- Mobil 1 (0-40): where to buy? any deals right now? does anyone know if...
- Ok whose Silver Avant w/ BBS & Kamai honeycomb grill is parked next to mine at Mt. SAC?
- Perl FATS calculator, version 2
- pollen filter after 70k miles is not a pretty sight
- Who sells a good tire pressure measurement thingy?
- Snowboard/ski rack
- Powdercoating stock wheels
- vibrating shifter in 2000 s4 normal?
- Need used S-03's 225/40 - 18
- Pre 2001.5 S4 problems
- LIke Mark P...Weekday repost! New wheels and BBK
- What would cause a front caliper to "lock up" during a pad/rotor swap?
- yesterday's M3 vs EVO vs S4: M3 side of story...
- 2001.5 headlight
- Wow, stock is smooth!
- hhhmm... Heat Wraps = Shorter Pipe Life as in manifold or header - Discuss
- EFU Update! Received the latest version of the EFU! IT ROCKS! The boost gauge and oil temp ....
- Anybody wants to sell their K03s???
- ABS Controller Failure....do you have to replace the whole ABS pump assembly?...or
- Repost: Opinions on Black A4/S4?
- Does anyone go 10k between oil changes using Synthetic on stock s4's ?
- Weekday Repost: Photos of my new RS4 wheels mounted...
- B6 Avant is hot
- Searched the forum. What is Bosch F5DPOR plug gap?
- A quick question about an available DTS (see inside).
- Does power steering work with the engine off and the key in the accessory position? Curious for when
- dc/md/va Audi fans: dcAudi BBQ - Saturday Aug 28 ALL DAY!!
- Many thanks to inviS4ble for the exhaust install and to chef Eric for the awesome bbq.
- weird. (M-box) pocket logger says 100% tp, 80% engine load
- ok, ecs is carrying 3 different PBR/Axxis brake pads for our cars now (semi long)
- Why does the index page nav bar point the S4 forum to the B6 forum?
- Anyone know the K&N part # that is the equivalent of the AFE cone filter from the EVO intake?
- MA area golf GTG 8/28@Red Tail
- Can a "L" ECU be replaced with a "M" ECU????
- Road feel issue in 2004 S4
- Anyone have a APR Bi-Pipe for sale?
- Sway Bar Options
- Rear Speaker Blown - any suggestions for a replacement?
- 2004 S4 Tuning : AmD
- Anyone in socal have a stock A Box ecu i can borrow or trade for my x chip for service?
- T-belt change at 65k was a HUGE waste of time. Everything was fine...
- Are the B5 S4 rear brake pads the same as a B5 A4
- LUCIFA- Red S4 on 91 North today in CT w/ tint/exhaust/rims/etc
- was goofing off with MovieMaker, videos of Summit Point DE
- Just got my LE-30 w/ additional transponder for the rear, Best place to mount it?
- will anyone (dealer?) just sell me the Grill Audi 'rings'?? Part #?
- E46 M3 lightweight vs. EVO VIII vs. S4Avant
- what are some of the presents people have brought to the *good* service people of stealerships?
- Snub Mount...
- Warranty questions (how not to void)
- What percentage of B5 S4's do you think are modded here in the US?
- Red old-badged seemingly stock tip S4 spotted in Champaign, IL
- How do i know if i have a boost leak?
- Anyone in Boston area can lend me a hand ASAP? IC hose came loose while on vacation..
- i am planning to change the inner tie rod on my right side
- I am SO confused! why isn't my VDO boost gauge visable at night?
- For All The DIYers
- Anyone got a set of 18" rs4 reps they want to sell?
- Are there any RS 6 4.2TQ brake kits for our S4 yet?
- Any one else here have cruise control problems?
- who has run labrees with test pipes here? Hows it sound?
- Installed boost gauge this afternoon
- New wheels and BBK kit installed...next is engine upgrades, but...
- #@&*F^%! stuck coilover #@(*F&!
- S4 Bonneville Speedweek results posted on Motorsports forum.
- Is it normal to need to crank the engine a few times to start it?...my car has always had this
- electrical types: pics showing guts of abs unit
- Refurb Bosch maf sensor from clair @ 102. Any issues or better deals out there?
- Please help....Very daunting no boost problem (long)
- why does the 2.7T motor have such a bitter sweet reputation??
- How do i clean Alcantara?
- X post.... on some used turbos.....
- New Rims and Brakes all Washed Up
- Will an Audi TT shift knob fit on a B5 S4?
- what areas should be covered with a plastic bag before cleaning the engine bay? The battery and
- NJ Theives go Int'l?
- Getting my front bumper from the shop tomorrow after I took the darn thing off...
- Help diagnosing battery problem.
- Anyone have a fairly large host for this video...
- All these new "home brew" software tweaks are great but there is 1 question that need to be answered
- Recommended suspension upgrade? More interested in lower ride height than performance...
- Goddammit!! Someone stole my coolant.
- Who has the best price for the E46 lip spoiler?
- Anyone ever do an impartial test on zero clearance turbos yet? Yes I already STFA...
