- what the hell is this crap with eric fletcher....
- anyone in Philly area that has a used stock flywheel (b5 s4 6spd) ..whatever shape ? TIA
- PureMS timing belt group buy kit arrived. Stage 3 getting closer!
- ~approx price? 2001 Audi S4 180,000 KMs on it...tia
- Which child seat do you guys have?
- survey of ipod friendly s4 owners, what's your stereo/integration/mount (if any) setup?
- why are asp snub mounts over $300 more than 034!!??
- Anyone selling their stock suspension?
- am i missing anything? (beside k04's)
- Where does one apply a door seal lubricant (gummi pfledge) to stop the creaking durring frame flex?
- fair price for ko4/rs6 hybrids with pnp option.. BARELY used.. No shaft play.. pretty much brand new
- Anyone have an S4 grille badge they can donate to me? Thanks!
- how many have had to replace rear lower controll arm bushings??
- i have read about cars falling out of 3rd gear on the track before
- audi "dope" decal in black
- Anyone need stock DPs Exhaust or K03s ?
- 2ks4 : Jason are you interested in this one?
- Best source for OEM head bolts? Any place that can beat PureMS @ 2.79/bolt? Also...
- Anyone getting rid of AWE intercoolers ?? Or would you consider
- creaking moaning while turning...
- Missing bottom mounting tab on A4 Headlight Housings (?)
- Beautiful Hibiscus S4 that needs a good home
- Hub Shark or Sir tools B90
- i need to replace my g89 temp sensor. the part number on the sensor i removed is
- Blown Turbo symptoms - some what long
- Simpply (Mike)...YGM
- I STFA but I can't find how many bolts are supposed to be holding the bell-housing to the...
- Well the silver S is finally legal. Now I gotta fix a few things on the black one. It is unhappy now
- where and how to repair three-piece OZ SL III's?
- Must read thread over on the E55 forums scammer getting owned !
- remind me again - the whistling turbo: it's a sign of
- Who's running GIAC Stage 3- software programmed for K04s? Looking for feedback
- MTM Adapters to fit K16's to stock S4 manifolds?
- Can someone do me a favor and send me a carfax for VIN#...
- Selling the A6, bought a 2001.5 S4...check her out!!
- has anyone contacted TM Engineering lately? Their website is gone & voicemail full...
- Is any DOT4 brake fluid OK for top off?
- Good source for replacement wheel bearings for y2k s4?
- Possible project car?
- Audi R8, Lotus Elise SC, Porsche 911, Evolution X MR, WRX STI vs GT-R
- Hello
- XPOST: Secondary Air Injection SAI Pump Rebuild write up
- For all you gys that have been around long enough to know the name "pat socal" well i got
- Steering rack main seal blown. Anyone tried a gasket between inner tie rod end and rack as temp fix?
- Anyone have awe twin 2, apr stealth or any quiter exhaust they are looking to get
- Wheel bearing: ABS and ESP LIghts help!!!
- What is an oil catch-can exactly? And does my 2000 tip need one?
- Is a small amount of oil in my Throttle body ok?...
- cold start misfires
- How can can someone blow up their turbos!? (If they hypothetically wanted to on purpose)...
- Anyone seen these in action yet? Awful cheap.
- VAG com for beginners
- GIAC BOOST controller
- Who was it looking for an Oettinger rear wing?
- ALROAD NEW 3+ SUPER GA* CLUTCH I HAVE A HEADACH
- I need help finding a pic that was in someone's poster :P
- repost, found out what my AC problem was, but dont know how to fix it.... more inside
- Should brake rotor be loose by 1mm when I remove rear wheel? I can push/pull it relative to hub
- Would i need longer lugs with 2mm or 3mm spacers? or could i use stock lugs.
- High Performance Tires that Don't Tramline
- washer fluid leak
- canyon cruise pictures
- X1 cai-does one clean it with just soap and water and then light oil coat?l
- Would the following codes cause limp mode at 4k rpm?
