- NEED HELP WITH CODING ECU AND CLUSTER!!!!!!!!!!!!!!!!
- Help with electrical problems-- more inside
- The new AWE gauge looks really, really good.
- Anyone know spanner wrench size for stasis tracksports?
- Bonus of swapping your seaonal wheels: Discover torn CV boots before the joint burns out.
- I REALLY want me some RODS !!!! ASP let's make it happen ! WHO'S IN SO FAR ?
- Hmm... too low in front?
- PIGGIES!!!!!
- headlight washer hose....
- Need some ECUx assistance. Can any of you open this file without hanging ECUx?
- Driver's side O2
- who has a front bumper for sale that isn't destroyed?...
- Been awhile since I've been here...here's a few pics I snapped today
- Just finished the new front mount what you guys think.. Sorry for such big pics
- 3/4 through an interior swap, notes
- Can anyone verify that I can fit B6 Avus wheels with spacers ->
- Who had a problem with their Stasis Transmission?
- GT2554 kit for sale with or without fueling
- Who's been molesting my car?!
- HELP!!! VAST RS4 IC to ER IC... Passenger side IC - lower turbo to IC charge pipe... Don't have
- Installed my boost gauge last night: is 18 psi normal for ASP chip?
- Brakes just locked up!!!! whats do I do?
- Central Locking system Vacuum Pump--took a dump....
- Paging Hibiscus Red S4: YGM. I am in need of a rear abs tone ring.
- Slave cylinder hose update...
- J/W will we get Tial results or a B8 S4 first?
- 18x10 et20 with 275/35/18 rubber? Will it fit on a widebody?
- Hartmann S8 Avus replica wheel special at Achtuning!
- About to flush coolant but can't find heater core hoses
- Help me fit 19" B7 RS4 wheels on my car!!
- Has anyone done an Eu tuning reflash on their car (M)
- More power on the horizon.. TIAL kit! gt 28 size.. question though-
- Lets play, what is this and where does it go:
- can someone problem solve this.
- URGENT - help needed - missing bolts
- Just out of curiosity, what kind of crank H.P. does..
- Anyone ever have their trunk release button get stuck in?
- Finally! Coilovers, control arms, and tie rod ends are done.
- O2 sensor line got fried by downpipe - can anyone recommend a good heat wrap for this wire?
- anyone have a healthy santorin-colored front bumper? i needs one.
- oil supply lines? aftermarket or stock?
- My life with a b5 ... (BWW)
- Spark plugs for Stage 1, what is the gap?
- Help car would not start after 3rd to 2nd over rev
- Help me with these problems......a lot of them.......
- Can you put a fidanza friction insert into a AWE flywheel?
- Please help... I am stranded. Rear brake calipers wont compress
- Anyone have a new-style Toyguy short shifter for sale?
- Help with tires for 18x8.5 and 18x9.5 ET?
- did a little investigation... any guesses why only one cylinder looks damaged?
- STG 3 driveline shock.. does it matter? When I left off the throttle or clutc sometimes
- trying to remove sway bar, help
- Caliper Carrier bracket: is this hole normal?
- Rusting Twin2 tips part 2 (Thanks AWE)
- So my slave cylinder is leaking and my clutch pedal doesnt go all the way up. anyone deal with this?
- Iz there anything missing from the PS motor timing kit that i would need??
- How to remove rear trim on avant hatch?
- Ok, so finally pressure tested for leaks and i found one near turbo (more inside.)
- Quick Review of the Sir Tools B-90 wheel bearing puller. It's a great tool
- While out shopping for avants today, I came across this beauty...
- Dyno results: 351 HP/409 Torque - where's my HP?
- Tomorrow 4/6/2008 California Speedway VW Audi event, $25 for 2 runs at the quarter
- [bpv] - whats the easiest way to replace the 'L' shaped samco hose that connects?
- 2000 S4 (aluminum uprights) front wheel bearing install.
- What tools/parts are in your car and where do you keep them?
- selling my stock pistons/rods to a forum member but I have no idea what's a fair value. thoughts??
- FPR's
- Front piston is all the way out and I can't get it back in - help!
- Any one here in North Wales, PA with a Black S4 (00-01.5) and a red TT?
- Is 25.5" ride height too low to enter car washes?
- Going to Frankfurt.. what Audi gear to bring?
- Carbon Fiber X1-intake
- Has anyone purchased these wheels on ebay?
- Accy belt broke last weekend - haven't had a chance to check it out yet...
- rotors?? would some that are drilled and good quality?? nice price too
- Looking into a set of wheels, have a quick question
- TIny puddles of oil in inlet pipes, and in intercooler..Catch can worth it? I am 2000 6spd.
- Found this on craigs list
- Quetion about reliability and maintance afer 50k?
- Okay! It Lives again!
- Are all tail light bulbs P21/5W, or 1157,.... Or are some different - I have 4 slots, and the to
- Stange and insane. +40 deg timing "OTS" AWE. Questions
- I want this
- How do you install a single DIN stereo in a 2001 B5 non bose?
- My slave cylinder hose just broke!!! Can it be changed without pulling the engine?
- I need a casa B5 S4 avant or sedan!
