- Does anyone have the APR bi-pipe in stock or a used one for sale?
- Just installed an Omori 60 mm gauge not to long ago . Whenever i give power to it , it will go all
- Where is a good place to get an Aluminum Floor Jack from??
- FK konigsport or Stasis Street coilovers?
- Downpipes beneficial on stock S4's???
- new look (BWW)
- who here is running autospeed lw pulley? your comments?
- Good car detailer in chicagoland area?
- Positive deviation DTC 17965 with TCD... check this out! (EDIT: Problem solved below)
- blue S4 in Baltimore at midnight..
- Nogaro in Harrison NY...
- What Downpipes??? TIA
- Link to Time slips? I know someone here has it in their sig and search turns up too many unrelateds
- Any S4 owner here live in DR....
- Wheel question
- Anyone besides Josh tracked a duh FMIC in temps above 85f yet?
- Where do you guys put the oil cooler core
- What a nice day that was.
- 255/40 Toyo RA1 on a 17x8 OZ SL ET 35 for a B5 S4 stock with rolled fenders, rub city?
- Arturo Fuente Cigar Tasting at EuroSunday Location
- Who was is that installed the fans
- Ran into a B6 S4 at the light just now
- Photoshop Q?
- Besides doing a LWFW/Clutch, RS4 motor mounts, and DTS...
- Visited AWE on Monday... AWE experience and revised Xchip code mini-review
- Can someone with an ETKA look up the part numbers for the cam gear on
- Can someone put me in contact with a paint shop that has done a CF hood with paint in the clear coat
- So recent discussions regarding 02 voltages and A/F
- Cheapest place to get a Spec 2 clutch or equilvalent clutch and lightwheel flywheel?
- put in a little too much oil, how bad is this to drive with?
- Wife hit a new low and made me shake head in shame
- Where is the best place to buy the correct lug bolts and 5mm spacers to go with Volk TE37 18x 7.5?
- Looking for BBS RE's (18Inch). Anyone here happens to know who has them in stock?
- Valve seal BT: I have two seals, one looks to be 5mm and the other looks like 6mm
- Headlight question?
- I dont have access to a laptop computer for about 2 months, but i want to get VAG-COM.. do i need a
- Rounded Hex Screw
- My S4 peeps... who NEED's a GMail invite?
- Everyone with PEB e-mail addy, YGM!
- Better spring/shock combo: Vogtland/Koni's or H&R/Grooved Bilsteins?
- Anyone know the sizing for an oil sandwich plate for the S4. STFA gives conflicting results.
- S4 Headlights, Clear Corner Mod, Broken Mounting Tab on Ebay...
- Stock Diverter Valves
- Can someone post a picture of Nogaro w/ BBS RE's?
- 2 Qwik noob questions...
- FS: Spec Stage 2/3 Hybrid, Brand New $699 shipped!
- Chicago / Illinois / Indiana / Michigan people - just a reminder.
- How would Stage 2 fair against a C4S? I was about to play with one this morning on the way to work
- difference between updated audi steering end links, and cpp spherical steering links?
- Please, someone help me buy diagnostic software....have both a laptop and PDA...
- MTM ECU: Is the same ECU compatible with the Avant and Sedan?
- Temp sender for secondary coolant pump
- how easy and or expensive is it to have a rim reconditioned?
- "Wheel Alignement Tools"... aka, that long steel pin to help align the wheel to the hub...
- does avant springs work on sedans. Im know that coilover work but does spring/shock combo work.TIA.
- Am I doing damage to my car by having different tires on it?... m
- Lug nuts different length on new Achtuning RS4 wheels?!?!
- Has anyone tried to remove the ac system in there s4 in order to free up some rotantional mass and
- Freakin' 91 octane weaksauce sux. Knew I was going on 250 mile drive yesterday, so I put 91 in
- Now that Mid Ohio is over, Who's going to Beaverun July 16-17?
- Hey...you guys seen this? Sorry if it's a repost. Not here much anymore.
- does anyone have handy a part #-s list for RS4 oil cooler
- e-codes and auto leveling..
- Are Axxis Ultimate and PBR Ceramic Brake Pads the same thing?
- Digital Boost Gauge?
- Yellow TT roadster with 3.2L badge in my parking garage. Guess they're out. Question:
- Anyone know when the Blistein PSS9 will be released in the U.S?
- Watch out for this apparent scam for K04's on Ebay. WTF, a minus 1 rating !!!!
- I'm a new member of the ABS Pump Failure Club.......
- How hard or easy is it to replace a wishbone link as well as the left and right straight link...
- Has anyone tried to fit the seats from an RS6 in their car?
- Next to an American car we look sooo good =)
- Question for your guys with k04's
- any one have pics of oz superturismos on their car? i stfed but apparently i suck at it
- For those that have volk le37
- S4 Jack Fell
- K&N filter Question!
- Pic of Nogaro with SSR Comp 18 in? Fit on H&R+Bilstein? Tire Size? Stoptech 335mm fit?
