- Will 17" SLs or SSR Comps clear ECS Stage 4 Cayenne brakes?
- Tony@EPL, YGM and voicemail. Please get back to me ASAP. Thanks.
- GIAC on Street Tuner Challenge Tonight! - 01/23/2008
- Engine Mounts need a subframe lift?? and 5 hours more labor + alignment???
- Picked up a rear engine avant to share the garage with the S
- I smoke tested my car, how is it possible that smoke is leaking out of the wastegate hose?
- What is the part # of the brown connector that connects to the passenger side EGT sensor? Also..
- Lower temp after-run switch mod part question
- So after annoying the ebay aluminum radiator seller for a while, he lowered price $100 bux
- Anyone here replaced the drive shaft can you advise me as to how hard it is?
- What is the weight ratio of the Audi S4 MY2000 (front/back) Thanks
- Random fuel leak. Don't know where to start.
- What spark plugs are people running??
- I think the cold killed my battery
- nogaro s4 at the eden in baltimore... you here?
- Question for RS4 instrument cluster guys:
- Caught in the middle w/EBC brakes and repair shop over runout
- Another reformed Lurker
- Found this in Orange Co.,Ca Craigslist.I think it's worth a look...
- Cylinder 5 misfire
- Need rear speakers (bose)
- Lots of new faces around these parts, not sure I recognize a single person. Anyways, hello...
- R8 with Edo Comp. Exhaust.
- There are so many things wrong with this ad...
- Anyone switched from stasis track sports to Vogtland GT setup? how would they compare?
- Braking issue SOLVED!
- gte678n, please email me your shipping address
- I think that I am trading my Avant in on a 2007 S-line Q7 (more)
- 6 Speed Tranny, the front drive axle seals are the same on each side correct? STFA count find
- If coolant is always supposed to be flowing through the heater core, how is heat flow regulated?
- steering issues
- What will happen if i put my dv's in reverse?, like i see some people doing.
- Why are so many stg3 cars sold with only a few thousand miles after all the work
- Anyone else running the Blouch KO4/997 turbos?
- Canadian S4 bumpers? Any difference from US ones? Just curious, I have the grills already...
- Clutch disc with approx. 5k on it. Does this look correct?..........
- Questions about lowered compression ratio with APR stage 3 kit...
- ANYONE have a new OEM front bumper skin......
- Anyone have a used 85 MM autospeed maf they would sell me?
- How do you secure LED city lights bulb?
- group buy for pauter rods/ weisco pistons?
- Level 10 transmission rebuild - GIAC/AWE Stg 3- first impression
- 2000 S4 with 69K for $15,000?
- PSA: Someone in the A6 Forum found a source in Germany to fix the clusters. Since I dont know how
- alcantara inserts - who has had them done that had full leather? What was the cost?
- Anyone have the b5 s4 commercial "these aren't destinations-they're the finish line" video.
- Rough Idle
- Crap!!!...ok, so got my clutch changed to RS4, now shop it's blaming the resurfaced flywheel
- Dumb question probably- Is a tip y-pipe the same as a 6 speed (if they are of the same vintage).
- Dying to do a "fun" upgrade to my car....
- B6 w/ 41k mi. for $13k?
- Fuel pressure doesn't drop when I hook the vacuum line to FPR. I checked the lines...
- Just drove my girlfriends '08 STI and was comparing it to my S4
- No start problem resolved.......
- Does this waterpump look ok?
- Can anyone tell me which transmission and differential fluid I should use? TIA
- 18258 - Powertrain Data Bus: Missing Message from ECU...........What Does This Code Mean? TIA!
- Repost: Anyone have photos of Light silver with Enkei RPM2s in hyperblack?
- Question about a 3.0T build...I'll use a 2.7t block bored out to 82.5mm and a 3.0L crank with
- Need a left front axle for a manual S4.
- What possible options does one have to open the trunk w/o the key cylinder?
- Just confirming I can drive w/ ko4s and my old giac x ecu, with no fueling yet right?
