- Anyone have Extended Warranty
- Pre S4 purchase question. Maybe Carson can add his 2ยข.
- Okay with all the control arm talk, I have a n00b question...
- Anyone have a picture of the carbon fibre Audi Sport frame installed?
- Noise From Febi Contol Arms When Hot
- Satin Black S4 EXALT Edition
- Ko4 is borg warner used in saturn sky, solstice gxp, and more?
- Anyone have a drivers side front fender for sale?
- Qucik question, a guy over on AZ w/ a 03 1.8 A4 is looking at buying my stock front brakes
- im getting worried =/
- Leaking coolant before and after having water pump & timing belt job done at dealer...
- Removal of engine to replace power steering rack
- anyone change their horn to something else?
- Vis carbon fiber VS OEM hood wieght...Whats the difference in wieght??
- Steering wheel
- K04's in Stock and available in different packages.
- Review: ASP Custom Tune vs. MTM: Stg 2+
- Why is it that when you go through the gears fast during accelleration, afterwards...
- Anyone got a Neuspeed or H-sport rear sway bar they can sell?
- This looks siick!
- Is this reading too low?
- Camshaft Position Sensor
- Need some help on deciding which brake pads to go with!
- Well....status update on the turbo issue...sent them back to Audspeed to be
- Could i please get the torque specs (FT LBS) for the, tranny mounts, motor mounts, axles, more
- Model # for rear deck bose speakers in 2002 S4?
- Installed a brand new set of k04/rs6 hybrids and it seems i have a oil leak now has this happend ...
- 21-22 psi on AWE OTS? Is this correct? I have never had it boost this high. Normally 18 to 19.
- WMS's steel flywheels are now avail !
- Best place to buy EGT sensor? They seem to be expensive these days.
- for those of you who tow and are lowered
- Vast 02s, are they bosch or some other generic brand? I don't see any
- A.W.E. Tuning 2.7T Intercooler Update
- Valeo B5 S4 Xenon E-codes on clearance sale at Achtuning
- Cassette EJECT button messed up (paint came off), dont look good, anyone got a non-functional one?
- Is the ECS CA Kit: besterest?
- Don't know if you guys dig the 4-banger stuff at all, but nonetheless, here is a B5 we just finished
- New tires. Best bang for the buck??
- For basic datalogging and A/F needs, the LM1 is good/better than LC1 correct....also,
- Looking for a passenger side fog light.
- parking brake not fully releasing
- almost...
- Timing chain tensioners.....
- Does my idle look irregular or am I just going nuts?
- Car idles ok with Maf unplugged (bit lumpy)..and revs ok....With maf sensor in, bogs real bad when I
- I was lucky enough to strip my rear axle bolt last night. Any idea's on how to remove this thing.
- RS4 Intercoolers on stage 1?
- Anyone want to trade any wheels for my Avus wheels?
- Paging guruman!!
- JCaps Engine Bay Dress Up...
- How many Nogaro sedans are there in the U.S?
- RPM drops to ~600 RPM for a second when I come to a stop then climbs back to normal
- car goes into gear but doesn't move...
- I guess bent is better than broken . . . =(
- anyone spoke to or heard from Skydive? or know how to contact him
- Mark@ASP - Please send me back my RS6 manifolds...
- ASP Stage 3 Logs with full tank of 91 octane and 2.5 gallons of e85
- Should throttle valve angle and igntion timing angle be fluctuating at idle?
- Ohlins Motorsport Suspension....
- Question for ErikS4 regarding sway bars...
- what size are the 2 little bolts that hold the coil pack in?
- Short Shifter
- ECU destruction risk with new AUDI diagnostics
- Wheel clearance at Achtuning, new selection and lower prices!
- Transmission Fluid Recommendations
- What's carson's current email? Is it C*****@riversideaudiDOTcom
- what do you guys think about this oil purems offers??
- What is the silver canister next to the ABS block? in this pic ....
- Downpipe clamp question....
- Help - ABS coming on randomly
- Is anyone else getting this ridiculous LLTEK ad up top occasionally? its all vertical and huge....
- Raw metal look, or camo for h2oi??? Edit for the Engirsh challengedded
- Review: VAST Performance Oil Cooler Kit
- I STFA.. RS4 Clutch not pulling in the biggest audience, but can i "lightly launch" :-p
- Little misfiring @ idle... I have nmbrs from 032, someone take a look!
- What's the easiest way to upload ecux files?
- Tires for the track
- B5S4 Garage Sale in AW classifieds...
- Is the H&R rear sway bar effective at countering understeer?
- Are there any instructions to install a shift boot ?
- Just a heads up, i have a pair of oem sports mirrors for sale..
- Stage 3....ish
- Need some part # inside ... please help!
- Met a guy today who owns an MTM supercharged V8 S4 Avant.
- Snapped Neuspeed Rear Sway..Any recommendations?
- Are Audi S8 Rear Brake Conversion worth it ?
- Front End Noise
- Stiff clutch, plus clutch pulsation/vibration = ??
