels to replace the Fikse FM's
- Finally saw a B7 RS4 at my local dealer today.
- Day 1 at dyno with Wicked GT with 034motorsports !
- got owned by a #$%@#$% GTO
- best place to get a stock shifter with the white plastic ball peice the shifter goes through...
- For EdyJun & search reference: Air Bag light, Fault Code 01217 - Side Airbag Igniter
- Finished install of Eibach Coilovers
- bi-turbo FTW!
- yeah i got On3d by my RS4 clutch today on the way out of work ;( pp part#1240300 10
- Ha, saw this Wash Post article and I actually thought they were advocating taking out the spare tire
- Soooooooooo, the pics I posted before of my exhaust manifold breaking into pieces....
- everything can be fixed with a ziptie. zipties = favorite tool!!
- Clutch Hydraulic Problem?
- Anyone heard of Sibon Carbon Fiber Hood? any thoughts? quality? fitments?
- It seems that this Forum turns to AWOT in the eve. Not a bad thing, just my opinion.
- dont know if this is a repost or not.. but AWOT.. saw the commercial the other day.. spit out coke..
- What is the impact of using an RS4 front end on a non-WB S4 sedan?
- Want to try better track pad than Hawk HP+ for next track event. Ideas? Rotor = DBA slotted OEM.
- Instead of shelling out the 150 for the flashloader i just downloaded Garrets switching option...But
- ok...Top 5 Closest Performing cars to a Stage 3 S4? =P
- Watched a Massachusetts state cop "push" someone in to speeding today.
- Update on coolant loss, help!!
- Blackstone report show high lead levels...could race gas be to blame? I'm sure it was unleaded
- top 5 closest performing cars (100% stock) to a well running stage II+...
- Anyone here from Colorado wanna maybe meet up this weekend. Im in Denver area (Westminster).
- POLL : Group buy ideas for the spring -- looking ahead a bit .. what do you think ?
- My car is still trowin codes. The codes that are thrown are:
- I just added the race program on to my GIAC ecu. I think i may go to NED again friday night
- Do i need a 5 bar FPR to run the GIAC race program flash?
- Need a Headlight Ballast
- I just had to say it .....
- Why wont a 2001 Transmission ECU work with a 2000?
- Can someone please look up the oil cooler part # for me?
- Mod list is shot until next year. Dog tore her ACL and just got surgery. Now, say that hadn't
- I hit the 40/40 mark today..................
- So how's Alex treating my baby? Any more damage since the raccoon incident?
- 1/4 times vs temperature. How much better (ET and trap) per 10 degrees for the same car?
- Alex@STaSIS can you find out something for me on the Stasis engine mount
- Does anyone know if thre's any way to quiet-down an EVO intake?
- Best floormats? Stratmosphere or LLTek?
- going to Houston for the weekend and need help on Saturday,
- Paging 2kS4...
- Whats a good 1/4 time for a stage 2 s4 with stock intercoolers? I went to the track last night for
- Every time I hit the gas my seat feels like a rocking chair, I took it off twice now but I cant fin
- Bye...Sold my S4.
- Stoptech 355 and 332mm kits in stock! Free UPS ground shipping today/tomorrow only
