- Need help!! Instructions for adjusting Koni dampers on Stasis Track Sport kit suck!!
- now if i can only figure out how to put it back together...
- need some advice real quick....tires
- RS4 intercooler kit and achtuning oil cooler kit going to make significant diff. in stage 2+ (more)
- E-codes: Halogen vs. HID, is there a difference between the projectors for HID application?
- Walmart seems to be the best place to buy Mobil 1?? would u agree
- How did y4play route his dual exhaust?
- Can downpipes be run by themselves to get to the exhaust shop, or will it melt the underside?
- For those of you who noticed it was down, the Audiworld user DB is back up now.
- any1 know whats going on with achtuning oil cooler, i was in on the gb and i heard it was going to
- Went out for a drive tongiht and felt a lot of side to side play in the shifter while in gear...
- I <3 My Car.
- If you had to get a small, used SUV as a second vehicle, what would you get?
- Is 295 whp/340 tq good for Stage 2+ on race gas?
- Pogers is God.
- Oil Filter...can u guys give me a lead for an OEM filter that is just as good as the audi filter
- shop in CT or MA for clutch install
- Anyone put a hitch on their S4?
- Guys I don't know much about suspension and I need someones help details inside...thanks guys
- Those of you with stage 3 headlights...
- Aftermarket oil cooler = less load on stock oil cooler = lower coolant temps = more timing = POWER?
- On the topic of the afterrun pump...(cooling syst)
- Pics of RS4 IC shrouds to show where the cutting happens ... Good as a half decent reference...
- Need urgent help with my suspension install please! I cant get the first bolt off! Am i missing
- I couldnt stop laughing, anyone want a 90?
- Does anyone make a wheel adaptor from a 5x100 to a 5x112?
- High Performance All Season Tires Question
- This could be a ridiculous question, but has anyone.....
- ok i gotta ask, what's the story behind PEB?
- Sound fishy?
- Just logged blocks 034 and 035 (EGT's) on the way home............
- Where can I get S4 logo decals for brake calipers? Already searched. TIA
- so if I have Stoptechs with the pad indicators soldered, and I get "(O)", my rears are low? I'm
- Where can I find a new or used steering rack...search was unsuccessful. Thanks
- We need more Audis to represent on Feb 26th at Buttonwillow
- QUESTION: StopTech 332 calipers are wider/thinner than the stock S4?
- Casablanca white S4, Richmond VA.
- Lawrence, KS Nogaro S4? You Here?
- I got H7 e-codes, can the low beam bulb carrier be swapped from H7 to HID & still keep the
- ASP Tru-dual 89 mm (ballAr tips) pictures, sounds, and video!
- champion motorsports is US distributor for ABT but not much on their site
- ANyone have experience with the Blinder laser jammer?
- MTM new supercharger for the A8 only .....
- Who here has upgraded their xenon bulbs on stock ballasts?
- 898 Ebay items for "Audi S4" and about 890 are worthless fluff.
- Repost? An honest eBay ad for an S4...
- Can I run XR on K03's with an MBC without 100+octane gas?
- CV Boot replacement?
- will these 32mm offset wheels cause rubbing in front w/ 1 finger gap & no rolling?
- warrenty horror stories.... share them with us.
- Xpost - I wrote up a detailed 2.7T timing belt replacement procedure and would like feedback
- CT/NY Audi Group "Spring" Gathering - Momentum Tuning, Wallingford, CT - 3/12/05
- Someone sell me their Borla Rear Section Muffler!
- Shock Absorber Test??
- The deal is done....last night with B5.....somber moment....
- loud pulley type noise? where to go near longmont?
- What is my H ecu with IBE 2 w/ 5 programs worth?
- Anyone have a bipipe they are looking to unload?
- don't flame me for not knowing: is the MAF on 00 the same as that on 02?
- The S4 Database's domain expired...it's down
- To you guys who read the CPO covered parts list last night..
