- anybody got a B5 S4 front bumper lying around in the garage??
- on the way to Wal-Mart....CRUSHED a yellow Viper (blk stripe) with a big wing
- whats the deal with the new spider hose?
- verruckt, i drew this from one of your pictures a while ago. somewhat OT but i wanted to share
- Help with some codes!!!
- Black junk on dipstick today, first time anything other than healthy oil has showed
- How do you loosen the tie rod from the upright assembly?
- TIAL GT28 housings at altitude?
- Paging LaserRedS4, I can't get any emails to go through to you!
- Feasibility of swapping aluminum uprights onto a B5S4 that isn't endowed as such?
- hey
- any1 looking for a euro avant trunklid?
- Some VAST Stage III logs...
- New, not reman, lifetime warranty, complete axles at my local Advance for $88 MT, $84 AT...
- Steering squeaks
- Could the wrong TOB be causing my problems?
- P/N request. A/C Pressure Switch (F129). Does anyone know the part number for it? TIA
- Has anyone noticed after installing the FMIC or upgrading to bigger intercoolers from
- Anyone have a bad hitachi MAF?
- Small report on ASP Socal Custom Tuning tour =) we have great sucess and
- AudiS4guy - NorCal AKA S4zero8 - SCAM Alert Update - Paypal refunded..
- Electronic gremlins? Windows, seat, temperature display weirdness.
- Anyone know the basics of why ABS Module goes bad? Maybe a even a fix?
- Big Props to Mike and the PureMS crew. I am testing the Stern Prototypes....
- Need help on picking out a good light weight battery.
- A little help? My coolant needle is going wacko
- Can anyone link me to some nice B5 S4 related wallpapers? TIA...
- PureMS.com - Maintenance Specials for your S4!
- Does anyone have the length of the stock exhaust valve?
- Anyone recognize this bushing?
- Can anybody run a radio code lookup for me today?
- 2 Piggie or NoT 2 PiGgIE??
- Crap! Changing my fuel pump and while trying to get the walbro out, the basket chipped.
- FYI to Top Gear fans... Season 12 Episode 1 available on Final Gear.
- yay gots some issues already
- Anyone know of this car in PA? Sounds too good to be true...
- Quick question: How do I remove the pilot bearing from the flywheel?
- Anyone have front slotted rotors laying around?
- Does anyone know where can I buy a turn signal bulb socket? TIA
- Weirdest damned thing...with clutch disengaged, rough idle?
- Need advice.
- Head Light Issues... more inside.
- new HID fogs installed..
- New Fault Code. Does anyone know what this code means?
- which direction do the plugs on the injectors face? to the sides?
- What's the going rate on a 2.7t block with a 3.0 crank installed?
- whats wrong with my car.. so now all the water is gone, i have another problem...
- Anyone know of a yellow 2001 S4 at Finish Line Ford in Peoria, IL.?
- Pix of my new setup: Vogtland GTs, 15mm spacers, ASP Tru-Dual 75mm.
- Wheel Bearings replacement - advice needed
- Lame question. Anyone have non-defect stock DV's they'd like to lend to me for good? :)
- So sad to see all the stage 3 s4's in the classifieds :(
- who has B5 RS4 fenderliners available ?
- Follow up question, Should I replace the entire Axle or just the CV Boot?
- gil@vast was at the track hmmmm why no numbers. That c4 s4 staked up pretty well did'nt it lol
- First try with Nyet's new ECU-x graphing program
- RNS-E shoe polish mod - yay or nay? I am worried if it make it greasy, or come off after a while
- is a compression test the best way to determine if i have a blown head gasket?
- Looking for stock S4 front bumper.
- Hard to find Pearl White S4?
- I need a boost gauge, hook a brother up.
- Anyone interested in sharing block120 graphs? I would like to see how my tune compares.
- Anyone have a writeup for replacing the front inner CV boot?
- WTB: APR Bipipe. Anyone selling?
