- Looking at buying S4 - owner says car is serviced with conventional oil - how big of a deal is this?
- need one OZ SL 18" X8 Race Silver(i know hopeless) or a set
- Larger Downpipe+exhaust on stock turbo/ECU... what sort of gains are expected?
- Does anyone know how many clips hold the beltline trim in place?? I'm switching my wood for CF and
- can't get rid of this code (16502)...
- Are there any down sides to 2.8 or RS4 intake cams?
- What do I need to run RS4 injectors? I thought it was just the four spacers for...
- Looking for upgrades for around 2K.. Any suggestions on products and manufacturers
- Paging Widebody peeps: What alignment settings are you guys running? Trying to get the most out
- This past weekend the turbo lady came....
- Anybody with APR OTS stage III could please post your engine load at idle and also
- Nothing makes you appreciate the S more than driving another car for several days. That is all.
- Went to the Quik E Mart today in LA anyone else been by to buy some Krusty os
- Please post your 60ft times and suspension/tire setups. Thanks .........................
- what has 4 turbos and 8 rings?
- Why doesn't anyone run MR-10, it's only $12.00/gallon . . .
- Why so little GT25 S4's running around??
- Anyone running 1 1/4" hitch on the S4? I need a way to haul my other toys and not real fond on the
- She's back, with a face lift... RS4 Bumper...
- am i missing bolts here?
- need a stock ballast for my '01. Anybody have one?
- My 245/35-18s Goodyears are about shot and am thinking about going 255/35-18 (F1's again)
- Black S4 wreecked on Gulph Rd near Creed's in KoP.. you here?
- Failed NY inspection. Any ideas?
- Need OEM Navigation Unit for B5 S4!
- Interesting read on the R8 vs the RS4
- Cam tensioner gasket nightmare part II, ok so there is absolutely no way in hell..
- Got the car flashed at EPL today. Night and day. I have never smiled so much behind the wheel.
- The s4 shipped out yesterday :(
- Where can I get the July Eurotuner with 2.7T tuning guide?
- I guess I'll give it one more try...
- Noob Question: How well would a hood (silver) from a 2000 A4 match my car?
- Where should I buy a stock 2002 T Box? Who sells them?
- Consistent squeaking sound in my 2.7t (video)
- Anyone have a spare cap for an OZ Superleggera or know if the Ultraleggara cap will fit??
- Any word on the new AWE pump file? Release date soon? or should I just get the programmer and
- for the peeps with after market exhaust manis...how is your coating holding up? i have
- Stern Different Power Ring now shipping!
- Cheapest place to buy a new N75?..ECS has em for $97..
- how NOT to warm the audi up :o)
- B5 A4 spindle/upright on a B5 S4. Can it be done?
- VVVV --- Do not click on "Hey, Look what could it be???" --- VVVVV
- Throttle Cut vs Boost Cut. Can someone clearly explain symptoms and causes of each? Already searched
- Hey Look, what could it be???
- Tech almost fuxored my car He rerouted my MBC setup by capping the wastegate inlet of the N75...
- For those of you who like some of the more vintage Audi models, 90q20v Turbo for sale (x-post)...
- new shop (York, PA) vid. ...wasn't sure I posted this one with....
- Lets play guess the hybrid.
- Anyone here an H&R dealer...
- Milltek Exhaust on Ebay, is this a good deal and are his claims true?
- new hybrids?
- What tire pressure should I run on 265-30-19 T1-R's for the street?
- HIgh Pitch Noise when starting car for the first each day
- Where can get the 11 bolts that bolt the tranny to the bell housing.....
- Bank 2 EGT sens.: done. Rebuilt ABS cont.: done. Next up, oil leak. (more)
- where to buy new oem drivers seat? black
- Pat...are you still coming to N. OC today?
- First ever.... B5 S4 on OEM R8!
- Dj Illusion mp3's ...
- How much gas does the S4 hold, 16.5 Gallons?
- clutchmasters stage 3 capacity
- Tried STFA already - Looking for pics with 25.75" ride height - anyone? Also.....
- My 2001.5 silver w/ 51000mi is up for sale. pls see classified section.
- Does the new lower-oil-pan include an oil sensor, or just transfer from the old oil pan?
- It's all mine! '02 S4 Avant! Now ... iPod question: can you do a direct hook up to the Bose?
- Any problems with running 104 Octane?
- Nogaro B5 S4 at Danbury Audi with stock wheels, snowties (in July?!?!?)....anyone here?
- Lower Oil Pan "Sealant" Question
- the benefits of lowering a car...
- FYI: changing the climate control from Fahrenheit to Celsius
- A little shameless advertising (BWW)
- Weekend modding
- Anybody interested in a set of 18" SSR GT1's with So-3 tires?
- Cold vs. Hot weather throttle cut
- Getting a "squeak" sound at idle every 5 seconds or so, but it's very consistent in timing.
- Where can I get replacement O-rings for the RS4 TBB?
- wholl be the first on here to do this?
- OT: Buck for a Z06 anyone?
