- Sigh, after almost 5 years, I really liked how my car looked until
- Post: Year & Mileage
- ABS / ESP light was on...brake booster problem solved
- What "fast" stock cars can a stage III s4 beat in a race?
- Can someone look at these codes, I have a CEL and need to pass inspection this month
- [Tip to Manual] What's the diff between the front inner axle on a 6-spd and a tip? Flange?
- Money pit motorsports presents .. another log run
- What do you think of this? (s4 coffee mug)(pic fixed)
- AWE K04 folks - how often are you changing plugs?
- does anyone know the size of the front axle bolt?
- Dilema: Play with Lemmi a little or cough up the cash for XR program?
- Who is near the dutchess county area. I would like to set up a meet some weekend soon.
- anyone have that picture from audi that explains the difference between the K03 and K04?
- Damn it!!! When I gave away my Samco TBB I left the clamps on it. Any sugs other than take bus to
- Sunflower seeds... bunch in the cheek or one at a time?
- UUC VM3...
- Clutch or tranny issue? 2nd gear grinding....
- Monday S4 project.
- my stage 3 vs. a friends stage 2 sti
- I would like to see a side by side shot of a k03 and the mitsubishi made turbo used on the 335
- Paging Mark@ASP: Get my email regarding intake manifold?
- Secondary Air pump issue - anyone have experience?
- Update on my HB vertical core FMIC
- 'bout to perform minor outpatient surgery on the S4. If all goes well, see yall in about an hour.
- Elighten me as to the function of the PITA hose on the bottom of the accordian hose after the MAF?
- ** serious car selling question: got power of attorney to sell friend's M3 Cabrio. Sell the car to
- Paid $0.268/gallon for Sunoco 94 here in MI this afternoon...station error. 8-)
- How do I know what Ecu I have. 'A', 'M' box ecu? I did STFA.
- Vogtland Sedan guys, opinions on rear sway bar needed.
- whats the general thought on installing dv's "upside down"?
- I have Koni adjust. susp., How much neg. camber (front) is good for mostly track car, I
- Change recommendations for APR ECUx 2
- would o2 sensor cause misfires, part throttle hestiation, low vac reading, cold start misfires ?
- could the grinding of second gear be low tranny fluid? which fluid should i replace it with and how
- Vagina light coming on, but front (brake) pads just changed 3/31/06. Ignore or replace pads?
- Dealer rplacing cam seal Under warranty. Any Idea what this job would have cost me?
- Almost cryed when I didn't see a dummy light on my dash. Thank you Lord. Now I can emissions test
- Just installed new Oil sensor. Warning light not on, but level never moves...
- Just put in my ModuleMaster rebuilt abs module, all dummy lights off for first time in six months
- Timing Belt Tensioner
- Thanks to the one and only ToyGuy, my shifter is butter smooth again, with no slop.
- Opened AW this morning and I was logged in on PiggieSmalls UID # 69223.
- if when accelerating and shifting into 2nd gear it grinds even when clutch is completely pushed,
- Was anybody here the S4 in Chadds Ford, pa yesterday?
- FYI On mtv now, is the aka rally. One of the cars, that theyre riding w/is a B5s4
- Weekday repost: I need to replace my aux fan behind the radiator. Is this the right part?
- Anyone try the BHP XPS brake pads in the Stoptech 332 BBK?
- what's up with these seats?
- TIP POLL. Need to know "Year", "Stage", "Trans mods"
- How many times have you posted something ..to find out you hit the preview message instead..
- Does something in this description seem wierd to you?
- ko3/ko4 rebuilds... can it be done?
- Silver, Gun Metal or something else?
- So, it seems my KO4s might not have been my NO BOOST issue......
- will this chip work in my 2000 S4 6-sp?
- What do I do with the plastic liner when I roll the fenders? Can I leave it off?
- Hey doc I gotta fueling question
- <Paging Mike2kS4::ASP> Just wanted to start a "Thank You" thread.
- Can anyone help with a part number for these hoses
- Has anyone tweaked the TC / ESP to stop it kicking in too early?