- My DICE mount came in the mail, but no way to attach it to the car? WTF DICE!?
- Bosch Icon contact issue
- The photo of Schwarzenbauer on the AW homepage is disturbing to me...
- CV Boot blew up on me today... anyone know a good place besides ECS to get a replacement?
- Selling the car, incase any1 knows someone looking for a clean, low mileage S
- whew whoooooo!
- X-post on overriding APR security lockout
- Haven't posted in a while ... Very strange sound coming from mid rear of the car when I let off the
- k04 dyno, post up, trying to see at what RPM does power drop off, state software too
- DonQ (aka Rob) YGM x2!!! Still got that armrest, my buddy needs it!! thnx
- Can't get PKBlu's email for some reason (fvckin macs), any1 got it?
- Clutch woes tonight, any idea's......
- Repost? Fortitude's write-up of the new S4
- Ok, came around a corner today and there was a huge puddle across the road and ...
- Anyone in the Chicago area know this car? (see clicky)
- Pics from the weekend project...
- what do you think of my new sig?
- Anyone need a Bosch alternator for a core? Needs to be rebuilt. Going to dump it if not.
- Been thinking about Jay's video and I've come to the conclusion he should not be allowed......
- UPS is my friend
- Anyone heard of this? Stage III turbo kit for 2.7t with tiptronic (stage III minus)???
- Installing a 2 way alarm with remote start soon
- THANKS to Mark & Frank @ ASP and Al, Paul and the great techs at CPT - RS6 setup. BW warn'g
- VAG MOTORSPORT GT KIT LOGS
- AWE Twin 2 vs. Milltek Dual... how do u rate these: Loudness, tone, drone, fit/finish, tip
- Sad news, anyone familiar with this car/owner? the BITURBO license plate seems familiar :(
- Has anyone used FCP Croton control arms kit, or what would be the best choice to put in my car?
- how many cactus avants were built?
- Losing 8+ LBS per corner makes a noticable diffrence....
- Brake question....
- well the saga continues, i cant win..... 50 psi on front left cyl.
- I dont suppose anybody has any ERs or AWE smics laying around for a deal?
- Does this K04 look ok?
- anybody here at the SEMA show??
- anyone running 245/45r17 on avus wheels?
- I'm getting a wierd fluttering sound with my new turbos.
- new idiot proof windows installer for ECUxPlot
- wow...that other forum is the worst......I guess I have CAMS and other W/E Engine mods
- So what does 2 degrees celsius and dry air + some free time equal? Time to play with the S! :-)
- I went by the detailer today and saw these...
- Trying some new wheels on the Casavant...
- Hello! Are there any uber-clean, low mile, no story stage III's on the market these days?
- P0102 DTC + ABS light + ESP light
- Tires on my S4 look pretty dinky
- Does getting lighter wheels increase performance substantially?
- If you were going to repaint the car white would you go casablanca or whiter?
- P1296 but no real problems other than fan running too much
- Money Saving Tip That No One Will Need! Click Here! 8D0-823-731-C
- Painted my wheels
- 2000 S4 Cranks...but wont fire when engine is hot
- Installing 034 Motorsport Snub Mount. To make sure, That is the mount that rests in the bracket on
- Apropos nothing: Mike@WMS is good people
- Need help with vag-com! all the sudden i cant connect?
- How hard is it/long does it take to remove the exhaust? Remove just for the strip?
- Oh hai.....
- Differential Seals
- First road log after ASP Socal custom tune trip =),
- z-tuned or anyone else : Will a 3.0l crank out of a 2004 a4 work for the 3l build?
- Anyone have their wheels powder coated? I'm thinking about it.
- My video tribute to "bassed"... from the Big Turbo B5 A4 vs STG3 S4 flame war for those
- ASP Stage 3 Tip dyno results
- K04 install specials Reminder
- Paging anyone at ASP, YGM, Stage 3 Tip needs! Mark, Frank, Ram
- Head Scratch - new brake pads - can't get rid of the warning
- Fiberimages carbon sunroof filler piece, Is this still available? Who here has done it?
