- the old 380/380 progressive springs from hyperco/stasis...will they work with the
- Was driving to work like a decent citizen this morning...
- FINALLY! The Snow has stopped!
- Got a code P1131. Apparently its an O2 sensor......
- Need someon to host a video of me drag racing an EVO 8 can anyone help TIA
- Clubbed a baby seal Saturday night......(long)
- Looking for information on BBS RGR's. (long)
- Anyone have any thoughts on the Autometer Nexus boost gauge? I saw one while i was browing online
- Someone from a local shop was talking smack about B5's saying it was a POS and that he'll "smoke"
- stupid ??: what is FATS?
- What's a fair price to sell stock S4 brakes?
- Washed the car, and swapped wheels for summer. New SL's are on.
- RNS-E navigation fully functional (almost) in a B5 RS4!
- Has anyone tried upgrading to a diversity antenna to improve the miserable radi reception?
- And yet another Darintake test for those interested.
- is this true?
- does anyone have any graphs for the MTM Stage 2( it might be called Stage 3) chip?
- Got pulled over today.
- I just busted the T-fitting that comes with the AWE vent gauge...
- Logged the low boost high altitude AMS chip today
- How do I get my radio code?
- will an EGT cause a blow off type sound
- Is this a new SCAM??? This has GOT to be!!
- Checking Key Fob status in Vag Com?
- Did the sport mode to my tranny using the vag, also changed the langauge to german and also did...
- Lemon law link?
- Okay, here it goes....(somewhat embarassing post inside)
- If the battery is disconnected temporarily, will the ECU lose its emission readiness codes?
- Alarm system problems
- Dyno analysis?(dyno chart inside)
- Arrrg- Clutch Slave cylinder needs to be replaced - is the Sachs OEM ?
- Am I crazy for considering selling my 18x8 OZ SLs w/ AVS ES 100s and using my brother's Avus for
- APR vers AWE - Turbo Kit 3
- torn CV boot! replace boot or whole axle? where to get parts?
- EBC . Which is the best for our cars?
- Noob thats been around.
- Planning to replace the trans fluid soon. Seems there are different opinions on how much to fill.
- Sometimes after driving a while it seems my car doesnt make boost....
- When swapping brake pads on the same rotor does one need to "prepare" the rotor...
- Just a TINY pic request...
- most experienced Dyno near NYC to tweak ko4/16s running AWE code - thanks
- This is my first attempt at multiple pics, so hopefully it works (BWW maybe)...
- NOOOOOOOOoooooooooooooOOOOOOOOOOOOOOOOOOoooooooooo !!!!!!
- What do turbos sound like when they start going bad?
- Anyone ever tried repairing an aux water pump?
- MTM FATS TIMES
- P'chop request...
- Interior Pics...
- Good Link to Up-to-date info on Speed Touring Race Today
- Pulled these codes this AM...P1130-Lean P1128-lean ( need a new MAF???)
- Just washed the car. Felt like taking some updated pics. ;) Black S4 pron:
- anyone have a source for oem vacuum hose clamps?
- Gas Mileage and blown turbos
- How bad an idea to rotate in brand new tire if others have 30-40% tread life?
- Good thing I didn't remove my winter wheels and floor mats yet! :)
- 17mm HR sway bar or 19mm
- Odd noise when reversing...
- Best compliment from girlfriends' friend as we were driving her home..
- Poll: At what point in the clutch pedal's travel does your clutch start to "catch?"
- Alcantara Install San Francisco?
- why do i get pulled over so much???
- Crankshaft sensor-
- Could someone post their MAF logs for the AWE K04 setups?
- Best place to pick up a set of 18" S8 Avus wheels, and what else will I need to install them?
- So how much would a stage 3 upgrade cost me?
- some dumba$$ just flicked a cigg at my car while driving home.. so i beat the ever loving snot out
- Whats the consensus on the Blitz DTT DCII turbo timer
- Just went and drove a Honda Ridgeline and new Acura RL
- Here.. HEMI..HEMI...just destroyed my neighbor in his Magnum..all black with deepdish chrome rims...
- BRAKES!! when i release the emergency brake..there is POP as i pull off?? the brakes are sticking??
- What stuff do I need to buy to install an AWE Center Vent Boost Gauge?
- maybe a stupid question.....but can I use any turbo timer?
- local guys selling a vag com for $100, would i be stupid not to jump all over this?
- Here's the type of hood vents I'd like to see in a CF hood
- Found these (2000 S4) TSBs in the NHTSA database
- front control arm replacement options
- Need new throttle body
- Whats the Vag login for working in the Xenon cluster?
- Installing boost gauge, need help
- Does anyone know where I can buy Kahn RS-S wheels 18*8 in US?
- Anyone looking to step out of their S4 into an older audi? i want to see who all may be interested
- Anything wrong with driving for a week with CEL due to bad coolant temp sensor?
- <x-post> [reminder] ALL photos from Buttonwillow 3-8-05 are online and ready for viewing...
- Can you recommend a set of jackstands for a lowered S4?
- Sportec Tuning?
