- steering problem
- Radio Problem
- What's the secret to popping the top grill out to replace w/RS4 grill? (Yes, I searched.)
- Saw two S4s (B5 and B6) up in Lake Tahoe this weekend while skiing. Guess which one...
- I have a Forge Tru-dual exhaust system and wanted to delete the mid-muffler. Would it be bad to use
- Since someone mentioned interiors, anyone prefer silver leather? I'd love to swap to a black...
- Just picked up a set of AWE intercoolers. Install them now, or wait till I go stg3? (i.e., is....
- Getting some Hakka 4's and need advice on the size.
- Is the new GIAC code out for tip owners?
- Matt Bugna, contact me please. Thx!
- Hit or Skip... Full set of Black with silver alcantara interior for
- Anyone know of a B6 A4 with removed badging, about 30% tints, and cheap aftermarket exhaust in......
- will replacing a front bumper trip the CEL? more inside...
- Is there any difference in a euro front S4 bumper? Or are the the same as US spec?
- Poll: those of you running testpipes, are you running rear O2s or not?
- Going to the Detroit auto show in about an hour any picture request?
- Track Junkies: Do they make a double trailer (2 car) to pull behind a large truck (full size diesel)
- Need answer on priming oil pump after UPPER oil pan change
- Reminder: EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help) -- Updated 1-15-06
- Anyone heading out to the Rolex 24 later this month?
- the original fast and the furious eclipse running an 18 sec. 1/4
- Here is a little taste of the exhaust development on the CGT.
- What's the best lube to use on coilover threads to protect them? Anti-sieze, lithium, silicone ?????
- Todd/AWE...your emailbox is full!
- STFA,got 2 different sizes for oil cooler sandwich plate,anyone??
- Can 440cc/min injectors @ 4 bar (~510cc/min) support 600+ chp?
- how long does it take the mechanically inclined to install an apr bipipe?
- Has anyone heard from Alex @ Europrice about the shipment of parts that were supposed to arrive?
- Video : 600 "Old-Skool" Horses, on ThunderHill
- does anyone know if a flashed ecu can be swapped with another ecu for a different car?
- It seems my ECS Stage III braking problem is fixed!!! (see link for original post)....
- what does it mean if the BRAKE light (that lights up with e-brake) is flashing?
- We will be getting ethanol mixed into our gas soon. Mixture will be 10% ethanol. Is this bad?
- Phones are down this a.m. , please email if you need something
- Hartmann wheel owners. Need help with the correct size of lug bolts. . .
- Boxter Seat in an S4
- More info about my friend Bob's Black B5 S4 stolen in Newark on Sunday night...
- 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XX Tuning - E. Hartford, CT
- Cruise control question?
- Got my GB twurbhos this morning - thats a good start to any day!!
- Hey 4Bidden. Did the ABS/steering re-code work?
- MODERATORS : Why was my post deleted asking about exhaust piping?
- getting a check engine....WHY!?!?
- Free Carfax alternative.... thought it may be of some use to you guys...
- Cowl Panel screws, possible to get seperate or do I need to buy new cowl piece?
- love the drive, sick of the cold
- potential b5 s4 owner... what do i need to know?
- Anyone have a stock (silver) RS4 grill surround they want to get rid of on the cheap?
- Walbro Fuel Pump installation instructions...
- Xpost redux: Post in flight pictures from AWOT. "Flying to FL to pickup an RS4 Comp chassis . . .
- Other than the stuff in this picture, what do I need to install K04's?
- Where can I get the rubber O-ring for the RS4 Airbox (upper)
- How much do the cargo nets go for? I saw this one on ebay. Whats a normal price?
- Specific tie rod end question for those with experience...........
- Finally had the Vogtland C/O's installed on Saturday.......
- Do you ever go drive your S alone - not to see, get or log anything....
- Anyone in the Denver/Ft Collins area have a stock B5 S4 exhaust
- Finally recieved new bulbs but fog lights still don't work...