- How about this for a project car ...
- Audi Q7
- Are there different e-codes for HID and halogens? Am I screwed?
- Audi Driving Schools, on TRACK
- Anyone know a Bernie from
- Nice S4 for sale, ends soon...
- My clutch is slipping, and I'm going to the stealership tomorrow...need some advice!
- S4 corner balance rec's for front/rear ratio. What is the desired value?
- any way of telling what kind of exhaust this is?
- Well, my blinker/hazard relay finally died....
- IS Nav-Plus.com legit? tried calling and the voicemail was full...
- hey u giac chipped guys. how do you guys fare with the e46's?
- EBAY Whores: Is it just me or is this auction really confusing...2 K04s? $1250? Hmmmmm
- CD changer installation question....TIA
- Just got my new gauge cluster in (thanks Craig!) - searched the archives but can't decide what to do
- My wife is the Bestest (Audi Content inside...)
- wow...Pontiac GTO's are pretty quick.......
- rattle in rear speaker area? help
- In case you were wondering why BMW's are so expensive,
- The improvement in my car from the coilovers is soo much better, i can't imangine having it handle
- Nav-Plus System
- Help diagnosing a sound....
- Question...Coolant Leak = Blown Turbos?
- What would a reasonably good security system cost for NJ?
- Who has the RS4 clutch in stock or is expecting a shipment soon (1-2 weeks)?
- would a brand new 355mm BBK from brembo, black caliper could run for 2700.
- Did anyone hear from the guy offering KO4's/w inlets for $1900????
- Can you guys post pics of a Santorin with painted RS4 grille borders?...
- Curious Has anyone tweaked around with AMS software via Lemmi?
- looking for part # for the rubber boot and claps that covers inner tie rod and end of steering rack.
- If I change my evoms cone to a itg foam cone will it sound the same?
- CPO Warranty Help
- Still looking for a 2001.5 Santorin / Alcantara S4
- Wheres the best place to get coolant sensors for cheap?
- Is anyone selling some H&R Streets? There's a local S4 owner who wants a set.
- What about resale value? rs4 bumper vs. stock s4
- does any one know where i can get the auto-leveling motor?
- Good Casa pics and B5 S4 vs B6 S4 pics
- Follow up to my thread from last PM re: timing correction and knock sensor activity........
- rieger roof spoiler, M3 lip spoiler, both or neither? pic post request (more)
- some of you into the VW Corrado might be interested in this.....I'll be heading on out to it...
- coolant leak issue
- m3 rear spoiler part number, and can it be bought from a bimmer dealer??
- could someone please post part# for 2001 s4 alum. sport mirror cover.
- Another Stasis suspension question...... for those of you that bought streetsports...
- Is there any deals out there with the Stasis Suspension stuff?
- Someone got a steal on this Tip MTM box. Anyone here?
- Bad A/C Airflow after Inst Cluster Change out
- Car's out of warranty, should I take the chip out if I want an oil change from the dealer?
- stfa already regarding Drivetrain Stabilizers and after reading previous posts is it safe for me
- x-post - need a body shop in LA
- Anyone know if the windshield sprayer nozzle from a B5 Passat will fit our car?
- People that have their headlight corners cleared out. did you...
- are authorized dealers allowed to give discounts or only when the supplier says its ok? just curious
- Anyone have a chip for a 00' Tiptronic???
- rubber bushing not centered on rear tracksport shock
- Ok, with all the discussion about CF's and KV's, I think some of us should build some knock
- Is this an AMS chipped ECU??
- What my car dreams of being....
- any1 have impressions of the full brake combo package from AWE tuning?
- This is actually kinda cute
- German Castrol 0w30 - less turbo whine when cold, faster spoolup (?), same engine temps...
- FATS afficianados: I know it is not an S4 (apologies for OT) but how about a sub-two second FATS
- Poll :what looks better on a stock suspension s4, stock wheels or 17 inch RS4 replica wheels?
