- Diverter Valves, reverse orientation?
- any las vegas guys here? (the sw board is always so dead)...
- Just a small tease...
- Need suggestion on how to get the slave clutch in to the tranny...
- Will a higher octane gas increase or decrease my hydrocarbon output?
- How does one check a 710n to make sure it's working correctly?
- *paging skolnick* please check your email
- Need to borrow a stock ECU.
- SupraS4's GT28 Car on the Auction
- Audi got back to me with production numbers for Hibiscus Red S4's
- uuc vm3 no resonator vid #2
- WOOT? Dealer wanted $66.95 per side for VC Gaskets! $24.95 ea at ECS. Thats nuts...
- RNS-E... what part# shall it start with? 4B0 or 8D0? I've seen both?!
- WTB Cam lock tool...some "Z" place I think but can't rememeber. TIA.
- Code Reader Help
- Spy Vid @ the Ring: New (white) RS6 sedan. I've also posted a black Avant some time ago.
- **Anyone want to go to the Lime Rock NEQ Event this Friday/Saturday?? I can't go so there is a slot
- Current best straight K04 w/ hardware pricing? So far, i'm leaning toward ECS.
- anyone here have some suggestions on a tranny drop? was talking to a tech yesterday at
- 2 used h&r struts..one i can push the rod in, and the other it barely moves..what gives?
- Is there an adapter bar necessary to use an engine lift with the S motor? (Prepping for turbo swap)
- Best Alignment Specs...for wear?
- few questions...first, what socket do i need for the six bolts on the front axles. second, what
- Poll: 00 Tip w/ 87k miles... Dead snails. Go w/ K04's or other, and why?
- Forza 2 heads...
- Are O2 sensors easy to get to? Looking for info on their location, any diagrams?
- I need some advice on the market for B5 S4s out there...
- for all the forza2 players...
- Ram....YGM from timc310 at hotmail......thanx
- Out of ideas-car has been predominantly misfiring on cyl 2, now with new coilpack and plug no change
- How can i verify my turbo's are blown? (before dropping $$$ for K04's and pulling the engine)
- Any1 know where I might be able to score a single H&r strut from a coilover kit?
- S Flo
- turbonut? check your email when you have a moment...
- Can you install a dif filter on the end of the awe sflow? More inside..
- A dilemma... and an ode to the B5 S4 (kinda long)
- Vacuum line freying
- bah abs problems, abs and esp light come on when i hit ~20mph, brake pressure code
- Looks like I'm going over to the dark side...(long)
- DTC Issues... done research with no real answers
- Should i get a check engine 1 week after going 2+ (piggies) with mtm "3"?
- engine won't start, sputters then dies...worse when given gas
- Video Game Pictures...........................
- Random engine doesn't crank/ignite but starter works
- Help!...Name that part! I am working on replacing my engine.........
- This is the correct part right? cam tensioner gasket...
- Anyones having issues with vag-com 704 not saving logs? Starting to piss me off after some good runs
- Weird day in the shop...
- Who's a good place/person to rebuild turbos or build or rebuild hybrids?
- Extra cash burning a hole in my pocket. Need feedback
- already searched...Sway bars, Hsport? neuspeed? H&R? help me out here...
- j/w do any 17's fit over alcon 355's?
- Edmunds 535i Review : The nearly perfect sedan
- the bolts that you use to allign your shifter (the ones in the rods that go to the tranny)
- AW Xbox LIVEFinder is, well...live
- Starting to paint wood trim
- Any Forza folks have something like this...gaming seat?
- Windshield Cowl
- I have a question from a friend considering an S4 purchase (Buy stock and chip it, or buy Stage 3?)
- How to access the dash behind the airbag? got a bolt rolling around back there driving me nuts..
- ESP goblin to me on 2001? You turn it off..and then it comes back on when it wants to? Is that right
- Carbon fiber gurus...
- Anyone have have silver trunk lid for sale?