- Any of you have your stock headlights you want to sell?
- Can you run a stage three APR ecu from a 2000 in an H box 2001?
- in KC, 92 octane is the best I can find, I have the 93 oct. GIAC prog...
- dumb question...where do the white and orange wires go when installing boost gauge?
- Long shot, but does anyone have a set of Induktion oil lines....
- Anyone know where I can get oil, cabin, and other filter info for a bunch of different cars?
- B5 RS4 Replica Color... What is the original finish on the OEM wheel?
- my weekend project was delivered today - bearings + brakes
- Didn't want your Veyron to be like eveyone else's? Check out the Hermes model. A bargain at $2.4M
- Just searched for 20 mins and want to make sure the info I gathered is correct...
- Still have oil leak, have replaced valve cover gaskets, cam tensioner seal, cam gaskets, ..
- daily driver
- BMW 1 series Tii: Weight reduced 135i with extras
- does anybody know the required conditions for O2 sensors to show ready?
- if you guys had to buy a car in the $35k- $40k range as a replacement for the S4 what would it be?
- anyone ever add there mods to there insurance policy. my insurance company told me i could do it.
- missing CD changer and tool box ?
- Interesting Article from CR....
- A Show of hands please!!!!!!
- Anyone know the symptoms of a worn center diff?
- anyone ever consider doing a car computer?
- It's time for the NAME THAT PART game! The Car: 1997 VW Passat VR6. The part...
- Anyone have a single 60# Siemens Mototron in stock or or sale? Need by Monday. TIA.
- Need some help gents...
- Gauging Interest: Who would be interested in an E85 tune/kit from EPL, JHM or the like??
- Does this sound right? - faulty O2 sensor - details inside TIA
- Log request for ER IC owners (and maybe AWE, too)
- Startup noise 02 S4
- Rusting AWE Twin2 tips
- need help I can't sustain boost
- The no sun roof club..
- Labor Poll - How many total Hours?
- Out with the old AWE Guage and in with the new....
- Figured it was about time I posted my Stage 3 build progress...56k = go take a nap...
- One more shot: Any common problems with the cigarette lighter (known fixes) besides the fuse.
- Ever seen someone widen a wheel?
- CA replacement?
- Leaky diff?
- beware of bicyclists
- So my motor is out, getting k04s, timing belt, seals, clutch....anything else i get while its out?
- Any secret to removing headlight leveling motor from driver side lower CA?
- Those that have painted the shifter surround trim to match the sport interior What was the closest
- Need some input on Stage 3 avant prices for insurance purposes.
- Just wanted to confirm that crank rotation is CW when looking from the front, is this correct?
- Looking for a set of 18x8.5 track wheels... anyone selling?
- one of my buddies is looking for a b5s4. it would need to have a manual,
- My mod philosophy after about a year of owning the car (useful for new buyers)
- New B8A4 Avant Video
- Thinking about a set of K04's. More inside...
- Opinions.. Toyo Proxy T1R??
- Mirror? Anyone resolve the difference between OEM:4B0-857-511-C-01C and 4B0-857-511-D-01C
- Does anyone have a pic of the bottom part of their S4 rectangular brake fluid reservoir handy?
- WMS Widemouth dp's or fast intention's split dp ?
- cxracing "Ebay" aluminum rad = 2 thumbs up
- Has anyone ever bought this Audi banner from Amazon? It's only $9.99?
- General Suspension question: What happens with our upper control arms when...
- Wheel poll, Please post opinions. EDITED second pic works now
- Nothing to prove...
- S10 > S4 :(
- Got a new sig.. Im not good with p shop or watever
- Making sure i got right one. the Coolant Temp sensor is the one under the accordian pas. side?
- Tip downpipe install
- Feeler: ABS Pump & Module
- Full Interior Silver S4 vs C6 Z06! (Video)
- S4 without the armrest....
- part number for rubber gromment aroung dipstick.....
- Cigarette lighter just stopped working (Its not the fuse) at least the one in the panel.
- my windsheild wipers just froze in a vertical position! :(
- alright, let's play a fun guessing game... i'll show the codes, you predict how much money i spend
- Sunroof drains, water filled up in rear compartments, and mildew... Avant specific.
- OK so maybe my alternator is not dead after all.
- most stolen:
- Spark Plug BT: Pulstar vs. NGK
- Which tires to go with? and which runs narrower? bridgestone pole positions or goodyear dsg3's
- does any 1 know what the two rear silencers are on the FI cat back??? or are they just FI custom?
- Vast intake for sale, with the Carbon Fiber shroud never used.
- Looks like worldimpex has best deal on coolant sensor/clip/washer. Any reason not to use them?
- Anyone need a Vibrant Catback with a 2.5" Y-pipe
- Eibach pro kit vs HR coil springs.......which.............more...
- Stage 3 to be completed next week, clutch question...
- The Achtuning onesie-twosie wheel clearance sale!
- Buying my first audi S4
- A message I got from my ebay ad selling my T-Box ECU???
- Can someone here give me some specs on the K03 and K04 turbos?
- ACNA Roebling Road HPDE this past weekend...
