- Could people post up picks of Angstrom wheels on S's? tnx
- Anyone know who sells the carbon fiber emergency brake handle?
- Hall of Fame....AW best of the best posts, 1998-2002 Audi S4. Theme: funny/bizarre
- Okay new Volvo got shopping cart dinged it appears, so both Cactus and the Volvo
- Can anyone hook me up with some sort of Amsoil discount?
- My "H&R street coilover" is blown (driver's side, my case). Any else?
- anyone with a subwoofer (or two) in the trunk, has this caused more rattles in the cabin?
- Paging RyanS4- ->
- To lazy to go look in my car to see if it would work but i have an idea thanks to the gallardo
- Steering gear preload adjustment
- VERY good program on the Armenian Genocide on KCET for west coasters.
- Either my car has too much power, or I'm a fatass...
- new car
- i was running yesterday 104oct and i had a whining coming from the back, could that be my fuel pump
- heh, I think it's hilarious that there are several RS6s for sale in the classifieds for over $70K.
- Palomar Mountain is one of the best (most white-knuckled) drives around. Highly recommend it.....
- Question for the thinkers: Ground strapping for the coilpacks:
- Looking to buy an '01 or '02 S4 Sedan, Yellow, any sellers?
- Downpipes or catback?
- repost. anyone know what a ko3 or ko4 is comparable to in size?
- Did some 80k service items today. Trans fluid, spark plugs, air filter & cabin filter.
- Suspension review (auto-x'd today!) loonnggg
- I now proclaim my self Pre-Cat Gutting Master.
- Are A4 coilovers compatible with our cars?
- Where can i buy sportec wheels
- Replacing single tire and mounting issues
- Is the PhatNoise for the Passat the same as the S4? If so they are $120 here.
- For you ice link folks: where did you ground the wire behind the radio?
- Carlisle Import Show, May 20-22, anybody going?
- Looking for Daryl from Tantrum, still wanting testpipes...ygm
- Bridgestone RE 750s?
- Are there any feature differences between the Phatbox and the Phatnoise?...
- Any one can help to identify the year of this manifold : 078133201AE
- Someone here had a paint cleaner that you apply
- hello 2 less wheel gap.
- Pics of Cactus with OZ, just temp for now
- When the Aux. Water Pump goes bad, what exactly fails on it?
- Paging HIS4- - ->
- Fender rolling questions.....
- nine "clean" pics after claybar, wax, sandpaper on tips, etc..
- whats the status on the KO4 based hybrid turbo testing?
- At what point will you buy a new car? (more inside)
- ok, bad, or really bad to drive with a bad/loose tie rod?
- Any1 that has RS4 intercoolers...
- I can just get spring with a stock suspension i wont need struts correct?
- 2nd Annual Connecticut S4/RS4 Drive and BBQ (Reminder)
- Had a run with a 2005 Maserati Coupe, I was minding my own business when he darted
- Is this a coupe quattro with an RS2 front bumper? This is hands down, one of the
- Any tuners have used stock parts for sale? I've seen sigs with parts listed...
- anyone have pics of an S4 with their fenders rolled? im about to do mine....
- Got a small leak from front right side what fluid is blue with oil consistency?
- Looking for spring... i think i want eibach any reason why not? Or any other company i should look @
- Will a PhatNoise fit in the stock CD changer location?
- Any word on Moss' Stage 3- specific software ??
- Anyone know where i can get rs4 tips? I really like the oval look. (more)
- Where to buy Ferodo DS2500 Brake Pads?
- X-Post - The new Audi Civic...(fearing for future)
- Ex-B5S4 owner hear w/a great link to a post about oil. The poster Tom is an ex-additive engineer
- What size are the Rear rotors on a 1992 S4?
- Please post pics of 25.25" fender height on 19's. TIA.
- Has anyone Lemmiwinks an APRv5 Stage I? Any kind of results?
- Took some pictures before the rain comes.
- 997 s ownage
- K03 XR -4.5 degrees of timing+MBC in parallel+K04/K16s=limp mode and/or TC
- Pics of Kinesis K19
- What do you guys use to clean the dash. I have been using micro fiber towels...
- The car was acting weird today...boost fluctuation at WOT
- Finally got my L10+KO4 car back this afternoon.......
- Is it a full moon or something?
- Shifter question (STFA'd)
- Texas track event in the plans - go to the Texas Regional forum for details . . .
- Will running very low on gas cause the following codes??
- I think my clutch is bad... need some advice
- Davenew, saw your post this morning about your car cleaning products, (more)
- ATTN silkenrocket: how is the clear corner mod coming along?
- Imola all cleaned up with new shoes finally installed.
- So I installed the greddy tt.....and now my taillight is out......
- Can anyone help with my misfire problem?
- Anyone in the Boulder CO area have a VAG tool I can try?
- Falken GRB FK-451 = y or n? (Other options?)
- what code is voltage terminal 30 low voltage? TIA!
- Can someone help me with this data?
- question about turbo sizes. would a ko4 be comparable in size to a 16g?