- Can traction control (ESP ON) affect 1/4 mile times?
- Heat Soak question....
- best fats of 3.39 with passenger and on xr with93oct.
- Sooo just picked up a pair of sparco milanos. Who had the S4 specific brackets in so cal??....
- is this brand of rotors worth a crap? Link inside. The brand is TRINET
- Completely OT, but I saw one of those Shelby GT-H mustangs while driving through the middle of KY
- Welp, gas is down to $2.48 here(93) and the new Roush Mustangs use Stoptech 355s on the
- New car on campus
- Going back to stage 0 tomorrow...
- p-shop request...
- Some new data w/Wideband data too! *BWW*
- Crushed fuel return line...is this a big deal?
- What type of grease for halfshaft and driveshaft?
- New Shoes for the S4, winter/beater wheels... most likely permanent change.
- Alternatives to RS4 inlet pipes? I have STFA and found little... anyone have a viable
- Where can I get one of those little GIAC window stickers?
- DO NOT BUY FROM Audspeed/Central turbos Located in So. Florida he also sells on ebay.
- Can a bad cat ruin an 02 sensor?
- Should I keep my TIP and invest, or go Manual? Whats the max 1/4 you've deen on a tip
- Anyone looking for BBS LM's.. I just found a very looking deal on a set:)
- i cant believe this didnt go over reserve...
- anyone have any experience with radiator fan clutch "breaking" so fan runs at engine rpm constantly?
- Repost:Are the boost acuated Dumps any better than the electronic? Mark P are you outthere? Anyone?
- Manual tranny fluid change- special socket
- May sell my '01 S4 soon.
- Spotted in Charlotte...Santorin S4 w/ sport pkg & plate reading "IMG SRC"...you here?
- Can't remove front upper control arm bolt (attached to wheel bearing housing)... Got nut, but bolt..
- I can't get into Reverse, 1st, or 2nd!!!????!! WTF? Other gears are fine
- Supersprint muffler, 3" everything else
- misfire/stall/buck after sitting hot (more)...
- A4 brake pad problem - maybe one of you can help
- wtb giac b-box
- Zeitronix log (Warmup) log .. check it.
- Is it possible for a bad ac compressor or a going bad alternator to effect FATS times?
- ok, call me what you want but i just changed my spark plugs and was suprised how easy it was
- Any special tricks to get the Zeitronix stuff to work?
- Stock rotors sufficient when chipped? Opinions? STFA already
- Who has the silver s4 in Provo, Utah off Freedom street?
- Who sells those nice carbon air boxes for the large open filters?
- driver seat heater and lumbar don't work. Do they run off the same motor?
- Can I pull the CEL out? I pulled the instrument cluster and took it apart but didn't see how to pull
- Any one on here from Western Illinois University?
- Which cylinder is cylinder #5
- Problems keeping the car running this morning.
- AWD can be towed with two wheels on the ground?
- REPOST for the day crowd, l would like to get some revolver cams, does anyone know who i should....
- GOOD EXHAUST?
- RS4 tranny mounts
- Anyone looking to get rid of their Greddy G2 exhaust?
- you think this would work~!?
- On the road to NASA Nationals... Audi in tow and the Verizon PC card rockin'!
- NE1 compared Toyo Proxes 4 and Kumho Ecsta ASX in snow? both are M/S tires.
- Twin Cities S4 Spotting
- A tired post....HB is a lot of work! :P
- WTF??? Do I need to get half of an S4 now???
- Well I ran some tests today and found that my A/C auxiliary fan is not working.
- I have to call bullsh*t on this one, there is no way it would take even just a chiipped rs4 this....
- A well running S4 should run (A) richer than, (B) leaner than, or (C) equal to stoich upon start-up?
- Could i make an M3 as fast or faster than a stage 3 (hyrbids) on race gas?
- Help! anyone, once again i would like to know where i can locate some revolver cams please.thank you
- Swapped out my boost gauge
- Mmmm new wheel pics.
- Ant way to retain brake wear warning and use aftermarket pads with stock system? Also
- What happened to that coolant bleeding thread I took so long to respond to?
