- Cleaning up my RS4 pressure plate
- i regret doing donuts on the grass last night, now the car is full of grass everywhere.
- other than what you bought is there any real substantive reason to choose Stasis Track Sport over...
- FYI: Thoroughbred Motorcars dealership pros and cons (longish)
- 245/40 Toyo T1-S + Tracksports + 17x8 wheels = rubbing?
- Silver S4, Yellow fogs, crossing rt.22 in NJ at 8am. Was it who I think it was?
- I'm getting misfires in Cylinders 4, 5 & 6. Plugs, MAF, coilpacks, or amplifiers, any thoughts?
- Massive tranny oil leak 8^(
- Just feeling around: How much would my car be worth....
- Sheizel, I'm slow again after trackday and some logging my RS4 sensor died completely. MORE
- anyone going to CA speedway track event Aug 13-14?
- The BoneStock boost gauge gets a little closer to reality :)
- Another ABS Controller Failure
- ko4s and new dvs
- stupid question of the day. can an intercooler be cut to a different size,
- Painted calipers and added decals today, came out nice. Pics inside...tell me what you think
- This was in response to the thread the other day....
- How much to install Downpipes at a shop? I'd do it myself but don't have jack stands or a lift.
- any updates on that OEM DVD nav unit that can fit our B5 S4s? i emailed bln07...
- VAG COM purchase... USB or Serial??? KEY COM or HEX COM??? Your thoughts...
- Somebody please make me a sig with Notorious BIG's body and a pig face to fit with my name!
- Anyone bored and want to make me a sig?
- I'm starting a car club at school. Need suggestions for events/activities
- Need help: Dying battery I think but have had a few wierd DTCs today...
- Is this going to be a PITA to adjust my ASP-TruDual? New house has steeper than normal...
- Going to Europe and im going to need to leave my s4 on my driveway what should i do to it ? i put on
- APR ECU Explorer
- lemmiwinks Q's
- Just when you thought you had a retarded question, B7 one-ups you again (xpost)
- Who's car is this?
- Great couple of days at Watkins Glen.....
- Brake test for Michelin PS2 and questions about the ABS…
- I did my first lemmi adjustment.. I think.
- FYI: G89 Fresh Air Intake Temperature Sensor
- Found both my engine mounts are leaking last night...
- new rims...
- Anyone have pics of their cars with different highbeam lights? blue etc than the stock ?
- im stock im thiking about borla exhaust from awe tuning is this good?
- City Lights?
- Is this possible?
- Problem starting car again, Idled very rough for aboot 1 min. Smokey exhaust too...
- Bought OZ SL's today!!
- Help! 710N and chip install...
- Anyone know the part number for the hazard / turn signal switch / relay?
- rough idle, hard cold starts, misfires, vag results
- Im thinking about putting in an exhaust system, any tips on which ones and prices and how much power
- Anyone off the top of your head know what size of Torx bit I need to unscrew the coil pack?
- Do any of you have a 5 bar FPR that I can have cheap?
- NEED TBB
- 6sp transmission rebuilt
- Any right or wrong way to put a 2.7T on an engine stand?
- removing front seats
- Will a 6spd passenger side halfshaft fit a tip?
- Paging Funkweasel: There is a 1.8t guy trying to 1 up you.
- Bently Manual Wiring Diagram Q's...
- Q: 02 S4 "wet rattle" sound from driver's front tire area????
- NE1 purchased a different brake vac-booster manifold line to eliminate the
- Question for the wheel fitment brain trust...
- Did someone post photo/location of a reinforced vacuum line for the diverter valves a short while...
- Mult too lean; Log file shows about 130G/sec max - MAF?
- stupid question, but where can I buy Bosch wiper blades locally? pn?
- I want to clarify for myself and for others what is required for use of the new GIAC 3- code...
- One more ABS Controller... at 42k miles...
- Door locks. Not sure how they are supposed to sound....
- For those with Stage 3 and Milltek exhaust, how many of the exhausts scream like Docs? Is it common?
- Anyone use a boost gauge smaller than 45 mm? If so, could you post what kind and PIC?
- Climate Control Econ- Smells stuffy
- "CLUNK" sound coming from the rear when I turn.
- Reminder - K04's in stock, $2200/pair + shipping.
- Is my alternator dead?
- What is the part/model # of the Walbro Fuel Pump for our car?
- My battery is completely dead (my fault) what do i tell the service dept?
- oops posted in wrong forum, need help quick
- STFA: Consensus on RS4 motor mounts is not good
- Does anyone know where to buy Valeo auto leveling motors
- New TIP Options other than Level Ten....
- Had my first ride in a stage 3 S4 on Sunday...(thanks Mark P!)
- new tracksport install (6 days), now: creaking passenger rear. swaybar bushings?
- HID ballast: can you buy this as an individual part (dealer or tuner)?
- finished up wiring for the RNS-E last night, tested Nav capabilities as well.