- Tips on driving a manual
- Went to the dealership for some warranty work, the main problem was that
- What's wrong with ricers ...
- are all 6spd trannys from B5 and A6 interchangeable?
- Jaw dropping.
- 2 aux fans wont work.
- Car audio guys: Where can I get Audison amps? There are no local dealers in my area.
- Block 115 Graph (Part 2)
- I already STFA: Need help on pressure test.
- i think i have a blown turbo..
- $$ Watch & Save $$
- How low can I go w/ 19x8.5's w/ Falken 235/35/19's w/ no or only slight rubbing?
- Is it just my computer, or is it the forum's fault? --->
- More sneak peak pictures of the Achtuning Oil Cooler Kit
- Beta program for Stage 3 .. Mark P?
- Swapping interior door handle pieces - quick question on the driver's door
- Anyone with ko3/16 or even ko4 turbos have boost logs they can post? Must be tiptronic.
- So what's the chance GIAC software can take up an open slot in an APR EMCS chip?
- Santorin pr0n
- 2000 S4 Owner's Manual inquiry...
- Where to get an 18x8.5 et35 RS4 rep?...
- Is APR any different regarding MBC and clamp?
- How does this block 115 chart look?
- I tried Permatex windshield crack repair resin today
- I have KEY USB and I can't get emulator to work because my laptop doesn't have serial ports
- LEVEL 10 TRANS w/K04s just installed.
- Tire recommendation needed!!!!
- Help w/ Labree DP install!
- Phatbox ?
- Read. (nonsense drama enclosed). My take on the PEB reactions to criticism.
- Doc, who's the "helpful" APR contact that you posted recently? Erin someone? What's his email? TIA
- Phatnoise 20gb Music Jukebox for $119.40 + shipping (hope not a repost)
- Anybody have spare B5 S4 Bumper Grille inserts they want to get rid of??
- Does anyone know what this error code is???
- Anybody bought these?
- Does anyone know if VAG com will work with the ECUx cable?
- Coworker borrowing my ECU to test his car?
- Q for those w/Caractere side skirts
- Can someone link me to hexcom/usb vag com emulator. need it to work on Lemmiwinks. Thanks
- Can anyone guess what I'm doing today?
- Help me Please
- And here I am, hard at work. On AW and traffic school online taking care of my..
- i dunno... but i kinda miss simmply's wise cracking remarks here of late...
- Note: Costco doesn't sell Dunlops
- launches from redlights much better than dragstrip!
- FYI...Steering wheel squeak fix. White lithium grease is the way to go, BUT.......
- Any thoughts on Nitto NT555s ...
- Dentist Drill sound in low gears...but none in 6th? ehh??
- 2001 or 2001.5 VIN numbers?
- Here a new one...what do you have..and how much have you spend on automotive tools?
- what are the spring rates of h&r coilovers (29471)
- Can we swap a 2001.5 Intake manifold bolt-on on a 2000 motor?
- Quick Poll : Time to sell the Piggie Pipes and Jump on 3" Downpipes?
- I was just checking the specs on the...I'm an idiot (electrical question)
- New ques: Can I have a Phatbox and a Blitzsafe aux. H/U adapter at the same time?
- It's been too long since we celebrated Bubb Rubb.
- Phatbox Question: are there auxiliary connections on the unit, or other way I can split a connection
- I thought this was a pretty funny dream.....
- anyone know if the ATP car ran last night? anyone see it?
- Got my Volks mounted but...
- Hitachi Maf Question
- whos got the highest miles here and what year?
- Stasis Tracksport Installation question- ->
- My gf's 2000 Daewoo Lanos...what oil weight should I go with?
- post up your car list- if $$$ were not an issue, give me your car list. say, you could have....
- How long does synth. oil last in your car? Time wise, if within 5000 miles.
- Does anybody know the part # for the headlight washer
- If only I had the money....
- With all the recent recommendations about running XR on a 5bar, anyone other than Sun in ND running
- wheel loose even after tightened to 89 ft-lb....
- Did anyone buy the $119 phatnoise system posted last week?
- S4 Avant cargo cover won't recoil
- M-box in 2000 A-box S4?
- Where (if possible) can I buy single Samco hoses (ex. intercooler hoses, intake hoses, DV hoses,...)
- Ok... since I put my X chip in, I've noticed a new sound under WOT (like air being...
- So who is (or has) run sub 18lb. 17" wheels as daily drivers?
- had run with a mustang gt today
- Are all H7 bulbs the same size?
- late thank you: to O.W. Kenobi, Mark P, and others re: turn signal problem
- clunking that sounds like it is coming from right side. only on certain bumps (more)
- Need a new sig something less flashy. Any of you p-shop masters
- Anyone have a schematic with P/Ns of the tbb sensor or that area?
- Anyone know a similar online service like paypal?
- Random cylinder misfire when using remote starter ?
- Funny.
- p shop request. can someone make my roof black in one of the pics on my PP?
