- B5 S4 vs C5 A6 2.7T vs B8 S4 - will the 'soul' of the B5 be replaced in the B8?
- Anyone have experience w/ GHL DP's?? Any measurements/diameter ect already checked the DP
- Help!! TRE pinch bolt...P/N please
- B8 S4 spied in Sweden
- How long can you drive with a split CV boot?
- throttle cut / surging problem resolved - wastegate line T-fittings cracked
- Im thinking about buying 2 guages...
- anyone looking for a 01 Avant S4 in the bay area, CA check out the link
- Valve gasket seals.
- Garrett K04 Hybrids K04/T28 New Turbos to test and tune
- Plasti-Dip FTW
- WTB but can't find: OEM S4 bumper
- Those with PIAA wiper blades - did you use 22" or 21" on the driver's side?
- I have a good feeling about this BSH place. I think they just need some time to learn the Audi
- So what would cause my fogs to stop working unprevoked?
- Question about engine noise in my pick-up thats driving me crazy!!!
- Any avcr install pics???
- To those who are in the startup CO GB what suspension are you guys replacing?
- I can't hit full boost on my KO4's until 4500 rpm what's wrong?
- Anyone use Raceware main studs...i'm having clearance issues...
- Last stupid post, how do you remove the clip that the sun visor clips into?
- rear rotor removal question - stuck bolt removal
- Need help with cylinder 2 misfires...
- [phatbox] - headunit says 'CD ERR'
- This is normal, right?
- a bit too much...
- upgrade
- can i use stock lugbolts on volk te-37 wheels..
- Heres a lil sneak peak of my front bumper mods, having grills painted in the next few, whad u think?
- Does RS4 fueling use a hitachi or bosch sensor?
- Any feedback on a ABD intake?
- Xenons are installed with auto load leveling right? So...
- Can anyone give me a few causes of High CFs on a Homebrew Stage III?
- Whats a good VW forum?Sold my 2001 S4, picked up an 08' GTI...
- Started engine pull last night. See link.
- Can anyone tell me how to remove the sun visors?
- Clutch Will Not Engage
- heya "Doc Slow Mini Person" have any opinions on a inline maf "eurospeed" vs a 740il?...
- Black, lowered, with no insignia and funky exhaust on I-394 eastbound...
- Headlight housing assembly: how do u get that little plastic ball into the joint? near the high beam
- Well, replaced the starter solenoid today and the bastard is still being a whore...
- Does anyone know how much it costs to upgrade from GIAC-X to the stg3 file?
- Coolant leak update: Need help diagnosing
- paging Mark ASP : i took out the MAF sleeve last night. the car feels sloowww...
- Starting work on a custom sub enclosure in the trunk. What is the unit with 5 cables
- Pulled with stock 996TT on Hwy from 60 to 130 today. Barely pulled on me. Maybe car length.
- NGK Iridium BKR6EIX-11...any use them? Thoughts?
- Anyone have a set of interior trim for sale, Preferably wood for piano black conversion?
- '00 Pearl S4, PA plates, traveling south on 95 from PA to DC today
- paging troy @ sdr. Hoods back up for sale?
- CV Heatshield Bolts - Trouble
- More pics of my accident fix.. Primed : )
- New Torque Converter = Finally no Check Engine Light
- Parking brake options for Alcons
- Tightening the Wastegate Actuators, Which direction
- Anyone know how I can talk to a dahlback rep?
- i got a stasis trans = broke but happy
- Ran over a rock and airbags deployed...damn (more)
- Questionable service from KMD Tuning in NJ
- Looking for front stock bumper cover...searched classifieds already
- So my passenger secondary O2 sensor wire melted against the downpipe, need suggestions
- Looking for tip chip installation photos
- A few first time logs...could you guys look over them and tell me what you think?
- Question regarding O2 sensors
- Anyone have a better write-up than the one in the tech articles to remove the interior trim?
- Stasis Tracksports or Vogtland GT's?
- what can i get for used 115k mile cylinder heads in great shape?
- Our Group Buy on Balanced GT Coilover Kits is coming to an end, and we are in the money!
- Does anybody have a passenger side front fender they are willing to part with in santorian blue?
- At what point is it appropriate to post a compliant about a supplier here???
- Help with wheel decision
- 01.5 oil feed line kink?
- Put in Mbox ecu in 2000....getting a 18057 fault code..any ideas why?
- dont hate me... but last help from you guys... about StartUp Coilover system
- Don't forget Vogt GT GB ends soon. We need a few more...
- Doing front rotors this weekend. Please tell me exactly what tools I'll need and
- I miss this forum =(
- I've STFA
- pagin dm-s4
- fluid
- my next mod
- OK, its on, finally getting into an S4 hand me down.. kinda long story, need suggestions
- new ride addition to my mod S4
- Only class of the day got cancled so decided to log. Please comment...
- Mobile Photo Radar Van Arizona
- Is there a bolt on version of this for the S4? Or is it just a VW thing?
- Does anyone have a used set of 3" downpipes they want to sell me?
- What is the preferred comfort-noise/performance tire?