- Does anyone have a headlight washer cap, driver side silver in VG/excellent condition.
- why isnt the TCD being sold anymore by Vast?
- Price is negotiable. Link to the classifieds.
- Shot in the dark: anyone have some Dunlop Sport Maxx in 255/30/19 that you want to sell?
- Falken RT-615's
- Where do i get these wipers for a 2002 S4?
- best place to buy 55w hid upgrades for the ecodes? TIA guys.
- Cooling system symbol showed up this morning...
- I've got a speaker rattle in the rear deak behind the rear sets, thoughts?
- Has anyone installed the WOT shift and 2-step box on their S4? I noticed a little talk of it
- Wondering if this single outlet Ebay intercooler kit has been discussed.... What's your take on it?
- *** Paging audiKP & McKennaS4 ***
- My Imola bretheren, help me out here!
- new toy.....
- Anyone that has put a trailor hitch on their s4??
- Just a heads up if anyone is interested my car is up for sale in the Classifieds.
- Air Bag light flicker
- I walked a 350Z this weekend. With an extra 500lbs in my car. Are they really that slow or am I just
- ~DonQ~'s new week end mod
- Need Help Diagnosing My Problem(Tranny ,Shiftlinkage)
- Life is good....
- A friend is considering buying a 2001.5 S4 sedan with 108K miles for $9700 and needs the usual...
- Insurance was going over my car and quoted the replacement for the driverside grill insert at $40...
- Does anyone have a front bumper lower grille insert (black)? Mine is
- Two questions about STaSIS Ohlins adjustment...
- Building the Suspense.... Pictures with RPF1s coming tomorrow morning.... STAY TUNED!
- for the stage 3 guys..
- total gauge failure
- Does anyone sell grills for a modded S4 bumper?
- clutch pedal problems.. advice please
- I've chosen a replacement. Now just have to wait for her to be built.
- Well i'm sure this request will go over like a brick isht house..... Need to know alarm module locat
- Just got some new ingition amplifiers, can someone help me, they are Oem, but it came with a
- Northeast S4 owners......
- anyone have (or know where i can get) oem rs4 bumper passenger side headlight washer cap?
- 600 AWHP+ 4 inch Exhaust Fabrication GT28RS
- NEED HELP! sweaking window / door frame is driving me nuts.
- Brake Booster Check Valve on 2000's... Can someone try to help me here??
- Why is it that i only get full boost when i 3/4 throttle it? wot i dont get all of it.
- Possibly selling my AWE stage 3 fueling - any interest?
- Thinking about selling. What's a fair asking price for the following: 2001 S4, Silver w/
- Tires... 245.40.18 / 265.35.18
- Sounds like a torn wastegate line? Boost flutter under part throttle, inconsistent acceleration...
- Hey Colin, with the red S4 in CA/UT are you on here?
- When my k03s go bad, should i replace with k04?
- My stock exhaust separated at downpipe to muffler section. Can I fix with sleeve clamp? 2" or 2.25"?
- boost gauge fogging question
- So what's the best way to verify that a leaky injector caused my oil contamination?
- anyone have any wood trim lying around?
- squeaking at low speed from front pass side.
- I have to sell my car.....
- Spotted the Imola S4 in Kansas on Friday ... the one w/ Avalon decals, he just posted pics of it
- so what are the differences between the M, T, and H ecu's?
- Audi RS5 Will Make World Debut at Detroit, RS > R > S, etc.
- Had a popped hose last night. Thankful about ......
- Ferodo DS2500 rear brake pads, is RaceShopper the best place to get them? Anyone else carry them?
- Epic awot repost link
- is the rear axle bolt a 14mm Hex???
- Which to get for SoCal: ContiExtremeContact || g-Force Super Sport A/S || Eagle F1 All Season?
- This might be of interest to the car nuts of this forum: Audi Sport Quattro spied this weekend.
- Anybody know why exactly ko4s are bcoming scarce? Are they
- Just order a JHM weighted aluminum knurled shift knob and shift stabilizer
- How do you get STaSIS Ohlins reservoirs behind the driver side firewall?
- 9.7 @ 146
- Some new pictures of the S4.
- Security mods on the S4?
- Would you guys mind listing the places that I can buy K04s & hardware only (not full STGIII)
- Just got a first hand experience what a massive boost leak feels like (story inside...Long)
- On its way to get a 4 inch custom Agtronic motorsports Exhaust
- Radio died, this worked
- Bumper
- Feeler Post::: Anyone looking for an immaculate '00 ASP Stage 3....
- Ran my friends GT30R STI with my stage 3 - vid inside
- A few pics since no one knows me here
- Oct Eurotuner has a couple of S4's.
- whos Nogaro sedan at Willow Park (Wayne) PA did I see/park next to yesterday?
- Running CM Stage4 6 puck with LWFW--was sent 8 puck from CM by mistake. Keep or send back? (more)
- I FINALLY parted ways with the BBS's....
- Is it possible to do Oxygen Sensor Mod without the sensors?
- Folks that installed a trunk mount W/Meth Inj... if you routed the hose under car, where did you
- where is the alarm module located on a 2001.5 s4?