- where can i find a pic of a silver s4 with 3 piece wheels and brushed centers?
- Sitting oil in parts of driver's side intake?
- X-Post for a buddy, VAG codes, any help??
- ac question... gets cold for a few minutes and then hot.... whats wrong
- HB - Why can't I get my O2 straight on K04/RS6 setup? (More Logs)
- Best price on Stoptech ST-40 355mm 2-piece, Slotted outer brake disc rings?
- RS4 OEM wheels and 255/30/19 will they fit?
- KN cone filter...whole setup
- Need some help - rear caliper piston. I'm trying to get it to retract but don't have the tool
- n00b to brakes questions: 2-piece, drilled vs. slotted, SS lines, etc (inside)
- Purchased Wrong Front Speaker -- Still Need Driver's Side Replacement
- Been gone for 3 weeks...
- Does anyone have 01.5 transmission rebuild kit part numbers?
- Just replaced vehicle speed sensor. It did nothing. Any suggestions?
- Going to sell as is or part out w/ trade in at dealership
- passenger side engine mount bracket question inside...
- Question-- When everybody is doing logging, they are using the stock narrowband 02 sensors, right?
- I've been feeling a strange vibration coming from the engine since yesterday, it sort of sounds.....
- just a heads up, i think today is the last day for pure timing belt GB
- Can't find duster for front Brakes
- Feeler Alcantara Blue front seats Heated PNW
- I gave birth for the first time (first motor pull success!)
- Saw this today sorry the pick are crappy at least one of us was rolling for each pic.
- Acura NSX vs. AWE Stage 3
- quiz time: what are these parts and where do they go? =)
- how 'not ok' is generic coolant mixed with the audi coolant? i'm in a bit of a pinch today
- got mad at downpipe install today... decided to pull motor and go with the tial kit
- What is the going rate for stock used sway bars front & rear?
- got this ABS/ESP DTC help please to find what could be
- Question on Meth injection...
- paging MSP_S4 or anyone who's done the armrest fix w/o removing center consel...
- Part # help - small metal clips that hold on center mesh to RS4 bumper.
- Happy Memorial Day - clean car pr0n
- I could use a little help. Installing new downpipes. But I'm stuck on getting the old ones out.
- what is the spec of the bolt that connects tranny bell housing to the back of the motor?
- Aftermarket downpipes for sale anyone?
- Bose right rear bass speaker buzzes during music with lots of bass
- boys and girls with RS4 mesh i need your help....
- Tried giac race gas program
- TiAL R650 kit went 11.55@127 on pump, at full weight, with only basic mods yesterday...
- Coolant leak follow up
- Crazy rear suspension housing question:
- What size are the front bose speakers? And whats the best battery? Optima yellow top maybe
- Saw this on a NSX today
- Ok, so whose nogaro avant in Alamo Plaza with NY plates is my new phone background.
- Question! TIP tranny!
- Paging Shaun Searcy, about RS4 intercoolers in classifieds, Sent you a few Emails with no response
- What shift knob is this?
- tire size S4 B5 - 235/45/17??
- Stoptech BBK bleeder seized into caliper...
- Nogaro Avant
- ECS 355mm disc rattle..
- paging woods4 or LI-S4, where can i get a piece of acrylic like this
- Whats a Euro S4 rear bumper worth these days? Keep in mind I'd need a stock bumper back
- Aux (After-run) Coolant Pump install question...
- question about stage 3 and accordion hose
- Ported/polished my manifold. beadblast/powercoat is done
- anyone from SF know anything about this stage 3??
- Who has the best prices on OEM piston rings and rod bearings?
- B5 S4 rules
- S4 wheel question from a D2 guy.....
- F-hose is F-in me up
- Thanks to everyone that helped me! GIAC runnin smooth, fixed misfire in cylender 6...
- rs4 mesh question LI-S4 maybe
- Anyone got a rear sway bar they want to sell? Neuspeed or H-sport would be nice
- RS4 Intake pipes now availible, special pricing on the first 10 units.