- Anyone in PA/NJ/NY/DE have a driver side turbo hose (stock or samco) they want to part with?
- What do you guys think about the LLTEK Cold Air Induction Kits any other suggestions?
- Any S4s in V-Tech area?
- Is the Coolant Temperature sensor located just below where the MAF...
- FATS RESULTS: K04/16 with homebrew fueling/tuning.
- Is it worth the $600 to switch from APR to GIAC
- so,what is basically what damages our syncros...i just fixed mine and dont want again!$
- POLL: What sort of boost are those with a) pure KO4's b) K04/16's running ?
- MBC options.
- E-46 M3 = 0...Aggressive Imola Tip = 1....Saturday 8/21...Atlantic City Expressway....Three hard...
- so when disconnecting the battery your car defaults into
- Question...what does FSU stand for?
- What trains to take from NYC-Villanova
- question on Revo software...
- Hear weird noise from suspension, sounded like rubber rubbing on metal. OMFG I could have died!!
- The quintessential FATS visual How-To post (with downloadable Excel file).
- My car finally looks like an S4, body kit, wheels, everything...
- Q For those that have done A8/S8 rear rotor conversions:
- my first DIY brake job - stoptech stg 2....
- Bilstein grooved...Adjustment?
- So if I go lower my car by, say, 1/2 of an inch, how will that affect my alignment settings?
- Toluene: 808 Guy's Abtsolutely Correct: Get A Filter...
- anyone know a good source for Getrag transaxles?
- I need some help, any 6 speed transmission expert installation in the house?
- Okay, what did I break and how screwed am I? Oil every where, hit a bump in the city, bottomed car
- Difference?
- When a race goes bad-for a wicked SS
- DIE Wheel bearing bolt (collar bolt) DIE! grr.....
- Bad MAF, no MAF FATS logs and an old debate
- Looking for advice when getting a Mini DV recorder.
- Torn hose exiting (?) BPV -
- what do you guys think??
- headers worth additional $1800-$2k?
- anyone with a stock A BOX ecu in socal ill pay you to let me borrow it 4 2 days cuz ya please
- To Tall For S4 FUN?
- New Sig, New Toy
- Axle Part # Questions
- finally got my sig to work, thanks to my girlfriend, check it out....
- Did I just see an M3 with dual calipers on the front....any chance of getting it for the S???
- [Farewell clear windows, HELLO TINT!]
- Bizarre issue on track-day, could be a SPEC clutch issue, please read ...
- Easiest/cheapest way to lower without losing smooth ride?
- Anyone have a stock lower airbox layin around that they wanna sell me? E-mail, thanks!
- The Fast and the Affluent...
- anyone heard from piggie lately??
- Is anyone at indukton today? (xpost)
- Turbo swap. What's easier: remove engine OR remove engine, exhaust, tranny and subframe?
- Cruising on highway, at 60 mph...you choose 4th @ 3250rpm or 5th @ 2800rpm?
- One more time...anybody willing to donate/sell a used P6000 in the Boston area?
- Are stock sway bar links that bad?? m...
- Need tuning keys please for H&R ultra CO someone get back to me please NYC or LI
- Photos of my new RS4 wheels mounted...
- Powdercoating done!!....here are some pictures
- How does the N75 "ambient side" connect in this picture?..
- Besides a loose gas cap, what are the main causes of the Check Engine Light? (yes, already STFA)
- Took car to dealer for EGT sensor codes and they replaced a 'leaky' hose. Problem still there...
- Sway Bar OEM upgrades
- is it bad form to taunt and then dust another s4?
- 1/8 mile drag race woes
- I just blew my turbos...going 50 in 3rd gear, half throttle. bam. i just got them replaced by the
- will be visiting washington next week, Any audi tuners i can buy stuff?? TIA
- Kevin must be a miracle worker.
- Just saw the new Audi commercial .....I love it!
- Does anyone have the specs for REVO stage 1 software? I was thinking of trying it out and ...
- i am rather bored so........any new news on k16's or there software to run them?
- finally got my sig to work!!!!!!!!!
- Remember that CLK55 AMG that I met last weekend? (Report from Heartland Park)
- What has happened??!!
- more fikse fm5 18x8.5 pictures
- brain fart..is the M box a hitachi or bosch MAF?
- So I just re-re-registered my Vagcom after another HD bit the dust..do they really work on weekends?
- If anyone has some 17" wheels for sale please e-mail me Thanks
- As requested: Silver S4, 18" DTM RS4's, Stock Ride Height.
- How To Calculate Your FATS Time 101
- sold my car :(
- Thanks Ed@Induktion! The oil lines arrived this am.......
- Chipping effect on instrument accuracy -
- Couple kill stories and me annoying the sh!t out of a ricer last night...
- Any west-side L.A. B5s want to get a run this weekend?
- finally got my stasis rebound tool
- EMERGENCY I need a H&R Ultra Wrench ASAP read for more
- Help anyone? See inside. TIA.
- What's my problem?