- Boost Taper in the K04s - help the newb
- Good source for body parts; new & used. also, how much to expect for hood? new/used?
- anyone has the link for the wiper motor fix?
- STAGE 3 KO4 V A HYBRID RS6/KO4-- does the hyrbid pull much harder? any videos?
- what all variables are involved in tweaking when one says i'm getting "tuned" by so and so?
- What do you guys think about this? Trading old bumper shell w/ small-ish dent and tear for painting
- Number of Imola, Nogaro, and Laser avants in US 2001
- Anyone selling their RS4 Inlet Pipes? How much d othey go for these days?
- Reminder: If you use tuner lug bolts, make sure your key is made for 17mm wrench/bar....
- I was poking around the engine last night, and noticed I am missing a heat shield nut
- Coupons.. Get your PureMS Coupons!
- 500hp A4? link inside
- To all the Forza 2 gamers......
- Read Mike@ASP's engine pull article (very good)... what differ's when pulling a TIP engine?
- Anyone have a diagram or install instructions for RS4 inlets?
- Speaking on VM3, I WANT ONE if anyone is trying to get rid of one...
- '(O)' the wear sensor is intermittent
- VM3 WITH RESONATOR REMOVED VIDEO #1
- Big Problems... Replaced front O2's yesterday, then drove and tons of white smoke came out!!
- Anyone heard of this guy Alex Lemieux? B5 S4 Black. Found him on Forza2?
- Source for power steering pump?
- where to buy conical lugbolts...
- Look here - need some advice about some upgrades, downpipes/turbos/exaust/misc etc...
- Is there something missing on the new style spider hose? I have nothing that...
- What is a fair price for RS4 CF trim in exchange of wood?
- preview of my sweet graphics package inside... yes, thats a panda on the roof
- I drove my car tonight for the first time in roughly 6 mos. Man, I love this car! That's all.
- 2001.5 asp stg 3 =1 2007 997 turbo=0
- Lemmiwinks BT: Why wont it work?
- Forza once more.. S4 challenge !!
- Forza: If anyone here is good at making a quick internet page....
- New Hips and Some Project Updates
- Ok lets go FORZA 2 gamer TAG = GRK S4, I will be waiting in my 350z hahahahah
- Mobil1 on sale at pep boys, stfa shows p/n 9212671 for 0W40. Help - local store says p/n is for 10W
- Running AW Forza Motorsports 2 ID's
- Well, here's what my K03's look like no that the engine is out.
- Stoooopid n00b question. I need to put my rear o2's back on...
- What happens when the AWE S4 tries to pass me in Forza??
- Best place to get clear headlight covers?
- any chance the RNS-E can take in a VGA input?
- I have always been very particular about installing things on the car that appear clean or almost
- S4 ignition
- Spent the day at Pole Position in Corona today. Great place to clear the mind, and relieve stress.
- Does anybody have any experience with the MTM TBB brace with a stock boot?
- Hartmann Wheels Blem Sale
- To guys with custom FMIC, what are you using for fan kits? Any recommendations? TIA.
- Car seems to sputter around 3k in second gear??
- Fault Code Help - Codes inside
- Does EFU have smart tire or a tire pressure integrated into the display?
- STFA - anyone ever have a CEL come on for a vaccum line? TIA
- Paging El empire......
- 2nd Annual A.W.E. Tuning BBQ and GTG
- Has anyone had any trouble with Alcon rotors warping?
- I am picking these up locally for CHEAP! Will they fit and do I need different lugs.
- Finally got a ride in MREDRUM's uber 1000HP M3 today .
- Will these wheelz fit on our S4s?
- POLL: What is your favorite dyno manufacturer and why?
- I added some folks to Forza yesterday, please accept so I can stop racing stupid evos...
- Does the CM IV clutch have the same life expectancy as say the RS4 clutch?