- Avant Owners: My Cargo cover will not retract. Disassembled and STFA, still no solution. Advice?
- EPL standup guys?... Had a good conversation with tony last week and they seem pretty solid - just
- brian@avalon YGM
- EGT Night, looking for one as well. If not where did you guys order yours?
- random interior shots
- ? Shop labor charge for All Front control arms, TREs, and wheel bearings (Al uprights)?
- HVAC issues
- why does everyone say that e39 m5's are slow or easily beatable? From reading posts around here i
- Costco car covers? Feedback on them? Won't see any rain or anything, mostly dust.
- Anyone know how to install the 034 Motorsport snub mount? Just bought one, here, hungry to put it in
- questions about short blocks, (long)
- couple pics of the last project
- The S is in surgery as we speak.
- Meet The Beckers, Episode 3 now available!
- Anyone have a working EGT sensor laying around...
- anyone have some ko4 inlets kicking around? custom or oem? thanks
- Dyno APR Stage-1, not sure if my exhaust is creating extra backpressure hence high Torque, comments?
- Election Day Specials!
- Thanks to All that came out to the Fall-BiTurbo S4 M33T....this past Saturday
- Just a reminder. For those of you who haven't done so yet, remember to vote today!
- Coolant Leak and Multiple cylinder Misfire
- Feeler : 01 Casa Sedan 6MT : 108K miles : ASP Stage 3
- noob question bare with me...
- It's been awhile since I last posted...the neighborhood looks different...what else have I missed?
- Looking at 2001.5 S4
- how much PSI of fuel presure with RS4 pump you see at idle?
- Coolant Leak and multiple cylinder Misfire
- Need serious help: Fuse 31 keeps blowing (revisited)
- I am considering putting a water/meth kit on my car from vast and...
- This is f-ing depressing....
- Broken headlight adjuster! Anyone have an old destroyed one piece headlight?
- Odd question, What makes e-Codes so special?
- Can anyone confirm that the OD of Borla pipes (at the downpipe connection) is 2.175"?
- paging silva or someone with a 85ish mm maf / need some custom inlets also
- Have any of you had any expierence with boschfuelpumps.com? I am looking to put a 044 pump in my car
- some photos from Angeles Crest drive yesterday morning
- thanks to all the guys at KMD for fixing my wheel bearing issue and having my car in and out in one
- rear passengers window problem (drivers side)...
- can anybody get me 2 or 3 pix from different sides of a sedan with the rs4 full body kit
- I dont think this guy ever made an apperance here or anywhere...WB content
- WMS pimps rides part II ... as you all remember last month we posted
- Reliable 400hp?
- problems w/DICE ipod integrator. plays sound but using the seek buttons on the radio don't work
- What goes in the holes?
- Corvette ZR-1 vs. Ferrari 599 GTB vs. Porsche GT2 vs. Nissan GTR = Drag race
- Quick Quest? what would you run, piggie pipes or xs downpipes?
- Porsche Cayeene bbk behind a oz superleggera wheel 18x8, Will that work?
- what is a good price for a 01.5 S4 stage 3 with 75k?
- Upgraded to Xenons, drivers headlight is much more dim than the other.
- Does someone have access to ETKA?? Looking for a P/N on....
- Soooo, I think I've lost my stock A-box chip. Anybody have one, they're willing to unload, cheap?
- anyone have a good. Condition b5 2001.5 s4 oil pan they can sell me asap??
- Monday Morning Madness...RS6 turbo'd car with the Methanol ON this time
- Said goodbye to the S4 today.
- AudiS4guy - NorCal AKA S4zero8 - SCAM Alert Update, help needed.. in SJC CA @ EIP racing
- How much would it cost for new coilovers and installation?
- Is there anyway to adjust the way the hood sits?