- RV: log VAG from blocks 3 and 115 regarding an earlier post on my boost problems
- Rear view mirror got cloudy and got liquid inside after a hot day in the sun?! Time to replace?
- Changing CHRAs on turbos? easy? or have shop do it?
- Thanks for everything
- Are there certain blocks I can/should log while going down the track tonight?
- Paging Jason......did you still want to try and use my front bumper as temporary till you get
- p/n request......there is a plastic tube that the f-hose connects to
- Clutch Install: Should any grease be used on the bore of the Release Bearing
- Silver, lowered S4 in Yardley, PA. Woman driver?.....Bueller?
- which rotors: 993TT or ECS drilled and slotted?
- How hard is it to replace the seals on the rear coolant crossover pipe? Part numbers for seals?
- I am headed to Island Dragway tonight in N NJ if anyone cares to join.
- bad throttle position sensor? or improperly seated sensor?
- Best cable for ECUx?
- brake fade...?
- Engine Fire... Common?
- Trolling Bimmerforums and came across this thread from their "Kill Stories" section.
- Now i need the samco F hose..new..anyone??
- What is the best M3 style Lip Spoiler for an S4 ?
- How much boost is OK to run on K04s with Bosch GG's?
- Coolant leak question
- Does anyone have a good passenger secondary o2 sensor they would like to part with? TIA!
- Anyone know anything about this car?
- Update: SOLD! - 01.5 6spd B5 S4 Whole or Parts? - SOLD!
- It was just a small fire
- Used AWE Twin2 price?
- New set of Tial 650 GT turbos 4sale .
- Damn it........(*&^%&
- Bumped into some cement siding the other day... bent the power steering cooler..
- Brake problem
- Anyone ever upgrade to k04's after blown k03's under warranty?
- Where did s4orces post go about new k04's?
- Looking for some opinions on these logs. Is this just a boost leak or...
- Tiptronic service. Is a special tool required? I have a long set of 12 points (3 square).
- anyone have a clutch alignment tool they want to send me? in DE k thx
- 7 months later, & I finally installed the Meth kit...
- I'm stumped, no leaks anywhere and yet still get negative deviation code+LIMP mode.I hate my car...
- Does anyone here have any experience with the O E RS4 reps off ebay? Or the R8 reps?
- :: ECS Tuning :: UPS 2nd Day Air Special Rate - Save up to 40% !!!
- Update to oil leak:
- check this out we all have to start to watch out 4.2's are comming linky
- Tranny mounts: 034 Density vs ASP Street - convince me I should pay $145 more for ASP...
- Is there any rotors on ebay that are better than stock? I'm not tracking the car or anything just
- why won't the 00032 code take in my car. I'm pretty vag-com ignorant so what am I doing wrong?
- First drive impressions of 2009 VW Scirocco
- 0-60 for a tip stg2+ is ~5.5sec? does that sound right?
- Can an exhaust leak be bad for the turbos?
- fak it,i'm gonna order spp a-pillar pod/ thoughts on dual pod?
- Everyone hates our headlights. Every drive home from work i get
- HOLY TOLEDO!... MY VAST STAGE 3 ROCKS
- Stoptech calipers hanging up.....rebuild advice? Seals, pistons, all of the above?
- After removing and cleaning my blower motor 5 times... (update... still need some help please!)
- Lol some guy on the B6 S4 forum put a b6 engine into a 2000 A6. ROFL.
- How much should I be looking to pay for a brand new throttle body???
- Air Intake theory: Lets beat the heck out outta this dead horse
- 034motorsport or samco tbb....looks like my old AMS one is ripped...
- Can I buy the control arm kit not for the aluminum uprights if I don't use the lower control arms?
- +25% more horsepower for only $33! [Worst eBay Ad Ever]
- Wow.....my car sounds like it has BOV's.....its probably the BPV or the TBB...
