- Will b7 RS4 et37 wheels fit on the S4?
- Motor Mount replacement help...
- Is anyone actually using the CF Y-yipe?
- About to add this to my tank...
- Do any of you guys have a dead MAF I could get off you? I need the housing...
- how does this happen...? is my s4 trashed?
- Dang Clutch Slave Cylinder
- Whats the curb weight of a stock S4?
- CEL Stage 3, Bank 1 & 2 fuel trim to lean...
- Does AW have a referral number for tire rack? j/w
- Finally turned on full power - K04/997's are nice :)
- does anybody here use safety wire????
- cant get driver's turbo inlet back in after motor mount install. any ideas?
- anyone usesd import performance parts rebuild kit?
- Does the B6/7 A4 use the same oil filter as the B5S4? Can it?
- CEL code- Tank ventilation valve open circuit.. what is it? searched but didn't find anything
- Is an OEM RS4 bumper tough to find now?
- What is the most labor-intensive job on a B5 S4... but shouldn't be? Highest labor:part cost ratio.
- what do audi engineers have to do in hell?
- Pressure tester near indianapolis?
- I'm hoping you guys can help. I'm sure you could do this operation in your sleep...
- A3 vs S4 Avant 01-02, 04-05?
- Fan switch questions
- does ecux have to be registered to work?
- "Smart Key" Class Action objection - Care to object? Read inside -->>
- NORTHEAST AUDI End-of Summer JAM !!!
- so i think my egt sensors are going bad, how to tell?
- Best looking wheels on a Nogaro sedan? Currently on Oettinger RZ's
- What are the chances that a 350z with a bolt on turbo kit and a reflash ran a 12.1??
- Well..an estimated $6.5-$7K in damage from the flooding...=/ Totalled?
- Whats a fair price to pay for a used RS4 Bumper? (Stock plus cash?)
- I picked up my car 8 years ago today...
- Dropped off the car this morning at WMS for some stage 3- surgery...
- Road America last week
- woodward
- Just installed new DV's and was wondering if i should avoid ....
- Are forged rods necessary for K04/16 turbos and a tune specifically for them?
- Anyone have pics of wire harness's in the engine bay? I STFA already...
- Did the rob knob ever come with an S emblem or do people just order the 6-speed knob?
- IS this the right Harbor Freight Caliper Tool set to twist and push back our rear calipers? TIA.
- Select wheels on clearance at Achtuning.com (as low as $449-set!)
- Anybody know what the blue & black wires are running to in the Steering wheel?
- What are our options for an alluminium WIEGHTED shift knob? I have a OEM RS4 but i want a wieghted
- anybody got a front bumper lying around in your house??? I need to replace my broken front bumper..
- My Tip Tranny is wierd....
- paging Skydive; How's the new tranny from Sam?
- Anybody need upper leading ca's?
- I know they said this was coming but has anyone seen this?
- whats more popular: Regular height JHM SS or 1 inch Reduced height JHM SS?
- Removing armrest from center console, both are out of car - any tips?
- VAST Stage 3 Dyno Results!! Xpost to my AZ Thread
- SchagenWagen no more
- Centergauge lcd
- Anybody know the dimensions (depth) of the ballast socket on the bottom of the Valeo headlights?
- Had my rear caliper off and accidentally hit the brake pedal a little...can this cause damage
- Anyone using ASP's Comp Series Transmission mounts on a DD?
- Can anyone recommend a basic code scanner tool that can read codes/clear CELs etc? This is NOT for
- ****TRACK DAY BOOKED**** - Roebling Road - 09/15/08 - $225!!
- **WTB - Low Mileage Avant S4 01-02 Stage 3 6spd CASH BUYER Located in San Diego, Willing to Travel!
- reply for sindoe: front license plate diy w/o drilling
- What is this car worth?
- Seems like an S4 exodus lately. I'm selling, who else is selling and what are you getting?
- o2 sensor woes, what blocks to log???
- wastegate settings screwed up...
- Parting out-advice, Makeshift wheels / steering wheel?
- So uhh...Was my shifter surround plastidipped or has anyone else rubbed it to a new finish.
- Just curious- What fog light bulb are you guys using? I definately want a brighter white....
- Help with why I have Limited Boost
- Dusting the S off after 15 mo. in Iraq. Mechanic says I need control arm bushings, how much $?
- What's the name of part that basically reroutes/bypasses coolant when there's a leak?
- Just a thought...Anyone selling a clean well maintaned Stage 3 S4?
- ~DonQPremiumTequila~: YGM
- Anybody notice something different in this picture?
- F/S Focal K2P with custom kick panels
- Anybody use Mings Audi Repair in Allston, MA? Can't make the trip to Vast this time :(
- Stupid question? (ETKA)
- Who would win? stock STI vs stage II Tip S4
- Water temp is slightly over the half way mark when idling or slow traffic
- Scotty - Give me more power!!!
- TONY @ EPL... SEE YOU TOMORROW @ 9!!
- would you take an evo 8/9 over an s4?
- Anyone ever changed the Rubber GM looking mount that comes with the ASP TSB?? Poly??