- Madman: Madman-approved tire pressure for ST115 in 235/40/18? TIA
- YO MOSSMAN DO YOU EVER ANSWER YOUR PHONE.
- Lidatek LE-30 arrived today... (comparison to ZR3)
- Wow... just investigated buying Toluene through a vendor at work...
- DC AUTO PARTS YO DAN WHEN ARE YOU STARING THE SITE?
- Need some help with oil catch can/vacuum hose routing...*bandwidth*
- ok ok, now we are twin turbo, but this is TWIN TURBO...
- can someone please post some hood pin install pics? can't find any.
- Met up with a couple of nice Porsches and their owners.
- how to remove the "trim" panel on the trunk lid? I see a bunch of things around the perimeter, but
- People with experience selling their car on the internet...
- what do you guys think of this log?? good boost..bad maf??
- GIAC X chip question
- does anyone know of a source for used stock rear S4 calipers?? TIA
- m4d props to Jeff Doyle, he saved the day...
- vogtland/koni shock setpoints
- Has anyone here played with the idear of port & polish or just port match
- Looking for P21S Total Auto Wash at a store in Northern NJ. Any clues at types of places that carry
- Any tuners/distributors have stasis motorsports on their shelf??
- Repaired and repainted my own wheels...
- $6.92 for ONE wheel bolt. WTF?! fricken audi.
- Does anybody want to trade their Nogaro Blue 6-Speed S4 for a...
- thoughts on abs control unit
- Where can I buy replacement S4 badges?
- Where can I get an APR chipped H ECU in chicago tomorrow?
- good place to have interior trim installed in chicago?
- Stage 3 Homebrew fueling UPDATE. Airbox mod and new Lemmisettings: (BWW)
- Paging Mark @ AutospeedPerformance
- What would a stage 3 2000 2.7t be worth?-->
- mmmkay - oil filter ain't coming off - any suggestions to unstuckify?
- What is the going price for 5 S4 wheels in good condition and 7K on rubber?
- Someone correct me. With k04s, x-chip, MBC (no n75), i will need a TCD?
- The enclosed O2 log looks a little lean to me........
- I want to buy a copy of the Gumball 3000 DVD
- Ok, who's going to The Glen in two weeks for the ACCNA NEQ DE?
- Searched but couldn't find PN for stock airbox (to modify). Anyone know PN?
- Center cap metal ring - anyone have one laying around?
- FATS test revision (poll/observations/ramblings/whatever)->
- Racing Subframe
- argggg. Help. ATTN. any bright color car owners...or anyone with panel repaint experience...
- Anyone have this part available? induction pipe connecting hose - 2 078 145 719 P
- stock wheel bolt part number?
- Paging Mark at Autospeed performance
- Reminder----Reading BBQ at my place next Satrurday,8/28
- Would it cost more than $2,800 for these repairs and labor?...
- Estimated install time for phenolic spacers on 2.7T?
- Attention Angular: Here's Your FATS Explanation.
- Anyone have a stock MAF plug for Hitachi?
- Can someone please tell me what "Piggie Pipes" are?
- Thoughts on this jack for your S4?
- anyone know a good upholstery shop in NY/NJ
- Lemmiwinks - Secondary fuel tweak
- Is there anyone looking for a transmission?
- VAG COM in So Cal...
- what should i sale a new style toy guy short shifter for?
- semi x-post from wheel/tire
- Curious, anyone out there have some more pics/info on this cosmetic mod?
- Would someone be kind enough to post a pic of a custom 3 inch exhaust on a UR s4 or atleast a off
- This weekend's project: Aquamist 2d...
- Any S4 (2.7) owners do this mod?
- Anyone bought from these guys (OEM RS4 bumper)? Seems too good to be true.
- Paging ANGULAR: I just saw your post about running 18x8.5 Flik Artics with 255/35 Toyo T1S...
- Does anyone make crossed drilled rear rotors for us?.....
- Mad props to kid NOVA for the boost gauge install. Tip for STEVE TRAC, stay away from the sushi.
- where to get K04 inlet tube couplers?
- My new wheels are here! Thanks Josh/Achtuning!
- Silver S4 on Rt22 around 9am, with Rims and Lip Spoiler. You here?
- Which K-04 Kit should I get AWE or APR , MBox
- RS4 owns M5 (repost?)
- When replacing turbos, do you re-use oil-contaminated intake piping?
- need help diagnosing a noise from my front drivers side wheel area --->
- european license plate holder
- In high gears my car *jumps* from 20psi to 12psi back and forth
- What is a used set of Tracksports worth and what is a set of used Stoptech 332 worth?
- VAG Motorsports MIA
- Totally confused on coil over options... help out this fool!
- FATS test question. What publication is "peers" data coming from?? (more)
- Why is getting the radio out of safe mode such a pain in the ass?
- pls help.... i unplug the MAF to check how it'll run, it makes the ESP and ABS warning lights on,
- Where is the best place to post this
- Since people have had such issues with the SPEC clutch, how is AWE stage 2 combo?
- AoA fiasco x-post
- Look what FedEx brought me today!!!