- : Ecs Coilover Help Plz - Cant remove spring seat and sleeve doesnt slide all the way on Bilstein
- Brake Pads
- where are the extra 200 pounds coming from between 2000 and 2001?
- Insurance hasn't looked at it yet but the dealer is saying new motor...
- Tracksports going in today...with new Meyle Control Arms, etc...Wheeee!
- Anywhere out there that can beat $217 for an EGT sensor? Thnx.
- will '00 silver match '01.5 silver?
- If I buy a pressure bleeder and want to flush out all of my old brake fluid do I just need to.....
- Should I dilute the G12 ( Replaced expansion tank, leaking) or straight up?
- VAST CELiminator pair raffle winner...........IS...........
- Any info on who won the piggie o2 emulator raffle?
- Accidently filled up with 89 oct. Car stumbled on start up this morning. Crap.
- Fvking retarded BMW drivers (rant about stupid/unsafe drivers.. long).......
- Has anyone tried to contact Buehn lately...??
- If I gut all cats on stock DPs, will I get codes if I go with the defouler mod?
- So this is the first time I'm going to need to get a smog check in Socal...any recommendations?
- Tony@EPL, can you please call me or answer my emails about the rich codes I'm getting on my car...
- white smoke... high RPMs solves the problem???
- Toyo T1R vs Goodyear F1 GSD3s Who has run both of them?
- Where'd the post on the MAFterburner go? Someone finally posts something NEW and informative and it
- DTC 18047
- So are these the bad boys I should go with???
- <Paging Snowtrooper> YGM
- Nearside Rear Window has stopped working???
- Rocking drivers seat... what's the solution? Is it worth taking it to Audi or is it an easy DYI?
- After-run fan not starting after engine off but runs fine while engine on. Any ideas?...
- toomuch boost or not____block 115
- Just a Tease of the Prodrive Goodness on my car...
- Went 2+ and got GS-D3s and I'm very happy!!
- Jared your smoking rocks.. The S4 on this game is so rediculous
- Lemon Jetta "Stg. 2 Weight Reduction" --> no start. Must have cut some "stupid wire" . . .bww
- A few snapshots from the Autostadt car show at VWoA in Auburn Hills, MI...
- Props to AWE, FM2 content...
- Feel like loser :( spent almost half of my Sunday on AW, posting nonsense Qs, anyone feel the same?
- Suspension install, MUST it be done by very good Audi shop or a VW shop can do it just as well?
- Anyone Attending?
- question re: hard brake line on HP2 calipers
- Bridgestone RE070 - Impressions? How are they for track/street/rain? how does it compare to RE050?
- EdyJun Alert - Add ImolaTipSoulja's latest Snake oil power product to your directory...
- Iconoclast......(regarding carlsson 1/6 wheels)
- Does this car belong to anyone here? What kind of mods do you think will get you $35K?
- Well I got 3 of the 4 o2s out, but can't see any way to get the drivers side primary out. STFA says
- Passenger side turbo oil line....
- A couple pictures of my Lidatek LE-30 installed in my grill.
- Melted cats, wtf, does this happen very often? Why Milltek? WHY!? ;-)
- Is 2000 the best year? due to the lightness? the no esp? anything elkse?
- Help! Riddle me this - Headlights don't work, only corner lights,interior lights and...>>>
- K04 DIY Installation Tips?
- engine seems too hot
- What shrouds do the ER side mounts use? Also whats the pricing on those bad boys?
- Autozone has Castrol Syntec for $4.49/qt
- what wheels are these... they look like rs4 dtms but also like the mtm type
- OK - Pentosin vs. Prestone multi... Consensus please?
- Which European F1 race would you attend given the choice of France, Britain, Germany, or Hungary
- when changing oil
- Saw an 07 ML320 CDI today...got to talking....might go for it...(long)
- Autozone doesnt carry oem spark plugs, where else can I go or whats just as good to get?
- So, My Wife wanted to learn how to drive a six speed ...................