- Cargo net partition
- Is there a P/N for the S4 badge / logo on Steering Wheel? -MY 01.5
- looking for new tires...currently running michelin pilot sport a/s.
- Whats this i hear about a "tuner" Working on a launch controll for out factory ECU's??
- Should I bother putting my test pipes on?
- how do you get the driver's side motor mount out? the a/c hard lines are in the way :(
- The Clutch Argument
- Could someone post a pic of the water (devilsown W/M)pump and the orientation of the power wires
- Anyone know if you can get the precut adhesive for the rear "rings" emblem? Part Number? Tanx!
- Anyone on the wait list for the ACNA Watkins Glenn - Aug event?
- Need Help! Post pics of front license plate solutions!
- :: ECS Tuning :: B5 S4 FK Highsport Coilover Kits - Now Available !!!
- what are the gains like when you're stg3 and then you add 2.8 heads, manifolds, dps, and retune?
- When doing an oil change, how many of you crank the motor without starting it to prime?
- Looking for a front wheel speed sensor
- Germany is beating me!!! Broke the slave as I was putting in the engine...
- stock stall speed for TC?
- Laser Jammer Blinder m45 with Cheetah wireless kit.
- ETKA help: can anyone tell me what 4B0 867 416 B is? TIA.
- When they tint windows, do they remove the interior door trim panels?
- Well, my quickly wearing rear brake issue was a seized up piston due to a torn boot...can
- if I ever meet the jackass who thought up the foglight housing for our cars...
- Purems.com Summer Coupon Codes!
- Best ECUx connection settings? Serial HEX+CAN cable, WinXP. Post your baud rate/connection method...
- S4DC is back baby!
- west coast customs responsible for this one???
- Nogaro about to get on the 10E from San Gabriel late last night (this morning)...
- Attended Audi R8 Driving Experience in Barcelona - great event! Details and pics to follow!!!
- does anyone know how to gut my precats and make piggies???
- EPL is very please to welcome Autosport Werks as our Colorado dealer!
- ER's and HFS-1 = Awesomeness. Red off, Blue on. 80* Ambient Temp. That's all.
- Autospeed, NJ - Rolling Road / Dyno day.... 8/23... X-Post Update
- Ruled out snub mount. What would cause in-cabin vibrations when revving engine? Bad flex pipes?
- Anyone know of quality aftermarket seat sliders that i can use with my Status Seats?
- Bored.... thought I'd post a pic of my motor back in the car...
- Anyone with a 2000 TIP live anywhere between florida and california? I need to test a different TCU
- new shoes for my girl
- Looking to get a tune, need suggestions....
- OK. Someone circle the N75 in this pic! Rookie question but wanna check wastegate line(s)
- Audio upgrades - suggestions
- Why is it that everytime I get some spare cash...
- Squeak when letting off the throttle under boost
- Rear License Plate Repair (long)
- Fwiw I fixed my problems. It was just spark plugs!! the funny thing
- Brake issue need help...more inside
- Problem with seat electrics... Manual adjustment?
- QUESTIONS B5/S4 UPGRADES
- In case anyone was looking for a GIAC X flashed M-box...
- Overboosting on AWE RSK04 kit (logs inside)
- Paging simpply: Im crawling in the S all the way to LA, i called the shop today, I'll be there in
- NE1 got the link to the company selling aftermkt RS4 y-pipe hoses? TIA
- ok, last deal fell through, anyone want to trade thier stock S4 gauge faces for a set of O.CT ones
- ok, just popped in 2 new 710n's, and a new pcv. i now have an abs light with the stability control
- Who here is from the Allentown PA area?
- anyone know a good source for replacement interior panels?
- We had a crazy storm here and w/ my luck...the S4 got flooded. Water halfway upto wheels and in =(
- 034 K04 inlet pipes, whats the info on these?
- Anyone parting out a silver B5 S4?
- MTM SC'd R8
- Canadian Lower Grills(ones with no fogs), where to buy? Part number?
- phone jack in arm rest?
- Car troubles, help needed. Logs and codes inside.
- Having trouble getting the bolt out on the rear axle to replace my wheel bearing
- What would be the risks in buying used k04 turbos with 20k miles?
- N75 duty cycle log...
- Buying b5 s4 today
- No power to cig lighter plug..
- Anybody know if changing steering wheel will require the same code clearing that clockspring does?
- Sweet Nogaro B5 parked next to my B6 at work today for a minute near Doylestown, PA...
- are the floor mats the same in the a4 as S4? just making sure.
- is SR the only vendor to sell Vogtland GT's?
- HPF video of the BADDDESSSTTT!! TURBO M3's ever!!!
- Has anyone hardwired their Garmin Nuvi or have a writeup for it?
- a8 rear brake upgrade, what size washer? i know 2mm but what size bolt?
- Anyone know the P/N for the plastic ring that clips the shift boot into place?
- Anyone have pics of ECS stage 1 rear brake kit installed?
- I let my car sit over night after a no start situation... Then this morning when "cold" it started
- Need help diagnosing a no start issue ( fuel pump fuse.) more...
- Someone please school me on O2's.