- alright hands down whats the best shifter on the market? nothing notchy smooth action for that 1-2nd
- anyone scotch gaurd thier alcantara seats?
- [badmoonrising] here is a pic of a welded RS4 pressure pipes I found
- Streets of Willow Photos are Online!
- Wanted: Stock S4 Exhaust in So-Cal
- Is it possible to have a small gas tank? I swear there is NO way I could put in 16 gallons.
- High mileage s4 any major problems
- Release of GIAC 3- software (K04's stock MAF and injectors)
- tried to do my first brake/ rotor install...
- Unknown engine noise...
- The failed CV-joint I thought I had turned out to be a loose wheel. Woops!! :-)
- ECS forgot my brake Fluid !
- I know AWers are not fans of LLTEK, but has anyone have any experiences w/ their wheels?
- LOL - I posted a pile of rust on Ebay and someone actually bid on it!
- would i lose to an SRT Neon, each of us stock?
- want to order a intake setup, which is best recomended and does anyone wanna sell me theres?
- Where is this pollen filter i hear about located??
- Problem starting car. All my car will do is turn over but it won't start. More>>>
- Uh-oh..I have Reefer_Bob's eBay disease..just bid on something not thinking that I would win and...
- K04 vs K16 showdown, courtesy docSlow
- Clutch opionions, who has a clutchmasters 6 puck clutch and how do you like it?
- I think I've finally decided on the Enkei ZR-1...
- God I love my car. Sorry I had to say it. I couldn't hold it in any longer.
- got lemmi working on USB port, now ecux won't work - anybody?
- These castings look familiar? =)
- Anyone get the new Autoweek?? There's a great congrats to Champion Audi and the R8 on page 3ish!!
- Another stage 3 question after STFA
- Achtuning OCK install update. I can't read.
- 100 octane program is AWESOME even in 112 heat. That is all!
- There is only one good way to wash wheels:
- What do you think of this wheel?
- Where/what is the cheapest way to fix a blown cv joint? Raxles.com for a halfshaft never gets back..
- 18" AVUS from B6 S4???
- New Signature Whatd U Guys Think?
- Suggestions for lowering water temps on the track?
- :) lookie lookie what santa brought me
- Off the shelf GT2X turbo kits?
- would you trade these champion wheels for oettinger rz
- Anyway to increase boost on AWE K04 kit?
- 2005 Audi A4 DTM version?
- update on my Bose rear PS speaker
- blown stock diverter valve
- Does anybody know if this car was ever on the forums?
- Fastest K04 kit????
- CyanS4's tint
- anyone vag while doing boost pressure test?
- Does a 2002 S4 use D1S or D2S ballasts/bulbs?
- Newbie in the house! :)
- Vag Locator??
- another wheel fitment question... 19*8.5, 225/35/19 all around + 6mm spacer in front
- Well some of you know about the FMIC I had done. I decided to do some logging today
- Anyone know where to find a DUH FMIC?
- So how much does shipping a set of wheels/tires from coast to coast cost?
- Single Turbo Supra vs Sport Bikes
- S4 vs E36 M3 vs Median = Ouch!
- Anyone/everyone running Achtuning/Hartmann RS6 replicas on your B5 S4 please respond.
- stoptech color choice... i'm prob going with black
- Tipsters - Anyone have a spare FAQ torque converter?
- S4 Rear Badge
- Need help with auto detailing info. Here's the scoop... More>>>
- Any difference in the sound of the first gen Borla as compared the second gen?
- Interesting electrical occurrence...
- Who has AWE stage3 s4 in SD/OC area that can give me a ride ?
- My friend bought an S4 about 3 months ago and just installed a boost gauge...it peaked at 16PSI.....
- S4 on Autotrader website......what makes it so special?
- I hope none of us live near this guy...
- calling kopork! calling kopork! where is your boy with the frontmount hookup? i cant reach him by...
- EGT sensors... anyone have them replaced under Audi Assured?
- Who's racing at Waterfest this weekend?
- battery options
- Please post lap times from 1.6 mile Streets of Willows. Pat, Bauer, Pete, anyone.....
- Ronal 17-18" SALE
- Any interest in someone buying a used AWE K04 kit?
- And a Happy 20th to me.
- blinker not working... and i checked the blinker fluid level... it's ok :P
- life after death *edit*
- Recomendations for Stage III install in NY/NJ area, 40 miles from NYC
- Ref Flashing "Brake" light on Dashboard...
- Thinking about doing A8 rear brake conversion. Need opinions from those with the install.
- Coolant expansion tank is starting to leak. Is it worth fixing or just replace?
- I have been infected...
- Is 94 octane that is ethanol enhanced not as good as a straight 94 octane fuel?
- disappointing test drives
- If anyone is still in need of the Audi Phatbox cable after buying the cheap VW Phatboxes...
- New whip...
- Can anyone help me out with this? (Paging Fletcher!)
- don't need to roll fenders, but what about the liners? i've already worn through them
- FK Grill Install / hood release question
- new gas mileage record for me....