- Coolant temp issue...I've searched the archives for about an hour now and can't find a similar...
- is an s4 for me?
- SPOTTED: New S4 engine testing
- '01 S4 Overheating to 116* C - Thoughts on root cause?
- Clicking in reverse
- Anyone else here nuts enough to have two B5 S4s?
- photos of me @ Big Willow arrived! w00t
- Would a clutch ever slip due to cold weather, or is any slippage a def. sign its time to replace?
- Looking to replace my tires......need advice
- What is the going rate for 4 B5 Avus wheels...
- so, decided to sell my car-> check clasifieds if interested.
- My 1st time ECUx logs inside. Help me learn... Stage 3 AWE
- RS6 fueling questions.
- leaking oil pretty bad.....like 1/2 qt. every four days.....
- Go Low - Ride Great - Adjustable Ksport Coilovers
- Ive about had it..replaced the coolant temp sensor with the upgraded green one..now misfires at idle
- Tranny fluid replacement...
- Going rate for a set of clear-corned OEM S4 headlights w/ all bulbs, ballasts, etc in great shape?
- power steering "cooling" lines WTF? is audi serious? they have a metal line coming from a hose and
- This wheel setup will clear OEM calipers right?
- Anybody got a straight on shot of the front of the engine showing the water pump and thermostat.
- old skewl
- Lil help. What could be the causes of random misfiring?
- The rear right hieght of my car sits higher then the left??
- TIAL GT turbo tuning ? What happened to that live tuning on WED?
- Hey can someone do me a photoshop favor? please
- Does anyone have a rear wrecked s4 the i could possibly by parts from to rebuild the front for imola
- Anyone here have a Key-USB cable from ross-tech they would be willing to sell?
- Any tech writes up for dropping the headliner in an Avant? Yes, I searched! TIA
- So anyone here ever raced a Turbo RX-8? (on the track of course)
- anyone have a front license plate cover in good condition they'd be willing to part with?
- I'm debating if I should turn up the boost a couple psi, running 19-20 right on custom EPL tune=>
- Drive cycle
- ANYONE running ASP, what kinda gas mileage you guys getting....im
- Seriously considering "upgrading" my S4 to a Lexus IS-F.
- Bad Weekend (Warning: S4 in pain)
- Anybody know what rims these are? I hate these post, but love these rims.
- Focal Component Speakers in Front Doors
- New turbos + VAST fueling/software yields my new personal best on 93oct! - 11.7@121.9 !
- Just finished my Downpipe install and had a few questions.
- Have people ever chipped their car and left in stock diverter valves for a little ?
- White S4 on West I-80 in NJ this morning, you on here?
- While I want to thank ECS for super fast shipping.. I gotta bitch a little...
- A question for all you DIY turbo swap guys. How many hours did it take you? More...
- which blocks should i log for.....
- Clamps: Constant Tension for Y-PIPE (TBB link)
- OK, I swear this is my last LWFW question: who is running SB OFE clutch w/ Fidanza? Driveability OK?
- These will look sooo good on our cars
- Paging Abdullah@VengeanceEuro when you going to put the big sequential turbo in man??
- RS4 K-04 turbo and inlet set sale at Achtuning! $2555 shipped!
- clearance questions OZ UL and ENKEI RPF1
- paging mark or frank @ ASP....to the white courtesy phone...
- Does anyone have a silver / sedan / S4 / passenger side skirt?
- Latest Review of new RS6 from Autocar in the UK.
- Hazard relay install?
- shedding some lite on UltraRev CM 3/4
- Anyone looking for an OEM TBB? I've got a few.
- any of yffs looking for a pair of caps in silver?
- Paging DxC: how did that ebay aluminum radiator work out for you?
- Anyone looking to upgrade to 4wheel Alcon's?
- So it is now parts collecting time for my turbo upgrade. I am going to buy mostly new but would like
- Anybody know if there is any practical difference between the ASP and the AWE DTS???
- OK, I've read every post ever made about LWFW's and can't decide. Going stg3 soon w/ SB OFE clutch.
- advice needed. Semi long....
- New ASP Stage 3 TIP...whoa.........
- woo wooo the project begins
- Guys that want to run 18s and aren't dropped or want better handling - get in on this Vogtland GT
- Good afternoon! Free Ground Shipping Offer.
- Anyone got a spare passenger side foglight assembly?
- I F'ed up and dropped and broke my u clips putting on the coolant sensor so my
- So to the mechanic who overfilled my engine oil by 2 liters, what can I say is damaged?
- Just pulled the trigger on a set of Bridgestone Potenza RE-01Rs, they look juiicy...
- Closeout Deal *BBS RC Wheels 18x8.5 ET32*
- *Edit* Auto Question: Is it okay to use gasket maker or sealant instead of gasket on water pump?
- Crappy snow...
- ok I got new u clips to put in the coolant sensor, but I'm having troble getting
- Repeated water pump failure. What could cause it?
- Anyone need a Milltek muffler set (just the muffler and center box)?