- Anyone have a used S4 cluster?
- Normal for the power steering to 'whine' when parallel parking?
- EMERGENCY help needed! Major TC problem
- Anyone Here Silver B5 S4 On 101 This AM?
- anyone know of a way to integrate the prewired optional phone...
- So with all the crappy L10 stories as of late I have to assume all of them have been crappy. So...
- Best suspension
- Anyone have an OEM S4 bra?
- Some logs.........
- Leaking power steering fluid..
- "No Start" - Success, it WAS the Fuel Pump - Even though it was
- A/C not blowing cold, just went stage 3 last spring... Anything to look for?
- paging Eric Fletcher.. re. Penske Setup.
- Desperate for ECS Cayenne Caliper details!?
- paging WMS. What's new at the shop?
- wierd no start problem: randomly my car will not start although I can smell it getting fuel and it'
- so excited i can't even stand it!
- What would be the reason for having higher knock in cyl 2 only?
- PSA: ALMS on speed Tv right now
- About to start the upper control arm removal. Need some advice...
- Came across this gem on Ebay...thought everyone could use a laugh
- Am I boostin enuf?
- When people say their car has a certain amount of horsepower...
- mtm 306hp chip questions
- front end shakes over bumps.
- Paging ZKNY: What was the outcome of the clutchnet setup you went with? Could
- Is there a write up, or could anyone point me through taking out the instrument cluster?
- help! name this part leftover after stage 3 install
- Update on my clunking/grinding front drivetrain. Problem solved.
- Recommendations on brackets to use for aftermarket seats??
- Rear lower control arm
- stripped stud on under carriage for heat shield separating drive shaft and exhaust
- Where can you get the "European Gauges" where its all silver?
- used ko4's in the classifieds
- Those with devils own or vasts meth kit...Where do you set "it" to come on?? I have it on 6 psi and
- Engine pull: Confused on how to remove drive shaft. decouple down pipes from exhuast first?
- Driving cross country. Is it worth getting a car bra?
- is this code a boost leak or could it be n75 related
- Raced a Z28 last night..
- Where can a set of new banjo bolts for the turbos be purchased?
- Anyone know where I can purchase just the crush washers and oil line seals that are needed
- car going on for cover gaskets..what else should i have done??
- Few clutch questions...I am most likely going to be giving clutchnet clutches a try, and
- How do I adjust my stasis coilovers? They are so bouncy!
- Need some urgent help..start up my car this morning..and the speedo rpm tach are not working..ideas?
- can anyone tell me...
- has anyone bought an aftermarket warranty for their car? Company, what they covered, price?
- Oettinger now has all wheels on the shelf ready to take your Audi to the next level.
- Who is running Clutchmasters Stg 3/4 Hybrid, thoughts, impressions..???
- leaving for my cross country trip tonight/tomorrow (4am)
- Need some insight on the VAST meth Kit
- ***Hartford, CT GTG, Tuesday, September 9th***
- Who is selling their stage 3/3+ S4 right now?
- what are the symptoms of a dying ABS unit?
- since i got hustled into buying the wrong DPs im hoping someone here wants to sell me theirs..
- Where to get aftermarket parts from? (Exterior parts)
- how much are a set of 6 speed downpipes worth with good flex joints?
- Anyone have experience with using Bilsteins with stock springs?
- Ok.. so lets hope this Q is as easy as the last......
- Help! I just changed spark plugs (BKR6E) and now the car wont start! WTF?!?
- Thinking about going with a clutchnet 4 puck ceramic disc...
- finished my FMIC install, but i'm not too happy with the pipes...any one have spare pipes
- okay lets see who wants to buy muh car :-)
- Boost gauge tap location (X post from C5 forum)
- So how many people baked the headlights vs drill method???
- any1 need tranny seals? (6sp) I have all four of them... FREE
- Need some answers about a clutch for stage 3...
- Anyone want an APR chipped ECU?
- Another victim to the damn Central Locking Module junk...
- Paging: Visintainer. YGM
- Using a W8 Throttle body on a modified intake mani... Discuss
- Using Test Pipes
- Anyone want to get rid of a set of stock exhaust manifolds?
- Anybody have an extra cam chain adjuster?
- Not 100% sure but cant u run 91 octane on GIAC flash?
- Quick poll Stock air box with hole in bottom with s-flo intake or k&n filter?
- Dyno proven horsepower for your B5 S4.
- those of you sporting roofracks, which one do you use?
- Man i just went out 5 minutes ago to show a friend what the s4 is capeable of and after two passes
- two auctions peeps might be interested in
- Is there an upgrade for the front subframe busings? Eurothane possibly? Mine are done.
- Clutch Suggestions
- PWOTD lol not really but another question. Who here has expierences with half cage roll bars?? Well
- Transmission BT: What about a longer first and second gear? This winter i want to build a tranny for
- well....almost exactly a year after my car was stolen....
- Biturbo shirts are now available at liquidcrack.de
- Sorry for all of the brake questions- which fluid should I use?
- what do you get when you have a little UPS and add a little FedEx....
- Li'l help please... this is a dying alternator, right? I charged the battery then let...