- Alright, I'll give this another try, ANYONE W/ A FRONT BUMPER??? i NEED ONE BAAAADDD!!!
- After run pump replacement without removing manifold
- Are the A4 and S4 fog light housings the same? They look the same, but hard to tell.
- X-Post: Need to paint fender - bought touch-up paint from dealership - can I get it matched somehow?
- feeler, whos looking for a stage 3 imola wtih 73k ...
- B5 with B7 front end?
- anyone looking to sell a 2.7 with bent valves?
- Is $338 including tax and shipping good price for 2 oem 02 sensors?
- Need Quick Help! Is this H-sport front sway bar on upside down?
- If M-Box and T-box are interchangeable, why does APR offer different Stg1 files for each ECU?
- Will 225/55/17 fit on the S4 without rubbing? Anyone using this size?
- Alright I've STFA'd but can't find a definitive answer - is my car an 01 or 01.5.. Old badges...
- Can anyone run a VIN for me?
- If I remove my MBC can I just cap off the T fitting or should I
- need a lil help please
- S4ptld -1 Audi B5 central locking pump -0
- Anyone want a Silver B5 S4 Sedan with ~95k miles? Stg II - 1 owner, v.clean...
- Im putting my motor back in this weekend but i only have the lower inlets think ill have a problem
- Is Wicked open this Saturday for tunning?
- anybody selling an exhaust for the b4 s4?
- Whos selling their stage 3!!
- Think I can use lemmiwinks to reduce my backfires??
- Curious, does the TBB popping off under acceleration hurt the turbos at all or no??
- Ram guess what I got from Carson? LOL!
- GIAC electronic boost control - what do the values mean?
- rs4 clutch questions
- R/S4 Xenon Headlight Housings - In Stock - Special Pricing!
- Indianpolis gtg sept 20th at EPWorks
- Saw a GT-R in person last night at the gas station.
- VAST FTMFW - Little VID inside
- OT but BMW is planning for more Turbo Charged engines.
- RS4 Grille Stock Elimination Sale - Riverside Audi
- Hey guys, I found a sweet deal on a bbk. what do you all think about this kit:
- Water in Drivers door pocket/cubby?
- anyone know part # for wastegate line t-fittings? TIA
- what oil and how much, in 6sp trans for my S4 2000, 75W 90 ??
- what other ecu's are interchangable with an M box?
- car was blowing white smoke like hell, turbo was dentist drill + screaming baby, pull turbos and..
- Anybody have any use for stock turbo heat shields?
- Mike@VAST - Can you please respond to my emails when you get a chance - thanks
- turn to A&E they are going to use an A4 as bate in NJ. has to be fun to watch.
- Just played with a Tesla...
- Thinking of selling APR Stage 3 fueling
- how much is a nice set of 18" BBS CH's worth?
- Does anyone have a picture of the reverse sensor location?
- rods
- Does anyone have an active Carfax? Need a VIN pulled...
- Valve Cover Gasket Replacement
- Does anyone sell Accuseal clamps in the LA area??
- Trying to sell a car (questions)
- Local shop has 4 x Mobil 1 0w-40 and 3 x Mobil 1 5w-50 -Is it a bad thing to mix oils?
- FYI IBG's casa avant is SICK
- Quick Question for those with any Stg3 experience...
- Another successful FedEx delivery :) Thanks Tomasz :)
- I just got off the phone with local Audi dealer and they put regular 10W30 non-synthetic in my car!!
- Can someone help me plot some logs? TIA
- Anybody used this gas container for storing/pumping race gas?
- When doing the TB should the fan switch be replaced too?
- :: ECS Tuning :: ECS B5 S4 Timing Belt Kits - New Pricing - Free Shipping !!!
- At what milage the reliability of a Stage 1/2 nose dives? @ 50K, knock on wood, mine's been flawless
- front license plate adapter
- Just saw this RS4 hood grill for cheap on EBay ...
- Anyone know if the RS6 "Dimpled" tip shifter will fit the S4? Want to match the RS6 wheel I have.
- Can someone run a CARFAX for me?
- Car is effing with my HEAD
- does any have wood belt line trim they want to get rid of. I only want
- Trying to isntall HID H7 fog kit...
- Got railed on the way to work today, looking for a rear bumper preferably black
- Anyone experience this? Left Hazard lights on...then weird electrical gremlins
- Found a Crack in one of my Flik Artic wheels today, can't find a replacement
- Blackstone Report - Yikes...
- Happy Birthday S4 Aviator
- 17834 Evap Purge Valve N80 Open Circuit and rough idle help
- Some pictures of the new Casavant...
- I've a guy asking me if an M-Box ABT/AMS ECU will work in his A6 2.7T...
- Just finished replacing both primary O2..
- who is running 19in rims??
- Milestone!
- Tactrix cable: is it compatible with Audi ECUs and the protocols used by VAG?
- paging johnnybravo....044 fuel pump??
- Which cat-back system is the quietest? Milltek/SuperSprint/Vibrant