- I spotted a stock looking Imola and a Nogaro w/ BBS CHs at the Pistons game. You guys here?
- Just noticed the Blitz reads in Kilopascal, not bar - the conversion for these is 1.0 though
- Wheel Spacers... (need help fast!!!)
- FMIC/16" fan Water temp update.
- Question, Chase said they had lease insurance
- how much boost
- The B5 S4 is definitely a highway cruiser...
- Pistons are the sh!t, that is all......
- Looking to the future of APR chip
- Need tires badly, but cant afford s03's :( How are Falken GRB's?
- What's this on my throttle body?
- spring or suspension set up
- Looking for one ABT A25 rim....................
- Just took a ride in a new Lambo Gerrardo.
- Anyone make 5x112 to 5x100 wheel adapters?
- Negative camber
- update on car recovery. here are the pics :(
- FINALLY got the H&R springs in!!!! After all the fuss with the shocks...
- Just got my new Flik Artics.............
- cross post to my ABS trouble post
- New , 18" just arrived
- are we still all in agreement that the stock air filter has as good airflow as aftermarket? tia!
- UPDATE on RS6 brakes being placed on my S4...
- So is 20 psi to redline in 4th gear on par with other M box APR stage 3 cars?
- Audi meet this sunday!!!!!(Union NJ.)
- NE1 have B5/S4 pics with the BBS RCs in 18x8"? 225 tire preferred.
- Does anyone have pics of fenders rolled and wheel liner trimmed???, looking to get an idea.....
- a couple r-32's I found on the b6 forum.....Is that the stock exhaust? Sounds pretty sweet.
- My car seens to take longer than it should to start, but it drives fine?
- Christmas in June, I love it! (BWW warning). Gonna need a new sig soon :)
- Upgrading to K04's, what else do I need to buy?
- Anyone ever try Zoop sealer for your stainless metals or polished wheels???
- Is there a TSB for the rocking front seat?
- Blast foiled again by AW...2weeks till the new recaros come,but not watching the forum sure would...
- Harness questions---repost for the evening/West Coast folks
- Anyone know what the windows font for Audi is or if it even exists?
- Thanks Fiber Images for keeping 6K off my car and making a decent product....rice inside....
- 60,000 mile maintenance???
- Ok, what box(es) are compatible with a 2000 A-box? Or anyone have a chipped ECU for sale...
- Quick question...Will these fit our car? I'm assuming the only thing that would need to be..
- Neuspeed G2
- just out of curiosity...anyone know where all our stolen healights are getting sold?
- I know he put a lot of work into this car and kudo's to him
- Some reflections after mid ohio...
- Where might I find a listing of all S4 recalls and TSBs, and a useful description of them?
- Does anyone know were i could get sheets of carbon fiber? I need them for our 944.
- getting a cel..vag says that it is the coolant sensor..
- Recommendations on brake pads for street use
- Is an A box compatible w/ an M box? Thanks
- woooT!
- Has anyone test driven the new Saab 9-2x or Subaru 2.5 GT?
- ran in with a chrysler 300 hemi last night
- Non RS-4 ie lower cost carbon fiber engine covers available yet?
- FYI: most Waterfest hotels are filled for the "special price" but....
- i know the other day there was a discussion about H&R avant coilovers being put on a sedan
- I really don't know what I am looking at with the O2 numbers. Someone want to decipher for me???
- This is one way to add toluene.
- anyone got any fresh leads on avants for sale???
- What's next? Any mod suggestions?
- S4 resale value. Not as low as you think
- waaaaa wwaaaa waaaaaa
- roughly how much do downpipes and high flow cats cost?
- I just opened all the boxes of AWE rs4 kit I am A box 2000 shoulf i have a fpr and a AWE maf housin
- stupid lexus driver part 2
- 49,980 miles as I pulled into the office parking lot this morning ...
- Seat harness/roll bar questions......(flame suit on)....Seeking real world experience
- is this a good or bad idea.
- Anyone want my spot on that AMD 1/2 price ecu programming?
- Thinking about new paint job, what do you guys think of the BMW M5 Le Mans Blue paint for the S4?
- update on silver rs4 bumper grill
- Noise in RS4 2001
- I had 2 dreams in one week about my turbos going. This is just my record of it in case it happens.
- Looking for an Audi shop in Delaware (more...)
- Rough Idle Question!
- Long commute--H & R coilovers a good idea?
- What is it worth?
- Got ticket by mail from DC ?!!? WTF, is DC using camera's now...?!?
- What other size of tires i can use on my stock rims? 205 40 17?
- Why the ebay's rims are so cheap 19 inch for 1..5 k... worth to buy? easy to bent?
- so since my feedback post was deleted (???) what is the status on these suspensions?
- So what is Chris (bollacks) and Dave (CPP) up to, haven't seen or heard anything from them
- Any good quality and good price body shop in San Diego or LA?
- UUC exhaust
- Where can I find a good shop to install K04 or stage III in San Diego or LA?
- Blue Samco/MTM S4 Silicone Hose Set
- Okay my local boys are too busy to help.. VAG vs Boost gauge discrepancy
- ko4 install dirs?