- Paging S4@Allentown - YGM
- need rotors any suggestions? Drilled and slotted 321mm. Which brands.....
- I gave a lesson to B6 S4; "Do not mess with elders"
- 2.7T makes German "Best sounding cars" video!!!
- 2001 S4 Repair/Maintenance History
- PSA: B5tS4t you need to contribute more before you post so much and talk crap
- How many lbs should I set blow off valves?
- Is 5 hours for labor for piggies and borla reasonable?.....
- Going to whatch a buddy of mine dyno a supercharged mondial in a few minutes....
- Radio Removal...we're stumped
- How the heck can you access the driver's side lower wastegate hardline to hose connection!?!!?
- Got the Zeitronix installed .. now on to the logging!
- how long should replacing the outer cv boot on the drivers side take, any writeups?
- final drive, 3rd gear, and rpm per mph.. what am i doing wrong?
- My car is so ffed up..
- Been running the X-1 intake for a week or so now, brief impressions inside....
- So you think you have trouble passing people in the rain. Try this! *Mosport WCTC spoiler*
- opinions please
- changed tranny fluid only took 2.5 liters.. is that correct ?
- What Wideband has the smallest display? All I want is A/F, something like this...
- Anyone other than Hal and Jeff successfully using Flyboy's ECUx spreadsheet?
- is there away to reinstal the n249 without using the check valve? I broke that plastic check valve.
- turbo question... ko3 58k chipped s4...
- Reminder/Feeler: AWE/EPQC Dyno Day - 10/7 at 9am
- why upgrade to K04's and not the T4's by Garret?
- are there carbon fiber rs4 fenders?
- cleaning products. im almost running out of all mine what do you guys use
- clear bra on black...
- S4 with a TB from A8 on a custom intake manifold?its on a car on ebay,any other info on this setup?
- September exhaust sale @ Tantrumwerks
- Anyone selling a nicely setup S4
- What should I ask for HID motor with connectors and does anyone need one?
- n00b question: When people say valve seals, are they really talking about the valve cover seals?
- Where does that phone line plug-in, in the arm rest, go to? Anyone have a diagram? TIA!
- does any one know where i can find a radiators with the hoses on both r&l sides
- Crap! Front driver's side CV boot is torn!
- What was different about the sport package. STFA not much there on it
- S4 pricing help (look inside for mods list and price)
- My ECUx is FUBAR - can someone please help me with a working image so I can re-register ?
- I inspected under the car.. and found couple problems.. and can you guys determine these?
- Those that have deleted your n249 have you noticed a loss in power? My car seems to be slower...
- jwolf:: ASP 3's car review
- Would tuning with lemmi on a stage 2 plus car work or do anything?
- Stasis Mono 4 328 + Rear Kit or Stoptech 4 wheel BBK???
- so i have a line with a co-worker that has 2 Coupe Quattro's black and yellow for sale
- Repost? 2007 911 turbo...first time a tip is faster than manual
- i just Joined the club, Second set of turbo's went
- pictures of my car
- So, does anyone know what's worse than getting new KO4s in and needing to pull the motor again?
- SlOgarO S3 AvANT -1 600 HP Whipple S/C COBRA - 0 Best Kill Ever to DATE!!!
- POLL: Speed limit Vs. speed you will get pulled over. NY thruway 80 is ok
- Attempted to go the nylon washer route in order to fix my shift linkage missing wedge....that went
- Interesting article on SPEED TV's website about Chip Herr and STaSIS Motorsports
- Broke motor mount again, switch to RS4? Any difference?
- Okay any Casa's running gold wheels?
- It's ALIVE, It's ALIIIIIIIIIIVE.......
- bypass valves
- Will a few gallons of leaded gas kill cats/o2's?
- Corner balanced... 3,400 sans driver. Not too bad for a car with AC and a stereo.
- RE POST! Lumbar will not defalte.....Please help
- Just playing around with the VAG tool. When I look at block 003 at idle, my BTDC
- anyone heard of CRP brake rotors?seen them on ebay as a set with front zimmermans.