- any ASP RS6 updates?
- European Car's Turbo issue is A+ and has a top 10 euro turbos section (B5S4 content)
- has anyone ever had any luck molding oem s4 front bumper to rs4 front fenders?
- am I correct that there is no aftermarket faceplate to match the RNS-E to our cars? anyone have.....
- Steering Wheel very slightly not perpendicular when driving straight.
- First attempt at a video... Dont be too harsh.. (3 minutes of video is what i had to work with)
- i'm stranded on the highway..
- for the archives: PBR metal master initial impressions
- Anyone with Eibach Pro-Street-S Coilovers
- Clock Spring?? WTF?
- Anyone modify S4 fuel rail to fit on RS4 manifold? Any useful pictures or notes & details?
- HOw many S4's left in USA, after all crashes, rapes and thefts? Anyone know roughly?
- SOCAL S4 owners, CALLING JEFF MOSS TOQUE FACTORY - moving to SD feb 1 need my stage3 sea level tuned
- anyone know if someone has custom modded the S6 DRL Leds to the B5 S4?? Would like to see it done
- what is the stock whp on the s4 just curious
- What's the difference between avant and sedan with suspension?
- Oil blow by at DV.... how much time do I have?
- My car is No longer Quattro friendly
- Is Spec'd Boost related to N75?
- S8 brake conversion, what exact parts do I need, and where to get it?
- POLL: insurance company / experience [pos, neg, or none] / do they cover track time?
- If you're reusing the same timing belt, do you need to pop the sprockets to re-install it?
- I'm not usually wow'ed by pics of concepts and new cars, but those pictures of the v12 r8 are hot!
- Sad X-post, my S4 is totaled...
- who in the LA area will do GIAC ecu upgrade?
- Is silver ext on silver interior a rare combo?
- S4 running rough at idle and has a bad sulfer smell from pipe
- I lubs the cold weather (23 degrees)...S4 pulls like a choo choo train
- Cam pulleys have no key? I bought a used pulley and it appear to have no key???
- does 3880lbs sound accurate for weight? car is empty, 1/8 tank gas, no spare/tools, no one in it.
- Collision repair Gurus, need advice...
- Anyone have the part number for the expansion tank tee fitting?
- Paging Carson @ Riverside .... need repair kit 8D0 998 122 - Can U Help? TIA
- paging four door: Last spring when I was at Road Atlanta, we met up and took a
- Anyone ever used the 'headlight repair kit' from Audi to repair the hd light tabs?!
- Still having ABS issues
- Paging Hdias....
- chains on a lowered car? how high do i have to be up? im dropped with about 1 to1 1/4 to the well.
- Installating the LATCH system cant be that hard.
- Poll: How many of you run without DP heatshields?
- Where can I buy the clamp set for the samco hoses?
- Thought I would share; mileage milestone
- How far is the thermostat supposed to open?
- Got my interior xenon kit in the mail. this morning. Will post some pics when installed.
- Where to buy DBA rotors? Tirerack seems to be cheapest.. any other place?
- Replaced my Stasis Streetsports with Vogtland GTs. Review inside.
- Looking for a decent priced set of coilovers...what are my options? I would like a set
- Center bar delete and RS4 mesh install finally done ... well, not really, but close!
- How many ASP Stage 3's are running a MBC due to overboosting? If so what psi is it set at?
- Curious...
- Anyone have a stock fuel rail they need to get rid of?
- Do timing belt or sell as stage 3 platform?
- B6 S4 seats in B5 S4
- Update on no start condition, plugs are black and wet with fuel. Fouled?!
- Does anyone want to part with a black stocker s4 bumper?
- Do I NEED the audi tool to loosen the tension on the cam tensioner?
- Installed B7 S4 300mm rear brakes
- where to buy b5 rs4 air leather steering wheel? cant find it anywhere
- Cold front in FL = AWEstgIII logs :)
- rs4 bumper
- STFA... Is the RS4 throttle body diameter 76mm/3'' or 82mm/3.235''?