- Help with Clear Corner Mod......
- powdercoated wheels makes you handle like youre on rails:
- What fluid goes into the dirty g12 plastic container?? brake fluid??
- call me a noob, but is this...
- Car Shopping
- Selling the S4
- Help Me pick my springs AW
- Who is this?
- Thoughts on Ko3/16 turbo ??
- I finially did the remote antenna mod, guy, just DO IT!
- to mod or not to mod
- Noticed on the bottle of CRC Thorttle body cleaner that you are not to
- Painting brake calipers
- paging, Chuck - S4, please send me those logs, thx
- Is the bottom part of the RS4 air box the same as the bottom if the stock S4 air box?
- I am looking for dark taillights. Can anyone recommend? JDM?
- Ouch, just saw the replay of the GMG porsche @ the GT Championship in Concord
- What 18" wheels look best on Silver S4? RS4, RS4 DTM, BBS CH, BBS CK or BBS RC?
- b7 18"x8 rs4 wheels What tire size to get???
- So the slave/master cylinder use brake fluid right??? If I bleed the brakes and change the fluid....
- cover part # help
- hit 66,666 today...
- Need help replacing wheel bearings!!!!
- Chamberlain Liftmaster and the opener
- CBRD open house (York, PA)
- Any other places I should look for an EGT sensor besides Miramar Volks/Audi?
- just broke 1000 post ftw!!!! that is all.
- [turn signal relay switch] - how do I open this to clean it?
- Friend is looking for a B5 S4,,, but which year?
- headlights pointing down... any ideas
- Let's play diagnose the sound:
- Big Puddle = Big Trouble
- center boost gauge: awe or apr???
- Finally got that mother f'n o2 sensor out.
- TPIWWOP but.... I hit a deer last night and am looking for a silver hood....
- who was it on this forum who had a white C6 A6, slammed on 19" B5 RS4 DTMs?
- BBS RC Wheel, 18", 5x100, ET38... do they fit? Is there an Audi centre cap for em?
- at stg3 is the S4 super car status??
- [blinker fluid] - where is this fluid and how do I change it?
- What are the symptoms of a bad slave and/or master cylinder? are there any good installs?
- What tools are required to do front and rear brake pads
- Went to the track last night 1/8th mile..........Video inside vs Bullitt Mustang
- you sneaky little...
- Is this a-arm the same on the A4 and S4's??
- Thank you to everyone who helped me get this far.
- SOB- stubborn bushing in rear A-arm...any ideas?
- S4 =3, House =0
- I just put on some new front pads and they are great at high speeds but right when I'm about to stop
- Mechanic in the OC??
- xpost: Gf's car is a 1992 100 with no AC in 90F+ weather. Few questions: How to diagnose?...
- Is there a conversion factor from o2 voltages (block 31) to AFR?
- Anybody have shocks/springs laying around?
- Any demand for aluminum trim these days?
- New Stage 3 install can someone identify this connection BWW
- Squeaky Clutch w/ Motul 5.1? Opinions please?
- do vast piggies come with new main cats? don't wannt bug vast since they are swamped.
- Stuck on last part of Engine Pull. Front drive shafts are in the way. They are hitting the tranny
- Can you select a Hibiscus S4 in Forza 2? If so I may have to go buy a 360...
- new problem: won't engage a gear
- Need some more ideas on troubleshooting an overboost problem....
- is there a way to loosen up a siezed wiper transmission
- Anyone have directions how to install a VAST Short Shifter??
- Hey Jeff Moss and Brent
- Anyone with Forza 2 up for some time trials???
- Oil coming out my exhaust on the highway
- might be a repost, but worthy imho....
- Ahhhh... Squeeking noise is driving me crazy but I cant figure it out......
- finishing up on my RS4 mesh but have a question....
- Oil Filter - Everyone seems to be into OEM, what about NAPA Gold?
- iconoclast - ever get the APR Bipipe? How is it?
