- How does the B&M short shifter compare to Tanoga, Stratmosphere, and ToyGuy?
- Installed TG short shifter. Happy with precision and throw length, more effort than expected though.
- Thinking of looking for a local shop to powder-coat my stock calipers. What would be a...
- questions about s4's...
- sidemarkers
- Software to change the boost value's
- Replace o2's with testpipes?
- Widebody:
- Lemmiwinks and USB VAG COMM
- vagd my car today...
- I think I found my new sig....>>>>>>
- Normal for mtm chip to spike at 20-21 psi?
- I finally have a sig....big thanks to Sonny, it looks great...
- anyone interested in trading a set of 18's for my anthracite OZ SL's 17x8, et35?
- airbag light on, horn not working
- Anyone ever try a FMU on our cars?
- 2.7T Vacuum T Fitting for Diverters
- RS4 tranny mounts, what did we say the silver color were the RS4 part the black were orig S4?
- Opinions needed: For the trim, would it be ricey to have the trim match the yellow CF/kevlar of the
- Some preliminary dyno numbers to share...
- Where can I get the OEM hose clamps
- here is the dyno graph from my dyno run at yarrowsport
- ok, so i broke some of my birdseye maple trim trying to take it out.....anyone with experience?
- Look at this cool tool I found:
- Stasis Tracksport Coilover Suspension Review (500f/600r/sport valving, on B5-S4)
- Do you guys think there is anything that I can do (Turbo Problem)...
- new mod: tint.
- what's wrong with this picture?
- Finally got my car running. I feel like SuperTech now.
- X-post: Calgary Audi Driving School Review (May 16, 05) (long)
- Putting on the H&R ultras, wondering how dificult it is to adjust..
- New Sig....I Wish I were a PS pro...maybe some of you guys could work on it...
- Picture of the car after reassembling it the other night
- Random Data: A-Box AMS/ABT Stage 2 Fats run, no lemi tweaks.
- Trunk rings on stock engine cover....
- Question: Black Leather Interrior, Silver Belt line trim. What color Center Console?
- has anyone installed their achtuning oil cooler yet?
- Cranked my car a little lower, what do you guys think?
- OK....Installed Snub Mount, Samco TBB, F-Hose and 710n's....what about intake....
- Vanity Plate Opinions - S4NIK8 :-)
- how many wires attach to the ground behind the coolant bottle?
- Please confirm: Gapping for stock plugs (NGK PFR6Q) at 30?
- what you you guys think of this? Tornado...
- Poll: Santorin, Cactus or Casablanca?
- Installed VDO boost gauge today and am only spikin at a little under 18PSI on ABT Sftware
- Where am I suppose to buy the new Audi Ipod adapter?
- Who do I send my oil sample into to get tested? I have one from 5k miles ago and one from today...
- I am buying a 90mm MAF housing and using my stock Y-pipe. Will a RS4 acordian hose work?
- anyone have a good creeper that they'd recommend? I've seen this "Bone Creeper" which is supposed to
- !!! NEED HELP!! I just removed the key from my ignition and the car wont turn off. i have a clifford
- My dyno day results
- Milestone for my S4...
- Edit->01 S4 for ~$18K hit or skip.
- I met reefer_bob and his charming girlfriend today at the Streetwerke Open House . . .
- took some pics after gettin the windows tinted and a lil work with the clay bar and wax :)
- will navigation plus work w/ the bose sytem?
- Downpipe removal...Stuck....finishing by tomorrow?
- What are these AW S4 guys doing?
- does this match my nogaro?
- Interior Light Bulbs
- Cacti.
- Turn signals are staying on constantly when i signal....bad hazard relay?
- Let's stop this AWOT crap now before it get's out of hand, whatcha think?
- Question for people w/ AMS flavored kettle chips [inside]
- and who says you cant get more power out of a stock ecu!?! +28 whp & +21 wtq!
- Has anyone purchased the Hella "teardrop" side marker lights from ecs???
- DAWG check out the new rims !
- Ok, cruising at 80 on the highway, 5th gear, when all of a sudden car just stalls. Make my way over
- Any one looking to get rid of some aftermarket things?
- Laser Red Thread get in here if you own a laser
- for you n00bs and others that have yet to deal with dealer monkey installed oil filters or have and
- Turbo going bad?
- S4 Woes.... Car keeps shutting off on me threw these codes
- Not making it to the open house, but who may I expect to see at the ND car show
- Ran at the strip last night. Also ran against APR Stg1 S4.
- Fuel Gauge Needle Acting Erratically: Moves Below Empty Or Past Full
- There are some heads on ebay from a 2000 S4. Buy it now is $2100. For those in need.
- Only because I can... freshy before she hits the shop in 2 weeks.
- I found out that my rear coilovers are flat, front are not. Is this nomal?
- silver s4 at the tropicana last night.
- argg. where is the luink to the thread of the HILARIOUS boost gauge install?
- diverter valves
- Thoughts?? 00 S4 with MODS with 102k
- Fuse location help - radio problem
- Thinking of going from an A6 to an S4...