- A quick Tutorial for Heel Toe Shift ...
- 6 speed avant for sale 58K miles (not mine obviously)
- Sup Fellas! just stopping by to say whats up....
- Goodrich vs Stoptech stainless steel brake lines. Thoughts??
- APR bipipe boost sensor too high?
- Lower boost issue...
- Cam tensioner gasket = 1, Me = 0
- HUGE THANKS to Mike and Wicked.
- Helix Projector Headlights...
- Made it back with the S4! 6 hours of miserable driving and 6 hours of sh!t eating grin driving.
- Big shout out to ICS
- Replaced an HID bulb and a ballast. What would cause the new one to be way less blue?
- Can bad, or going bad, 02 sensors cause idle misfirings?
- how much do you think its going to cost to rephosterize (spelling)
- Misfiring my balls off and need help please......
- Anyone here successfully running the Bentley on Windows Vista?...
- cam tensioner removal...i've got the special tool in, the 3 T-30 bolts out..
- My S4=0.. Team Sawzall=1!
- ABS sensor help: should they look like this or are these EXTREMELY dirty?
- Another GT car?
- How many have had the front bumper re-painted and what did it cost you?...
- Overboost TC issue on '00 TIP GIAC 3-. Seems to only happen at high RPM WOT. Ideas?
- About to replace valve cover gaskets and cam seal tensioner gaskets..
- To the users here running Bluetooth Handsfree Kits with RNS-D head units which bluetooth kit
- To whomever posted about the 50% off Sears gear wrenches - THANKS! <more>
- Lug Bolts vs. Studs
- stereo in safe mode, code in manual does not unlock it what should i do wife is going nuts w/o music
- PSA - LADIES AND GENTLEMEN: CHANGE YOUR FUEL FILTER!!
- Whats the up to date on the burnt out clusters? Module masters chip..or should I just buy a replacem
- WWAWD?
- Can I get some sort of community prayer for no timing belt damage? :(
- How much air pressure are you stock size sedans running? Just mounted General Exclaim UHPs
- did some dyno runs... VAG graphs *appear* okay but what do I know ;-) any thoughts? rktskicar?
- Stage III Homebrew getting ready to post some logs, whats the best way, they are in an excel file?
- Where can I find the plug for the hitachi maf sensor?
- anyone have a oem fog light plug ?i still need one
- Not mine...Stage 3 fueling kit on ebay,
- Blew a turbo today and have some noob questions to ask...(long)
- asp fmic install: Day One:)
- What's missing?
- where to buy g12 coolant other than dealer???
- headlight access door missing tabs
- It's been 5 years...
- air filter change missing air box clips?
- Will 18" 2003 A4 wheels fit my 2000 S4?
- **Wanted** - any one parting out there cars have a center vent and / or pass vent avail?
- Turbo Lady arrived today :( What to do now?
- stage 3 or daytona 675 triple? hmmm
- i need some help
- 3635 pounds stock, thats not bad eh? just nixing the spare will get her below 3600 right?
- turbo oil feed leak.
- First to post from an iPhone
- With all this talk of ebay exhaust i want one where do you buy them if there not on ebay?
- RPM's bouncing 300-400 RPM under very light pedal pressure - any ideas?
- New k04's... whooshing sound
- Driving impressions of the full ASP mount setup.
- good morning what downpipes are these? on ebay any one on here? tia
- Anyone have a set of stock rear calipers they want to get rid of??
- Just reread my original SRS review. OWK approved! For a noob like me, was flattered to rereadVVVVV
- Paging: vrsix, RASTAMN, LJH ----- SRS Suspension Follup Up
- My car is now studly.
- New Member
- New to the boards, full of dreams and questions (56k diaf)
- Ooo - biatch...
- cheap ebay short shifters? any good?
- hard line removal on top of turbos
- Anyone else having issues with the "nubbies" falling out of their AWE pedals?
- lolz, hibiscus red gets tagged as Burgundy on most car for sale sites
- shipping plug x-post
- It's been raining for 18 days...
- Damn it. Can't decide between Penske Contest or Alcons 328.
- repost: upper oil pan
- Test Pipes
- for the people parting out their cars...i am in need of a set of horns. TIA.
- *** FYI **** Sears - 50% off all GearWrench Ratcheting Wrench Sets 6/29-6/30.
- water pump replace
- Best Oil Cooler for our cars? And how much should I plan to pay?
- if i put sea foam in oil is there anything else i have to do other than oil change?
- <Pokes head in> What did I miss?!
- phillys4951 could you email me @ LLoyyyd@yahoo.com for vagcom, I will pay $ for services
- trying to replace my primary o2's . can't get passenger one to budge .
- Got fuel?
- Who's-Your daddy?
- Radio channels go to $hit at speeds over 50 mph
- Yokohama tire clearance sale at Achtuning (savings of up to $613.60 per set)
- Kudos to SCR Performance!
- Slowest hybrid S4 ----------------->>>
- Getting a bov type "chirp" from the engine when I shift hard at WOT - DV's bad already?