- Price for Tip Tranny remove and replace? Manual says 11 hours...?
- Can someone run a carfax for me? Vin - WAUED64B0YN085927
- Swapped from all black seats to black with silver alcantara.
- RS4 rear doors on ebay....not mine
- Need some new rotors sometime. Anyone used these that can comment on them?
- Does anybody know the specific number of misfires that will trigger a DTC or CEL? Have STFA'd
- Those who have removed the rubber moulding on bottom of doors: Can u post some pics?
- So my car has been making some weird noises and need some help!!! (inside)
- ECS Tuning CF Engine Covers
- Does anyone have a MAP sensor they are not using? Parting a car? Shoot me an email.
- What is this called and where can I find it?
- Plastic or metal impeller in the water pump, What is better?
- Anyone know the part #'s for the clips you need to hold on the sport trim?
- I think I might be the first B5 S4 to do it...E85!
- Tips for working on HVAC flapper motor.
- Anyone running VMR wheels?
- What do you guys think cause my o2 sensors to go out so frequently? form earlier post...
- Creative thinkers: How do I get the last bit of fluid out of my broken rear view mirror?
- What kind of damage would you see if you used a mobil synthetic blend oil?
- Need to tighten Oetiker clamp for new inner tie rod boot. Can you post a pic of a tool that will
- Need a answer, GIAC 93 reflash, can i have rear o2 sensor delete option added? (more inside)
- supersprint cat back exhaust any one running them on there S....
- If I were to get a wideband setup, would it be pointless for me to get ECUx as well?
- Who here is already stage 3 and considering an RS6 or GT setup?
- I am replacing my brake pads after 40K, do I need to replace the rotors?
- Any special tools required to replace the alternator?
- changed all my spark plugs and resolved the accelerationst issue, How long R ur NGK BKR7E's lasting?
- Longest run on orig. O2 sensors?....I am at 129,000 miles
- Anybody have any fast times to post for a B5 S4 at Buttonwillow configuration # 13?
- Anybody got a single 17" Avus / Ronal Rim in good cond. for sale?
- Have you guys seen these tial development photos ? interesting!
- ECUx, Ross-Tech, Flashloader, Vista, questions inside....
- dealer told me my rear differential seal needs to be changed
- writing this on the highway, little help
- photoshop gurus... need some help/ opinions.
- father's coolant temp sensor needs to be replaced on his 2.7T allroad
- buy my stoptech 332 and buy my car- gogogogo
- Installed adjustable FPR @ 5 bar and went for a log...
- Summer Tires?: Bridgestone Potenza RE960AS Pole Position
- I need a shop to CNC a 20 mm wheel adapter/spacer to bolt to an audi hub and
- I was walking by the Porsche dealer. Why do some carreras and caymans come without amber reflectors
- A big thumbs up to Brian @ Avalon Motorsports. He has done an incredible job turning Avalon around.
- Long insurance story/questions for those bored... theft/recovered/bodywork done/what's next?
- Clicking/Thumping Noise
- Dear ASP, PLEASE come to Texas!
- Anyone have stock of ER's on the east coast? near Pa?
- poll: calipers to be powdercoated. what color? choose 1 of 2
- Bad MAP sensor? Req/actual boost and AVCR questions
- awesome rollercoaster..
- Vishnu tuned EVO X
- are there any cheaper options for primary 02 sensor's? Like maybe a cheaper VW part number?
- New S4 Compilation Video
- New Vast Stg 3 logs
- I've got a weird brake noise problem... Any help?
- horn, cruise and paddle shifters are dead
- LAST CHANCE to sign up for EPL Custom Tuning in Colorado
- Paging snowtrooper: its seems that you have the most knowledge with nitrous on
- Anyone know where to obtain Vogtland GTs? Startup is backordered.
- Tial gt dyno numbers,...
- How is the mpg the B5 S4...?
- Need MAF logs PLEASE?!
- Anyone in need of OEM RS4 foglights and l/r bumper grilles
- Any AWE stg3 cars in the DC area? I am flying out on Friday for Curry's Clash in Dulles
- Help ASAP! I'm in Miami right now, and apparently my F'N alarm will not stop going off at home
- Hows the quality of fiber images cf hood and fenders? Anyone have any pics other then the website?
- OG's--- whose engine is this and why? From 2004.. just for looks?
- is there any slight gains to be netted from a slightly larger Y pipe?
- repost? old audi drag race
- Frustrating - CEL light
- Those who upgraded to Ecodes.. wanna sell the stock housings to me?.. TIA
- Statmosphere V-Maxx coilovers, any chance they're half decent for $699?
- Aftermarket Cats
- Anyone selling their S4 soon? clean, lower miles and 6spd? Around 14k. Thanks
- the little o-rings on my throttle body ripped while reinstalling my APR bipipe. Are there any last
- My S4 now has a sidekick - an 08 Hyundai Elantra named Bonzai. Signed the papers today, picking it
- Last day for free shipping on Hartmann wheels from Achtuning!
- surging with cruise control activated.
- where can I find a lower R oem bumper grill??...any1 parting out a s4?
- :) :) :) My quest to the STGIII world has begun... Pics