- PSA: if your water temps are rising in this heat...CHECK THE FANS CONNECTORS BY THE PS. RESERVOIRE!
- HID ballast: one unit failed after heavy rains a few days ago
- paging PaJohn, regarding vag-com.
- Anyone know what is car/vehicle is? Saw it this morning.
- Anyone the Nogaro S4 w/ Rims I passed with my bike on MacArthur Rd. last night around 10:45?
- Jason@streetwerke , krazylegs, virginS4me and mjtaylor, thanks for the help !
- Photoblocker: Is this legal, does it work?...
- Neuspeed 19mm Sway BT: I got a creek - normal?
- What a beautiful day for a good spirited drive on some out-of-the-way country roads...
- I was reading some thread and read one box is faster than other with chip... than what is fastest?
- What's another late night without another FATS result? 4.64 with full block 003 Data:
- Why'd the chicken cross the road?
- show me pics of casablanca with flik wheels....
- Full service cost?
- BLOCK!
- Does this really stop the rocking?
- Is this the best solution for Pocket PC VAG tool...
- Looking for a titanium license plate frame or sheet Ti...
- <sigh> some dude in an A4 (stock looking 2.8) tried to bait me into a race...
- Hey Any takers on a Eibach Prokit Springs used for 9 mos.
- XPOST: I saw 2 nice looking b5 s4s today....
- Anyone have any numbers from the AMS dyno day?
- M3=brunch :) Hows the car, any new news, did I miss a post?
- Throttle Body Boot Query
- So my homemade viton intake mani gaskets are squishing out when torqued . . .
- I did the diy for my "blown" Bose rear speaker today...
- few shots from the weekend....
- Had an interesting Saturday
- Chicago Audi Mechanic
- can someone tell me why my rs4 clutch feels softer than an oem clutch?
- has anyone run Bridgestone Potenza RE750 in 17x8.5, 245/40?
- Coolant temp gauge just falls to C sometimes then pops back up to the middle
- just got my s4 and already a check engine light after changing the oil
- Question on turbo upgrade
- S8 Rear rotors, revisited - Worth doing with ECS Tuning Stage III fronts?
- Rear Speaker Fizzing
- Yo Dutch Daddy, you still around?........
- does anyone else ever bottom out in the rear when launching?
- [edit] Could 19's add .5 sec to FATS times?
- Got my oil changed...mobil1 15w-50???
- Radio removal... Help!!!!!!!!
- Custom Plates: anyone have custom plates on their S4's if so what does it say...mine is S4ORCE
- last night when i was doing fats times my brakes were shooting sparks slowing down
- Broken legs
- This afternoons progress:
- Aftermarket Navigation?
- Track suspension recommendations...
- Anyone have a pic of a painted black stock grill with the trim still chrome? Im getting ready to
- Problem clearing "service" light with VAG COM.....
- GIAC and TC.. not happy.
- Nürburgring lap video in my BMW (saw some cool Audis yesterday)...
- Well, it looks like this old timer may be getting an S4 for a project car. Here are my planned mods
- Noticed a new sound lately, sounds like a boost leak when I get on
- EMERGENCY: DOES ANYONE KNOW HOW TO DO SS BRAKE LINE INSTALL??
- My Stoptechs have started humming/vibrating AFTER a hard stop, whose had this too?
- More progression from the K03 car that could.....
- I have couple Questions... (m)
- new england folks: anyone know tjm motorsport's new address? i need ...
- Help please. Who here has had success in installing Achtuning's OCK?
- Just for the record, an STP #S16 oil filter does NOT fit our car
- Streets of Willow Preview... <x-post>
- i would like to take this time to give a personal thank you to Mike (piggie) and Mike2ks4
- anyone know if these fit the s4? Axis PHIN 19*8.5 thanks
- woohoo. got my mbc to work. now im running mbc only spike to 18psi.
- BBK time! What color - red, black, or silver? (silver avant)
- how about some IC ducts made out of aluminum sheetmetal and pop rivets?
- who have RS4 K04 with inlet pipe in stock ?
- today's (slow) sunday drive yields fats times of 4.42,4.44, & 4.40 seconds
- Ditch racing is bad, mkay!
- in baltimore last night S4=1: Civic (nos)=0...
- what should I do?? tranny advice
- do the RS4 rear brakes use the same caliper as the S4....just a different bracket and rotors?
- PAGING ERIC FLETCHER, regarding turbos/S4.
- does this look normal? no 02 sensor readings at all during fats run only a little before
- i've been told that running with maf unplugged is temporarily harmless, but can i do it forever?
- Do piggie pipes fuq with emissions? 2nd will it cause any check eng lights?
- i dont know if you guys agree with me but this board is slow as heck, where is everybody?? =/
- I decided to try a fats run with my maf unplugged this morning. 5.01 fats. *whew!*
- Very impressed with my Tom Tom Go 300
- OEM RS4 bumper plate mounting option
- How easy is it to take a 3-piece wheel apart? Just remove the bolts?