- Proformance Transmission for a Tiptronic
- Checked classifieds... does anyone have RS4 IC'ers for sale?
- Door Noise?
- http://forums.audiworld.com/s4/msgs/2665674.phtml my waterpump was replaced at Clair Audi in MA and
- I searched. RS4 bumper part numbers, grills fogs etc. ?
- used calipers
- brian@avalonmotorsports : Thanks for the quick shipment on the E-codes!
- Oxygen Sensor Locations
- Whoever told me to argue market comps with my insurance co, thank you
- E85: Now that its becoming more readily available, which tuner will be first to write a Stg 3 file?
- Anyone have a spare S4 sunvisor?
- crap, the smell of a burning rubber hose in the engine bay can't be good.
- Heavy Steering... what could it be?
- Planning on changing the ECT sensor this weekend, any special pointers? TIA.
- drift king!
- Buying an '02 S4 Avant tomorrow! Have a few questions:
- best price on BBK? Stoptech, Brembo?
- Is my car spiking abnormally high?....
- ac seems to be causing excessive strain and hisses momentarily after switched off..
- anybody go so far as to vag com the car before they bought it?
- anyone have or know where to source a set of aluminum trim?
- Coolant temp sensor replace
- eipsucks~!?
- Sort of OT: Just watching Jackass on MTV and there was a quick clip of a Nogaro sport B5 S4.
- sj6spd, >>drop me an email i cant find your address
- Car shuddering and white smoke (long)...
- replacing upper oil pan
- Trying to reclaim space. Just put a bunch of B5 S4 parts up for sale in the classifieds
- Replaced my Falkens with Pirelli P Zeros today. Initial impression ...
- this worth more than tree fiddy?
- Is Audii-Dudii still around? I sent him an email, I hope it was the correct address.
- To be able to use a 245/35/18 tire, What et will you need on a 8.5 rim?
- Those of you who have/had BMW's before w/ DINAN mods... (suspension question)
- How many hours did it take you to install your stage 3 kit???
- EFU 4U users, anyway to reset peak hold boost while driving? Please don't tell me you can't...LAME.
- Need a little help finishing my stereo install...
- Stern Differential Powerring Sneak Peek!
- Headlights in LA
- very slight clunk noise from under driver's floorboard
- Any more updates on the baker electronics o2 simulators?
- ASP and PureMS rear diff mount install review.
- Video of Vik's M3 Turbo messing around:)
- Can anyone do a carfax for me?
- I'm an indecisive POS. New tires: RE050A pole position ($147/ea) or F1 GSD3 ($171/ea)?...
- any have stock dps for a tip?
- loose exterior door handle
- Throwing a hailmary pass here....Anyone know anybody selling a Scorpion cat-back?
- All sedan owners who carry a laptop in the trunk - Check this out....
- N75 voltage question
- Does anyone know the color production numbers for the s4 avant?
- Well, it looks like I might be spending some time over in this forum. Picking up my Avant on Mon :)
- Stoptech calipers going 'bad'? Anyone else?
- Is it true that AMS may be closing or sold?
- Wideband sensor/controller shootout!
- need help with DTCs : manifold baro pressure
- Anyone going to the American LeMans Northeast Grand Prix at Lime Rock on 7/7?
- Question about DTC's 17539 and 17521
- Exhaust Gas Temp Sensor Problems
- It has been another 3 months, any word on the IC comparo between IPP, AWE & RS4 ICs?
- copper vs platinum on turbocharged cars, i thought i read somewhere that copper was good for turbo c
- Exterior driver's side door handle doesn't work...anyone help... (Paging Streetcrawler(Cole))
- exhaust diameter and dual setups much difference?
- When upgrading to a Big Brake kit, how neccessary is it to upgrade rear brakes?
- Cheapest place to find RS4 motor mounts?
- 2001 S4 rear caliper replacement: S4 caliper or S8 caliper?
- Battery/Alternator Problems- Low voltage
- has anyone had their sunroof switch stop working?
- Until I get this figured out, how bad is it to drive with Random Misfires?
- Need my rear wheel bearings pressed, dealer or a shop? Experiences? TIA
- Anyone ever ghut out their aftermarket CATS?
- What size tires (beyond stock size) can i run on 17s? Is 235 45 17 too big for front and rear?
- Custom exhaust what is the largest diameter piping anyone has gone with a custom setup? 2.5, 2.75,
- WB shootout
- people with custom stereo's which route did you go?
- about to start work on my piggies this week and probley a few questions will follow.
- Almost two years with my S4
- sticky tachometer problem
- opinions appreciated, 2000 silver, 72K miles, manual, clean&stock , $14.5K...good/fair price?
- Advice on throttle cut please: just installed APR stg2+ chip and anything
- In the market for some used Hartmann RS4s or RS4 DTMs. Anyone want to offload theirs?
- Anyone have a stg II+ or III car for sale? My friend is in the market.
- ROFL ROFL ROFL:
- real easy to tell when the Ritalin supply is gone ... Marc's posts increase exponentially
- If all goes well I will have some slightly used almost blows KO4s for sale.