- OK, so with the talk about using CF as a better guide to tuning with Lemmiwinks than knock sensor...
- sigh. notched the FCK out of my front bumper on the left
- give me your opinion of the BEST wheel for my Pearl S4..and where i can get them..thanks
- K03 turbos
- Stock Flywheel Resurfacing
- Probably a long shot, but does anyone want to trade a silver RS4 alcantara knob for air leather +
- I miss my car :(
- Finally got pics of ASP exhaust on!!
- I have a Compustar 2WSS-AS Alarm (Turbo timer/Remote Starter) - But I'll probably sell it...(more)
- If i can space the O2 sensors out of the exhaust path, will that get rid of my CEL for no Cats?
- I love my ASP exhaust, but it fits like sh!t. Is this install error, or does anyone else have this
- People with ITG airfilters, do they work well? (not inside of airbox)
- Any tips on removing the radio?
- hey guys thinking about getting aftermarket seats.....(M)
- Wow, the Nokian WR V-rated tires are the quietest I've ever owned, compared to the S03s, Pilot Alpin
- Anyone have a pic of a Pearl White S4 with Axis Sevens wheels
- Whats the site to ITG airfilters?
- Repost re: B7 RS4?
- Abnormal tire wear....just had an alignment...
- super old school audi video "jump"
- Looking for an SUV...Suggestions?
- anyone read some of the bull**** b6 guys talk about?
- Audi Certified Pre-Owned Coverage List
- Everyone's Invited to Our European Autoshow!!!
- Fixed my first headlight washer this weekend. Thanks Don!
- what makes audi sealing (ie head gaskets so durable) compared too......
- Porsche 928 GTS what stage S4 do you need to compete..off the line roll on etc?
- dahlback RS4 on ebay
- What should I look for in a used 2001 S4 avant?
- APR ECUx updating?
- cheapest stock size rotors are found where?
- Check engine light & codes
- Need suggestion on pricing/websites
- RS4 parts on Ebay... IM, TB, Fuel Rail, Intake pipes, etc...
- I finally got around to fixing the broken tiptronic shifter pull-up lever...
- Advice needed: MAF and Coolant sensor checking *Gas mileage gurus get in here.
- Request for logs->Headgasket thickness changes. I'd ideally like to
- PSA for the archives: VW 06A906262Q works as primary or secondary O2 when spliced in...
- Does anybody with the GFB Stealth FX have video or sound clips?
- Again: NOOBS, POST YOUR SPECS! --->
- Anyone used the Griot's "Low Profile Ramps with Extension Kit" on a lowered S4?
- What are the approximate dimensions of the RS4 center mesh piece, please. I need length, width,
- Question about a new intake set up...
- Verrückt; YGM :-)
- Broke plastic nozzle on top of Baileys bypass valve
- broken rear wheel bearing
- rieger sides and rear valence out, but please post pics of rieger roof spoiler with M3 lip spoiler
- anyone have piston + rotor size data for ap racing 6 pot kit?
- found decent shop for corner balancing ohlins
- ECUx and USB cables
- New to the S4 Forum, got a few questions...
- stfa. hitachi conversion i have the maf housing i need the sensor stuff, ne1 know the part #?
- Stock rotor upgrade pending. Anyone have pros/cons for BIRA/Coleman rotors or ECS 2-piece?
- do u not recommend replacing suspension parts with used (yes, i wrongly posted on B6, arggg)
- had to refill my coolant for the 2nd time this month... is this bad?
- My first boost graph (awwww)...
- Looks like Toy Guy's back in business again!....Great shifter at good price
- My experience with Pep Boys' Mobil1 Buy3Get3 coupon...
- Simply J, contact us: Another possible buyer for your engine.
- Which susp. combo might/would perform better on the street and at the track? (inside)
- SO Mike2kS4 and some other people have suggested I check for rubbing or some other cause of high KV
- I'd like to give a public thanks to Mark at Autospeed
- questions for those who drive in the snow ....