- Is this normal?
- Anyone know the intake Y-Pipe hose clamp size where they connect to the rubber pieces?
- Photoshop Help Please - can someone make Passat brilliant black leaving the rims gunmetal
- Coilover install gone bad. Please help me!!!
- My body shop said I could wax my newly painted bumper right away. This seems highly unusual to me (m
- Replacing Timing Belt and turbo hoses, Need to remove bumper?
- Which exhaust is on this RS4? Sounds badass...
- Any reputable place in SoCal to get my used KO3 modified?
- I need to replace my passenger's side, stock intercooler on Monday. Anyone have directions for me?
- Me 0 Tie rods 1
- Just had some fun with my GF......:)
- Finally got around to logging boost ramp up with my clipped Buehn Engineering K04/K16 hybrids....
- NJ folks...a reminder: GTG/car show Saturday the 21st....
- Stasis comments - I must say a few words - I asked about sway bars - I asked Ryan - and
- Sport Alcantara interior = cheaper?
- Stoptech 332 wet braking = much improved vs stock.
- dad got into car accident
- Can someone give me instructions/tools needed to change brake pads?
- 225/40/18 and 235/40/18 work together on quattro?
- Timing Belt Broke on my 01 S4 6 speed, now what?
- dyno results from my dyno at yarrowsport..dyno dynamics dyno
- got my car back after a long wait, and test drove a porsche 997 carrera s (long) :-O
- Finally got my S back after 2 weeks. Had to readjust to driving in real life after "driving" for 2
- i've been itching to spend some money on the S all day, no idea what to buy though.
- Hella 100w HB bulb upgrade (impressions)
- Anyone have pics of oem bumper with Center Bar Deletion?
- HR springs off an 01 fit an 00?
- mcmaster-carr bolts to bolt driveshaft to tranny
- Need some help with control arms!
- WTF?
- First experiance with AWB...
- Getting ready to change the TBB, F-Hose and installing 710n's on my "early" 2001 S4......
- Easy question - Will 17x8 OZ SL's fit a B5 S4 (2001) without spacers? Making Sure (Yes/No)
- Who here has used ModuleMasters for their ABS controller repair? Any problems?
- since it's so slow today anyone want to make me a sig?...I am teh suck at such things
- Just discovered, RS4 shift knob is not the best idea during the summer...
- Tweaking with narrowband 02 sensors....
- Help, Problem with HVAC/NAV/Foglights
- A friends laser red S4 in for body work at my shop..
- Can anyone beat $125 for updated 19mm Neuspeed swaybar brackets?
- Brake Through with STaSIS and APR
- What all should you replace when installing suspension?
- gumball pics. no more S4/RS4?
- Please help!!! I'm stuck with the car (tie rods)
- GIAC Flashloader not working anymore, stuck in pump mode.
- How can I determine what type chipped ECU I have? Opened it but nothing says ABT or AMS.
- this was probably asked 100 times before..will piggies(from a 6 spd) fit with no issues a tip car?Tx
- anyone have experience/opinion on rotora brakes?
- Car Shipping Cost Cross Country
- Any issues with running a 70 deg C thermo stat..
- Are offsets on wheels such as ET38 measured in millimeters...so et30 versus et38 sticks out 8mm more
- live in S Fl. i have APR chip 93 oct, how can i get 100 oct, how would i go bout doin that? reflash?
- Speedventures Big Willow weekend event on August 13th & 14th, 2005!
- So after 5 1/2 years of ownership, I finally filled up with 100 octane.......
- Repost for daytime crowd (valve noise)
- Another part help request - which radiator fan switch is correct? ....
- Ok, so the Euro Xenons are on permanent backorder from the factory. I was told that
- Do all you modders have tons of extra cash or do you just blow all your cash on the ride?
- P/N help needed - long hex bolts that hold tranny mount bracket to tranny...
- Anyone have ASP testpipes
- NorCal, good weldert that could add a bung to my upper IC pipes? Aluminuminum
- Anybody wants to get rid of K and N filter. Need it cheap for project
- Where is the best spot to place the jackstands when lifting the front?
- While the S is in the shop: new S4, A3 and A8L - W12.
- darintake in car?
- issue: click sounds at low speed horizontal motion only
- If you got to choose a BBK... which one? and why? ($$ not a factor)
- someone trade me s4 mods for a 96 impreza :p
- ECU Explorer versus VAG-COM
- stupid question: What's the part # for our stock spark plugs?
- Repost from last night: Can someone please tell me where to find Wurth Silver METALLIC Paint?
- Tech Guru's: I hear this low pitch rpm related noise/vib. coming from the rear right pass. wheel
- Silver S4 at key Audi Jax service yesterday.
- Discussion: NOS and Intercoolers.
- once in a while, I hear: TICK TICK TICK TICK TICK TICK TICK TICK TICK coming from the engine while
- Repost: I can't believe EuroTuner called One Nice Audi's car an A4. kinda funny but still wrong.
- Does anyone know the A-hole selling these seats??
- beautiful day for some pics w/ new nikon 5600!