- anyone know what's going on with Brian aka Todeshandler aka avants4? last time i heard he's back
- Do I need a lift for the engine if I want to replace engine mounts?
- Audi crash....
- New to the club...
- silly mazdaspeed, racing is not for kids with fart cannons and blacked out wheels.
- Vibrant or Borla for a stage 2 setup?
- oh noes - drivers side turbo now sounds like a teakettle :/
- hiss under the hood
- what would happen if i was bouncing off the rev limiter and sprayed extra...
- Speaking of fuel.. 118 leaded NOS
- for some reason whenever i see "Milpitas" i think of creepy ass bugs
- Ok, who has the "G-Timer"? Is it hokey, or does it actually work?
- nyet - suggestion for the S4 Wiki : how about a ECUx page, since APR is so lousy
- For those of you with GPS... i'd really like to see actual rpm/mph in 3rd for stock wheel diameter
- to he, whom has sent me intercooler, may you please email me..Ive lost your email. thanks
- If I get 15mm spacers what size bolt's do I need and what type? Taper?
- AUDI R8 hill climb vid check it out
- Anybody here ever have any experience with this Ebayer?
- Car is trapped in my garage. Haven't driven it in over two weeks. Starting to get the shakes...
- Post some motor out pics...
- Xpost from AWOT. This makes me drool...
- POLL for H.B. Stage 3: MAF size, injectors, FPR, and sustained boost levels are you running?
- I was just thinking how refreshing it was to have seen the end of "will a chip void my warranty?"
- repost for daytimers... 3.39 FATS ~70F 100oct
- After 5 years of owning this car, I think I need to buy a VAG-COM.
- xpost: i'm getting my puppy snipped and chipped next week...
- Hypothetical offer (kinda) ....
- looking for a good shop in ny
- boost guage
- Mark@ASP is awesome.
- Last chance before price increase on Vogtlands.
- How bad is it to drive on a squeeking tie rod with a loose rubber boot?
- Anyone else noticed BMW's quality is starting to feel like a Nissan's. ex) new 335. not a solid feel
- aaaargh!!!! i need more power! like, like , like bigger turbos, hmmmmm!..........
- So I'm taking the plunge and buying stage III ASP code
- First attempt at logging block 003, does this look right?
- Upcomming traffic court advice...
- Got her back (but the drama continues)...
- Help!!! Cant Shift
- A friend of mine just Wreced his S4 ( a moment of silence please )
- <View from my new office> I am actually a bit excited after seeing what I get to look at
- raced a TIP maxima last night and I was taken by 2 cars each time. he would stop at 60
- PSA: have VERY empty tank when doing fuel filter swap. !@$%$#@^^$%^!
- Anyone done or heard of TIP to MANUAL conversion? whats the Cost?
- Can anyone tell me how to bleed my coolant system?
- What is FATS? Anyone care to explain?
- Trying to figure out this injector thing for Homebrew. Lots of thoughts and questions. If we flow
- JD is having a track day next thursday, we (some socal AW'er) are going to chip in and buy him this
- ASP K04 FATS inside 93 and 100 oct,,,
- Click for retarded street driving
- Installed my AWE vent boost gauge tonight...I love it! Thanks to AWE for their awesome service and
- BIG THANKS to PSmalls, fixed my TCD and bam...edit...3.39 FATS on 100oct and stock IC's
- here's the Gumball episode 2
- So has ASP implemented the higher reading MAP sensor yet or still sending out TCDs with stg 3 kits?
- any swimmers, MP3 player for swimmers
- anyone near CT know a David Howe Jr email audi01s4@optonline.net??? - think i have been scammed!!!
- Question about Ceramic Coating (Swaintech)
- Come on, i know one of you ba$$-t@rdS has a blank key you want to part with..lol
- 3.57 FATS on stock intercoolers, going to install AWE SMIC's tommorrow and run some comparisons...
- Lumbar seat wont deflate. PLEASE HELP!....
- got a new ride today...
- How about these boost actuated dumps..are they any better than the electronic?
- Does Toyguy SS = Vast SS?
- Wow...3 days later Eibach CO's are now in...review/comparison soon!