- Price Input Please: '00 Audi S4 w/50,000 miles
- Is it possible for a Hitachi Maf to pull.....
- Any reason why the AWE DTS is almost $100 more than the identical ASP model? Is not...
- any actual dyno testing of piggie pipes VS aftermarket downpipes?
- MTM Logs
- Give me some ideas for some black wheels for around $400 or less.pics on nogaro would help thnx
- S4-1 Carrera 4s-0....
- help with a chipped 2000 S4
- What am I doing wrong?
- [Problem Solved] Charge pressure control: positive deviation
- HID rip-off help please - caught in the act!
- battery BT
- Found a company that makes exhaust resonators. Have been searching for a while ...
- looking for a boost gauge. who makes the best for the buck and is there a shop in socal?
- Fuel filter autopsy photos
- Now I'm convinced my car is chipped
- Need Help!!!! Found a Sprint cell phone, think somone in my
- What is spp tip mod? please explain
- Good news for CPP/Istook owners! <repost??>
- Ya my airbox was modified poorly i cleaned it up though!
- Damn..... how do i post a pic on here?
- Eibach ProKit for Avant the same as Sedan
- Had a friendly 'encounter' with a CTS-V today.
- so if they dont make o2 simulators for the s4 what happens when i gut my cats?
- A farewell
- Welcome myself to the family!
- filled up with some 100 octance tonight (10 gallons), a few questions (one about rain and BBKs)...
- My new.. well.. used ASP Exhaust!
- KMD Tuning has the AWE center boost gauge for sale for $11 less than AWE?!?.....
- Well, my first oil cristening was tonight...
- Changed my front control arms and tie rod ends today...
- Rate my 2.7T K03 GIAC chipped log
- TBB's: any difference between Samco's and that sold by AMS? Impressions please. TIA
- Time for brakes, what the favored OEM-sized replacement rotors?
- Update: Replaced both EGT's on my car today - took it out for a few hard runs to see..
- Poll: Are most S4 owners Democrats or Republicans? (more)
- Another set of healthy K03s on the scrap heap
- Thinking of an older S4 - got some questions
- paging Todd/AWE: I need a chipped ECU for a Euro-spec 00 S4 (manual), will your GIAC work, or...
- I'm looking at an S4 avant 6-spd... 2001 they are asking
- Are diverter valves supposed to make noice, kinda like blow offs!??
- Good price on 2001 S4?
- Took the plunge on the Autospeed 3" DP groupbuy by Startupracing.com
- Have you seen the new mustang cobra (gt500) true american LEGEND!!!
- Great :- / The front end just started to "thunk" over bumps.......
- What is D-flo? Not same as Darintake, is it?
- Running Nitrogen in my tires :)
- Wow. DUH Engineering is back as an advertiser? I couldn't believe my eyes when
- New to x-chip - Was spiking to 22psi. Adjusted N75, now seems to be contained to 18 or 19.
- I have a pleasure of shopping for a new car. It is for my wife...
- turbo problems....
- what's up with autospeed - no return calls/emails - good product poor support? hope not
- best dealerships in the SF area to have warranty maintence done? just hiht the 40k mark...
- Okay, just got my LF inside door handle unit from ECS Tuning. Do I need
- Where can i find that list of codes and their meanings?
- Negative Experience with Audi Customer Service
- Tank Mileage? 220mi. using 93
- How easy is it to damage the N75 valve? Mine got beaten up a bit when I was moving things around...
- already searched, looking for additional tint pics on Nogaro (please state %, brand, details) thanks
- Believe it or not I'm actually considering selling the S...
- hardwiring the escort 8500 tomorrow. Any ideas on where to put the display?
- Many thanks to Jose at Euro-Tech Motors
- Fair price on 2001 S4 with 70k miles?
- Questions re wheels, especially BBS
- I want an '@PEB tuning' handle. You guys take UrS-cars in your lot?
- Where is El Cheng?
- anyone have a Pic of 18" BBS RC on a B5 S?
- Pictures from todays interior detail...
- Champion or Classic? She is paid for and I have saved $10k...
- Any thought's? Logs posted....
- LOL. What a freakin' n00b. (Time to reminisce)
- I STFA but still have no conclusion: will the Darintake + Funkweasel ITG system work better than...
- just joined the Audi Reich
- What would cause cupped tires to work on one car and not another? Suspension? (more)
- Can I lower the boost using Lemmiwinks?
- straight up noob Question of the day! Are K04s worth it without race gas?
- i hate fvcking funeral processions. that is all.
- are the B5 chrome mirriors the same as the B6? can you swap them?
- Any one have a4 132 sport wheels on their b5??
- GIAC Flashloader 1st Impressions - I just got back from doing some runs with updated GIAC...
- Paging Reefer Bob - this one's for you ;-)
- how much do you guys think I should ask for a MTM stg2+ (old stg3) chip only?
- B7 RS4 Avant...
- I heard a rumor LosGatos is selling his S4 for a minivan?
- I dont suppose anyone out there would want to trade their black interior for my cream?
- S4 Stumbling / Skipping at Low RPM!
- Anyone in the market for a $239,800 S4? Low miles! (more)
- Manual for using Vag Com?