- Anyone have any S4 parts for sale in the Reston, Virginia area?
- Loss of Power - Bad Idle Problem *solved*
- tonggi learn to drive... :)
- My S4 stopped shifting into gear
- Valve tap after hard driving...
- Did Europe have more color options for B5 S4's?
- So purchased that check valve that hooks in behind the N249 part number
- APR Stg1 S4 vs. Neu Stg2+ S4 vs. modded Track 350Z - all dead even.
- ko3/k16 time slips?
- Dealership woes...
- Found some old pics of the country house
- Dealer Rant... Dealer Rave... (Audi Assured, 55k)
- whose S4 was just on Monster Garage? Nogaro, CF hood, Stoptechs, stickers, SSR GT3's (i think)
- looking to replace my Euro lights & get an RS4 bumper. anyone know .
- Is the Turbo XS BOV's a direct replacement
- Lubro Moly Jectron- anyone used to clean injectors?
- NASA roll call!!!
- Going to do some wheel reapir using NASA Racer's post as a guide.
- lookin at...
- HEADLIGHT WASHERS
- woe is me, 1st gear synchro failing!
- ok.. fine.. I'm gonna take my volk stickers off. I don't have any Goof Off but will WD40 work?
- How much do stock Bose sub's cost, and where can I buy them?
- Just bought 02 Black S4....have a question??
- sounds like k04s are back? any reason for them to cost more than before?
- Poll for Stage 3/homebrew folks
- I was changing the afterrun thermoswitch today and there was a bit of an accident...
- Is this someones car on here?
- Can this be done to the S4 like this "CRX of Death" ??????!!!!! (BWW)
- Classifieds buyer: Murray Carthy sent me an email for two items I have in the classifieds, SCAM!!
- those that dynoed at the yarrowsport dyno day in april if you were stage I,II or II+.....
- How bad/stupid is it to run H&R sport springs on stock shocks?
- pressure testing
- And you think Audi service sucks......here's a great Porsche service tidbit........
- Paging Imolavirus -- is Jacob alive?
- screeching/squeaking sound
- turbo timer?
- Blast from the past
- I need a list of who has RS4 Inlets in stock please!!!!!
- looks like I'm gonna make the jump here to an S4...
- Damn, there are now 2 b7 S4's at my work. now we have 2 b5's and 2 b7's...that is all
- Eric Fletcher thinks STaSIS SUCKS, just incase everyone didn't already notice. :)
- Finally! I have confirmation that I will be receiving 12 sets of K04s next week. Who needs em???
- Need help, what do I need to run an X-chip with greentops?
- Poll: How many of you are running Turbo Timers? My tech/buddy's dad wants me to ask. I HAVE 1.
- Who has had a tiptronic failure?(more)
- might be a repost..but great read for potential S4 shoppers
- Where is the best place to find paint that matches OEM wheels?
- Caption Contest: funny pic from the track this weekend.
- which chip is the best for the s4?
- went to track last night ran 4 times....
- APR Software Specials from 5/20-5/22
- cv joint
- Some cool top fuel dragster info: Acceleration put into Perspective.
- Anyone buy one of the cheap M3 style lip spoilers from eBay?
- perhaps dumb question (STFA)..AutoWarrenty brokers...
- part # for the clip that connects the maf to the airbox?
- I STFA. Does anyone have a write up for RS4 motor mount install??
- Cayman S opinions?
- Once again Piggie is the man....
- graphs of boost, maf, throttle angle, please comment
- wtf - universal stage 3 turbo, is this a joke?
- I am confused!! Redline 75w-90 or 75w-90 NS for our rear diff?
- Should my turbo inlet pipes be heat wrapped.
- Sigh... the S is in the shop for new Motor Mounts... so I'm driving the TL-S...
- Your opinion please on tire size and handling/performance...........
- X-Post: NE OHIO - Valley Cruise, Bunker's, BBQ, and ALMS this weekend!
- Changing dash lights
- Q: How many of you ask to be given old parts when having something replaced out of
- Do we need to replace the 710Ns ever so often as preventive measures?
- does anyone have the link to the recent dyno day at yarrowsport, someone posted results?
- Anyone have a source for inexpensive wheel studs and nuts?
- To those with tiptronic:
- Why are Achtuning's Avus replicas ET35? Even Ebay has ET45 reps. How is that really a replica?
- Houston Raceway last night....
- Hey, why did my name change poll get deleted?
- Well, we've added another turbo vehicle to the family.
- Funny Noise
- What does this thing do?
- Argh! I've been without the S for nearly 2 full work weeks now...
- STFA...Onyx interior of S4 vs A4
- Anyone have a pointer to a DYI spark plug change for the novice?
- why did audi give the b5 horrible wheel gap, fix it for the b6, and then give the b7 huge gap again?
- Quick response needed: putting my stock airbox back in¬iced the screen right before the MAF
- Loweing compression: Discuss...... RS4 compression is 9 i believe, S4: 9.5 any way to lower to 8.8?
- Question about warrenty and giac chip
- Pulled the trigger on 19x8.5 RS-GTs