- suggestions for removing the 8mm allen bolt on the drivers side turbo?
- maybe im just slow, but does this mirror housing look "new in box" to any of you?
- Thinking about getting a radiant propane heater for the garage.
- paging str8blst.
- Help: I just started having a noise coming from the back of the car. It sounds almost like an motor.
- Reinz gasket kits
- what is stock front-rear quattro distribution? B5 S4
- Paging golfrsi: Trunk handle, waited over 2 weeks since you said it was sent.....
- X-post - any silver S4's from Reno?
- looking for a source of b6 a4 airbag for my rs4 wheel...anyone ? thx
- 3 cheap mods for today :-) (iPod mount, caliper paint, ashtray mod)
- heeeeere piggie piggie piggie
- Anyone running 245/35ZR19? If so...
- ITS ALLLIVEEEE!!
- Does anyone have any experience with Autowerkstat in San Jose?
- anyone near central jersey have an extra m-box ecu i can borrow for a few days?
- OT - Who makes good exhausts for a Porsche Boxter S???
- OMG this is too good
- Those of you running the Bosch Platin plugs, how often do you replace? Do you replace them per OEM
- I forged wheels BT: I would like to get a set of 18 inch i forged wheels. What widths should i run?
- Finally got some pix of my Casa Avant!
- anybody have experience with koni sport shocks?
- Help! Need a shop that has the rs4 grill in stock.
- Anyone have problems with Lemmi saying "Hey NAK,NAK,NAK" when you try and read?
- question about coolant...
- Trans output shaft gasket?
- reminder !!! Feb 1st -28th 2006 GB turbo install , only 3 spots open ; p
- RS2 chasing RS4
- do directional tires have inside and outside?
- Walbro 255lph high pressure fuel pump install.
- Bilstein PSS-9s Installed, First Impressions
- APR saga continues....with a happy ending :)
- Rim sizes?
- Engine is back in.... but found a bad engine mount (Episode 6)
- Anything *wrong* with using Meyle S4 Engine Mounts? instead of Febi? I know HT RS4 are bad...
- Hal_S4Shizzle::CBP I just took two boost gauge videos
- Will the 5 spoke 18" B7 S4 wheels fit on a B5 S4 w/ a BBK?
- do i need to replace my rear main seal?
- I have Forge Tru-dual catback exhaust and I wanted to delete the mid muffler. If I were to have
- ACNA Thunder Hill Event...
- Car in dealership for alignment. Called for update - they said the tie rods were frozen and would
- S4=0 90Q=1 ;p
- And the search for a logo continues.... (Updated - added 7-9)
- Anyone with a open Carfax account?
- How much is a stock 2001.5 Santorin S4 silver interior with 25K miles on it worth?
- PSA: Black S4 with EMT plates stolen in Newark last night...
- EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help) -- Updated 1-27-06
- Can I torque the Front Sub-frame bolts with all 4 wheels on the ground.
- OK...how many widebody S4's are there in the US? Am I missing any that may be tucked away in NJ or..
- Anybody have the Vast shortshifter? Is it basically the same as the toy guy?
- Headlight Install Issue....
- Thoughts on overboost situation - N75/WG circuit likely cause?
- DTC help..18034: Data-Bus Powertrain: missing message from transmission control..stfa and found....
- It's amazing how pathetic people are...
- Front O2 sensor replacement done...one minor problem remains:
- Why aren't cross-drilled rotors a wise choice to replace stock rotors with again?
- Photos's from 1/14 CT/NY Audi Group Gathering at EPL in Stratford, CT (BWW)
- On 7/20/05 I changed oil with 35,800. Now I am at 38002. Should I change it due to time?
- Brake Problem - One wheel lockup/freeze/stopped in it's tracks.....
- PAGING VWAUDIDRIVER...this is getting rediculous
- Anyone here live near Winter Park CO? I spent the past week there and..