- dahlback exhuast manifolds any one fun them??? there cast
- rear subframe
- little help... smoke after short drive
- anybody have a zeitronix wb cable handy? I need to know which colors go in what order on the rj45
- proud new owner of a newer s4 i think
- Anybody here ever tried the OEM RS4 injectors ?
- Oil all over front transfer case pictures within...
- Did u guys see the F1 race?! The most incredible race I've ever seen [REMOVED TITLE]..SPOILER INSIDE
- check out my security system. (crappy iphone pics)
- Has anyone done comparison work on IC performance with and w/o fog lights?
- I got this Clutch Circuit Performance or stuck off code
- How many disable the EDL or ABS for launching at the drag strip? Does it help much?
- Alternator(s) woes continue - Getting ready to do 2nd swap in 2weeks
- Help; Disconnected Battery --> Car won't start
- are there (ideally official) audi b5 rs4 posters (minimum 20x30") available anywhere?
- Some Pictures~
- Powder coated my wheels! What do you think?
- running rich
- So how was the GTG @ EE:OutofBounds' Shop?
- Ebay FMIC installation question...
- Definition of rice in my garage....
- yikes! just put together a spreadsheet listing my mods
- As far as gear lube what are all you B5 S4 guys putting into the front of your MT these days?
- Looking for a Tire Pressure Monitoring System... any recommendations? STFA but only found old info.
- If I am running catless - is there like a plug or CEL fix for these cars? or do I need to
- Rattle seems coming from everywhere...hate them
- What kind of drill bit should be used to install hood pins?
- Replaced twisted axle, vibration still present. Questions inside.
- Kevlar clutch folks - anyone get grumbling / groaning sound when clutch lightly engaged?
- Anyone Interested In Dumps For Autospeed Downpipes?
- Alternator replacement BT: Stuck on lock nut, help!
- Anyone else cringe at the CSI commercial where a crane crashes into a building and kills a guy?
- where to buy mounting bracket for dension?
- Can't wait to see some runs between Stage III and VF supercharged B6/B7s...
- HELP; About To Install DICE kit --> Radio Ground?
- This board just saved me $600.
- HOW TO: Install a clutch slave cylinder the right way the first time
- Sighting yesterday in Portland, OR: Moro Blue with FMIC and euro front plate on Terwilliger Blvd.
- What windshield fluid are you guys using for your W/I?
- Finally got a ride in b7 rs4
- My car has a weird boost issue. anytime i get in high boost it seems to buck/misfire
- wierd noise from the front! TIA
- 93/94 Octane gas on the NW... Anywhere between Seattle to Portland off I5?
- Opinnions on the c5 rs6 18 inch rims on a silver b5 s4? Yea or nay and any pics would be great.
- I'm gona replace my Secondary air pump but should I get the combo valves as well? my car has about
- Catch can second stage.
- Im in Denver CO for the weekend. anyone want to meet up tonight?
- assembling short block and bolting on heads today. which bolts need loctite on them?
- just filled up the S4 with 93octane for $34
- Avant Porn for friday
- After Putting header wrap on your downpipes did they produce a bit oi smoke
- OT: Storm Troopers drive SC'd Lotus Exiges- Happy Halloween
- Is there a way to program a remote without a driver's side door lock?
- If You've Got Noisy Control Arms..
- any chance someone has some oem inlets laying around? need a measurement, thanks
- Thumbs up for Mike & Anthony @ WMS & Mark @ ASP ! DYno Results
- My how things have changed...I just looked back on the post I made to intro myself here when my car
- I was driving north out of Hartford, Ct today and saw this. Anyone we know? Imola sighting
- Going to Portland Raceway for Quattrofest... anywhere in Portland I could get 93/94 Octane gas?
- You Audi drivers are just Animals: Wocka wocka wocka
- issue with my foglight switch...
- Okay i have a request,
- Poll: At a red light, who sits with car in gear and clutch in - vs. car in neutral and clutch out?
- looking to get a rear sway bar...anyone selling one..or does a store have