- To the guy with the white S4 that I saw in the Provigo parking (Montreal)
- interesting EC article about the effects of aftermarket wheel and tire setups
- Which one would you guys go with for a VSC? Just curious as I'm sure both will work. However...
- Poll: who has satellite radio and if so where is it mounted..pictures?
- 3-4 grind at high RPM
- Anyone have the part # for the N75? I called the dealer and they said 078 133 517 H. But,
- Big thanks to Ed@Induktion.
- Level10 Tip w/K04s ---Programing needed!!
- License plate screws: Anyone know where to get security torx bolts in this size?
- Someone posted a "how to" on modifiying the Audi center caps...
- Thinking turbos are going. When i turn the car on after being cold, hear loud whooshing noise....
- Will 17x8 BBS RGRs clear Alcon's?
- Replacing front rotors and pads...which pads are recommended anyone have particularly good luck with
- Anyone know how to get a radio code
- Is shifting at about 5600 rpm in 2nd gear a good idea while at the strip if I want to take
- HRed gets a stable-mate... TWINS!! : O
- Anyone with Bentley can you Confirm these wires?
- someone sell me a set of K04 inlet pipes for $300, asap. :p
- anyone have the part number from IGT for the filter? there are 2 that fit, a cone and one big round
- almighty sages of the B5 forum, please help a B6 noob out!!!
- Sparco seat brackets...
- What's a good price for a OEM S4 grill that's in very good condition?
- When i crank my car up, i hear a small winding, what could it be, it goes away in a min. or so!
- whos rolling around west palm beach in a black B5, sounded sick!!!
- Mad props to Dave @CPP. Mix up on drop shipping me new front links so he 3 days them on his dime.
- x-post : wheel lugs and locks questions.....
- Where can I get more trim options
- I can't take it over there anymore, can I just hang here for a while?
- Tracking Car need Racing Harness advice......
- Seen a few threads recently on exhaust leaks ... what are the signs/symptoms?
- Does anyone have the new motorola IHF1000 bluetooth kit?
- Lance is falling behind... Updated FATS and VAG results w/ boost & TC blocks ready for analysis
- NEW 2005 PRICING!!
- potential probs for 45K 2001.5, not TBB, BPV, talking t-belt, clutch, etc...
- Metal grinding sound from LR wheel turns out to be this surprise...
- What's the going rate for a set of 2.8 heads with RS4 cams and valves...
- anyone running ko4/16s on AWEKO4 software yet? looking for feedback before my "tuning" begins - thx
- i want/am going to need to change my clutch.....
- Advice needed: Can I use Fuel line for vacuum line (temporarily)? Here's why....
- After removing the radio, did anyone have to enter the radio code?
- Roof Rack Removal
- Problems with getting a chip?
- One lap of MAM (chase car perspective)
- does anyone have a auto rear diff forsale?
- Eibach -vs- Hyperco's with STaSIS T'Sports...Followup to lastnites discussion- - >
- Anyone here have a Santorin S4 in the shop at Empire Motors?
- A little more info about my claim with AWB. (m)
- Imola AND Nogaro Avant sightings on the 405 North around South Coast yesterday...anyone here?
- Help with pricing on replacement door skin
- Does anyone actually have KO4's in stock??
- Car going on dyno today. What blocks in Vag should I log?
- So I finally saw it happen....
- Is $2200 a decent price for NIB K04s w/o inlets?
- Forza Motorsport or Midnight Clubbed Dub Edition?
- friend just got a new mustang GT, we swapped cars for about 30 mins.. damn is that thing
- Autothority chip...reliability for normal driver?
- SPP is sold out of 80w Super White H7 bulbs...
- The Icelink plus install was WAY too easy...I can't believe I was stressing about the install.
- Questions with BOV's, yes, i know many people hate them...
- Boooooooooo!!! My driver side turbo now has the infamous dentist drill sound!
- PEB stage 3 @ 20psi + 104 octane = 12.68@112mph
- Can silver s4's with OZ Sl's silver and Anthracite post pics of their cars. I want
- okay 235/40/18 Kuhmo MX rub on the front and stock brake pads are dusty (1 week with SL's, ick!)
- got a nice compliment to the S a few days back...
- Pre lim pics of Tein adjustment mod:
- interesting road sign a fellow nceuro guy snapped a photo of. wtf?
- Best lemmiwinks settings for a stage 1 GIAC-X (A-Box)?
- Best method for breaking in an engine?
- Where to find some Manifolds.. need them cheap :)
- HELP! Can anyone tell me how to open up a boost gauge?
- vm3 exhaust coming loose?
- Red-Top followup- ->
- So Jessica called today...
- Wanted to get some info today about the B7 S4 from Audi of Mendham and the salesman didn't know
- more CEL investigation...possibly bad cats?
- not sure why but i think this looks really good....
- Help needed with detailed explanation.
- Looks like ol' Bob wants the X sauce.
- Anybody know of a place to get a new intake for my '01 S4?
- ROAD NOISE!! what i thought was road noise decreases when brakes are applied
- Clear corner ?