- RELATED Q: if the ignition won't turn, the wheels are locked in place and won't turn either.
- lol @ the el camino trying to run away from me in 4th, the look on his face=priceless!
- NEED HELP! car is stuck at supermarket and the ignition won't turn at all.
- Finally got my car back. Vast Kevlar/RS4 clutch stock flywheel vs. CM stage 3/4 w/ lwfw comparison
- Quick question can a boost leak cause a cel?
- Took some pictures today before the Patriots game.
- Car won't start today, 8 degree's out....
- Tach Wire / RPM wire
- How much is a Phatbox in perfect condition with all the accessories worth these days?
- considering a b5 s4 as new car, couple of ?'s
- 2001.5 pearl white Avant 6mt, bone stock with 70k for 16.5k....opinions..
- How do you remove the passengers side knee bolster?
- Why does boost spike and then fall off?
- Paging poseidon5 - does the offer to help me with my APR chip situation still stand?
- To people that have 034 Motorsport adjustable FPRs....
- Okay, going for the front bumper install today ... any tips?! TIA!
- So i just got a fat boost leak followed by a cel, is that normal?
- Why the hell are there different interior clips?? lol
- Right side lights don't function with Hazards on...
- What special tools do I need for a CV boot replacement?
- Whew! S4 Saturday comes to a close ... mod's o plenty underway...
- rear diff oil change,
- has anyone seen this before- one cylinder registering 50psi other ok - broken rings you think
- RS4 bumper install
- Could this possibly be right? Dyno question inside.
- ECU question- if I unplug the ECU on my A3 for 30 minutes, will it reset the ECU and clear any codes
- Can ASP stage 3 fueling be run by a stock ECU? Need to send my ASP ECU in for update.
- X-post: hit or skip on new R32 lease?
- Just switched intakes and now I get misfires/stumbles... bad maf?
- Question regarding engine and transmission mounts.
- anyone have a sock front bumper?
- Avant rear window washer problem. Major water ingress. Pics for Greyhound1.
- Is it possible to AWD dyno w/ 2 seperate 2wd Dynos w/ our center diff?
- Paging anyone at AUTOSPEED - URGENT
- Big thanks to Marc in NY for GIAC ECU that I plugged in today! Sweet!
- Big thanks to homer-j-fong, BingS4, and Sidespar for thier advice on front bumper pull ...
- Boost leak test results in "boiling" sound from engine--intake loses pressure to engine by about
- Where to get a GIAC tip chip to speed up the shifting? Best deal?
- Just received OEM RS4 inlet pipes w/ blue (ugh) silicon hose couplers. How visible are these
- my clutch went out->bought rs4 one, now the mechanic says it needs a flywheel. i thought u can
- Front spoiler/bumper
- [ipod nano 3G] - any decent cradles out? mounting ideas with DICE?
- is wicked open today? tried calling but on one picked up...
- Music for your s4 , my boy jcast is starting to blow up, 15,000 downloads of this song.
- Check the front page, cool article on the R8 V12 TDI. ;-)
- Misfiring Continues ... =[
- red coolant temp indicator light... no CEL, coolant fluid at correct level between min/max, let...
- Bouncy Idle ... Pleeeease help!
- Question of the day.. What does 37.6 mean to you? Answer inside..
- Strange gas leak.
- looks like B8 will be supercharged - not turbo charged : (
- best place to get a vag-com?
- Will just leaving your S4 parked out in the ice and snow nonstop for 2 weeks do any badness?
- Crappy cell phone pics, but nonetheless - - NICE! (Porsche Pr0n warning)
- Selling some stock parts..
- ABS module
- Does anyone have a wrire up or link to article for replacing rear rotors and pads?
- OEM Rear Rotor - Is there any quality difference between Zimmerman, ATE, TRW, Audi OEM?