- How many people own a 50? How many people have thought about it and
- Freakin Air Bag light came on while driving...
- Trying to Find New Style Toy Guy SS
- Great....got a rattle now =(
- i have STFA, still no answer on adjustment of these high seats...
- Stock 2001.5 Santorin blue/black Interior s4 For Sale
- FK Konigsports vs. H&R (ultra or reg.)
- E-code WANTED!!! Trade with my stock housings + cash is Welcomed as well~~
- Downpipes and emissions!!!
- Anyone everthough of using a nitrous express N-intercooler system on the twin turbo's . . .
- Be up in SF July 1st-5th, any GTG happening then?
- washed and waxed some toys today
- Opinion on new interior
- Vote on AW t-shirts
- Downpipes and high flow cat
- S4 Rims/P-Shop Request
- modded black S4 coming back from dub wars last night?
- Would this Dry Ice induction system work on our turbo rides?
- Back from Mid Ohio. I don't want it to be over yet! :((( (56K killer)
- Follow-up to my suspension posting earlier today. I just finished installing front Bilsteins and...
- Has anyone painted trim to look piano black trim
- whats AWs thoughts on SUVs? gonna need to buy one soon...
- Does anyone make S4 Logo Floor Mats??
- Anyone have a video of an S4 vs Supra?
- Video of the only B5 S4 that passed me at Mid-Ohio, and for good reason. :-)
- Just got a boost gauge on my Stage 2 tip...
- Dentist drill sound seems much louder the past few days.
- I STFA for info on the best oil for the S4...
- cant get tires off... please help
- 18 X 7.5 Possible?
- Just picked up my AWE ko4 kit, finally....
- whiners bitching about lambert on the 'tex
- Thanks for the prompt help for my newbie questions
- Does AOA care about SCCA? Mitsu sure does...
- paging: mike01s4/piggie
- Hey whats a good muffler? borla, magnaflow, ?? etc.
- I need tires!!!
- Debadged & lowered silver S4 on Cal Young Eugene OR
- Anyone associated with PEB tuning want to talk on the phone with me? I am really conisdering k04/k16
- FYI: Flix do fit with Stoptech 332 kit.
- Thanks ECS for the quick service!
- How close is the butt dyno between Stage 3 and Stage 2 with Race gas and Race program (APR)?
- Has anyone ever heard of Agstrom wheels?
- Recaro seat special
- Welcome to Testosterone Monday.. Damn
- Have UUC VM3 + pig pipes. I hear pop-corn popping when I downshift. is there something wrong?
- Thanks to AWE and ASW!! New clutch will be here and swapped out on Wednesday morning.
- Help!! looking for a good mechanic in NJ
- Back to the EVO vs. S4 insurance topic....I was just quoted for 200 a year less on an evo.
- Good Audi Tuner in San Diego or LA area?
- Two people emailed me to say that their Lidatek is on its way. No phone calls for me yet. :-(
- for those tiptronics out there fearing tranny death...here is possible fix...
- RS6 rims on S4/avant
- 1/4 mile results, plus pics of my car at dubwars...
- Nogaro S4 in Port Barrington, Illinois
- Clutch is slipping big time...anyone know if theres a big difference between Spec I and II clutches?
- Is there anyway to fit 19x9.5's in the rear w/ a 35 offset??
- Got a GMail Invite for one of my S4 Peeps...
- Still looking for 2 more golfers for 6/19 GTG in MA :o
- flik artic's on a black S4..any pics in anthracite or black? opinions between the two?
- paging jacob/imolavirus.....
- S4 wins the 1/4 mile drag and the road course events at Dubwars
- downpipes....rs4 vs labree...input??
- Help! Blown turbo!
- Transmission / Drivetrain Movement on 6 Speed Question???
- What shipping line does Audi use?
- who here lives in washington? might be moving there and would need to get to know some people
- timing belt... good prices?
- New England winters and salt sucks! I did the wife's suspension yesterday and...
- Anyone here vouch for the CG-Lock device? Search shows one positive review a while back.
- Looking for Shop Recommendation in Central New York
- California guys - whats the procedure for smogging (registering) a highly tuned car?
- any issues sending a chipped ECU from 1 tuner, to another tuner for their chip? any problems with
- Does use of the parking brake causes premature rear brake warpage?
- part # and price? or....
- Do I have a turbo problem?
- has anyone ever sent money to a shop or person
- Picking up my car tonight (from the K04 swap). I ran over at lunch for a quick drive.....
- jeff moss where are you????
- Is there any definitive data on exactly how much power the 6-speed tranny can take?
- Anyone have any pics of Carbon Fiber hoods with paint mixed in with the clear?...searched with no...
- So the stage 3 clutch is pooched...still waiting to hear what/if any resolution there is. Either way
- Anyone have an H-box I could buy/borrow in the DC area?
- Hilarious - Germany in training for EURO
- Should I get this for my friend. . Alcantara® 6sp shiftk knob and boot for Audi S4 (B5)