- ABT/AMS chipping my car, few questions
- So Ive got myself a beater
- Anyone know what causes fan blades to break off?
- installed my k03/16, some initial impressions
- looking for non-crushed 5 bar fpr. who sells?
- Need help on my decision...
- Anyone running 235 Falken ST115 on stock Avus...
- Anyone have the P/N for the driver's door latch?
- GIAC X - Stage II+ - Experiencing infamous TC - Do I need the MBC, TCD and the N75 or...
- ok finally another LA GTG, Friday FEB 11th @ The Stand in Encino -- 7:30pm
- since i am going stage III, what clutch is recommended? rs4?
- Avant owners - have you changed your rear wiper? At dealership, or aftermarket?
- A little something that made me laugh
- for those of you had a Spec clutch failure... when did you purchase the clutch?
- EGT sensor 1 is bad. Should I replace sensor 2 as well?
- Is there a part number for the wiper inserts?
- The first thing out of a woman's mouth this morning was "That's not my choice of a color for a car"
- Feeler Post --> would anybody be interested in my front and rear fenders and my doors......
- For those running the RS4 airboxes on Stg3 setups:
- B6 shootout: another reminder of the advantages of turbo...
- A good weekend driving the S4 around Florida
- Gutting Precats HELP!!!!!!!!!!!!
- Can someone please summarize the H/J Box to M/L Box conversion process ?
- Need Help!!! Dilemma between APR and GIAC
- Anyone selling a GIAC H box ECU?
- Paint experts: how do you paint on matte aluminum? for a brushed colored look?
- anyone have pictures of all hardware pieces for a neuspeed swaybar
- Is this the future of our car?
- found the meguiars nxt wax at walmart:) i did my hood and trunk as a test..sweet stuff
- It was a good day...(long)
- Anyone know of a great Mercedes CLK forum?
- Can I put 225/60/17's on my car without having any difficulties in clearence?
- S4 is is running fine...but at a stand still the car has the slight shakes,,idle
- taking the pearl to Karosserie for the paint to be checked in the front.
- I'm looking for a nice mechanic's roller seat. I keep going through the POS ones. Any reco's?
- Funny Sound
- Going XM...A few questions for that have it- - >
- Am I reading this correctly? This tuners Stage IV package for STi only makes 320 whp and [edited]
- just wanted to verify that the ECS tie rod ends are what i need
- Tiptronic shift cover: brushed aluminum project *what i did this weekend* LONG&Detailed
- XPost: Goodyear GSD3 opinions?
- Did some logging today - 020, 026, 115, all that fun stuff
- Does Achtuning stock euro-s4 rear bumper valances?
- How much do you think it would cost to repaint 4 upper door mouldings (middle mouldings)
- Im still under warrenty so i get all the servicing done through my dealer......
- I've got a set of K04's... should I have them reworked?
- so did SRS EVER, finally make that B5 suspension kit?
- what kind of play should there be in a new set of k04s?
- Ebay whore....
- how do you go about un seizing coilover spring perches?
- Does anybody has a 6 disk changer magazine they want to get rid off?? please email me. Thanks
- umm yeah. so i was washing ym car today and noticed the headliner in the rear is hanging down
- Anyone know the part number for, Tiptronic shifter cover, inlays?
- Clean car pics and Sportecs w/ 9 inch spacers installed :)
- New Rear Brakes
- LaBree custom exhaust is the sh!t!
- 50,000 mile post and my first posted pictures ever
- Stasis Motorsport install... success!
- Just courious should I put a new s4 badge on my 2000 or keep old school?
- Leaking motor mounts. Rs4 dealer install success stories??
- NE1 know of an OEM part place or dealer part place open today? also, i need help with finding (more)
- i cant decide, A4 or S4 under $20k, my first car, low on cash