- My brake sensor warning light wont go out on my display. I searched with no luck. (more)
- Rear passenger side caliper......OF DEATH! Update of REAL fix.
- o hai i upgraded ur snowz
- dealer says my oil cooler is leaking...
- Mazda MazdaSpeed 3
- how to log iat delta using vagcom?
- Another attempted theft in the dirty Jerzy
- Is a alignment needed after rear wheel bearing replacement?
- any of you have you stock bumpers to get rid of? looking for a black one but will buy any color!
- Got a lil somethin somethin in the mail today...
- is there any market for a full engine wiring harness? what could i get for it
- Hey Mike (or others) care to chime in about any ammendments to this DP install article?
- Misfire in Cyl5, replaced CP, didn't help...
- Does someone have a stock ECU they'll sell me?
- Hit a large pothole and bent a wheel, now hearing a cracking sound....
- Frank @ ASP did you get a chance to ship those clutch kit parts i was missing
- My wife is driving the car and called to tell me her front right wheel sounds like
- Is it normal to see misfires on a cold car?
- Audi Pics
- New stage III wasting gas at $3 a gallon...
- Spotted you - S4NIC8.. Eastbound 10 fwy ~4:00 pm
- Headlights flicker a little at idle. Original Xenon bulbs. Are they going south or other problems?
- Someone PLEASE take my CPP arms.. And give me stockers instead.
- Cheapest place for K04 w/ inlets?
- Fair price for used KO4's
- which N valve should i use? N75j N75K or maybe a Vast MBC
- DIY last wknd...plug question (B2S1, N249, N75, 4:6 plugs!, Oil, Air...
- quick need help i was installing a new coolant temp sensor and was
- what did u replace besides TIMing PaRts when u did ur Timing Belt??
- Stage 3 fueling kit installed, but ran into some problems....
- I would like to make a formal apology to Mark and ASP for yesterday's thread...
- Anyone have the RS4 brushed aluminum mirrors for sale?
- AVIC D3 Harness and Dash Kit
- NO ONE carries P/N: 4D0-698-671 (caliper seals) I need immediately. Help! Danke.
- Anyone have a rear passenger side tailight assembly laying around
- Thinking of jumping on the group buy for the Vogtland GT's but before I do
- I need one of these in black. Can anyone help me out?
- Cracked my windshield. Insurance is recommending Safelite auto glass. Are they reputable?
- How much better (if any) is the AWE LWFW than the Fidanza at twice the price?
- Reminder: Group Buy on Gran Turismo Suspension Kits
- AWE Stage 3 installed. AWE + Avalon Rocks! Thanks Brian!
- Sneak peek at my new winter setup....
- Ne1 have a front plate mount 4 sale?
- did i adjust this right, or do i need to move little fins over more?
- Anyone have a stock ballast they might want to sell. maybe if you've upgraded yours.
- Where does the Outside air temp sensor (G17) connect to car?
- Has there been an update on the new AWE vent boost gauge? ETA?
- Not sure I want to know the answer to this...
- stable energies harness bar
- Got a coolant leak...again. Seems to be happening in 20k mile intervals now.
- Had 17 DTC codes and 1 for ABS, checked fuse 34 which was blown but
- big power!
- anyone have carbon brakes ??????
- We have finished another ASP Stage 3 car :-) Customer transported his car from
- should stainless steel brake lines for stock brakes have banjo bolts?
- How do u know if your in limp mode and how do u reset it?
- I guess I need a caliper after all...poop
- what's the difference between "bi-turbo" and "twin turbo"?
- Looking for some super sticky tires for the summer and a few track days....suggestions?
- High speed fan runs after, no overheating, no CEL or codes
- Loud pop on downshift in tip, gear selector icons on display all blanked and became red
- B5 on TSW Volcanos (18" only $549-set, 19" $649)
- pretty slick! the audi for people that can park themselves :o)
- Any definitive answer on spark plug torque? 22 ft/lb or 22Nm?
- Hey guys can anyone of you get me the radio code for my symphony radio..
- AWE Stg III mileage calibration
- Just got a replacement coolant temp sensor, and I dont know where it goes.
- Break Pad Recommendations
- 01314- Engine Control Module- No communications Int...
- Whose going to be first to try em????
- if my p/s pump were going out...
- Cross-post: What original colour did your stock B5 S4 rear calipers come in?
- Can i hook up my EFK to the foglight wiring?
- Eurotuner's vid of the Ecode/ASP car
- Q. will a 2000 ecu work in a 2001, dont care about cel or whatever just need
- anyone have any experience with ecs V-Checker Scanner-Pro.....
- Quick question...what color is B1S2 o2 sensor plug?
- post for whoever was looking for stock s4 calipers and rotors, not mine
- Just wanted to say thanks to the guys at VAST. Always a pleasure dealing with you guys!!!
- Turbos: RS6 vs GT25R vs GT28R vs K04?
- Stock ECU vs GIAC ECU Fuel Economy: Is there any difference with apples to apples driving style?
- Clutch Install
- Kinda funny encounter.. Guy thought it was a Mitsu.. [more]
- Emissions