- Alignment in Phoenix Arizona
- Convert stock mirrors for Asymmetrical mirrors
- Power front Seat won't go front and back
- Exhaust Systems
- More of coolant smell. So no blast of steam from defrost cant see any red coolant from intake
- Who's got the heaviest pig of them all?
- Has anyone pulled the trigger on the Stratmosphere V-Maxx $699 Coilovers?
- Was behind a B7 RS4 Today
- Any suggestions on cleaning up/de-gunking under the hood while its torn down?
- Can a dealer give you a price on a car with tax and tags, put a deposit on it and then reneg on the
- cruise control in the rain?
- Just got the APR chipped ECU back. Problem: my car has no check engine light... Any solutions?
- Clutch pedal height
- whrere am I looking for secondary waterpump leak?
- Prob a dumb ? but since I'm in progress. Can I just drill like 50 little holes in the bottom of the
- Altitude and Boost: How well does OTS Stg3 handle altitude vs custom tuning (done at alt vs sea lvl)
- I drive around and see these bimmers (thoughts/ramblings for a friday afternoon)...
- AWE Tuning RS4-k04 fueling kit for sale. Selling this for a customer here that is parting his
- who has done engine mods with their stage 3 upgrade?
- K03 Paper Weight..
- hit 130k today! .. ok i went a little overboard..
- Has this ever happend to anyone else (expansion tank cap failure)...
- Paging Mike @ WMS
- Anyone have engine covers they want to sell???
- Paging LI-S4, YGM
- Roll call: How many original buyer B5 S4 owners left?
- German Castrol FTW!
- KO4s- is 025 Drivers side and 026 pass side or does it matter?
- Back to Black formula works pretty well on rubber trim around windows, just a heads up
- Why cant i get the clutch fan off? Can someone break it down, maybe im missing something.
- K & N Air Filter worth it? and if so, where to get one?
- No heat problem continued - got the water pump and thermostat out...
- CF
- Is it ok to drive for a while on clunky lower control arms?
- Best Price For EGT
- probably a repost but man i love this video
- Need help ....PLease!!!
- PA fun
- Avant Rear Window washer problem
- Future B8 S4. Hear what the head of Audi Products has to say: Video
- Can someone confirm - are EGT sensors involved during WOT?
- Anybody running a backup camera with their AVIC-D3 or any other video unit?
- Need new wiper blades. Bosch Icons or PIAA Silicones?
- Anyone here ever run a solid hub clutch disc setup with the stock flywheel? More inside...
- Question about clutchmasters stage 3 ceramic 8 puck hybrid
- Why is it...
- different strokes for different folks.....
- Pic request: Enkei GTC01 or RPF1 (on car) stfa, found nothing. Also, are...
- ? about the length of Milltek DP's
- 3M clearbra
- How not to install B7 300mm rear brakes
- Already STFA, didn't find any clear write up's on pulling / installing the front bumper ...
- anyone have a pic of an OEM ballast outside of the assembly?
- cant decide if i want a ceramic or kevlar clutchmasters stage 3
- Would a wideband be overkill when doing simple Lemmi tweaks?
- Best way to ship wheels with mounted tires (used)?...
- Bored question: Your guess (wheel or flywheel). How much power is an S4 making for the following.
- has anyone bought a rear view mirror from the dealer lately?
- does anyone have a spare driver's side turbo to intercooler pipe (it's silver)
- does anyone know if the FX300 Clutchmasters Stage 3 fits over the AWE LWFW?
- Anyone have a spare silver B5 RS4 replica to get rid of? 18x8 35mm ET
- has anyone ever modified the rs4 bumper so it doesnt have the little gills on the sides?
- EPC light. Does this mean limp mode? Mine isn't on, I'm just curious what it means.
- i stfa, I need a definitive answer on how many specialty tools are needed to drop a motor...........
- does anyone have a link to the rear deck speaker diy fix with the glue and stuff? i stfa to no avil
- New Design! Inspired by Arc to the teryx.
- 2001 Audi S4- what features does the sport package include? chrome side mirrors?