- Intake pressure test question: is the pressure supposed drop quickly?
- Clutch question....
- Anyone have a guess as to what's wrong with my car?
- What is a lightly used old style UUC shifter worth?
- Just back from Thunderhill. Had a great time on and off the track.
- took out amber corners..cant really tell with the lights on but ill post any ways
- Future Chips...?
- for my next b5...casa, nogaro, or black again? thinking ahead :)
- Center vent boost gauge
- anyone got any pics of a brilliant black on Neuspeed Rs10s...not finding much in archives
- Wow was just looking over some of my old reciepts for the Audi.
- A confession...
- Thoughts on Revo code inside.
- Just installed Neuspeed RS10 19 x 8.5 ... i have rubbing issues! HELP!
- Can you make a tiptronic ECU work in a 6-speed?
- Extended warranty for '00 Tip S4
- In need of some advice.....
- If i have piggie pipes, is my B2 S1 0xygen sensor the drivers side behind the main cat?
- been gone for a couple days. was in mill valley (oakland-ish). big audi town actually.
- Any S4 guys out in tampa Clearwater arear tonight? My brother is out there and has nothing to do, as
- Who was the silver S4 with Kahn RSSes pulled over in Miami last night? Hope you didn't
- probably a dumb question, but for anyone who has done a BBK upgrade
- Yea so I saw this S4 and needed a new pair of pants...
- Anyone use the ECS coilover kit with Bilsteins?
- I am mad. Wanted to move the audi out of the garage and the Corrado in to work on tomorrow
- Did a boost log, comments...
- First ride in a true stage 2!
- sound of turbos on 2.5. buddy's might be going. need some advise
- Has anyone ever attempted to mount their Ice Link+ in the glove box?
- Problems trying to re-code ABS module/steering angle sensor...
- Anyone have the autospeed manifolds? How do they compare to AWE besides being cheaper?
- Anyone put in a RS4 alcantera steering wheel?
- WOW wat a game
- Is there any way this joker is spiking at 22psi @ 7000 lol also look at his #'s... discuss
- Will the dealership be open tomm. on Martin Luther King holiday?
- Test-fitting new shoes! (BBS LM's)
- I want to install Bluetooth in my 01...What has everyone found to be the best??
- Where is the best place to get the Audi GPS console???
- Would there be any use for stock S4 ICs? .. I don't plan on ever using them and they just take up...
- Now that my rear speakers a blown....has anyone used freeair subs??
- I ordered Oil Level Snsor and it's here today, but it didnt says its for s4 but says a4 a6 a8 tt ...
- Anyone know what this LED Red Light Is???
- What was I thinking when I bought this car? I should have just pounded a nail through my d1ck.
- Should I do a pre-emptive rebuild of my K03s?
- hey bigblue,which lw battery r u usng,is it hard to start in cold weather?...
- seem to have lost power steering on our b5 a4 ...
- S4 Front bumper
- Why, oh why, won't my K03's just die?!?!?!
- Yes I am the greatest man alive!!!!
- my stg 3 was no match (i got my @$$ handed to me)
- i just received a rear driver's side 02 sensor from ECS...
- NiceS4, I tried to respond to your email but your server sent my message back...
- Clutch going?
- anti-theft device...
- Whats the difference between D2S type and D1S type ecodes?
- Need some help with the value of my 2001 S4, might go for sale. thanks
- chip for a tip, any recommendations?
- silver S4 sedan driving down from Tahoe last Sunday 1/8, i was nogaro avant
- bilstein sport shock
- strange problem. Rear seat will not latch on Avant. The button is sticking way up and will not go..
- more EPL pics
- Stripped my drivers side rear axle bolt while doing wheel bearings today
- Engine misfire while slowing to a stop.
- I need some help removing the AC compressor please
- this or that?
- [badmoonrising] nice Casa S4 Avant in EuroCar magazine.
- My GF asked why the RS4 wasnt sold in the U.S. I really cant answer that and im ashamed. Anyone?