- Ok. Just got my tax return! Whose got an A4/S4 NavPlus for sale???
- ECS selling new tuning software.....
- I just got pulled over by the NYS Police and got a ticket for "Inadequate Muffler"....
- Has anyone have before and after results between k03's and k03/k16?.....
- Cracked oil pan.....
- Goose bumps...
- What do RS4 Recaros cost in Silver Nappa and who has the part#s?
- would it make sense that I am seeing 5-7 better MPG with 100octane vs. 91...i drive pretty much the
- If anyone looking for an ABT chip, nice find on e-bay
- I just got HAD really bad! Watch yourselves today and don't be a victim of April Fools. That is all.
- Service description / load index: higher is better, right? (more)
- Update on my wheel/tire problem / GS-D3s vs. PS2s? Need advice quick.
- Help!! Wheel Decision
- What is up with the Matrix OCK GB . . .
- who has the best prices on AWE exhausts?
- Grrrrr, Lemmi can't communicate with my ecu....
- Noooooo....Turbo's went KaaBoooM this morning....
- The lighter the better....
- Just did my first FATS run! 4.2, I think that's pretty good for non-turbo eh?
- im having a little problem with my brakes. the brake pad light comes on and goes away, whats that?
- Imolavirus...you around ? could you Email me price list and option on the hybrid ?
- Strange metal rattling noise when I turn the A/C on
- anyone here have a silver s4 w/brushed aluminum mirror housings? please post pics...
- pulled a code today that i haven't seen yet: Secondary Vaccum Presure. CEL came back on - 30 miles..
- it is PITA to installed Greedspeed snub mount, this is the most difficult snub mount to install
- "car will be chip tuned by quattro himself"....
- dumb question: this rotor is for the driver's side, right? (more)
- need help here...blown turbos?...kinda long(m)
- QUICK-Do I need to re-use the little screen filter when replacing the stock FPR with a 5 bar?
- Deciding between used S4 and new Legacy GT
- give me some opinions ppl.. the archives are full of conflicting results and they are too old
- does anybody know if REVO ever made thier advanced tuning software?
- Stock bipipe or upgrade? need to replace
- Quick help: Any way to remove a hubcentric ring/adapter from OZ SL?
- STFA Just installed lemmi. Anybody have good settings for x chip stage 2 ?
- Thanks MarkP! Picked up the 1.5 ton jack on my way home!
- S4 going into the dealer for some trany work. My turbos are on the brink of death...
- Has anyone done FATS testing when upgrading to Bosch Platin spark plugs from stock? What were the
- stfa........any definitive answer on the strongest sidewall for 235/35/19?
- Need new windshield wipers, which ones to get?
- Paging DAP@PEB Tuning
- Can you use a cooper tubing kit instead of a nylon one when installing a boost gauge?
- Any other 2000 (A-Box) owners have an X-Chip they feel is smooth as butter?
- thanks to zev@avalon the blacked out look of my car is complete!!! (almost :P)
- Any special tips or suggestions when installing a fuel pressure reg?
- Poll: Best Vendor Give Away/Marketing Trinkets
- Met a guy with an identical car to mine (nogaro, stage 3,stoptech,coilovers) in Orange, CA today....
- how do you guys think a 2 chamber flowmaster will sound(M)
- Is there any noticable difference between 2001 and 2002 models?
- ACHTUNING and JOSH
- need pagid orange for stock s4 calipers
- Is it my tires or my wheel bearings?
- Input please >>> looking to buy S4
- X-1 Intake: which ITG filter for stock MAF?
- ECUx
- Checked Shokan, ECS, Impex, couldn't find CV boot kit. Just want to find a price to compare to. TIA
- S4 spotting....Nogaro S on Hertel Ave. crossing Deleware in Buffalo......
- help me decide on rear to match Oem Rs4 front and Jms sideskirts...
- AWE boost gauge broken..any idea where i can get just the replacement gauge (aside from awe)
- For people who have done the White Lithium Steering Wheel Squeak Fix, does it work immediately??
- Poll: Is the RS4 and stock S4 clutch disk the same?
- CV-joint/boot questions / sort-of followup to my wheel drama (more)
- AutoSpeed Performance 3" DP Group Buy Update:
- Paging SilkenRocket
- FYI Bosch Fuel Pressure Regulator Seal Kit
- info on rs4 heads (long)
- Haven't been on here in a while...what's it worth?
- Who here has bought from Harborfreight? Ordered something on 3/19 and still nothing.
- AWE Boost Gauge question follow up..so...
- another call for data: I updated fats calculator with SAE correction and better drag equation
- Thermal coatings and our brakes, lets discuss.....
- Found this web site that lists wheel weights for just about any wheel. Even has Ronal wheels listed.
- ARGH! Still at an utter loss about these wheels, and I have a new problem (more)
- Does this MAF reading look normal? ADJUSTED
- well, left induktion $4,000 poorer. All the CAs had to be replaced, aux water pump, rear pads/rotor
- RS4 or S4 flywheel needed ASAP
- "Right now I lack the special tool required for maintaining an S4, a big wallet."