- Anyone have low pitted fogs or just the lenses they want to get rid of?
- Can leaving the car up one side with the factory jack for a few hours cause any frame damge?
- Track tires...need some help from people who track the car often and/or have tried different tires
- Stealership & the other B5.
- OT: Sharpie'd Lambo Gallardo.. reminds me of the RS4 Art Car
- Ignition Control Module went out on me. Why does ecs offer 2 different ones?
- Transmission mounts DIY questions...
- how much to rebuild K04 turbos? thinking about buying a pair but they have a "little" shaft play
- owner's manual for 2001 audi s4 and stock y-hoses
- Does anyone with a CASABLANCA sedan, want to trade me for my silver stg 3? Stock ok.
- ignition coil pack #4 not responding???
- A/C question - works off idle but at stop blows hot
- How long does it take to reset readiness codes? 4 emmisions testing?
- Another Teaser LOL i know i am bad
- A.W.E. Tuning partners with StopTech
- Should I DarIntake my RS4 Airbox for fueling that im installing 2night?
- '02 S4 Avant LOW MILES WARRANTY (tip)
- Any 2002 avants for sale with low milage 6 speeds only.
- Anyone ordered from sportcompactonly.com recently? Recieved my order confirmation 9 days ago but no
- Door lock pump (stfa but no luck) - replaced pump with used - locks and alarm work now but.....
- xpost, b5rs4 and evo torched
- I could prolly think of something better to do with an R8..
- B5 S4 Coilpacks ...
- Anyone have the Ebay FMIC kit from CX Racing? pic?...
- anyone interested in a used set of ecodes? updated
- Keeping with headlight theme this morning... What are my headlights "supposed" to do when I...
- Installing headlights - a q about the "infamous" 3rd torx screw (a little long-ish)
- black s4 on passaic ave in clifton yesterday...
- A++ customer service from Mike at purems.com.
- Headlights. My sidemarkers stopped lighting up, but the blinkers still work.
- FYI Registration for Watkins Glen HPDE with the NEQ is open : )
- what is a set of used track sports worth?
- It's vids like this that help me draw unfair conclusions about your typical B6 S4 driver...
- anyone here in SLC?
- I need some help regarding the blower motor fix
- anyone around DC area able to install and tune for aquamist???
- Do stock front brake calipers w/ approx 100k miles have any value?
- Would you buy coilovers used that had about 30k miles on em? For 400 bucks?
- might be a dumb question but i don't know, so,
- Anyone have a new samco tbb for sale (blue)??
- Do you guys have any lowering springs that you're willing to part with cheap? I wanna go..
- How do I recode my TIP?
- How to remove ignition modules on top of airbox? Can't get the metal clips off
- so is removing the beltline trim really that big of a pita?
- Continuing to get new personal "bests" of miles per tank after fuel filter change.
- Does anone have pictures of the tranny cooler fluid lines bolted to the tranny on a TIP?
- Need Help regarding RS4 upper inlets. Missing one....
- I'm on my way, car is getting fixed post getting keyed, new suspension is on the way...
- Which one looks better on Black Sedan?? 18in. RGR's
- X-Post from the PNW forum: OWK Mem track day event group photo. Very cool. (BWW... it's big).
- OT and possible repost but did everyone see the R8 to compete the 24hrs at the Nurburgring?
- So I have been pushing back and pushing back to get emissions done on the silver S for awhile now.
- Need the help of the true gurus here on this "near crank" oil leak:
- I saw a silver avant for sale down the street. He want 20k its a tip with many xtras.
- Frickin Nazi's .... That is all ...
- If one was to put on a carbon fiber hood and trunk and maybe some doors, would it still be a bad
- Stg 3- tuning options.....does this sound right?
- I am going to try and not flip out. I have a slipping clutch question.
- chipped people, how much vacuum are you pulling at idle ?
- DIY Diverter Valve: removing/reattaching stock hoses a PITA?