- Where's mpwolf been?
- You can laugh at me but I would like it if you could also help......................................
- Revo should not be allowed to distribute liquid crack!
- Imola Avant-Washington plates (sticker for front plate) and Startup Racing stickers lurk here?
- Can I get an amen?
- Thanks again EPL for the great GTG...
- Need to find out if my car is chipped
- Is anyone running a stock clutch on stage 3? Bad idea? Need to upgrade?
- Either race bigblue n shut him up or get off his TIP,and its a street car...
- Why does the stereo suck in my avant?
- Location of Bose Amplifier
- Free Shipping on Hartmann Winter Packages with Dunlop M3 Tires
- RS4 carbon interior trim on ebay.de and used RS4 IC's
- Just bought new S, quick question
- LOL at BigBlueTrackCar158942800345178492
- 04 Audi Ultra Sport Rims from an A4 would they fit an 01 s4???
- Black S4 driving I-70 in Colorado eastbound with California plates...read this!
- Anything else I should replace while getting my K03 swapped?
- Xpost: Need Toyo RA1's. Recommend where to get best price/service?
- RKA, etc: Got a knob and boot. Thanks for the offers anyway.
- did the STFA thing......looking for homebrew stage3 parts list/recommendations....TIA
- Anyone know anything about this iPod interface!?
- When making the F-hose from edyjuns directory does anyone have the measurment of the actual hoses
- Need some help...
- anyone here have a really good rim guy?
- didnt kno volvos were pretty quick
- Can one of the VAG-COM log experts take a look at this .....
- If this were your interior, whats the first thing you'd do to dress it up
- well i just blew my turbo's!! i guess ill be stage 3 sooner than i expected!
- What's wrong with my car? .. Installed APR ECU .. worked for a day, then got these codes..
- Does the ECU use the oil temp sensor that controls the temp gauge to do fueling/timing adjustments?
- Boost leak pressure test carried out today - strange noise heard ....
- PAGING VWAUDIDRIVER!
- ive searched the board and found good review of the abt/ams chip but how is it now with apr 5.0 and
- wife got me my bday present early....window tinting.
- Is it bad to drive the car with a bad turbo?
- Car is running cool, just above the second line.
- Vogtland C/O's going on this morning. Do I need to cut the bump-stops on these????
- Paging MarkP....Please pickup the white courtesy phone. I have some logs for joo! :)
- Paging golfrsi=ryan.....email me back about the status of my caliper decals, thanks
- How much more can my turbos take? BWW Boost Gauge Pics
- Anyone know of differences between the old files of GIAC and the new?
- New set of wheels..thoughts and comments
- lurem u should hook up with the 150 mph ride ur ass guy for 10 mins..
- Did anybody ever used G-TEC timer for 0-60 and 1/4 mile?
- Got pair of clear tail lights for sale by Achtung.
- Cluster LCD burning out, need new one, any1 know of alernative to dealership parts department?
- How much does crashing my car detract from resale value <LOL>
- ABS Control Module with ESP
- Okay, the dirt on Microsoft's lengths in making Project Gotham Racing 3 from the Streetwerke pov . .
- Re: My S4 vs M3 race post from 1-12-06
- WTB 2001+ S4 Sedan Tip, Silver Alcantara, email me.
- had a minor bumper-bender
- metal to metal sound.....
- If first you don't succeed ... use a bigger hammer. (Differential removal and LSD install.)
- Ecu signal help needed
- Will my phatbox work with the RNS-E install?
- What blocks to log for eratic boost?
- Will a GIAC chip and ecryption board work in a socketed ecu that previosly had an MTM chip?
- Anyone change their (evap) charcoal canister?? And know how much a new oen costs???
- Anyone got any good pics of a B5 Nogaro RS4?
- Hans Stuck getting it on in the rain circa IMSA Audi
- Edy Jun & forum - Thoughts?
- Xpost, battery question...
